【STM32F429心得\疑问】+最新FreeRtos(版本8.0)上手指南 最近折腾一块stm32f107rc的板子,摸索了一下FreeRTOS 的使用 发现起步不太难有点经验和大家分享。) s4 h6 P$ U9 c. j7 ~ 1,先从官网http://www.freertos.org/下载 FreeRTOS 8.0.0 ! f/ G! T- g j8 W7 W% D, V' C 2,用标准库(STM32F10x_StdPeriph_Lib_V3.5.0)模板建工程/ D2 `, o# x3 g 3, 在工程中添加FreeRTOS 文件。tasks.c list.c queue.c heap_2.c$ `. q0 t2 l9 u& K8 [* u+ f port.c 其中port.C是cotex M3的移植文件。选择目录..\..\Source\portable\RVDS\ARM_CM3\ 下的port.c 3,修改启动代码(.s文件)如下,主要是链接FreeRTOS的三个中断函数 / K* c- h/ r, B IMPORT xPortPendSVHandler IMPORT xPortSysTickHandler IMPORT vPortSVCHandler3 ?6 y6 D0 O9 j1 g4 m8 y ....., m% V+ y: e) N4 \( t/ p DCD vPortSVCHandler ; SVCall Handler7 P' Q4 y7 b6 J; P; B DCD DebugMon_Handler ; Debug Monitor Handler5 ^: x' H3 v; R: n2 g DCD 0 ; Reserved DCD xPortPendSVHandler ; PendSV Handler9 N7 ]! {* ?" o% K! l DCD xPortSysTickHandler ; SysTick Handler - ]2 a+ f& s$ R. l) E 4.在main中建立自己任务开始 rtos /* Create one task. */. l; h+ V. p0 s4 O4 A8 T3 Y" e xTaskCreate( vTask1, /* Pointer to the function that implements the task. */ "Task 1", /* Text name for the task. This is to facilitate debugging only. */5 o# `. W) Y& R/ Q; n( o2 _5 d 200, /* Stack depth in words. */9 U; Q& f! C4 l, ]0 ` NULL, /* We are not using the task parameter. */ 1, /* This task will run at priority 1. */% n; Y- l1 o i! `! F! Q2 _ NULL ); /* We are not using the task handle. */- r6 W, n7 D' z H6 B; y. J: [* ~& a* P0 w+ f /* Create one task. */" B7 y* P+ Q' b8 r xTaskCreate( vTask2, /* Pointer to the function that implements the task. */ "Task 2", /* Text name for the task. This is to facilitate debugging only. */ 200, /* Stack depth in words. */ NULL, /* We are not using the task parameter. */ 2, /* This task will run at priority 1. */ NULL ); /* We are not using the task handle. */ /* Start the scheduler so our tasks start executing. */ vTaskStartScheduler(); .............. ..............- {) Z/ G0 f0 w7 d2 R1 I 8 b6 O$ p+ G# g# [7 Q% g2 ? void vTask1( void *pvParameters ) {- p5 z* f) }. j' F0 n+ h# m /* As per most tasks, this task is implemented in an infinite loop. */6 U8 o! A$ d; n, b while(1)2 j) g/ C1 x; G4 l. n* h' A { LED_Toggle(0); LED_Toggle(2); vTaskDelay(800);. y. c: \! O* i& X" e8 G$ ? }- ?4 Z% g3 |. \( w( t% p } void vTask2( void *pvParameters )2 T o4 |! O) K. E& L# j- |. [3 H {4 ~6 L- C! \% U7 _9 q /* As per most tasks, this task is implemented in an infinite loop. */; t# R& r$ }1 f0 S8 V* y while(1) { LED_Toggle(1); LED_Toggle(3);/ a! Z/ Y9 u6 ?2 m- J Z vTaskDelay(1600); }" M1 h% q Y$ L& ~9 L0 c } |
【福利三:雨露均沾·逢7狂欢】之四:用一个定时器同步另外两个定时器输出PWM
【逢7发帖赢大礼】STM32开发之WIFI实时时钟
【逢7发帖赢大礼】STM32开发之指纹识别!
【逢7发帖赢大礼】STM32开发之环境空气质量监测
【逢7发帖赢大礼】STM32开发之人体实时运动信息监测!
【逢7发帖赢大礼】全网最简单的Arduino_STM32开发环境搭建教程!
STM32F4中文用户手册
STM32F400、STM32F402 Cortex-M4超值单片机
