STM32L4,用CUBEMX生成代码,用了FREERTOS,DMA,FATFS,SDIO,FATFS用了信号量,有一个BUG,好多年了,新的库都还没改,忍不住
陳勝・呉広 提问时间:2021-10-28 20:19 / 未解决
STM32L4,用CUBEMX生成代码,用了FREERTOS,DMA,FATFS,SDIO,FATFS用了信号量,有一个BUG,好多年了,新的库都还没改,忍不住了,所以发出来。sd_diskio.c代码附后,更改了的地方,或者需要更改的地方红色注释。
/* USER CODE BEGIN Header */
  * @file    sd_diskio.c
  * @brief   SD Disk I/O driver
  * @attention
  * <h2><center>© Copyright (c) 2021 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under Ultimate Liberty license
  * SLA0044, the "License"; You may not use this file except in compliance with
  * the License. You may obtain a copy of the License at:
  *                             www.st.com/SLA0044
/* USER CODE END Header */
/* Note: code generation based on sd_diskio_dma_rtos_template_bspv1.c v2.1.4
   as FreeRTOS is enabled. */
/* USER CODE BEGIN firstSection */
/* can be used to modify / undefine following code or add new definitions */
/* USER CODE END firstSection*/
/* Includes ------------------------------------------------------------------*/
#include "ff_gen_drv.h"
#include "sd_diskio.h"
#include <string.h>
#include <stdio.h>
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define QUEUE_SIZE         (uint32_t) 10
#define READ_CPLT_MSG      (uint32_t) 1
#define WRITE_CPLT_MSG     (uint32_t) 2
enable the defines below to send custom rtos messages
when an error or an abort occurs.
Notice: depending on the HAL/SD driver the HAL_SD_ErrorCallback()
may not be available.
See BSP_SD_ErrorCallback() and BSP_SD_AbortCallback() below
#define RW_ERROR_MSG       (uint32_t) 3
#define RW_ABORT_MSG       (uint32_t) 4
* the following Timeout is useful to give the control back to the applications
* in case of errors in either BSP_SD_ReadCpltCallback() or BSP_SD_WriteCpltCallback()
* the value by default is as defined in the BSP platform driver otherwise 30 secs
#define SD_TIMEOUT 30 * 1000
#define SD_DEFAULT_BLOCK_SIZE 512
* Depending on the use case, the SD card initialization could be done at the
* application level: if it is the case define the flag below to disable
* the BSP_SD_Init() call in the SD_Initialize() and add a call to
* BSP_SD_Init() elsewhere in the application.
/* USER CODE BEGIN disableSDInit */
/* #define DISABLE_SD_INIT */
#ifndef __CC_ARM
#define __CC_ARM//这个要增加使能//因为涉及到地址没四字节对齐,所以要判断转储下
#endif
#if defined   (__GNUC__)      /* GNU Compiler */
  #define ALIGN_32BYTES(buf)  buf __attribute__ ((aligned (32)))
#elif defined (__ICCARM__)    /* IAR Compiler */
  #define ALIGN_32BYTES(buf) _Pragma("data_alignment=32") buf
#elif defined   (__CC_ARM)    /* ARM Compiler */
  #define ALIGN_32BYTES(buf) __align(32) buf
#endif
/* USER CODE END disableSDInit */
* when using cacheable memory region, it may be needed to maintain the cache
* validity. Enable the define below to activate a cache maintenance at each
* read and write operation.
* Notice: This is applicable only for cortex M7 based platform.
/* USER CODE BEGIN enableSDDmaCacheMaintenance */
/* #define ENABLE_SD_DMA_CACHE_MAINTENANCE  1 */
/* USER CODE END enableSDDmaCacheMaintenance */
* Some DMA requires 4-Byte aligned address buffer to correctly read/write data,
* in FatFs some accesses aren't thus we need a 4-byte aligned scratch buffer to correctly
* transfer data
/* USER CODE BEGIN enableScratchBuffer */
#define ENABLE_SCRATCH_BUFFER //这个要使能
/* USER CODE END enableScratchBuffer */
/* Private variables ---------------------------------------------------------*/
#if defined(ENABLE_SCRATCH_BUFFER)
#if defined (ENABLE_SD_DMA_CACHE_MAINTENANCE)
ALIGN_32BYTES(static uint8_t scratch[BLOCKSIZE]); // 32-Byte aligned for cache maintenance
#else
__ALIGN_BEGIN static uint8_t scratch[BLOCKSIZE] __ALIGN_END;
#endif
#endif
/* Disk status */
static volatile DSTATUS Stat = STA_NOINIT;
#if (osCMSIS <= 0x20000U)
static osMessageQId SDQueueID = NULL;
#else
static osMessageQueueId_t SDQueueID = NULL;
#endif
/* Private function prototypes -----------------------------------------------*/
static DSTATUS SD_CheckStatus(BYTE lun);
DSTATUS SD_initialize (BYTE);
DSTATUS SD_status (BYTE);
DRESULT SD_read (BYTE, BYTE*, DWORD, UINT);
#if _USE_WRITE == 1
DRESULT SD_write (BYTE, const BYTE*, DWORD, UINT);
#endif /* _USE_WRITE == 1 */
#if _USE_IOCTL == 1
DRESULT SD_ioctl (BYTE, BYTE, void*);
#endif  /* _USE_IOCTL == 1 */
const Diskio_drvTypeDef  SD_Driver =
  SD_initialize,
  SD_status,
  SD_read,
#if  _USE_WRITE == 1
  SD_write,
#if  _USE_IOCTL == 1
  SD_ioctl,
/* USER CODE BEGIN beforeFunctionSection */
/* can be used to modify / undefine following code or add new code */
/* USER CODE END beforeFunctionSection */
/* Private functions ---------------------------------------------------------*/
static int SD_CheckStatusWithTimeout(uint32_t timeout)
  uint32_t timer;
  /* block until SDIO peripheral is ready again or a timeout occur */
  timer = osKernelSysTick();
  while( osKernelSysTick() - timer < timeout)
#else
  timer = osKernelGetTickCount();
  while( osKernelGetTickCount() - timer < timeout)
#endif
    if (BSP_SD_GetCardState() == SD_TRANSFER_OK)
      return 0;
  return -1;
  Stat = STA_NOINIT;
  if(BSP_SD_GetCardState() == SD_TRANSFER_OK)
    Stat &= ~STA_NOINIT;
  return Stat;
  * @brief  Initializes a Drive
  * @param  lun : not used
  * @retval DSTATUS: Operation status
DSTATUS SD_initialize(BYTE lun)
Stat = STA_NOINIT;
   * check that the kernel has been started before continuing
   * as the osMessage API will fail otherwise
  if(osKernelRunning())
#else
  if(osKernelGetState() == osKernelRunning)
#endif
#if !defined(DISABLE_SD_INIT)
    if(BSP_SD_Init() == MSD_OK)
      Stat = SD_CheckStatus(lun);
#else
#endif
    * if the SD is correctly initialized, create the operation queue
    * if not already created
    if (Stat != STA_NOINIT)
      if (SDQueueID == NULL)
      osMessageQDef(SD_Queue, QUEUE_SIZE, uint16_t);
      SDQueueID = osMessageCreate (osMessageQ(SD_Queue), NULL);
#else
      SDQueueID = osMessageQueueNew(QUEUE_SIZE, 2, NULL);
#endif
        Stat |= STA_NOINIT;
  return Stat;
  * @brief  Gets Disk Status
DSTATUS SD_status(BYTE lun)
  return SD_CheckStatus(lun);
/* USER CODE BEGIN beforeReadSection */
/* can be used to modify previous code / undefine following code / add new code */
/* USER CODE END beforeReadSection */
  * @brief  Reads Sector(s)
  * @param  *buff: Data buffer to store read data
  * @param  sector: Sector address (LBA)
  * @param  count: Number of sectors to read (1..128)
  * @retval DRESULT: Operation result
DRESULT SD_read(BYTE lun, BYTE *buff, DWORD sector, UINT count)
  uint8_t ret;//这里增加个定义,如果生成的文件里没有的话
  DRESULT res = RES_ERROR;
  uint32_t timer;
#if (osCMSIS < 0x20000U)
  osEvent event;
#else
  uint16_t event;
  osStatus_t status;
#endif
#if (ENABLE_SD_DMA_CACHE_MAINTENANCE == 1)
  uint32_t alignedAddr;
#endif
  * ensure the SDCard is ready for a new operation
  if (SD_CheckStatusWithTimeout(SD_TIMEOUT) < 0)
    return res;
  if (!((uint32_t)buff & 0x3))
#endif
    /* Fast path cause destination buffer is correctly aligned */
    ret = BSP_SD_ReadBlocks_DMA((uint32_t*)buff, (uint32_t)(sector), count);
    if (ret == MSD_OK) {
    /* wait for a message from the queue or a timeout */
    event = osMessageGet(SDQueueID, SD_TIMEOUT);
    if (event.status == osEventMessage)
      if (event.value.v == READ_CPLT_MSG)
        /* block until SDIO IP is ready or a timeout occur */
        while(osKernelSysTick() - timer <SD_TIMEOUT)
#else
          status = osMessageQueueGet(SDQueueID, (void *)&event, NULL, SD_TIMEOUT);
          if ((status == osOK) && (event == READ_CPLT_MSG))
            while(osKernelGetTickCount() - timer <SD_TIMEOUT)
#endif
                res = RES_OK;
                the SCB_InvalidateDCache_by_Addr() requires a 32-Byte aligned address,
                adjust the address and the D-Cache size to invalidate accordingly.
                alignedAddr = (uint32_t)buff & ~0x1F;
                SCB_InvalidateDCache_by_Addr((uint32_t*)alignedAddr, count*BLOCKSIZE + ((uint32_t)buff - alignedAddr));
#endif
                break;
#else
#endif
    else
      /* Slow path, fetch each sector a part and memcpy to destination buffer */
      int i;
      for (i = 0; i < count; i++)
        ret = BSP_SD_ReadBlocks_DMA((uint32_t*)scratch, (uint32_t)sector++, 1);
        if (ret == MSD_OK )
          /* wait until the read is successful or a timeout occurs */
#else
                ret = MSD_ERROR;
                while(osKernelGetTickCount() - timer < SD_TIMEOUT)
#endif
                  ret = BSP_SD_GetCardState();
                  if (ret == MSD_OK)
                    break;
                if (ret != MSD_OK)
                  break;
#else
#endif
          * invalidate the scratch buffer before the next read to get the actual data instead of the cached one
          SCB_InvalidateDCache_by_Addr((uint32_t*)scratch, BLOCKSIZE);
#endif
          memcpy(buff, scratch, BLOCKSIZE);
          buff += BLOCKSIZE;
        else
          break;
      if ((i == count) && (ret == MSD_OK ))
        res = RES_OK;
#endif
  return res;
/* USER CODE BEGIN beforeWriteSection */
/* USER CODE END beforeWriteSection */
  * @brief  Writes Sector(s)
  * @param  *buff: Data to be written
  * @param  count: Number of sectors to write (1..128)
#if _USE_WRITE == 1
DRESULT SD_write(BYTE lun, const BYTE *buff, DWORD sector, UINT count)
  uint32_t timer;
  osEvent event;
#else
  uint16_t event;
  osStatus_t status;
#endif
  int32_t ret;
#endif
    return res;
#endif
    the SCB_CleanDCache_by_Addr() requires a 32-Byte aligned address
    adjust the address and the D-Cache size to clean accordingly.
  SCB_CleanDCache_by_Addr((uint32_t*)alignedAddr, count*BLOCKSIZE + ((uint32_t)buff - alignedAddr));
#endif
  if(BSP_SD_WriteBlocks_DMA((uint32_t*)buff,
                           (uint32_t) (sector),
                           count) == MSD_OK)
    /* Get the message from the queue */
      if (event.value.v == WRITE_CPLT_MSG)
#else
    if ((status == osOK) && (event == WRITE_CPLT_MSG))
#endif
        while(osKernelSysTick() - timer  < SD_TIMEOUT)
#else
#endif
            res = RES_OK;
            break;
#else
#endif
  }//这里增加个花括号,        和前面 if (!((uint32_t)buff & 0x3))判断下面的花括号配对
  else {
    int i;
     * invalidate the scratch buffer before the next write to get the actual data instead of the cached one
#endif
        memcpy((void *)scratch, buff, BLOCKSIZE);
        buff += BLOCKSIZE;
        ret = BSP_SD_WriteBlocks_DMA((uint32_t*)scratch, (uint32_t)sector++, 1);
        if (ret == MSD_OK )
            if (event.value.v == READ_CPLT_MSG)//这是写函数里面,为什么这里条件是READ,应该改成WRITE
#else
              if ((status == osOK) && (event == READ_CPLT_MSG))//这是写函数里面,为什么这里条件是READ,应该改成WRITE
                ret = MSD_ERROR;
#endif
                  if (ret == MSD_OK)
                    break;
                if (ret != MSD_OK)
                  break;
#else
#endif
        else
          break;
        res = RES_OK;
//  }//这个花括号注释掉,估计是前面那个条件的括号错了位置。
#endif
  return res;
/* USER CODE BEGIN beforeIoctlSection */
/* USER CODE END beforeIoctlSection */
  * @brief  I/O control operation
  * @param  cmd: Control code
  * @param  *buff: Buffer to send/receive control data
#if _USE_IOCTL == 1
DRESULT SD_ioctl(BYTE lun, BYTE cmd, void *buff)
  BSP_SD_CardInfo CardInfo;
  if (Stat & STA_NOINIT) return RES_NOTRDY;
  switch (cmd)
  /* Make sure that no pending write process */
  case CTRL_SYNC :
    res = RES_OK;
    break;
  /* Get number of sectors on the disk (DWORD) */
  case GET_SECTOR_COUNT :
    BSP_SD_GetCardInfo(&CardInfo);
    *(DWORD*)buff = CardInfo.LogBlockNbr;
    res = RES_OK;
    break;
  /* Get R/W sector size (WORD) */
  case GET_SECTOR_SIZE :
    *(WORD*)buff = CardInfo.LogBlockSize;
    res = RES_OK;
    break;
  /* Get erase block size in unit of sector (DWORD) */
  case GET_BLOCK_SIZE :
    *(DWORD*)buff = CardInfo.LogBlockSize / SD_DEFAULT_BLOCK_SIZE;
    res = RES_OK;
    break;
  default:
    res = RES_PARERR;
  return res;
/* USER CODE BEGIN afterIoctlSection */
/* USER CODE END afterIoctlSection */
/* USER CODE BEGIN callbackSection */
/* can be used to modify / following code or add new code */
/* USER CODE END callbackSection */
  * @brief Tx Transfer completed callbacks
  * @param hsd: SD handle
  * @retval None
void BSP_SD_WriteCpltCallback(void)
   * No need to add an "osKernelRunning()" check here, as the SD_initialize()
   * is always called before any SD_Read()/SD_Write() call
   osMessagePut(SDQueueID, WRITE_CPLT_MSG, 0);
#else
   const uint16_t msg = WRITE_CPLT_MSG;
   osMessageQueuePut(SDQueueID, (const void *)&msg, NULL, 0);
#endif
  * @brief Rx Transfer completed callbacks
  * @retval None
void BSP_SD_ReadCpltCallback(void)
   osMessagePut(SDQueueID, READ_CPLT_MSG, 0);
#else
   const uint16_t msg = READ_CPLT_MSG;
#endif
/* USER CODE BEGIN ErrorAbortCallbacks */
void BSP_SD_AbortCallback(void)
   osMessagePut(SDQueueID, RW_ABORT_MSG, 0);
#else
   const uint16_t msg = RW_ABORT_MSG;
#endif
/* USER CODE END ErrorAbortCallbacks */
/* USER CODE BEGIN lastSection */
/* can be used to modify / undefine previous code or add new code */
/* USER CODE END lastSection */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
收藏 评论3 发布时间:2021-10-28 20:19
3个回答
xmshao 回答时间:2021-10-29 09:51:39
谢谢你的反馈与分享!
至暗时刻 回答时间:2021-11-2 15:45:39
正准备学习CubeMx 刚好也是用L4,先mark一下
陳勝・呉広 回答时间:2021-12-16 11:11:26
至暗时刻 发表于 2021-11-2 15:45
<strong>正准备学习CubeMx 刚好也是用L4,先mark一下</strong>
如果功能不用这么全,好像不会出这个问题。几大功能同时使用会有错误。
