stm32f107裸机+HR911105A+lwIP 1.31 SYN发送失败的问题
鹿与怀桥 提问时间:2026-6-22 17:00 / 未解决
stm32f107裸机+HR911105A+lwIP 1.31 动态获取IP与远端服务器连接,网口link灯常亮,信号灯闪黄灯。 配置静态或者动态IP与远端服务器发起TCP连接,ARP回包后(Wareshark抓包),pcb状态一直为TCP_SENT状态,直至重试次数耗尽。tcp_connect()返回0,但是回调函数没有执行。请大佬们给看看,谢谢了
void TCP_Client_Init(u16_t local_port,u16_t remote_port,unsigned char a,unsigned char b,unsigned char c,unsigned char d)
    struct ip_addr ipaddr;
    struct tcp_pcb *tcp_client_pcb = 0;
    err_t err;
    mqttinfo.pcb = 0;
    if((IPaddress!=0)&&(tcp_active_pcbs == NULL))        //确定IP已建立连接,获取到IP地址
        IP4_ADDR(&ipaddr,a,b,c,d);           //服务器IP地址
        tcp_client_pcb = tcp_new(); /* 建立通信的TCP控制块(Clipcb) */
        if (!tcp_client_pcb)
            return ;
        err = tcp_bind(tcp_client_pcb,IP_ADDR_ANY,local_port); /* 绑定本地IP地址和端口号 ,本地ip地址在LwIP_Init()中已经初始化*/
        if(err != ERR_OK)
            return ;
        printf("server:%d %d %d %d\n", a, b, c, d);
        tcp_connect(tcp_client_pcb,&ipaddr,remote_port,TCP_Connected);//注册回调函数
void LwIP_Periodic_Handle(__IO uint32_t localtime)
    /* TCP periodic process every 250 ms */
    if (localtime - TCPTimer >= TCP_TMR_INTERVAL)
        TCPTimer =  localtime;
        tcp_tmr();
    /* ARP periodic process every 5s */
    if (localtime - ARPTimer >= ARP_TMR_INTERVAL)
        ARPTimer =  localtime;
        etharp_tmr();
    /* Fine DHCP periodic process every 500ms */
    if (localtime - DHCPfineTimer >= DHCP_FINE_TIMER_MSECS)
        DHCPfineTimer =  localtime;
        dhcp_fine_tmr();
    /* DHCP Coarse periodic process every 60s */
    if (localtime - DHCPcoarseTimer >= DHCP_COARSE_TIMER_MSECS)
        DHCPcoarseTimer =  localtime;
        dhcp_coarse_tmr();
    if (localtime - IPaddTimer >= IP_TIMER_MSECS)
        IPaddTimer = localtime;
        ChangeNetifLinkStatues();
        /* We have got a new IP address so update the display */
        if (IPaddress != netif.ip_addr.addr)
            IPaddress = netif.ip_addr.addr;
            if (netif.flags & NETIF_FLAG_DHCP)
                /* Initialize the client application */
                TCP_Client_Init(TCP_LOCAL_PORT,TCP_SERVER_PORT,TCP_SERVER_IP);
        else if (IPaddress == 0)
            /* We still waiting for the DHCP server */
            /* If no response from a DHCP server for MAX_DHCP_TRIES times */
            /* stop the dhcp client and set a static IP address */
            if (netif.dhcp->tries > MAX_DHCP_TRIES)
                struct ip_addr netmask;
                struct ip_addr gw;
                dhcp_stop(&netif);
                IP4_ADDR(&ipaddr, 192, 168, 1, 252);
                IP4_ADDR(&netmask, 255, 255, 255, 0);
                IP4_ADDR(&gw, 192, 168, 1, 1);
                netif_set_addr(&netif, &ipaddr , &netmask, &gw);
#define TCP_SERVER_IP 192.168.1.52
#define TCP_LOCAL_PORT       10300
#define TCP_SERVER_PORT      18183
uint32_t IPaddress = 0;
uint8_t  MACaddr[6];
/* Private function prototypes -----------------------------------------------*/
extern CHGSTATINF SysInfo;
extern uint8_t EthInitStatus;
extern void Ethernet_Configuration(void);
extern void client_init(void);
extern void server_init(void);
void My_IP4_ADDR(struct ip_addr *ipaddr,unsigned char a,unsigned char b,unsigned char c,unsigned char d);
void ETH_link_callback(struct netif *xnetif)
    uint8_t i = 0;
    struct tcp_pcb *pcb = 0;
    struct tcp_pcb *cpcb = 0;
    struct ip_addr gw;
    if(netif_is_link_up(xnetif))     //联网
        /* Restart MAC interface */
        ipaddr.addr     = 0;
        netmask.addr    = 0;
        gw.addr         = 0;
        IPaddress = 0;
        netif_set_addr(xnetif, &ipaddr , &netmask, &gw);
        dhcp_start(xnetif);
        /* When the netif is fully configured this function must be called.*/
        netif_set_up(xnetif);
    else                             //断网
        dhcp_stop(xnetif);
        netif_set_down(xnetif);
        for(pcb = tcp_active_pcbs; pcb != NULL; pcb = pcb->next)
            i++;
        for(pcb = tcp_active_pcbs; i > 0 ; i--)
            cpcb = pcb;
            pcb = pcb->next;
            tcp_abort(cpcb);
        IPaddress = 0;
        g_tcp_link_state = 0;
        mqttinfo.pcb = 0;
        mqttinfo.state = MQTT_STAT_ERR;
void LwIP_Init(void)
    struct ip_addr gw;
    /* Initializes the dynamic memory heap defined by MEM_SIZE.*/
    mem_init();
    /* Initializes the memory pools defined by MEMP_NUM_x.*/
    memp_init();
    ipaddr.addr = 0;
    netmask.addr = 0;
    gw.addr = 0;
    Set_MAC_Address();
    netif_add(&netif, &ipaddr, &netmask, &gw, NULL, &ethernetif_init, &ethernet_input);
    netif_set_default(&netif);
    /*  Creates a new DHCP client for this interface on the first call.
    Note: you must call dhcp_fine_tmr() and dhcp_coarse_tmr() at
    the predefined regular intervals after starting the client.
    You can peek in the netif->dhcp struct for the actual DHCP status.*/
    dhcp_start(&netif);
    netif_set_up(&netif);
    netif_set_link_callback(&netif, ETH_link_callback);
void LwIP_ReInit(void)
    struct ip_addr gw;
    netif_remove(&netif);
    IPaddress = 0;
    mem_init();
    memp_init();
    ipaddr.addr = 0;
    netmask.addr = 0;
    gw.addr = 0;
    Set_MAC_Address();
    dhcp_start(&netif);
  * @brief  Called when a frame is received
  * @param  None
  * @retval None
void LwIP_Pkt_Handle(void)
    /* Read a received packet from the Ethernet buffers and send it to the lwIP for handling */
    ethernetif_input(&netif);
void Reset_link_up(void)
    netif_set_link_up(&netif);
//检查网口物理连接状态
void ChangeNetifLinkStatues(void)
    if(((ETH_ReadPHYRegister(0x01, PHY_BSR) & PHY_Linked_Status) == Link_Down))
        if(g_eth_link_state != Link_Down)   //拔网线
            netif_set_link_down(&netif);
            g_eth_link_state = Link_Down;
    else           //插网线
        if(EthInitStatus == 0)
            Ethernet_Configuration();      // 有1S左右的等待时间
            LwIP_ReInit();
//            netif_set_link_up(&netif);
            g_eth_link_state = Link_Up;
        else
            if(g_eth_link_state != Link_Up)
//                TCP_Client_Close();
//                LwIP_ReInit();             //此处不能再ReInit,会导致掉包
void TcpMonCom(void)
    LwIP_Periodic_Handle(LocalTime);                  //TCPIP
int main()
    while(1)
        TcpMonCom();
赞 收藏 评论1 发布时间:2026-6-22 17:00
xmshao 回答时间:2026-6-23 13:32:47
不管怎样,你的主循环里至少应该把LwIP_Pkt_Handle() 加进去才合理。
LwIP_Pkt_Handle(); // 处理接收包
当然,不排除还有其它原因要查。
