stm32G030C8T6 ADC读取到的一直是4095
王东丶 提问时间:2022-8-22 17:10 / 已解决
大佬们,为什么adc读到的值一直是4095,换个通道还是一样,万用表量的值都小于3V,是不是配置有问题
赞 收藏 评论7 发布时间:2022-8-22 17:10
7个回答
xmshao 最优答案 回答时间:2022-8-23 09:52:09
首先硬件线路看看有问题,连接、供电,尤其VDDA之类的脚。然后你先拿ST的Cube库里的例程跑跑,也顺便
熟悉下相关函数。再自己从一个通道开始操作。不难的,加油!
王东丶 回答时间:2022-8-22 17:12:25
void MX_ADC1_Init(void)
  ADC_ChannelConfTypeDef sConfig = {0};
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
  hadc1.Init.Resolution = ADC_RESOLUTION_12B;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.ScanConvMode = ADC_SCAN_SEQ_FIXED;
  hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc1.Init.LowPowerAutoWait = DISABLE;
  hadc1.Init.LowPowerAutoPowerOff = DISABLE;
  hadc1.Init.ContinuousConvMode = DISABLE;
  hadc1.Init.NbrOfConversion = 1;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.DMAContinuousRequests = DISABLE;
  hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  hadc1.Init.SamplingTimeCommon1 = ADC_SAMPLETIME_12CYCLES_5;
  hadc1.Init.OversamplingMode = DISABLE;
  hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_11;
  sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
    Error_Handler();
王东丶 回答时间:2022-8-22 17:13:49
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
  if(adcHandle->Instance==ADC1)
    PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADC;
    PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_SYSCLK;
    if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
      Error_Handler();
    __HAL_RCC_ADC_CLK_ENABLE();
    __HAL_RCC_GPIOB_CLK_ENABLE();
    GPIO_InitStruct.Pin = GPIO_PIN_10;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
    __HAL_RCC_ADC_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOB, GPIO_PIN_10);
王东丶 回答时间:2022-8-22 17:14:36
int main(void)
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_ADC1_Init();
  MX_USART1_UART_Init();
  MX_USART2_UART_Init();
  /* USER CODE BEGIN 2 */
HAL_ADC_Start(&hadc1);
  while (1)
                printf("VREFINT_DATA:%d \r\n",HAL_ADC_GetValue(&hadc1));
                HAL_Delay(500);
yklstudent 回答时间:2022-8-22 20:24:44
mark,直接参考官方demo
王东丶 回答时间:2022-8-23 09:13:20
yklstudent 发表于 2022-8-22 20:24
mark,直接参考官方demo
好的 我试试
王东丶 回答时间:2022-8-24 09:12:04
熟悉 ...
好的,谢谢
