STM32H723ZG ,CUBEIDE原来版本是1.7.0,升级1.9.0后原来项目编译就报错了,后来用1.9.0版本重新生成新的代码,移植原来的用户代码,移植后编译成功,可以连接目标板,但是没法调试,也不运行,调试配置好像都没问题,下载时有错误警告...Target halted (DBGRQ, PC = 0xF3AF4804),连接下载信息如下:,大神给看看什么问题呀SEGGER J-Link GDB Server V7.62a Command Line Version JLinkARM.dll V7.62a (DLL compiled Feb 23 2022 16:58:13) Command line: -port 2331 -s -device STM32H723ZG -endian little -speed 1000 -if swd -swoport 2332 -vd -----GDB Server start settings----- GDBInit file: none GDB Server Listening port: 2331 SWO raw output listening port: 2332 Terminal I/O port: 2333 Accept remote connection: localhost only Generate logfile: off Verify download: on Init regs on start: off Silent mode: off Single run mode: on Target connection timeout: 0 ms ------J-Link related settings------ J-Link Host interface: USB J-Link script: none J-Link settings file: none ------Target related settings------ Target device: STM32H723ZG Target interface: SWD Target interface speed: 1000kHz Target endian: little Connecting to J-Link... J-Link is connected. Firmware: J-Link V9 compiled May 7 2021 16:26:12 Hardware: V9.20 Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB Checking target voltage... Target voltage: 3.25 V Listening on TCP/IP port 2331 Connecting to target... Connected to target Waiting for GDB connection...Connected to 127.0.0.1 Reading all registers WARNING: Failed to read memory @ address 0xF3AF4804 Received monitor command: WriteDP 0x2 0xF0 O.K. Received monitor command: ReadAP 0x2 O.K.:0xE00FE003 Reading 32 bytes @ address 0xE00FEFD0 Connected to 127.0.0.1 Reading all registers WARNING: Failed to read memory @ address 0xF3AF4804 Received monitor command: reset Resetting target Downloading 88 bytes @ address 0x08000000 - Verified OK Downloading 4 bytes @ address 0x08000058 - Verified OK Downloading 4 bytes @ address 0x0800005C - Verified OK Writing register (PC = 0x 8000000) Starting target CPU... GDB closed TCP/IP connection (Socket 1108) ...Target halted (DBGRQ, PC = 0xF3AF4804) Reading all registers WARNING: Failed to read memory @ address 0xF3AF4804 GDB closed TCP/IP connection (Socket 1112) Restoring target state and closing J-Link connection... Shutting down... |
新款H7馋的眼珠子掉出来了.快申请啊
惊喜快到了,预热的板子这就来了,赶紧周三申请
新品尝鲜到货,NUCLEO‑H7P5II 先给各位开开眼。
来了,老铁!混合信号 + 高性能双杀!NUCLEO-G564RE & H7P5II 试用马上来
STM32H7系列再添新成员,这次是高性能微控制来了
【2026.11.07】每日签到:STM32H735G-DK评测、Coremark跑分结果显示在LCD
【2026.10.31】每日签到:STM32H735G-DK评测.TouchGFX在LCD—text中显示动态字符
【2026.11.1】每日签到:STM32H735G-DK评测.接收串口字符并显示在LCD—text中
STM32H747的四线SPI(QUADSPI)是否支持slave模式?
[STM32H735G-DK评测]tocuchGFX中的时钟时针和秒针在MDK中丢失了
