【stm32U3测评】FDCAN 满载性能实测
短笛君 发布时间:2026-7-5 23:49
本次测试会将FDCAN配置为FDCAN模式 仲裁段波特率为1Mbps 数据段为8Mbps,基本工程可以参考上一版本中FDCAN配置成classic模式通信的代码
主频调整至96Mbps
配置参数如下
参数 仲裁段 (1 Mbps) 数据段 (8 Mbps)
Prescaler 1 1
TSEG1 63 7
TSEG2 32 4
SJW 32 4
Mode Normal
Frame Format FD with BRS (FD + Bit Rate Switching)
Auto Retransmission Enable
Transmit Pause Disable
Protocol Exception Enable
注意 模式要配置成Bit Rate Switching
初始化代码如下
void MX_FDCAN1_Init(void)
  /* USER CODE BEGIN FDCAN1_Init 0 */
  /* USER CODE END FDCAN1_Init 0 */
  /* USER CODE BEGIN FDCAN1_Init 1 */
  /* USER CODE END FDCAN1_Init 1 */
  hfdcan1.Instance = FDCAN1;
  hfdcan1.Init.ClockDivider = FDCAN_CLOCK_DIV1;
  hfdcan1.Init.FrameFormat = FDCAN_FRAME_FD_BRS;
  hfdcan1.Init.Mode = FDCAN_MODE_NORMAL;
  hfdcan1.Init.AutoRetransmission = ENABLE;
  hfdcan1.Init.TransmitPause = DISABLE;
  hfdcan1.Init.ProtocolException = ENABLE;
  hfdcan1.Init.NominalPrescaler = 1;
  hfdcan1.Init.NominalSyncJumpWidth = 32;
  hfdcan1.Init.NominalTimeSeg1 = 63;
  hfdcan1.Init.NominalTimeSeg2 = 32;
  hfdcan1.Init.DataPrescaler = 1;
  hfdcan1.Init.DataSyncJumpWidth = 4;
  hfdcan1.Init.DataTimeSeg1 = 7;
  hfdcan1.Init.DataTimeSeg2 = 4;
  hfdcan1.Init.StdFiltersNbr = 1;
  hfdcan1.Init.ExtFiltersNbr = 0;
  hfdcan1.Init.TxFifoQueueMode = FDCAN_TX_FIFO_OPERATION;
  if (HAL_FDCAN_Init(&hfdcan1) != HAL_OK)
    Error_Handler();
还有滤波器配置
void MX_FDCAN1_Config(void)
  FDCAN_FilterTypeDef sFilterConfig;
  /* Configure standard filter: accept all standard IDs into Rx FIFO 0 */
  sFilterConfig.IdType       = FDCAN_STANDARD_ID;
  sFilterConfig.FilterIndex  = 0;
  sFilterConfig.FilterType   = FDCAN_FILTER_MASK;
  sFilterConfig.FilterConfig = FDCAN_FILTER_TO_RXFIFO0;
  sFilterConfig.FilterID1    = 0x000;
  sFilterConfig.FilterID2    = 0x000;
  if (HAL_FDCAN_ConfigFilter(&hfdcan1, &sFilterConfig) != HAL_OK)
    Error_Handler();
  /* Set global filter: reject non-matching std/ext frames, filter remote frames */
  if (HAL_FDCAN_ConfigGlobalFilter(&hfdcan1, FDCAN_REJECT, FDCAN_REJECT,
                                   FDCAN_FILTER_REMOTE, FDCAN_FILTER_REMOTE) != HAL_OK)
    Error_Handler();
  /* Tx delay compensation (required for FD + BRS data rates >= 8 Mbps).
     TdcOffset = DataTimeSeg1 = 7 (SSP position in data phase), TdcFilter = 0 */
  if (HAL_FDCAN_ConfigTxDelayCompensation(&hfdcan1, 7, 0) != HAL_OK)
    Error_Handler();
  if (HAL_FDCAN_EnableTxDelayCompensation(&hfdcan1) != HAL_OK)
    Error_Handler();
  /* Start FDCAN module */
  if (HAL_FDCAN_Start(&hfdcan1) != HAL_OK)
    Error_Handler();
以上为FDCAN初始化部分 为了测试最大总线负载,我们发送字节填充为64字节
  TxHeader.Identifier          = 0x123;
  TxHeader.IdType              = FDCAN_STANDARD_ID;
  TxHeader.TxFrameType         = FDCAN_DATA_FRAME;
  TxHeader.DataLength          = FDCAN_DLC_BYTES_64;
  TxHeader.ErrorStateIndicator = FDCAN_ESI_ACTIVE;
  TxHeader.BitRateSwitch       = FDCAN_BRS_ON;
  TxHeader.FDFormat            = FDCAN_FD_CAN;
  TxHeader.TxEventFifoControl  = FDCAN_NO_TX_EVENTS;
  TxHeader.MessageMarker       = 0;
  for (uint8_t i = 0; i < 64; i++) {
    TxData[i] = i;
在main主循环中暴力发送
   if (HAL_FDCAN_GetTxFifoFreeLevel(&hfdcan1) > 0) {
      if (HAL_FDCAN_AddMessageToTxFifoQ(&hfdcan1, &TxHeader, TxData) != HAL_OK) {
        BSP_LED_Toggle(LED_RED);
      } else {
        BSP_LED_Toggle(LED_GREEN);
FDCAN盒为busmaster X2 最大支持12Mbps
实测性能如下 数据段为64字节 峰值发送10K帧/S
理论上限计算
64 字节 FD 帧 + BRS 模式下,一帧的总线上时间消耗:
阶段 内容 比特数 速率 时间
仲裁段 SOF + ID(11) + RRS + IDE + FDF + BRS + ESI + DLC(4) + 填充 ~26 bits 1 Mbps ~26 µs
数据段 64×8=512 位数据 + 21 位 CRC + 填充 ~600 bits 8 Mbps ~75 µs
帧尾 ACK + DELIM + EOF(7) + IFS(3) + 填充 ~14 bits 1 Mbps ~14 µs
单帧总计 ≈ 115 µs(典型),理论最优 ≈ 100 µs(零填充)
  • 100 µs/帧 →10,000 fps (理论极限)
  • 115 µs/帧 →~8,700 fps (典型实际)
总体性能已经十分接近理论极限
如果使用FDCAN来进行IAP升级
假设固件大小为128KB
总线仅需要传输2048帧,消耗时间约为0.21S 则剩下瓶颈全在flash擦写上,性能十分可观。
测试源码见链接
https://1811627153.share.123pan.cn/123pan/ZVgRVv-vSgt3?pwd=LZzc#
赞 收藏 评论0 发布时间:2026-7-5 23:49
