我配置的时钟文件如下,外部晶振是8M void RCC_Configuration(void) { ErrorStatus HSEStartUpStatus; RCC_ClocksTypeDef RCC_ClocksStatus; /* RCC system reset(for debug purpose) */ RCC_DeInit(); /* Enable HSE */ RCC_HSEConfig(RCC_HSE_ON); /* Wait till HSE is ready */ HSEStartUpStatus = RCC_WaitForHSEStartUp(); if(HSEStartUpStatus == SUCCESS) { /* Enable Prefetch Buffer */ FLASH_PrefetchBufferCmd(ENABLE); /*000b Zero wait state, if 0 < SYSCLK≤ 24 MHz 001b One wait state, if 24 MHz < SYSCLK ≤ 48 MHz 010b Two wait states, if 48 MHz < SYSCLK ≤ 72 MHz*/ /* Flash 1 wait state */ FLASH_SetLatency(FLASH_Latency_1); /* DISABLE PLL */ RCC_PLLCmd(DISABLE); /* Select PLL as system clock source */ RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); /* HCLK = SYSCLK */ RCC_HCLKConfig(RCC_SYSCLK_Div1); /* PCLK1 = HCLK / 4 */ RCC_PCLK1Config(RCC_HCLK_Div4); /* PCLK2 = HCLK / 2 */ RCC_PCLK2Config(RCC_HCLK_Div2); // /* ADCCLK = PCLK2 / 4 */ // RCC_ADCCLKConfig(RCC_PCLK2_Div4); /*这里是我下载了官方F2系列 时钟配置文件 ,参考此文件做的 RCC_PLLSource_HSE = 8M*/ /* PLLCLK = (RCC_PLLSource_HSE/8) * 192/2 = 96 MHz */ RCC_PLLConfig(RCC_PLLSource_HSE,8,192,2,8); /* Enable PLL */ RCC_PLLCmd(ENABLE); /* Wait till PLL is ready */ while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) { } /* Wait till PLL is used as system clock source */ while(RCC_GetSYSCLKSource() != 0x08) { } /* Get Clock */ RCC_GetClocksFreq(&RCC_ClocksStatus); // /* unused GPIO pins set to analog-input mode to improve EMC */ // GPIO_AIM_Init(1); } // SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK);//使用与系统同样的 // SysTick_SetReload(0xffffff); //以最大开始重新装载 } 而我实际得到的是300M,附件里面有我读到的时钟值 不知道是哪里出错,望指点一二!!! |
STM32F207+LWIP的网络丢包问题! 【悬赏问答】
STM32F207+DP83848+RTL8019可不可以实现双网口设计
深圳市旺宝电子STM32F207开发板例程集
STM32F2 器件 -25° 上电正常 复位就挂了
STM32F229 TIMER CNT问题
哪位工程师有STM32F2xx的寄存器手册?
STM32F2xx RTC启动不了,求助!!!!
STM32F2外部按键触发中断问题
STM32F205 低功耗模式有BUG?
STM32F207 两个ADC同时采样问题
