正在使用stm8作为从机与esp32进行i2c通讯,但是发现主机扫描的i2c地址与stm8从机设置的i2c地址不一样,请问如何解决?
Troy-_Wong 提问时间:2024-10-24 10:51 / 未解决
这个是stm8从机代码
#include <Arduino.h>
// #include <stm8s.h> // 假设你使用了STM8标准库
// #include "i2c_slave.h"
#include "Wire.h"
#define I2C_SLAVE_ADDR 0x30
#define I2C_DATA_SIZE 8
#if ((I2C_DATA_SIZE > 0) && ((I2C_DATA_SIZE & (I2C_DATA_SIZE - 1)) != 0))
#error I2C_DATA_SIZE isnt a power of 2.
#endif
#define uint8_bits_def(x)         \
  union                           \
    unsigned char x;              \
    struct                        \
      unsigned char x##_Bit0 : 1, \
          x##_Bit1 : 1,           \
          x##_Bit2 : 1,           \
          x##_Bit3 : 1,           \
          x##_Bit4 : 1,           \
          x##_Bit5 : 1,           \
          x##_Bit6 : 1,           \
          x##_Bit7 : 1;           \
uint8_bits_def(tagI2C);
uint8_t i2c_addr = 0;
uint8_t i2c_data[I2C_DATA_SIZE] = {0x00};
int tagI2C_Bit0 = 0;
// // I2C中断服务处理函数声明
// void I2C_ISR(void) __interrupt(19); // I2C中断向量号
void Serial_print(const char *str)
  while (*str)
    Serial_write(*str++); // 逐个字符发送
void I2C_Slave_IRQHandler(void)
  volatile I2C_Event_TypeDef Event = I2C_GetLastEvent();
  Serial_print("STM8 I2C_Slave_IRQHandler.");
  /* Slave address matched with the address sent by master */
  /* EV1: ADDR = 1, 顺序读SR1,SR3寄存器清除此标志位 */
  if (Event == (I2C_EVENT_SLAVE_RECEIVER_ADDRESS_MATCHED))
    tagI2C_Bit0 = 1;
  /* Slave received the data byte from master */
  /* EV2: RxNE = 1, 读DR寄存器清除此位 */
  else if (Event == (I2C_EVENT_SLAVE_BYTE_RECEIVED))
    uint8_t ch = I2C_ReceiveData();
    if (tagI2C_Bit0)
      tagI2C_Bit0 = 0;
      i2c_addr = ch;
    else
      i2c_data[i2c_addr++ & (I2C_DATA_SIZE - 1)] = ch;
  /* Slave received STOP byte from master */
  /* EV4: STOPF = 1,读SR1寄存器后再写CR2清除 */
  else if (Event == (I2C_EVENT_SLAVE_STOP_DETECTED))
    I2C_GetFlagStatus(I2C_FLAG_STOPDETECTION);
    I2C_GenerateSTOP(DISABLE);
  /* SLAVE TRANSMITTER */
  /* Data transmited from slave to master */
  /* EV3: TxE = 1, 写DR寄存器清除DR */
  else if ((Event == (I2C_EVENT_SLAVE_BYTE_TRANSMITTED)) ||
           (Event == (I2C_EVENT_SLAVE_TRANSMITTER_ADDRESS_MATCHED)))
    uint8_t ch = i2c_data[i2c_addr++ & (I2C_DATA_SIZE - 1)];
    I2C_SendData(ch);
  /* Acknowledge failure */
  /* EV3-2: AF = 1, AF is cleared by writing '0' in AF bit of SR2 register */
  else if (Event == (I2C_EVENT_SLAVE_ACK_FAILURE))
    I2C_ClearFlag(I2C_FLAG_ACKNOWLEDGEFAILURE);
// INTERRUPT_HANDLER(I2C_IRQHandler, 19)
//   I2C_Slave_IRQHandler();
void I2C_Slave_Init(void)
  // open I2C clk
  CLK_PeripheralClockConfig(CLK_PERIPHERAL_I2C, ENABLE);
  I2C_DeInit();
  I2C_Init(50000, I2C_SLAVE_ADDR, I2C_DUTYCYCLE_2, I2C_ACK_CURR, I2C_ADDMODE_7BIT, (CLK_GetClockFreq() / 1000000));
  /* Enable Error Interrupt*/
  I2C_ITConfig((I2C_IT_TypeDef)(I2C_IT_ERR | I2C_IT_EVT | I2C_IT_BUF), ENABLE);
  /* enable IIC*/
  I2C_Cmd(ENABLE);
  // enableInterrupts();
void setup()
  // 初始化串口通信,波特率为9600
  Serial_begin(9600);
  // 给串口输出一条消息,表示系统已经启动
  Serial_print("STM8 initialized and ready.");
  I2C_Slave_Init();
  // pid_i2c_init();
void loop()
这个是esp32主机代码
#include "Wire.h"
uint32_t I2C2_SPEED = 50000;
void setup()
  Serial.begin(115200);
  Wire.begin(21, 22, I2C2_SPEED);
void loop()
  byte error, address;
  int nDevices = 0;
  delay(3000);
  Serial.println("Scanning for I2C devices ...");
  for (address = 0x01; address < 0x7f; address++)
    Wire.beginTransmission(address);
    // Wire.write(0x11);
    error = Wire.endTransmission();
    if (error == 0)
      Serial.printf("I2C device found at address 0x%02X\n", address);
      nDevices++;
    else if (error != 2)
      Serial.printf("Error %d at address 0x%02X\n", error, address);
  if (nDevices == 0)
    Serial.println("No I2C devices found");
esp32 debug:
I2C device found at address 0x18
当esp32扫描到这个i2c地址后stm8会重启,当前不知道是什么原因导致的
赞 收藏 评论6 发布时间:2024-10-24 10:51
6个回答
butterflyspring 回答时间:2024-10-25 11:00:02
通常可以调试看看地址寄存器的内容是否是设置的地址,同时看看响应时的寄存器标志位 ADDR 是否置位。
另外STM8速度通常只有16Mhz,响应中断要尽可能快,所以最好优化中断执行时间,可参考一下例程。
Troy-_Wong 回答时间:2024-10-26 11:48:43
butterflyspring 发表于 2024-10-25 11:00
通常可以调试看看地址寄存器的内容是否是设置的地址,同时看看响应时的寄存器标志位 ADDR 是否置位。</p>
<p>
`当esp32扫描到这个i2c地址后stm8会重启,这个重启会是什么原因导致的呢,而且debug一点报错都没有,stm直接是重启了,只要主机扫描到i2c设备从机stm8就重启了
Troy-_Wong 回答时间:2024-10-26 12:00:12
Troy-_Wong 发表于 2024-10-26 11:48
`当esp32扫描到这个i2c地址后stm8会重启,这个重启会是什么原因导致的呢,而且debug一点报错都没有, ...
[md]请问下有stm8作为从设备的案例吗
butterflyspring 回答时间:2024-10-28 09:49:05
Troy-_Wong 发表于 2024-10-26 12:00
请问下有stm8作为从设备的案例吗
有的,在标准外设库里,注意中断尽可能快些。优先级高。
stm8sfwlib2.31\STM8S_StdPeriph_Lib\Project\STM8S_StdPeriph_Examples\I2C\I2C_TwoBoards\I2C_DataExchange\Slave
Troy-_Wong 回答时间:2024-10-31 17:56:44
butterflyspring 发表于 2024-10-28 09:49
有的,在标准外设库里,注意中断尽可能快些。优先级高。</p>
<p>
我试过这个案例,stm8 作为从机,但是主机一旦扫描到从机的i2c地址后,stm8就会自动重启。如果stm8作为主机的话扫描其它从机则不会出现重启现象,请问这个如何解决呢
butterflyspring 回答时间:2024-11-4 14:28:05
Troy-_Wong 发表于 2024-10-31 17:56
[md]我试过这个案例,stm8 作为从机,但是主机一旦扫描到从机的i2c地址后,stm8就会自动重启。如果stm8作 ...
这个现象很奇怪,需要调试看看。
1. 可以简化I2C 中断内容,看看是否还会重启。
2. REST 有个状态寄存器,首次上电清零,然后复位后判断输出看看是什么复位标志置位起来的。
