【MCU实战经验】+基于STM32F429的RS485通信参考代码例子
☆笨⊙笨☆ 发布时间:2014-4-15 13:02
在研究stm32的时候,曾经遇到过不少问题,就拿UART来说吧,遇到过RS232数据发送错误的,遇到不能接收字符串的,遇到RS485不能接收的,或只能接收一个字节的等等问题,但这些问题都 一一解决了。下面这段代码是在最新STM32F429探索板上测试通过的,费话不多说,直接上代码,采用中断接接,查询发送( L# ?5 A1 ]: _- U+ E
void Uart5_Init(void)
4 O" z" ]; \" i1 f6 {/ `+ ?* `+ a3 f{
- A6 v' S  K1 [" Y1 S# J) O9 a$ \    GPIO_InitTypeDef GPIO_InitStructure;( I+ V* s. f: o
# ?% O5 A. D- s1 G/ ]0 `    NVIC_InitTypeDef NVIC_InitStructure;
! ~. {* Y" b/ u  _7 W6 N/ h    ' i9 F) _  n* i3 y$ F* U6 _
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB|RCC_AHB1Periph_GPIOC|RCC_AHB1Periph_GPIOD,ENABLE);; S8 O$ v) o6 i! N% w
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART5,ENABLE);
+ T( D/ W; P+ s4 r
. E& R) U1 G5 C  U; w
; K. \& f7 h# z( L    GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF;. ]) ]. A2 a. V/ w3 g  p: d& c0 C
    GPIO_InitStructure.GPIO_OType=GPIO_OType_OD;
7 Q& M. o" X6 l* x& B    GPIO_InitStructure.GPIO_Speed=GPIO_Speed_100MHz;$ q6 B$ ~, c; `/ X
    GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_NOPULL;
. A3 h9 E! d! O5 P    GPIO_InitStructure.GPIO_Pin=GPIO_Pin_12;2 w% }1 m' p" t3 A
    GPIO_Init(GPIOC,&GPIO_InitStructure);4 m: I1 @" }+ X$ w5 |6 }
8 g4 C$ j! `+ l# ?
! D( B' J7 p9 H) G    GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_UP;
# c, @' a8 V- F1 R% S  b    GPIO_InitStructure.GPIO_Pin=GPIO_Pin_2;
. h& x, O1 z9 ?- S3 i    GPIO_Init(GPIOD,&GPIO_InitStructure);) X7 c  |& q3 S( d3 C3 C, R
         V8 W' ?8 {/ z, _
    GPIO_InitStructure.GPIO_Mode=GPIO_Mode_OUT;- S5 [- o) Y% W
    GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4;
" W( [2 A$ k# q: m6 `/ q3 U) q    GPIO_Init(GPIOB,&GPIO_InitStructure);
3 h" I  W5 N( m    * O8 q5 b8 J0 s& k0 E+ r' j+ l8 a/ v0 W  r
    GPIO_ResetBits(GPIOB,GPIO_Pin_4);
) r3 w8 Y% q( d; N3 c! t      O3 Q  }; d( t" H4 [1 g
    GPIO_PinAFConfig(GPIOC,GPIO_PinSource12,GPIO_AF_UART5);+ }9 H$ Q" k" g5 z1 h
    GPIO_PinAFConfig(GPIOD,GPIO_PinSource2,GPIO_AF_UART5);. N( X5 u; N' o) b) ~$ O
        ! m2 Q5 e2 X0 j1 ]! q8 Q
    USART_DeInit(UART5);. ^  T8 j7 e1 N- [, s
# B- W5 W) i$ G! X( A# R    USART_InitStructure.USART_BaudRate=4800;
* p4 W( i6 S, c( ]. @& O: c. ]    USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;" _4 S9 s# m5 D% A" p* B
    USART_InitStructure.USART_WordLength=USART_WordLength_9b;% x; n' D: P( R$ K( w; C( Y
    USART_InitStructure.USART_Parity=USART_Parity_Odd;" M2 v8 d1 n! o/ ~* Z7 T% R
    USART_InitStructure.USART_StopBits=USART_StopBits_1;
( ~1 M6 \  r3 l6 B    USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
* X1 q) g% H3 N0 c! A' w    USART_Init(UART5,&USART_InitStructure);
( _/ x/ [4 u* L$ ^0 X+ J( q
9 g3 C# c3 J8 S. h     NVIC_InitStructure.NVIC_IRQChannel=UART5_IRQn;
9 v$ U4 c) w, B- \7 E    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3;  P8 f0 c8 C; H% _& [
    NVIC_InitStructure.NVIC_IRQChannelSubPriority=2;9 D3 I) `7 p6 h9 B; F' r
    NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
& a; t& w. e$ k5 H8 p    NVIC_Init(&NVIC_InitStructure);" a  E7 J& b, ~7 r) ~0 E; H& @- X
    & U7 U) g5 w9 V
    USART_ITConfig(UART5,USART_IT_RXNE,ENABLE);0 C; D2 q( S( N) U# `0 b- G; K# z
    USART_Cmd(UART5,ENABLE);+ \+ \5 V3 j/ q% `. l1 W2 K% x
, ^3 m6 T; W- c( X
}4 u& o$ Z4 R6 e6 J1 i
5 [. r3 J* C3 |; r/ U4 ^void UART5_IRQHandler(void)
. s/ g8 c0 _6 [3 U{& t; d: b( k+ b) {9 b' w" H
: i6 Z5 F) C9 w7 }, ~& r
; v/ a+ U1 T9 Q0 m. P& L      if(USART_GetITStatus(UART5,USART_IT_RXNE)==SET)( f+ H5 |+ k* n! ^8 ]
       {; \( E  `! I2 D% z9 C
           USART_ClearITPendingBit(UART5,USART_IT_RXNE);
' m0 s; o, K. u           recdata[rec_num]=USART_ReceiveData(UART5);
0 r8 K6 {* ?% z: l+ L# Q% l           rec_num++;
* j7 ^! ]5 o& ], o       }8 O6 ~% S3 q, W$ F( r- i/ h/ M$ P
    4 j0 U6 ?3 P* f4 u8 _0 r; k
    GPIO_ToggleBits(GPIOG,GPIO_Pin_14);5 g7 |. z9 `6 w( c1 ^8 z. P9 z) g" h# J
- C- {9 h. k& R. ]' s' F, ]
}) w! y/ }, W3 ^6 x
$ M$ [* n. a1 m3 P% ^void USART_SendStr(USART_TypeDef* USARTx,uint8_t *str)
4 A0 w: d7 p: d$ A{1 b% v! p% _' e" Z
    //USART_ITConfig(UART5,USART_IT_RXNE,DISABLE);& z: V; ?( G& s1 l- z: D3 C2 c
  GPIO_SetBits(GPIOB,GPIO_Pin_4);" I7 j" M) ]2 |3 c) G5 G
    while(*str)7 P2 D* u' c* C: h# H2 F7 `* T
/ |9 V# W2 G( \0 k6 i* W8 D        while((USART_GetFlagStatus(USARTx,USART_FLAG_TXE))!=SET);
* F* ~  K: x9 G0 C. G/ U2 u        USART_SendData(USARTx,*str);
- W1 l( F! s% |7 P$ n# Z5 ^( _7 x        str++;
. {6 {8 ~7 M" W    }
. L( ~, M7 A0 |1 K; S    while((USART_GetFlagStatus(USARTx,USART_FLAG_TC))!=SET);
  C& R* J3 A# y/ g, s, U3 ^
* {* {8 ^& h  n    GPIO_ResetBits(GPIOB,GPIO_Pin_4);3 `! {# G/ S8 v5 @. p
    //USART_ITConfig(UART5,USART_IT_RXNE,ENABLE);$ P5 K6 b% Z0 ?, {* @
赞 收藏 评论5 发布时间:2014-4-15 13:02
5个回答
☆笨⊙笨☆ 回答时间:2014-4-16 08:56:47
RE:【MCU实战经验】+基于STM32F429的RS485通信参考代码例子
自己先顶一个,有问题请跟贴
沐紫 回答时间:2014-4-16 08:58:25
楼主已经拿到板子了?
☆笨⊙笨☆ 回答时间:2014-4-16 09:20:01
回复:【MCU实战经验】+基于STM32F429的RS485通信参考代码例子
回复第 3 楼 于2014-04-16 08:58:25发表:
& u; [' _% a& e  K) g0 o7 {1 {楼主已经拿到板子了?
& j0 {1 q$ Q  h" M! o
4 V/ |$ _0 k$ S+ `) o5 c一直在研究STM32,有同事在另一个论坛得到一块这样的板子,我就顺便写写代码,拿别人的板子测试了一下,感觉还不错,比STM32F103强多了,所以也想来申请一块深入研究。
沐紫 回答时间:2014-4-16 09:28:19
回复第 4 楼 于2014-04-16 09:20:01发表:
' n& l) V) E* `$ x, E- Q( P回复第 3 楼 于2014-04-16 08:58:25发表:
6 A" e' c1 H, l楼主已经拿到板子了? , m8 w- X$ p  _6 e
. F5 r) D! n" P/ z: p6 c1 U一直在研究STM32,有同事在另一个论坛得到一块这样的板子,我就顺便写写代码,拿别人的板子测试了一下,感觉还不错,比STM32F103强多了,所以也想来申请一块深入研究。# H8 K. C6 P4 M% W9 d
4 ^% T) q2 P' D) p# l, R( p  b8 e+ G" `3 I2 E2 ^+ h# g
希望你申请到!
☆笨⊙笨☆ 回答时间:2014-4-16 09:34:04
回复第 5 楼 于2014-04-16 09:28:19发表:
# W5 ]# U* ]8 q" K: O" ~+ J  P/ D% K回复第 4 楼 于2014-04-16 09:20:01发表:
. `! y7 P0 w( q3 _回复第 3 楼 于2014-04-16 08:58:25发表:
3 u0 T- R/ Z$ x楼主已经拿到板子了?
7 q" ^1 c6 h) n" K9 ?2 j2 Y( L. g: J8 g8 r& W) l/ s
2 G2 J- i9 @! m* _5 g5 I , |/ B; j$ n& b) k1 S# s
1 x2 I( ~  {5 D8 l& N2 E
希望你申请到!
/ r* n2 S: k5 w* `# d: O7 f. |
4 d( C& M% m2 Q4 F
7 G/ g1 g# F& y1 {能走走后门不?
