接着上篇,详细情况可以查看usb_core(.c/.h),STM32 USB中断事件为以下几种: - z- a4 b8 f& o void ISTR_CTR(void); void ISTR_SOF(void); void ISTR_ESOF(void); void ISTR_DOVR(void); void ISTR_ERROR(void); void ISTR_RESET(void); + o! C3 d0 G5 c* L7 t void ISTR_WAKEUP(void); void ISTR_SUSPEND(void); 9 L" X8 p4 g4 E9 m 这些处理函数使能由定义CNTR_MASK决定: // CNTR mask control + C: @+ z a% j #define CNTR_MASK CNTR_CTRM | CNTR_WKUPM | CNTR_SUSPM | CNTR_ERRM | \ CNTR_SOFM | CNTR_ESOFM | CNTR_RESETM | CNTR_DOVRM \ 其中着重说明的是ISTR_RESET()和ISTR_CTR()函数,ISTR_RESET()主要处理USB复位后进行一些初始化任务,ISTR_CTR()则是处理数据正确传输后控制,比如说响应主机。 2 k9 x/ Z5 A. Q. }8 D4 x & S; j0 ]' X$ M4 r7 p' f. d# ]- q // ***************************************************************************** // Function Name : INT_ISTR_RESET % F% v0 }; K4 h/ F1 J // Description : ISTR Reset Interrupt service routines. 9 D) y8 B' ]7 f8 A n! ~; q // Input : U: o- h4 g2 G6 w* T: b // Output : # r3 K% ^4 q% v% Y // Return : // ***************************************************************************** void INT_ISTR_RESET(void) { // Set the buffer table address SetBTABLE(BASEADDR_BTABLE); ) v5 U+ ]/ f. d // Set the endpoint type: ENDP0 9 P1 O9 _0 A% | SetEPR_Type(ENDP0, EP_CONTROL); * B& G7 H' ]) u1 F( N Clr_StateOut(ENDP0); * m0 [0 G5 L' t/ [ Z // Set the endpoint data buffer address: ENDP0 RX ; K/ g' I: U3 Z* s# ^ SetBuffDescTable_RXCount(ENDP0, ENDP0_PACKETSIZE); 2 ~' T$ j0 f4 B1 i5 W SetBuffDescTable_RXAddr(ENDP0, ENDP0_RXADDR); // Set the endpoint data buffer address: ENDP0 TX SetBuffDescTable_TXCount(ENDP0, 0); SetBuffDescTable_TXAddr(ENDP0, ENDP0_TXADDR); // Initialize the RX/TX status: ENDP0 SetEPR_RXStatus(ENDP0, EP_RX_VALID); SetEPR_TXStatus(ENDP0, EP_TX_NAK); 5 C) L. ~, n5 r4 K0 V' D 1 o/ p# [8 Q: Z) N/ a // Set the endpoint address: ENDP0 . h, |- V0 s I( U SetEPR_Address(ENDP0, ENDP0); // --------------------------------------------------------------------- // TODO: Add you code here % f- x. }5 y9 g2 ?- ^( z) k: s // --------------------------------------------------------------------- // Set the endpoint type: ENDP1 " @: N. e, K( n: {+ H' x SetEPR_Type(ENDP1, EP_INTERRUPT); ; f' a3 ~& E% ~8 r& @: { Clr_StateOut(ENDP1); 6 V/ V. k2 K- q+ A+ A / S x! W: ]' z7 C // Set the endpoint data buffer address: ENDP1 RX SetBuffDescTable_RXCount(ENDP1, ENDP1_PACKETSIZE); + {6 i2 O+ X( I8 [4 y! |" p5 t: e SetBuffDescTable_RXAddr(ENDP1, ENDP1_RXADDR); & T% g+ {3 G- H7 l7 \& U* `% W / s5 O4 v8 {3 k1 e) _' E // Set the endpoint data buffer address: ENDP1 TX SetBuffDescTable_TXCount(ENDP1, 0); SetBuffDescTable_TXAddr(ENDP1, ENDP1_TXADDR); // Initialize the RX/TX status: ENDP1 8 g/ l/ {) n0 o( w2 _ SetEPR_RXStatus(ENDP1, EP_RX_VALID); SetEPR_TXStatus(ENDP1, EP_TX_DIS); , K8 V; Y+ [, e4 f% q: W8 D1 b$ N // Set the endpoint address: ENDP1 SetEPR_Address(ENDP1, ENDP1); ( }* X% e5 S( B5 U5 w SetEPR_Type(ENDP2, EP_INTERRUPT); Clr_StateOut(ENDP2); u% U& |7 {" a4 q( }9 J9 p 7 c* a7 i# H3 E/ b" \% [* w // Set the endpoint data buffer address: ENDP2 RX SetBuffDescTable_RXCount(ENDP2, ENDP2_PACKETSIZE); SetBuffDescTable_RXAddr(ENDP2, ENDP2_RXADDR); // Set the endpoint data buffer address: ENDP2 TX 6 ]' I: O2 l/ G# @ SetBuffDescTable_TXCount(ENDP2, 0); ' e- l" I p& P0 D SetBuffDescTable_TXAddr(ENDP2, ENDP2_TXADDR); ; k0 d) j+ \3 e4 C/ V0 j // Initialize the RX/TX status: ENDP2 SetEPR_RXStatus(ENDP2, EP_RX_DIS); SetEPR_TXStatus(ENDP2, EP_TX_VALID); / T9 [& S& t! R: J6 L1 U/ Q8 C # f% `9 V. C" C4 Y // Set the endpoint address: ENDP2 ' z" I$ o' @& B2 P9 }0 Y SetEPR_Address(ENDP2, ENDP2); : F* i- ?: q3 d. q" r ! V( w9 Q0 A9 f( J // --------------------------------------------------------------------- 3 X0 W! G3 g0 N6 u8 I& E# j // End of you code ( l% Q* w3 M. p8 A% Y4 o7 X# H* g // --------------------------------------------------------------------- 7 X, `6 a+ H6 x% g2 Q( @% Z SetDADDR(0x0080 | vsDeviceInfo.bDeviceAddress); vsDeviceInfo.eDeviceState = DS_DEFAULT; 3 n+ o/ ?8 o N4 M8 {" @ vsDeviceInfo.bCurrentFeature = 0x00; vsDeviceInfo.bCurrentConfiguration = 0x00; " L0 q; g4 \4 E5 G- ?1 u vsDeviceInfo.bCurrentInterface = 0x00; + e7 G& k! G$ x% w. {1 e: y# k vsDeviceInfo.bCurrentAlternateSetting = 0x00; 5 H: E8 Y6 Z2 F/ \5 i vsDeviceInfo.uStatusInfo.w = 0x0000; * E$ Q6 n* W+ w- Y' x } 在这个ISTR_CTR()函数中,定义了EP0、1、2的传输方式以及各自的缓冲描述符,其中EP0是默认端口,负责完成USB设备的枚举,一般情况是不需要更改的。其他端点配置则需根据实际应用而决定,如何设置请仔细理解STM32的参考手册。 1 X4 i8 F$ h& D$ u 值得说明的是STM32的端点RX/TX缓冲描述表是定义在PMA中的,他是基于分组缓冲区描述报表寄存器(BTABLE)而定位的,各端点RX/TX缓冲描述表说明是数据存储地址以及大小,这个概念需要了解,ST提供的固件很含糊,为此,我在usb_regs.h文件中进行了重新定义,如下: 6 L3 m) e) H1 h8 J7 }6 v$ k // USB_IP Packet Memory Area base address #define PMAAddr (0x40006000L) ! o# k, Q# j% Z2 O6 P! B9 p R // Buffer Table address register #define BTABLE ((volatile unsigned *)(RegBase + 0x50)) 6 H4 t! Y. m6 s O6 f9 B // ***************************************************************************** ' _% j. p5 _- d // Packet memory area: Total 512Bytes // ***************************************************************************** / O& u) ?: W) t5 B; F, u; [3 | #define BASEADDR_BTABLE 0x0000 // ***************************************************************************** * j9 G- F, H+ k# O) {6 f# O // PMAAddr + BASEADDR_BTABLE + 0x00000000 : EP0_TX_ADDR 6 F$ U ?3 B6 l$ l F- _# P! G8 f# h // PMAAddr + BASEADDR_BTABLE + 0x00000002 : EP0_TX_COUNT // PMAAddr + BASEADDR_BTABLE + 0x00000004 : EP0_RX_ADDR // PMAAddr + BASEADDR_BTABLE + 0x00000006 : EP0_RX_COUNT 2 M. J8 \# s! c6 x7 _ // 2 F' ?8 f( b4 G // PMAAddr + BASEADDR_BTABLE + 0x00000008 : EP1_TX_ADDR ( Q' Y) q2 ]2 p( o% K, S // PMAAddr + BASEADDR_BTABLE + 0x0000000A : EP1_TX_COUNT 0 ^$ g3 V; i6 k1 p; H // PMAAddr + BASEADDR_BTABLE + 0x0000000C : EP1_RX_ADDR 8 ~4 E5 L5 L( |: l" I/ ]) O# d4 m // PMAAddr + BASEADDR_BTABLE + 0x0000000E : EP1_RX_COUNT 9 E: Q* m7 i, A0 z! }- A // // PMAAddr + BASEADDR_BTABLE + 0x00000010 : EP2_TX_ADDR // PMAAddr + BASEADDR_BTABLE + 0x00000012 : EP2_TX_COUNT 5 J3 X9 I( D9 t4 C. x // PMAAddr + BASEADDR_BTABLE + 0x00000014 : EP2_RX_ADDR // PMAAddr + BASEADDR_BTABLE + 0x00000016 : EP2_RX_COUNT // // PMAAddr + BASEADDR_BTABLE + 0x00000018 : EP3_TX_ADDR // PMAAddr + BASEADDR_BTABLE + 0x0000001A : EP3_TX_COUNT % l& G- ]& J$ p0 V; G // PMAAddr + BASEADDR_BTABLE + 0x0000001C : EP3_RX_ADDR . a; `9 k4 N+ T* ?. | // PMAAddr + BASEADDR_BTABLE + 0x0000001E : EP3_RX_COUNT // 2 |- L/ D. z+ K8 o // PMAAddr + BASEADDR_BTABLE + 0x00000020 : EP4_TX_ADDR 9 @8 {5 Y3 c: K8 N7 p0 [$ Z // PMAAddr + BASEADDR_BTABLE + 0x00000022 : EP4_TX_COUNT # D5 J( F1 y$ ?3 W. _ h4 Z // PMAAddr + BASEADDR_BTABLE + 0x00000024 : EP4_RX_ADDR // PMAAddr + BASEADDR_BTABLE + 0x00000026 : EP4_RX_COUNT 5 U$ g N! i: j4 G5 ]( r' s // % W! l' j' k* g0 y8 t) A1 S2 Z // PMAAddr + BASEADDR_BTABLE + 0x00000028 : EP5_TX_ADDR . P7 }, t, \$ K1 h/ ?% T // PMAAddr + BASEADDR_BTABLE + 0x0000002A : EP5_TX_COUNT // PMAAddr + BASEADDR_BTABLE + 0x0000002C : EP5_RX_ADDR // PMAAddr + BASEADDR_BTABLE + 0x0000002E : EP5_RX_COUNT // : `$ V) R5 Y6 k0 I- d0 l // PMAAddr + BASEADDR_BTABLE + 0x00000030 : EP6_TX_ADDR 6 O" @3 K3 C: @/ o // PMAAddr + BASEADDR_BTABLE + 0x00000032 : EP6_TX_COUNT // PMAAddr + BASEADDR_BTABLE + 0x00000034 : EP6_RX_ADDR + v3 [& T( ]: L- \, |( R // PMAAddr + BASEADDR_BTABLE + 0x00000036 : EP6_RX_COUNT // * P$ {- y4 E# |2 k4 j8 d // PMAAddr + BASEADDR_BTABLE + 0x00000038 : EP7_TX_ADDR // PMAAddr + BASEADDR_BTABLE + 0x0000003A : EP7_TX_COUNT , H) k/ e: j$ i7 b0 q // PMAAddr + BASEADDR_BTABLE + 0x0000003C : EP7_RX_ADDR // PMAAddr + BASEADDR_BTABLE + 0x0000003E : EP7_RX_COUNT / g7 ^' k5 o# @7 z2 s // ***************************************************************************** d+ |% l2 m# m# q+ w0 G" X // // PMAAddr + BASEADDR_BTABLE + (0x00000040 - 0x000001FF) : assigned to data buffer // 9 s1 n6 `/ a# [0 T1 l // ***************************************************************************** #define BASEADDR_DATA (BASEADDR_BTABLE + 0x00000040) // ENP0 #define ENDP0_PACKETSIZE 0x40 #define ENDP0_RXADDR BASEADDR_DATA 8 h! X5 e" x2 ~& g0 z #define ENDP0_TXADDR (ENDP0_RXADDR + ENDP0_PACKETSIZE) // ENP1 ! R1 m- z8 W0 s" ?7 a/ ~& C #define ENDP1_PACKETSIZE 0x40 #define ENDP1_RXADDR (ENDP0_TXADDR + ENDP0_PACKETSIZE) 3 X0 j9 }6 Q9 G( w5 ^, K+ W& ~ #define ENDP1_TXADDR (ENDP1_RXADDR + ENDP1_PACKETSIZE) & i+ f3 Z+ d. z0 q$ s , Y. v% c- _ P2 D4 {% X; V# u // ENP2 #define ENDP2_PACKETSIZE 0x40 #define ENDP2_RXADDR (ENDP1_TXADDR + ENDP1_PACKETSIZE) 8 @. w/ B0 x; H. I' I* ^+ ~ #define ENDP2_TXADDR (ENDP2_RXADDR + ENDP2_PACKETSIZE) 1 {' d) `3 N4 S. a3 B: x% G // ENP3 #define ENDP3_PACKETSIZE 0x40 ! V& ~- `* H( s #define ENDP3_RXADDR (ENDP2_TXADDR + ENDP2_PACKETSIZE) #define ENDP3_TXADDR (ENDP3_RXADDR + ENDP3_PACKETSIZE) // ENP4 7 L+ w( C! _" _3 j( B #define ENDP4_PACKETSIZE 0x40 #define ENDP4_RXADDR (ENDP3_TXADDR + ENDP3_PACKETSIZE) #define ENDP4_TXADDR (ENDP4_RXADDR + ENDP4_PACKETSIZE) // ENP5 9 \( u' _. |: G; u. [9 u% q( j! k- S #define ENDP5_PACKETSIZE 0x40 #define ENDP5_RXADDR (ENDP4_TXADDR + ENDP4_PACKETSIZE) ) s& U1 b2 ~0 t! L #define ENDP5_TXADDR (ENDP5_RXADDR + ENDP5_PACKETSIZE) % \1 H7 Z1 B) B: [% L! g3 \1 D9 Q& y 8 y. x# L' l: I // ENP6 u6 v& A4 U: [" O0 z/ F. B #define ENDP6_PACKETSIZE 0x40 #define ENDP6_RXADDR (ENDP5_TXADDR + ENDP5_PACKETSIZE) #define ENDP6_TXADDR (ENDP6_RXADDR + ENDP6_PACKETSIZE) + p* `' {" a" z. g4 [5 m7 ` // ENP7 #define ENDP7_PACKETSIZE 0x40 #define ENDP7_RXADDR (ENDP6_TXADDR + ENDP6_PACKETSIZE) - V8 o: k- L% n* P/ p& h. N #define ENDP7_TXADDR (ENDP7_RXADDR + ENDP7_PACKETSIZE) 7 Q& j' A" u7 f 这样,一般只要在PMA的大小区域内(512Bytes),修改端点EPnR的数据包大小就可以了,当然,实际情况可以根据需要进行更改。 4 e. z: n1 E: f. E3 F3 { // ***************************************************************************** // Function Name : INT_ISTR_CTR 5 K( y' Q1 n5 K // Description : ISTR Correct Transfer Interrupt service routine. // Input : // Output : // Return : // ***************************************************************************** % X5 X) P9 b/ Z8 A8 C( h void INT_ISTR_CTR(void) . Q, ]/ ]+ l' V. o8 y { + X- w2 M) { _$ c T; \. Y unsigned short wEPIndex; unsigned short wValISTR; * r2 C" J, f$ ?0 q" g unsigned short wValENDP; # S+ f1 X0 r# R7 @. c' f# P Y8 `6 u# {: r8 h5 s4 e4 W while( ((wValISTR=GetISTR()) & ISTR_CTR) != 0 ) . Y* _& g, }* @9 r5 I {$ u { // Get the index number of the endpoints 5 h: p% y* h9 q! E; f+ C% W! o' E wEPIndex = wValISTR & ISTR_EP_ID; 0 @/ q1 t8 R4 s if(wEPIndex == 0) ( k2 m$ O; K2 P { // Set endpoint0 RX/TX status: NAK (Negative-Acknowlegment) SetEPR_RXStatus(ENDP0, EP_RX_NAK); 0 r9 M' a$ T' x# Z SetEPR_TXStatus(ENDP0, EP_TX_NAK); ! I" x! O! s! `; k // Transfer direction / Q, ^; O+ t- n, ?- |' k if((wValISTR & ISTR_DIR) == 0) { & c- a. W$ V; d* x: j# R9 Z // DIR=0: IN // DIR=0 implies that EP_CTR_TX always 1 * x5 b( x7 y- c, y ClrEPR_CTR_TX(ENDP0); CTR_IN0(); $ W6 b5 @& [: {$ N return; & |- c1 N" G# f. T } 8 C# I, V) }0 X8 M% w2 U. E else { ) ^0 d7 i8 ^( a4 C4 { // DIR=1: SETUP or OUT " g, l f, M' s // DIR=1 implies that CTR_TX or CTR_RX always 1 0 A" P7 s+ R8 b' e3 s) r7 }# S wValENDP = GetEPR(ENDP0); 9 n+ k) L! g- F; F$ o if((wValENDP & EP_CTR_TX) != 0) { ClrEPR_CTR_TX(ENDP0); CTR_IN0(); return; ' J/ c m4 J& K7 G/ S) e% `. p } - C P: p2 O/ l2 c | else if((wValENDP & EP_SETUP) != 0) " r& I/ U5 j0 ~( R: q/ K! Q1 [ { ) K- I0 P: x- s3 o- H ClrEPR_CTR_RX(ENDP0); 3 l, F. ^- O- O8 y, [9 a9 G( E CTR_SETUP0(); 7 M' K+ O8 i3 t return; } else if((wValENDP & EP_CTR_RX) != 0) 2 r6 n4 b8 {9 d- F% S { ClrEPR_CTR_RX(ENDP0); CTR_OUT0(); return; } } 0 X- h; G+ f5 g4 X% B4 w } // Other endpoints " V( W( B4 f: Z. @. K4 Z7 { else 5 [8 J5 _7 \: }$ [ { wValENDP = GetEPR(wEPIndex); * Z6 t. g' @- z 6 W7 W: ~* r% ]5 R4 ^ SetEPR_RXStatus(wEPIndex, EP_RX_NAK); SetEPR_TXStatus(wEPIndex, EP_TX_NAK); 5 Y) d" L; |) V- Q3 o if((wValENDP & EP_CTR_TX) != 0) 1 P; i/ i) q# } j7 @) q2 g { ClrEPR_CTR_TX(wEPIndex); switch(wEPIndex) 6 I" e4 C" D6 ?( o# ^* ] { case ENDP1: CTR_IN1(); break; case ENDP2: CTR_IN2(); break; / q. }. _) k6 ]1 g6 g1 P case ENDP3: CTR_IN3(); break; case ENDP4: CTR_IN4(); break; case ENDP5: CTR_IN5(); break; 4 B' b: ]) X6 z/ b case ENDP6: CTR_IN6(); break; case ENDP7: CTR_IN7(); break; ( w& p) Q4 S+ W9 F2 J% [ default: break; } 1 ] v a+ L5 z2 q } 3 s6 J( a# ^4 X; O if((wValENDP & EP_CTR_RX) != 0) { . F# t) c2 ?% p: X0 P% Z ClrEPR_CTR_RX(wEPIndex); - J* g6 ? R" N# s$ U+ } switch(wEPIndex) { case ENDP1: CTR_OUT1(); break; ) T; l9 j: q% n; t% Z case ENDP2: CTR_OUT2(); break; case ENDP3: CTR_OUT3(); break; ; B3 T w/ l8 Y case ENDP4: CTR_OUT4(); break; case ENDP5: CTR_OUT5(); break; case ENDP6: CTR_OUT6(); break; case ENDP7: CTR_OUT7(); break; default: break; ; {: x& e0 t* j8 h& q0 Y } } } & _. z5 L; {" o( R. E! i } } + H! p" ]% M% }/ K% P, |" R5 g 2 G# c3 a3 ^' n$ V$ }0 g INT_ISTR_CTR()函数将各自响应事件提取出来,默认端点EP0也是最为复杂的,这个需要查看STM32的参考手册以及USB协议才能更好了解为何如此。到这里STM32 USB里数据传输事件就指向了各个对应的端点。下篇着重说明USB设备的枚举。 |
最全USB HID开发资料,悉心整理一个月,亲自测试
【源码】STLINK-V3MINI 高速USB仿真器,成功改刷【高速CMSIS-DAP】
STM32 USB CDC 虚拟多串口
实战经验 | 选择USBX模块生成USB CDC ACM无PD的项目
STM32 USB HID键盘例程
刘氓兔的杂谈【001】-片上USB 高速PHY
【经验分享】在进行 USB CDC 类开发时,无法发送 64整数倍的数据
在线直播|无需编写任何代码即可在STM32上实现USB-C Power Delivery
圈圈发布USB图书第二版有感,以及分享一些我学习USB过程...
USB Audio设计与实现
回复:基于STM32的USB程序开发笔记(三) ——STM32 USB固件函数的一些介绍
