STM32L151串口中断发送数据
labi41 提问时间:2013-8-28 22:31 /
 我在做STM32L151串口中断发送数据时,初始化程序总是有问题,请帮我看看。
void USART1_INIT(void)
  /* Enable GPIO clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE);
  /* Enable USART1 clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); //PA9-TX  PA10-RX
  USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_Parity = USART_Parity_No;
 /* Connect PXx to USARTx_Tx */
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource9,GPIO_AF_USART1);//PA9-TX
  /* Connect PXx to USARTx_Rx */
  GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_USART1);//PA10-RX
  /* Configure USART Tx as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  /* Configure USART Rx as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =GPIO_Pin_10;
  GPIO_Init(GPIOA,&GPIO_InitStructure);
  /* USART configuration */
  USART_Init(USART1,&USART_InitStructure);
  /* Enable the USART Receive interrupt */
USART_ITConfig(USART1, USART_IT_TXE, ENABLE);        //程序总是死在这里
  while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  /* Enable USART */
  USART_Cmd(USART1, ENABLE);
中断函数
void USART1_IRQHandler(void)
        if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
        if (USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
还有点不明白,这几个定义都表示什么意思?
#define USART_IT_PE                          ((uint16_t)0x0028)
#define USART_IT_TXE                         ((uint16_t)0x0727)
#define USART_IT_TC                          ((uint16_t)0x0626)
#define USART_IT_RXNE                        ((uint16_t)0x0525)//接收中断使能
#define USART_IT_IDLE                        ((uint16_t)0x0424)
#define USART_IT_LBD                         ((uint16_t)0x0846)
#define USART_IT_ORE_RX                      ((uint16_t)0x0325) /* In case interrupt is generated if the RXNEIE bit is set */
#define USART_IT_CTS                         ((uint16_t)0x096A)
#define USART_IT_ERR                         ((uint16_t)0x0060)
#define USART_IT_ORE_ER                      ((uint16_t)0x0360) /* In case interrupt is generated if the EIE bit is set */
#define USART_IT_NE                          ((uint16_t)0x0260)
#define USART_IT_FE                          ((uint16_t)0x0160)
收藏 评论2 发布时间:2013-8-28 22:31
labi41 回答时间:2013-8-28 22:36:23
回复:STM32L151串口中断发送数据
 使能发送中断是USART_IT_TXE还是USART_IT_TC?
使能接收中断有USART_IT_RXNE,为什么没有USART_IT_TXNE呢?
这个比较难理解。
fengye5340 回答时间:2013-8-29 17:38:09
RE:STM32L151串口中断发送数据
USART_Init(USART1, &USART_InitStructure);
USART_ITConfig(USART1, USART_IT_RXNE,ENABLE);            USART_Cmd(USART1, ENABLE);
只用这三句就可以使用中断了。
不要使能发送中断
下面这两句去掉:
USART_ITConfig(USART1, USART_IT_TXE, ENABLE);        //程序总是死在这里while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
意法半导体边缘AI套件
ST - 理想汽车豪华SUV案例
ST意法半导体智能家居案例
STM32 ARM Cortex 32位微控制器
