我想用QSPI FLASH 作OTA,选用的是W25Q64,现在对QSPI的读写都正常,但是把QSPI 映射成内存模式,一对 0x9000000UL 进行读,就进入HardFault_Handler, 下面是我配置映射的代码,哪位大侠能帮看看有什么问题没有我芯片是用的STM32H750VB 用的STM32CUBE static unsigned int QSPI_EnableMemoryMappedMode(QSPI_HandleTypeDef *QSPIHandle) { QSPI_CommandTypeDef s_command; QSPI_MemoryMappedTypeDef s_mem_mapped_cfg; // Configure the command for the read instruction s_command.InstructionMode = QSPI_INSTRUCTION_1_LINE; s_command.Instruction = QUAD_INOUT_FAST_READ_CMD; s_command.Address = 0; s_command.AddressMode = QSPI_ADDRESS_4_LINES; s_command.AddressSize = QSPI_ADDRESS_24_BITS; s_command.AlternateBytes = 0x00; s_command.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE; s_command.AlternateBytesSize = QSPI_ALTERNATE_BYTES_8_BITS; s_command.DataMode = QSPI_DATA_4_LINES; s_command.NbData = 1; //??????? s_command.DummyCycles = 6; s_command.DdrMode = QSPI_DDR_MODE_DISABLE; s_command.DdrHoldHalfCycle = QSPI_DDR_HHC_ANALOG_DELAY; s_command.SIOOMode = QSPI_SIOO_INST_EVERY_CMD; // Configure the memory mapped mode s_mem_mapped_cfg.TimeOutActivation = QSPI_TIMEOUT_COUNTER_DISABLE; s_mem_mapped_cfg.TimeOutPeriod = 0; return HAL_QSPI_MemoryMapped(QSPIHandle, &s_command, &s_mem_mapped_cfg); } */ static unsigned int QSPI_EnableMemoryMappedMode(QSPI_HandleTypeDef *QSPIHandle) { QSPI_CommandTypeDef s_command; QSPI_MemoryMappedTypeDef s_mem_mapped_cfg; // Configure the command for the read instruction s_command.InstructionMode = QSPI_INSTRUCTION_4_LINES; s_command.Instruction = QUAD_INOUT_FAST_READ_CMD; s_command.Address = 0; s_command.AddressMode = QSPI_ADDRESS_4_LINES; s_command.AddressSize = QSPI_ADDRESS_32_BITS; // 24 32 都试过 s_command.AlternateBytes = 0x00; s_command.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE; s_command.AlternateBytesSize = QSPI_ALTERNATE_BYTES_8_BITS; s_command.DataMode = QSPI_DATA_4_LINES; s_command.NbData = 1; //??????? s_command.DummyCycles = 6; s_command.DdrMode = QSPI_DDR_MODE_DISABLE; s_command.DdrHoldHalfCycle = QSPI_DDR_HHC_ANALOG_DELAY; s_command.SIOOMode = QSPI_SIOO_INST_EVERY_CMD; // Configure the memory mapped mode s_mem_mapped_cfg.TimeOutActivation = QSPI_TIMEOUT_COUNTER_DISABLE; s_mem_mapped_cfg.TimeOutPeriod = 0; return HAL_QSPI_MemoryMapped(QSPIHandle, &s_command, &s_mem_mapped_cfg); } |
STM32H7A3VGH6Q D1、d2、E1、E2是SMPS功能对应的引脚,裸片量测D2与C1、D1对应的地没有短路现象,PCB板量测也没有短路,但芯片贴到板上D2 VLXSMPS就会与地短路。不知是啥原因。是否芯片型号与批次不对?
mmt 工具如何管理NAND和LCDinterface 设备
调试器如何通过AP0~AP3访问H757?
STM32H7的LSE起振问题
使用STM32H7A3的FMC接口驱动LCD 是否可以用DMA传输数据
stm32h743 lan8720 cube配置lwip无法ping通
型号相同,尾椎不一样
请问有没有人见过这样的报错
在Vscode中,如何将touchGFX的图片资源下载到QSPI FLASH中?
STM32H750+FreeRTOS uart DMA无法使用
麻烦给个连接,我学习一下啊
链接在这里,查看
[md]连接打不开啊
感觉发生了非法访问导致硬错。
好好检查下配置,尤其注意地址方面被给错或越界了。
