stm32g431cbu6,dac无法输出
知更鸟 提问时间:2024-3-8 13:24 / 未解决
一个很简单的问题,我的 DAC DAC_CHANNEL_1无法输出电压。
1.首先我的ioc配置界面如下:
2.初始化代码如下:
/ USER CODE BEGIN Header /
  • @file dac.c
  • @brief This file provides code for the configuration
  • of the DAC instances.
  • @attention
  • Copyright (c) 2024 STMicroelectronics.
  • All rights reserved.
  • This software is licensed under terms that can be found in the LICENSE file
  • in the root directory of this software component.
  • If no LICENSE file comes with this software, it is provided AS-IS.
/ USER CODE END Header /
/ Includes ------------------------------------------------------------------/
include "dac.h"
/ USER CODE BEGIN 0 /
/ USER CODE END 0 /
DAC_HandleTypeDef hdac1;
/ DAC1 init function /
void MX_DAC1_Init(void)
/ USER CODE BEGIN DAC1_Init 0 /
/ USER CODE END DAC1_Init 0 /
DAC_ChannelConfTypeDef sConfig = {0};
/ USER CODE BEGIN DAC1_Init 1 /
/ USER CODE END DAC1_Init 1 /
/** DAC Initialization
hdac1.Instance = DAC1;
if (HAL_DAC_Init(&hdac1) != HAL_OK)
Error_Handler(); }
/** DAC channel OUT1 config
sConfig.DAC_HighFrequency = DAC_HIGH_FREQUENCY_INTERFACE_MODE_AUTOMATIC;
sConfig.DAC_DMADoubleDataMode = DISABLE;
sConfig.DAC_SignedFormat = DISABLE;
sConfig.DAC_SampleAndHold = DAC_SAMPLEANDHOLD_DISABLE;
sConfig.DAC_Trigger = DAC_TRIGGER_NONE;
sConfig.DAC_Trigger2 = DAC_TRIGGER_NONE;
sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_DISABLE;
sConfig.DAC_ConnectOnChipPeripheral = DAC_CHIPCONNECT_EXTERNAL;
sConfig.DAC_UserTrimming = DAC_TRIMMING_FACTORY;
if (HAL_DAC_ConfigChannel(&hdac1, &sConfig, DAC_CHANNEL_1) != HAL_OK)
Error_Handler(); }
/ USER CODE BEGIN DAC1_Init 2 /
HAL_DAC_Start(&hdac1, DAC_CHANNEL_1);
HAL_DAC_SetValue(&hdac1, DAC_CHANNEL_1, DAC_ALIGN_12B_R, 0);
/ USER CODE END DAC1_Init 2 /
void HAL_DAC_MspInit(DAC_HandleTypeDef* dacHandle)
GPIO_InitTypeDef GPIO_InitStruct = {0};
if(dacHandle->Instance==DAC1)
/ USER CODE BEGIN DAC1_MspInit 0 /
/ USER CODE END DAC1_MspInit 0 /
/ DAC1 clock enable /
__HAL_RCC_DAC1_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/**DAC1 GPIO Configuration
PA4 ------> DAC1_OUT1
GPIO_InitStruct.Pin = GPIO_PIN_4;
GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/ DAC1 interrupt Init /
HAL_NVIC_SetPriority(TIM6_DAC_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(TIM6_DAC_IRQn); / USER CODE BEGIN DAC1_MspInit 1 /
/ USER CODE END DAC1_MspInit 1 /
void HAL_DAC_MspDeInit(DAC_HandleTypeDef* dacHandle)
/ USER CODE BEGIN DAC1_MspDeInit 0 /
/ USER CODE END DAC1_MspDeInit 0 /
/ Peripheral clock disable /
__HAL_RCC_DAC1_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_4);
/ DAC1 interrupt Deinit /
HAL_NVIC_DisableIRQ(TIM6_DAC_IRQn); / USER CODE BEGIN DAC1_MspDeInit 1 /
/ USER CODE END DAC1_MspDeInit 1 /
/ USER CODE BEGIN 1 /
/ USER CODE END 1 /
3.main函数:
int main(void)
/ USER CODE END 1 /
/ MCU Configuration--------------------------------------------------------/
/ Reset of all peripherals, Initializes the Flash interface and the Systick. /
HAL_Init();
/ USER CODE BEGIN Init /
/ USER CODE END Init /
/ Configure the system clock /
SystemClock_Config();
/ USER CODE BEGIN SysInit /
/ USER CODE END SysInit /
/ Initialize all configured peripherals /
MX_GPIO_Init();
MX_DMA_Init();
MX_TIM1_Init();
MX_USART1_UART_Init();
MX_TIM2_Init();
MX_TIM4_Init();
MX_DAC1_Init();
/ USER CODE BEGIN 2 /
__HAL_TIM_CLEAR_IT(&htim1,TIM_IT_UPDATE);//清除中断标志位
HAL_TIM_Base_Start_IT(&htim1);
/ USER CODE END 2 /
/ Infinite loop /
/ USER CODE BEGIN WHILE /
while (1)
/ USER CODE END WHILE /
/ USER CODE BEGIN 3 /
HAL_DAC_SetValue(&hdac1, DAC_CHANNEL_1, DAC_ALIGN_12B_R, 2000);
HAL_DAC_SetValue(&hdac1, DAC_CHANNEL_1, DAC_ALIGN_12B_R, 0); }
/ USER CODE END 3 /
我用示波器点PA4引脚,单步调试,并没有电压输出。。。
所以,能否给出指导。
赞 收藏 评论12 发布时间:2024-3-8 13:24
12个回答
yr 回答时间:2024-3-8 14:34:32
如果是要输出一个定电压,需要hal_dac_setvalue() 和hal_dac_start()这两句就可以,所以把它们放到while前面
butterflyspring 回答时间:2024-3-8 14:48:01
DAC响应是有一定时间的。
貌似代码跑得太快了。
所以最好调整一下逻辑。
知更鸟 回答时间:2024-3-8 15:37:26
<br /> <br />
你好,按照你的描述,我把那两句代码放在while之前,还是没有电压输出,这是为何呢?
yr 回答时间:2024-3-8 16:22:35
sConfig.DAC_Trigger = DAC_TRIGGER_NONE;这个要选software触发啊
知更鸟 回答时间:2024-3-11 08:44:21
<br /> <br />
按照你的指示,尝试了还是不行
如下是dac.c:
  • @file dac.c
  • @attention
include "dac.h"
/ USER CODE END 0 /
Error_Handler(); }
sConfig.DAC_Trigger = DAC_TRIGGER_SOFTWARE;
sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_ENABLE;
Error_Handler(); }
/ USER CODE END 1 /
如下是main函数:
int main(void)
/ USER CODE END 1 /
HAL_Init();
MX_GPIO_Init();
MX_DMA_Init();
MX_TIM1_Init();
MX_TIM2_Init();
MX_TIM4_Init();
MX_DAC1_Init();
__HAL_TIM_CLEAR_IT(&htim1,TIM_IT_UPDATE);//清除中断标志位,防止一使能定时器就进入中断
//HAL_DAC_SetValue(&hdac1, DAC_CHANNEL_1, DAC_ALIGN_12B_R, 0);
/ USER CODE END 2 /
/ Infinite loop /
while (1)
/ USER CODE BEGIN 3 / }
/ USER CODE END 3 /
yr 回答时间:2024-3-11 09:53:17
检查一下硬件是否有问题了,比如vref对吗?
知更鸟 回答时间:2024-3-11 11:17:06
<br /> <br />
vref我测的是0v
是硬件问题吗?需要多少的参考电压
知更鸟 回答时间:2024-3-11 12:46:20
<br /> <br />
看下芯片手册里面关于vref的章节描述
这个里的VREFBUF_CSR怎么设置?我们的硬件工程师回复的是他接的是一个电容。
知更鸟 回答时间:2024-3-11 14:31:10
找到问题了,硬件没有作外置参考电压。拉高vref就可以了
但是,硬件改动成本较大。
请问,软件程序上怎么修改?如何使用内置的参考?
butterflyspring 回答时间:2024-3-11 16:12:56
知更鸟 发表于 2024-3-11 14:31
[md]
试试下面的配置方式行不行
知更鸟 回答时间:2024-3-11 16:20:53
<br /> <br />
是的,内部也可以了
但是我看了许多资料,有开发者说内部的参考寄存器--VREFBUF寄存器有局限。
所以想请教几个问题:
1.内部的最大参考是2.9V,这个值还可以改变吗?毕竟与3.3V差距还是比较大。
2.我DAC使用内部参考后,HAL_DAC_SetValue(&hdac1, DAC_CHANNEL_1, DAC_ALIGN_12B_R, 4095);似乎也只能输出到2.9V,也是无法继续增大的是吧?
3.内部的参考是否稳定呢?与外部相比较来说是不是精度不好?他们主要的区别是什么?
感谢!
butterflyspring 回答时间:2024-3-11 16:35:28
知更鸟 发表于 2024-3-11 16:20
[md]是的,内部也可以了
1. 只能是这几个选项,最大2.9 v。 内部是没有做升压的。
2. 因为参考电压就只有2.9,所以最大输出就只能到这了。
3. 这是个电压稳定精度数据手册上有,已经很高了。 如果需要更高标准的,就要外接,估计成本不会低的。
