用STM8S105实现程序升级,想在bootloader里可以使用中断,参考网上写的资料,中断表放在RAM中实现bootloader和APP都可以中断,RAM区域0x0780~0x07FF 放中断向量表(128字节);但bootloader里卡住,中断函数不正常;定义了TIM1和TIM4中断,只有TIM1会中断,TIM4不进中断,或者只定义一个TIM4,TIM4中断正常,只要定义了两个以上中断就只有前面一个中断正常,后面的中断都进不了中断函数。不知道是什么原因?一、main.c函数 #if 1 typedef void (*isr_type_t)(void); typedef struct { uint16_t interrupt_instruction; isr_type_t interrupt_handler; }interrupt_vector; #pragma location=0x0780 interrupt_vector vector_table_[32]={0}; #endif #pragma vector=25 __interrupt void TIM1_UPD_OVF_TRG_BRK_IRQ(void) { if(TIM1_GetFlagStatus(TIM1_FLAG_UPDATE)==SET) { TIM1_ClearITPendingBit(TIM1_IT_UPDATE); //清除中断标志 Time1_Cnt.x1msFlag=1; if(++Time1_Cnt.x1msCnt>500) { Time1_Cnt.x1msCnt=0; LED_RUN=!LED_RUN; } } } #pragma vector=26 __interrupt void TIM4_UPD_OVF_IRQ(void) { if(TIM4_GetFlagStatus(TIM4_FLAG_UPDATE)==SET) { TIM4_ClearITPendingBit(TIM4_IT_UPDATE); if(++Time4_Cnt.x1msCnt>1500) { Time4_Cnt.x1msCnt=0; LED2=!LED2; } } } int main(void) { vector_table_[25].interrupt_instruction=0x8200; vector_table_[25].interrupt_handler=(isr_type_t)&TIM1_UPD_OVF_TRG_BRK_IRQ; vector_table_[26].interrupt_instruction=0x8200; vector_table_[26].interrupt_handler=(isr_type_t)&TIM4_UPD_OVF_IRQ; SystemClock_Init(HSE_Clock); LED_Init(); Timer1_Init(16-1,1000); Timer4_Init(); 。。。 } 二、ICF文件修改 define memory with size = 16M; define region TinyData = [from 0x00 to 0xFF]; //define region NearData = [from 0x0000 to 0x07FF]; define region NearData = [from 0x0000 to 0x077F]; define region Eeprom = [from 0x4000 to 0x43FF]; define region BootROM = [from 0x6000 to 0x67FF]; define region NearFuncCode = [from 0x8000 to 0xFFFF]; define region FarFuncCode = [from 0x8000 to 0xFFFF]; define region HugeFuncCode = [from 0x8000 to 0xFFFF] 三、stm8s_interrupt.s文件修改 __intvec: DC8 0x82 DC24 __iar_program_start ;; RESET 0x8000 DC8 0x82 DC24 0x0784 DC8 0x82 DC24 0x0788 DC8 0x82 DC24 0x078C DC8 0x82 DC24 0x0790 DC8 0x82 DC24 0x0794 DC8 0x82 DC24 0x0798 DC8 0x82 DC24 0x079C DC8 0x82 DC24 0x07A0 DC8 0x82 DC24 0x07A4 DC8 0x82 DC24 0x07A8 DC8 0x82 DC24 0x07AC DC8 0x82 DC24 0x07B0 DC8 0x82 DC24 0x07B4 DC8 0x82 DC24 0x07B8 DC8 0x82 DC24 0x07BC DC8 0x82 DC24 0x07C0 DC8 0x82 DC24 0x07C4 DC8 0x82 DC24 0x07C8 DC8 0x82 DC24 0x07CC DC8 0x82 DC24 0x07D0 DC8 0x82 DC24 0x07D4 DC8 0x82 DC24 0x07D8 DC8 0x82 DC24 0x07DC DC8 0x82 DC24 0x07E0 DC8 0x82 DC24 0x07E4 DC8 0x82 DC24 0x07E8 DC8 0x82 DC24 0x07EC DC8 0x82 DC24 0x07F0 DC8 0x82 DC24 0x07F4 DC8 0x82 DC24 0x07F8 DC8 0x82 DC24 0x07FC END |
为何STM8S003F3进不了TIM1中断?
求STM8S105C6T6的安装软件完整版和安装步骤,谢谢!
STM8S003无法检测到引脚电平
STM8 @svlreg 问题
STM8AF62XX+L99PM62GXP LIN通讯的电路原理图有吗?官网提供了一套软件,没找到对应的原理图,请大家指教一下
求一个STM8S207例程
STMS005K6T6 如何采集内部参考电压。
stm8s003 adc中断和通道切换的问题
adc施密特触发器stm8
