芯片是STM32F030C8T6,代码是根据F103可以通讯的代码移植过来的,接线也没有问题,但是寄存器就是没有数据,希望大神帮忙看看是哪里有什么问题吗?谢谢大家! ```SPI1(主机模式)初始化代码: void SPI1_Init(void) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE); RCC_AHBPeriphResetCmd(RCC_AHBPeriph_GPIOA, ENABLE); // SPI_Cmd(SPI1, DISABLE); SPI_InitTypeDef SPI_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Pin = SPI1_SCK_PIN | SPI1_MOSI_PIN | SPI1_MISO_PIN; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(SPI1_MISO_PORT, &GPIO_InitStructure); GPIO_PinAFConfig(SPI1_SCK_PORT, SPI1_SCK_SOURCE, GPIO_AF_0); GPIO_PinAFConfig(SPI1_MISO_PORT, SPI1_MISO_SOURCE, GPIO_AF_0); GPIO_PinAFConfig(SPI1_MOSI_PORT, SPI1_MOSI_SOURCE, GPIO_AF_0); SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStructure.SPI_CRCPolynomial = 7; SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; SPI_Init(SPI1, &SPI_InitStructure); SPI_RxFIFOThresholdConfig(SPI1, SPI_RxFIFOThreshold_QF); SPI_Cmd(SPI1, ENABLE); } ``` 主机发送数据代码: ```uint8_t SPI1_WriteRead8Byte(uint8_t TxData) { while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); SPI_SendData8(SPI1, TxData); // *(uint8_t*)&SPI1->DR = TxData; while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET); return SPI_ReceiveData8(SPI1); } ``` SPI2(从机模式)初始化代码: void SPI2_Init(void) { RCC_AHBPeriphResetCmd(RCC_AHBPeriph_GPIOB, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE); GPIO_InitStructure.GPIO_Pin = SPI2_SCK_PIN | SPI2_MOSI_PIN | SPI2_MISO_PIN; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(SPI2_MISO_PORT, &GPIO_InitStructure); SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; SPI_InitStructure.SPI_Mode = SPI_Mode_Slave; SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStructure.SPI_CRCPolynomial = 7; SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; SPI_Init(SPI2, &SPI_InitStructure); SPI_RxFIFOThresholdConfig(SPI2, SPI_RxFIFOThreshold_QF); SPI_Cmd(SPI2, ENABLE); SPI_I2S_ITConfig(SPI2, SPI_I2S_IT_RXNE, ENABLE); SPI_I2S_ITConfig(SPI2, SPI_I2S_IT_ERR, ENABLE); NVIC_InitStructure.NVIC_IRQChannel = SPI2_IRQn; NVIC_InitStructure.NVIC_IRQChannelPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } 从机中断函数: ```void SPI2_IRQHandler(void) { if (SET == SPI_I2S_GetITStatus(SPI2, SPI_I2S_IT_RXNE)) { ucSPI2_RxBuf[ucSPI2_RxCount] = *(uint8_t*)&SPI2->DR; while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET) ; *(uint8_t*)&SPI2->DR = ucSPI2_RxBuf[ucSPI2_RxCount] + 0x05; ucSPI2_RxCount++; if (ucSPI2_RxCount > SPI_BUF_LEN - 1) { ucSPI2_RxCount = 0; } SPI_I2S_ClearFlag(SPI2, SPI_I2S_IT_RXNE); //SPI_I2S_ClearITPendingBit(SPI1, SPI_I2S_IT_RXNE); } SPI_I2S_ClearFlag(SPI2, SPI_I2S_IT_RXNE); //SPI_I2S_ClearITPendingBit(SPI1, SPI_I2S_IT_RXNE); } } ``` 主函数: ```int main(void) { int i = 0; System_Initializes(); while (1) { for (i = 0; i < SPI_BUF_LEN; i++) { ucSPI1_RxBuf[i] = SPI1_WriteRead8Byte(ucSPI1_TxBuf[i]); Delay_ms(10); } } } ``` |
USB Host 外部中断按键失效
调用HAL_FLASH_OB_Unlock()直接进入 HardFaultHandler
STM32 增加 WiFi + 以太网的低成本方案
NUCLEO G474RE无法运行程序
STM32H563的QSPI接口不能读取W25Q256的后128MB数据
STM32C5 HAL SPI CRC 错误无法触发错误回调
STM32F407VGT6 开发板Beak at address "0x0" with no debug information our outside
HAL 库建议支持GPIO 同时配置为AF 与外部中断 EXTI
BootLoader 与 DFU 模式的区别
STM32 是否有各种接口的官方 Bootloader 方案
测试通讯最好用逻辑分析仪看看,否则很容易因为硬件问题导致分析出现错误。另外spi收发是分离的这样用逻辑分析仪可能更好分析一些。
另外标准库的方式已经落伍了,而且厂家也不更新维护了,尽快使用CUBE库吧。
用起来省事,移植方便,例程相当多~~~
我去看看,谢谢!
