void Timer2_Config_Init(void) { CLK_PeripheralClockConfig(CLK_Peripheral_TIM2,ENABLE); //时钟配置 TIM2_DeInit(); TIM2_TimeBaseInit(TIM2_Prescaler_1, TIM2_CounterMode_Up,16*624); //1分频,向上计数,每625us定时中断一次 TIM2_ARRPreloadConfig(ENABLE); // TIM2_SelectOutputTrigger(TIM2_TRGOSource_Update); // TIM2_SelectOutputTrigger(TIM2_TRGOSource_Enable); // TIM2_ITConfig(TIM2_IT_Update , ENABLE); TIM2_ITConfig(TIM2_IT_Update , DISABLE); } void Ad_Config_Init(void) { ADC_DeInit(ADC1); CLK_PeripheralClockConfig(CLK_Peripheral_ADC1, ENABLE);//打开ADC1外设的时钟 GPIO_Init(GPIOA, GPIO_Pin_6, GPIO_Mode_In_FL_No_IT);//电源 GPIO_Init(GPIOB, GPIO_Pin_0, GPIO_Mode_In_FL_No_IT);//电流采样 GPIO_Init(GPIOB, GPIO_Pin_1, GPIO_Mode_In_FL_No_IT);//参考电压采样 delay_us(20); ADC_Init(ADC1, ADC_ConversionMode_Single, ADC_Resolution_12Bit, ADC_Prescaler_1);//初始化ADC1,模式,12位分辨率,ADC时钟1分频 ADC_SamplingTimeConfig(ADC1, ADC_Group_SlowChannels, ADC_SamplingTime_384Cycles);//配置ADC采样时间,384个时钟周期 ADC_VrefintCmd(DISABLE); //禁止内部电压基准源 ADC_ITConfig(ADC1, ADC_IT_EOC, DISABLE); ADC_DMACmd(ADC1, ENABLE); ADC_Cmd(ADC1,ENABLE); //使能ADC1 ADC_ChannelCmd(ADC1, ADC_Channel_0, ENABLE);//打开ADC1的0通道 ADC_ChannelCmd(ADC1, ADC_Channel_17, ENABLE);//打开ADC1的17通道 ADC_ChannelCmd(ADC1, ADC_Channel_18, ENABLE);//打开ADC1的18通道 } #define ADC1_DR_ADDRESS ((uint16_t)0x5344) #define BUFFER_SIZE ((uint8_t) 0x03) #define BUFFER_ADDRESS ( (uint32_t)(&Buffer)) uint16_t Buffer[3]; void DMA1_Config_Init(void) { CLK_PeripheralClockConfig(CLK_Peripheral_DMA1, ENABLE); DMA_DeInit(DMA1_Channel0); DMA_GlobalDeInit(); SYSCFG_REMAPDMAChannelConfig(REMAP_DMA1Channel_ADC1ToChannel0); DMA_Init(DMA1_Channel0, BUFFER_ADDRESS,//缓冲区地址 ADC1_DR_ADDRESS,//ADC数据寄存器地址 BUFFER_SIZE,//缓冲区大小 DMA_DIR_PeripheralToMemory,//外设到内存 DMA_Mode_Circular,//循环转换 DMA_MemoryIncMode_Inc,//内存地址自增 DMA_Priority_High,//优先级为高 DMA_MemoryDataSize_HalfWord );//内存数据是半字位宽 DMA_SetCurrDataCounter(DMA1_Channel0,BUFFER_SIZE);//设置转速的数据个数 DMA_Cmd(DMA1_Channel0, ENABLE); //DMA Channel0 enable DMA_ITConfig(DMA1_Channel0, DMA_ITx_TC, ENABLE); // Enable DMA1 channel0 Transfer complete interrupt DMA_GlobalCmd(ENABLE); //DMA enable } INTERRUPT_HANDLER(DMA1_CHANNEL0_1_IRQHandler,2) { unsigned char i=0; // ADC_Cmd(ADC1,DISABLE); if(DMA_GetFlagStatus(DMA1_FLAG_TC0)!= RESET) { } DMA_ClearITPendingBit(DMA1_IT_TC0); } INTERRUPT_HANDLER(TIM2_UPD_OVF_TRG_BRK_USART2_TX_IRQHandler,19) { if(flg==0) { Vcc_Swich_On; flg=1; } else { Vcc_Swich_Off; flg=0; } TIM2_ClearITPendingBit(TIM2_IT_Update); } void Time_Adc_Dma_Init(void) { Timer2_Config_Init(); Ad_Config_Init(); DMA1_Config_Init(); ADC_ExternalTrigConfig(ADC1,ADC_ExtEventSelection_Trigger2,ADC_ExtTRGSensitivity_Falling); TIM2_SelectOutputTrigger(TIM2_TRGOSource_Update); TIM2_Cmd(ENABLE); // ADC_SoftwareStartConv(ADC1); } |
请教专家,STM8L052的GPIO口做输入检测,为什么不能反应管脚实际电压变化?
stm8l051f3 TSSOP20 封装,待机模式下,2天后,电流突然增加到140UA
stm8l050j3
STM8L的LCD调试时不亮
STM8L050J3使用SWIM下载方式,无法下载,总是报错
STM8L52、在主频1M下I2C 100K 时序异常,在主频16M就没问题。这是什么原因
stm8l152 低功耗7uA,降不下来
STM8 flash 库函数 startaddress = startaddress + ((uint32_t)BlockNum * FLASH_BLOCK_S
stm 8 flash 在RAM运行代码的问题,是不是库函数有问题 Library call (?sll32_l0_l0_a) from within a
批量中有少数几片STM8L101F3的uid多次读出不一致
另外发现楼主贴上的代码好像没有使能全局中断的语句 enableInterrupts();
