STM32H743 以太网 为什么需要设置在0x30040000才能使用
RST问题请教
关于STM32WB09例子程序中,是否能够不使用串口的问题,引脚另有他用
关于使用STM32CubeIDE for vscode配置freertos的问题
HAL_I2C_Mem_Read_IT读取INA226多个寄存器只有第一个寄存器是对的,其他全为0XFF
关于STM32WB09使用CUBEMX进行配置的问题
STM32CUbeMX生成的代码里面没有HAL_ADC_Calibration_Start和HAL_ADCEx_Calibration_Start
stm32 motor control workbench生成代码时,找不到STM32CUBEMX
有没有大佬更新了CubeIDE2.0.0,在软件内更新后体积大了一倍
STM32CUBE调试中出现没有 “uwTickPrio() at 0x20000004” 对应的源文件
ADC_HandleTypeDef hadc;
DMA_HandleTypeDef hdma_adc;
/* ADC init function */
void MX_ADC_Init(void)
ADC_ChannelConfTypeDef sConfig = {0};
/** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc.Instance = ADC1;
hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
hadc.Init.Resolution = ADC_RESOLUTION_12B;
hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_BACKWARD;
hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
hadc.Init.LowPowerAutoWait = ENABLE;
hadc.Init.LowPowerAutoPowerOff = DISABLE;
hadc.Init.ContinuousConvMode = ENABLE;
hadc.Init.DiscontinuousConvMode = DISABLE;
hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc.Init.DMAContinuousRequests = ENABLE;
hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED;
if (HAL_ADC_Init(&hadc) != HAL_OK)
Error_Handler();
/** Configure for the selected ADC regular channel to be converted.
sConfig.Channel = ADC_CHANNEL_0;
sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
sConfig.SamplingTime = ADC_SAMPLETIME_71CYCLES_5;
if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_1;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_2;
Error_Handler();
/* USER CODE BEGIN ADC_Init 2 */
// ADC1->CFGR1 &= (uint32_t)~ADC_CFGR1_DMACFG;
// ADC1->CFGR1 |= (uint32_t)ADC_CFGR1_DMACFG;
/* USER CODE END ADC_Init 2 */
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
GPIO_InitTypeDef GPIO_InitStruct = {0};
if(adcHandle->Instance==ADC1)
/* USER CODE BEGIN ADC1_MspInit 0 */
/* USER CODE END ADC1_MspInit 0 */
/* ADC1 clock enable */
__HAL_RCC_ADC1_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/**ADC GPIO Configuration
PA0 ------> ADC_IN0
PA1 ------> ADC_IN1
PA2 ------> ADC_IN2
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2;
GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/* ADC1 DMA Init */
/* ADC Init */
hdma_adc.Instance = DMA1_Channel1;
hdma_adc.Init.Direction = DMA_PERIPH_TO_MEMORY;
hdma_adc.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_adc.Init.MemInc = DMA_MINC_ENABLE;
hdma_adc.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
hdma_adc.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
hdma_adc.Init.Mode = DMA_CIRCULAR;
hdma_adc.Init.Priority = DMA_PRIORITY_LOW;
if (HAL_DMA_Init(&hdma_adc) != HAL_OK)
Error_Handler();
__HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc);
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
/* USER CODE BEGIN ADC1_MspDeInit 0 */
/* USER CODE END ADC1_MspDeInit 0 */
/* Peripheral clock disable */
__HAL_RCC_ADC1_CLK_DISABLE();
PA0 ------> ADC_IN0
PA1 ------> ADC_IN1
PA2 ------> ADC_IN2
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2);
/* ADC1 DMA DeInit */
HAL_DMA_DeInit(adcHandle->DMA_Handle);
/* USER CODE BEGIN ADC1_MspDeInit 1 */
/* USER CODE END ADC1_MspDeInit 1 */
还有初始化
HAL_ADCEx_Calibration_Start(&hadc);
HAL_Delay(100);
HAL_ADC_Start_DMA(&hadc, ADC_Value, 150);
处理函数
void read_V(void)
for(i=0,ad1=0,ad2=0,ad3=0; i<150;)
ad1 += ADC_Value[i++];
ad2 += ADC_Value[i++];
ad3 += ADC_Value[i++];
ad1 /= 50;
ad2 /= 50;
ad3 /= 50;
ChongDDY= ad1+ad2+ad3;
