[url=mk MSITStore:E:\盖特信息\煤矿\水文分站\软件\stsw-stm32077\STM32L1xx_StdPeriph_Lib_V1.2.0\stm32l1xx_stdperiph_lib_um.chm::/group__ADC1__AnalogWatchdog.html#ga840291bc02cba5474a4cb46a9b9566fe]00061[/url] int [url=mk MSITStore:E:\盖特信息\煤矿\水文分站\软件\stsw-stm32077\STM32L1xx_StdPeriph_Lib_V1.2.0\stm32l1xx_stdperiph_lib_um.chm::/group__ADC1__AnalogWatchdog.html#ga840291bc02cba5474a4cb46a9b9566fe]main[/url](void)00062 { 00063 /*!< At this stage the microcontroller clock setting is already configured, 00064 this is done through SystemInit() function which is called from startup 00065 file (startup_stm32l1xx_xx.s) before to branch to application main. 00066 To reconfigure the default setting of SystemInit() function, refer to 00067 system_stm32l1xx.c file 00068 */ 00069 00070 /* Configure LED1 available on STM32L152X-EVAL board ---------------------- */ 00071 [url=mk MSITStore:E:\盖特信息\煤矿\水文分站\软件\stsw-stm32077\STM32L1xx_StdPeriph_Lib_V1.2.0\stm32l1xx_stdperiph_lib_um.chm::/group__STM32L152__EVAL__LOW__LEVEL__Private__Functions.html#ga01e1a245e786705357f741c8d42cbd3a]STM_EVAL_LEDInit[/url]([url=mk MSITStore:E:\盖特信息\煤矿\水文分站\软件\stsw-stm32077\STM32L1xx_StdPeriph_Lib_V1.2.0\stm32l1xx_stdperiph_lib_um.chm::/group__STM32L152D__EVAL__LOW__LEVEL__Exported__Types.html#ggaa059704b7ca945eb9c1e7f2c3d03fecdadac6477842247cab1a8c02c65f431b44]LED1[/url]);00072 00073 /* Configure PB.12 (ADC1 Channel18) or PF.10 (ADC1 Channel31) in analog mode -*/ 00074 GPIO_InitStructure.[url=mk MSITStore:E:\盖特信息\煤矿\水文分站\软件\stsw-stm32077\STM32L1xx_StdPeriph_Lib_V1.2.0\stm32l1xx_stdperiph_lib_um.chm::/structGPIO__InitTypeDef.html#a55bd77e335c2bfeec9caa5dc922b791b]GPIO_Mode[/url] = [url=mk MSITStore:E:\盖特信息\煤矿\水文分站\软件\stsw-stm32077\STM32L1xx_StdPeriph_Lib_V1.2.0\stm32l1xx_stdperiph_lib_um.chm::/group__Configuration__Mode__enumeration.html#gga1347339e1c84a196fabbb31205eec5d4a6e5c0d7e6d2e22b834b24e1ca1d6d0db]GPIO_Mode_AN[/url];00075 GPIO_InitStructure.[url=mk MSITStore:E:\盖特信息\煤矿\水文分站\软件\stsw-stm32077\STM32L1xx_StdPeriph_Lib_V1.2.0\stm32l1xx_stdperiph_lib_um.chm::/structGPIO__InitTypeDef.html#aad62942c003bc2083d37f10f6f39bd5f]GPIO_PuPd[/url] = [url=mk MSITStore:E:\盖特信息\煤矿\水文分站\软件\stsw-stm32077\STM32L1xx_StdPeriph_Lib_V1.2.0\stm32l1xx_stdperiph_lib_um.chm::/group__Configuration__Pull-Up__Pull-Down__enumeration.html#ggafb7ecd99c44b4fd702d669304a36c2c8a013a40bdeb6b3f43e02f8e4da896ba51]GPIO_PuPd_NOPULL[/url];00076 00077 #if defined USE_STM32L152D_EVAL 00078 /* Enable the GPIOF Clock */ 00079 [url=mk MSITStore:E:\盖特信息\煤矿\水文分站\软件\stsw-stm32077\STM32L1xx_StdPeriph_Lib_V1.2.0\stm32l1xx_stdperiph_lib_um.chm::/group__RCC.html#gae0b30d8598b8393bdba9c3fefba3a968]RCC_AHBPeriphClockCmd[/url]([url=mk MSITStore:E:\盖特信息\煤矿\水文分站\软件\stsw-stm32077\STM32L1xx_StdPeriph_Lib_V1.2.0\stm32l1xx_stdperiph_lib_um.chm::/group__RCC__AHB__Peripherals.html#ga16d4ffadf5b50e96653c8b426d20cc27]RCC_AHBPeriph_GPIOF[/url], ENABLE);00080 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; 00081 GPIO_Init(GPIOF, &GPIO_InitStructure); 00082 #elif defined USE_STM32L152_EVAL 00083 /* Enable the GPIOB Clock */ 00084 RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE); 00085 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; 00086 GPIO_Init(GPIOB, &GPIO_InitStructure); 00087 #endif 00088 00089 /* Enable the HSI */ 00090 RCC_HSICmd(ENABLE); 00091 /* Wait until HSI oscillator is ready */ 00092 while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); 00093 00094 /* Enable ADC1 clock */ 00095 RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); 00096 /* ADC1 Configuration -----------------------------------------------------*/ 00097 ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b; 00098 ADC_InitStructure.ADC_ScanConvMode = ENABLE; 00099 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; 00100 ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None; 00101 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; 00102 ADC_InitStructure.ADC_NbrOfConversion = 1; 00103 ADC_Init(ADC1, &ADC_InitStructure); 00104 00105 #if defined USE_STM32L152D_EVAL 00106 /* ADC1 regular channel31 configuration */ 00107 ADC_RegularChannelConfig(ADC1, ADC_Channel_31, 1, ADC_SampleTime_16Cycles); 00108 #elif defined USE_STM32L152_EVAL 00109 /* ADC1 regular channel18 configuration */ 00110 ADC_RegularChannelConfig(ADC1, ADC_Channel_18, 1, ADC_SampleTime_16Cycles); 00111 #endif 00112 00113 00114 /* Configure high and low analog watchdog thresholds */ 00115 ADC_AnalogWatchdogThresholdsConfig(ADC1, 0xE8B, 0x26D); 00116 00117 #if defined USE_STM32L152D_EVAL 00118 /* Configure channel31 as the single analog watchdog guarded channel */ 00119 ADC_AnalogWatchdogSingleChannelConfig(ADC1, ADC_Channel_31); 00120 /* Enable analog watchdog on one regular channel: channel31 */ 00121 ADC_AnalogWatchdogCmd(ADC1, ADC_AnalogWatchdog_SingleRegEnable); 00122 #elif defined USE_STM32L152_EVAL 00123 /* Configure channel18 as the single analog watchdog guarded channel */ 00124 ADC_AnalogWatchdogSingleChannelConfig(ADC1, ADC_Channel_18); 00125 /* Enable analog watchdog on one regular channel: channel18 */ 00126 ADC_AnalogWatchdogCmd(ADC1, ADC_AnalogWatchdog_SingleRegEnable); 00127 #endif 00128 00129 /* Configure and enable ADC1 interrupt */ 00130 NVIC_InitStructure.NVIC_IRQChannel = ADC1_IRQn; 00131 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; 00132 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; 00133 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; 00134 NVIC_Init(&NVIC_InitStructure); 00135 00136 /* Enable AWD interrupt */ 00137 ADC_ITConfig(ADC1, ADC_IT_AWD, ENABLE); 00138 00139 /* Enable ADC1 */ 00140 ADC_Cmd(ADC1, ENABLE); 00141 00142 /* Wait until the ADC1 is ready */ 00143 while(ADC_GetFlagStatus(ADC1, ADC_FLAG_ADONS) == RESET) 00144 { 00145 } 00146 00147 /* Start ADC1 Software Conversion */ 00148 ADC_SoftwareStartConv(ADC1); 00149 00150 while (1) 00151 { 00152 } 00153 } 在这个文档中,为何必须使用内部时钟,AD才能运行,如果我使用外部时钟,程序一直运行在while(ADC_GetFlagStatus(ADC1, ADC_FLAG_ADONS) == RESET)处, 请指教 |
STM32L151 stop模式 rtc 闹钟唤醒不稳定
STM32L151RDT6 SDIO读写SD卡 FIFO下溢错误,不知是什么原因
STM32L152 RTC唤醒STOP mode问题
STM32L151为何FLASH擦除后全是是0x00?
求助!!STM32L151中的RTC唤醒(wake up)中断问题
STM32L152开发板原理图及说明文档
STM32L1系列,如何释放PA15为普通GPIO端口
STM32L151读取W25Q16的ID错误,请帮忙看看是什么原因
STM32L151 STOP模式唤醒程序跑哪儿了
请问有人可以STM32L152驱动LCD段码屏例程吗?
æ¶é
