stm32F4使用cubemx+Freerrtos和lwip以太网通信,stm32做server端,通信一段时间后,stm32接收不到数据,过几秒又恢复正常,发
Do vis 提问时间:2023-12-4 13:48 / 未解决
void Propulsiontask(void const * argument)
  /* USER CODE BEGIN Propulsiontask */
  /* Infinite loop */
    struct sockaddr_in server_addr_push;
    struct sockaddr_in connect_addr_push;
    int socket_push;
    int socket_connect_push;
    socklen_t addr_len;
    int err;
    int recv_push = 0;
    int send_push = 0;
    unsigned char data_buffer_push[50];
    socket_push = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
    if(socket_push == -1)
        closesocket(socket_push);
        return;
    memset(&server_addr_push, 0, sizeof(server_addr_push));
    server_addr_push.sin_family = AF_INET;
    server_addr_push.sin_addr.s_addr =inet_addr("192.168.5.100");
    server_addr_push.sin_port = htons(9895);
    addr_len = sizeof(struct sockaddr_in);
    err = bind(socket_push, (struct sockaddr *)&server_addr_push, sizeof(server_addr_push));
    if(err < 0)
        return;
    err = listen(socket_push, 1);
    if(err < 0)
        return;
    while(1)
        socket_connect_push = lwip_accept(socket_push, (struct sockaddr *)&connect_addr_push, &addr_len);
        if(socket_connect_push >= 0)
            send(socket_connect_push, "connect success!\n\r", 20, 0);
            break;
        else
            vTaskDelay(10);
    for(;;)
        vTaskDelay(10);
        recv_push = (int)lwip_recv(socket_connect_push, (void *)data_buffer_push, 50, 0);
        if (recv_push > 0)
            recv_time ++;
            if(recv_time == 32762) recv_time = 0;
        if(0 == strncmp((const char*)data_buffer_push, "$MTC", 4))
                CanResive_data_handle(data_buffer_push,recv_push);
        if (true == Propulsion_Flag)
                Propulsion_Flag = false;
                Propulsion_data_handle();
                send_push = send(socket_connect_push, (void *)data_propulsion_push ,strlen((char *)data_propulsion_push),0 );
                if (send_push < 0)
                    while(1)
                        closesocket(socket_connect_push);
                            break;
                        else
                            vTaskDelay(30);
赞 收藏 评论3 发布时间:2023-12-4 13:48
3个回答
xmshao 回答时间:2023-12-4 13:55:26
会不会有中断优先级方面的问题呢?或者堆栈方面的配置问题?
Do vis 回答时间:2023-12-4 16:08:22
[md]今天又测试出来是`lwip_recv`()影响了send(),我把`lwip_recv`去掉,只接收不发送的时候,接收就完全正常了
找补 回答时间:2024-5-21 09:21:25
老哥 我这f407加freertos程序下载到板子上没反应能不能帮忙看那看那
