STM32L431内部温度AD值不随温度变化
懵逼 提问时间:2025-9-4 14:49 / 未解决
本人使用STM32L431RCT6单片机和STM32CUBEMX配置ADC进行内部温度采集,程序如下:
/ ADC1 init function / void MX_ADC1_Init(void) {
/ USER CODE BEGIN ADC1_Init 0 /
/ USER CODE END ADC1_Init 0 /
ADC_ChannelConfTypeDef sConfig = {0};
/ USER CODE BEGIN ADC1_Init 1 /
/ USER CODE END ADC1_Init 1 /
/* Common config / hadc1.Instance = ADC1; hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV16; hadc1.Init.Resolution = ADC_RESOLUTION_12B; hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE; hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV; hadc1.Init.LowPowerAutoWait = DISABLE; hadc1.Init.ContinuousConvMode = DISABLE; hadc1.Init.NbrOfConversion = 1; hadc1.Init.DiscontinuousConvMode = DISABLE; hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; hadc1.Init.DMAContinuousRequests = DISABLE; hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED; hadc1.Init.OversamplingMode = DISABLE; if (HAL_ADC_Init(&hadc1) != HAL_OK) { Error_Handler(); }
/* Configure Regular Channel / sConfig.Channel = ADC_CHANNEL_TEMPSENSOR; sConfig.Rank = ADC_REGULAR_RANK_1; sConfig.SamplingTime = ADC_SAMPLETIME_2CYCLES_5; sConfig.SingleDiff = ADC_SINGLE_ENDED; sConfig.OffsetNumber = ADC_OFFSET_NONE; sConfig.Offset = 0; if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK) { Error_Handler(); } / USER CODE BEGIN ADC1_Init 2 /
/ USER CODE END ADC1_Init 2 /
采集AD程序如下:
void GetInternalTemp(void) { HAL_ADC_Start(&hadc1); HAL_ADC_PollForConversion(&hadc1, 0xff); if(HAL_IS_BIT_SET(HAL_ADC_GetState(&hadc1), HAL_ADC_STATE_REG_EOC)) { ADC_Value = (float)HAL_ADC_GetValue(&hadc1);
ADC_Value = ADC_Value*3.0/2.5;
measure.temperture_internal = (float)((ADC_Value-*TEMP30_CAL_ADDR)*1.0/(int16_t)(*TEMP130_CAL_ADDR-*TEMP30_CAL_ADDR))+30;
可以获取AD值,但是AD值随温度不变化,求助这是什么原因导致的
收藏 评论3 发布时间:2025-9-4 14:49
3个回答
xmshao 回答时间:2025-9-12 10:15:51
提醒几点:
1、针对温度传感器做测量时,校准时使用的参考电压与实际应用不一致时要做换算,换算成相同参考电压的数据后再做计算。
2、采样时间要够。
下面文章内容是以STM32G4系列的内部AD通道讨论的,你完全可以参考。
基于STM32片内信号的ADC应用演示
butterflyspring 回答时间:2025-9-12 17:51:14
用STM32L432KC测试了一下,用风枪加热,看到了ADC值的变化,所以传感器没问题。
需要注意一下,由于外壳的存在,对外部的温度变化不敏感。
所以通常用来测内部结温。
目中无神-STM 回答时间:2025-9-19 09:16:56
butterflyspring 发表于 2025-9-12 17:51
用STM32L432KC测试了一下,用风枪加热,看到了ADC值的变化,所以传感器没问题。</p>
<p>需要注意一下,由于外壳的 ...
有没有STM32L431RCT6中文数据手册发一份
