《STM32+WIFI+Linux+安卓智能控制开发板应用手册》PDF
微云电子 发布时间:2014-9-11 11:13
赞 收藏 6 评论1079 发布时间:2014-9-11 11:13
1079个回答
yyyl0 回答时间:2014-11-30 23:17:42
亲们。群号码多少。。。加我企鹅; T% m  |$ u8 t' `; Z
641377684
+ v* u& }7 F1 s$ ]* u8 B. V" y2 f3 o或者邮件641377684@qq.com
lovemingtian 回答时间:2014-12-1 08:21:27
void LED_Init(void)
! n' v7 v5 |6 l8 G5 |2 w3 q{, C6 Y9 I/ ]( O; l1 B
( ]. g  Z; o# `! t: e
3 ]" c# x/ Z' ^5 t1 v5 ^  a" N4 p4 s2 s9 S. }8 `" Y
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOD, ENABLE); //使能PA,PD端口时钟4 Y, y' O7 Y3 U- B- O. z4 Y
% ^4 \& o, l8 ~GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //LED0-->PA.8 端口配置, ?- g% g3 V; Q$ p
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
& x3 m3 x* n# v$ X) L4 T8 mGPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz* v/ E  J! |  q9 H* p
GPIO_Init(GPIOA, &GPIO_InitStructure); //根据设定参数初始化GPIOA.8
2 [1 z0 ~# ^# ?  WGPIO_SetBits(GPIOA,GPIO_Pin_8); //PA.8 输出高$ j- g1 s' ^3 @: K; h8 W8 @2 N6 R
! }; v) N* S3 A: v- FGPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //LED1-->PD.2 端口配置, 推挽输出$ p0 Q5 b# B4 G
GPIO_Init(GPIOD, &GPIO_InitStructure); //推挽输出 ,IO口速度为50MHz
) l- e' ^. s- h) e# u1 K0 i  XGPIO_SetBits(GPIOD,GPIO_Pin_2); //PD.2 输出高
# l. k7 P! B4 F" F( k}
% B, V' v* i) u, g& j; X# V# y先看第一个程序 程序试过 没啥问题 从第一个开始看起
lovemingtian 回答时间:2014-12-1 08:21:49
void LED_Init(void); {- y1 _, p! T# n: y2 \6 [
{. U$ U. r0 }6 U% U  l. ?9 L. |
7 ?+ r- J4 N5 ]* `GPIO_InitTypeDef GPIO_InitStructure;( e: S$ n% S% K7 U
9 t3 W* l' H7 GRCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOD, ENABLE); //使能PA,PD端口时钟" a' A0 b7 t! ^( W5 Q9 y: ~  T% k
0 `1 Q/ k  X, p; C( B, NGPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //LED0-->PA.8 端口配置
+ o; U, |  |7 Z& OGPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出1 J& A2 x4 ]" f
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz6 W2 t7 v' Q2 e9 q& v
7 J, V1 y- q' i0 C8 iGPIO_SetBits(GPIOA,GPIO_Pin_8); //PA.8 输出高
5 Z/ V/ y; R7 @; r2 g3 P- ]
( p& Y5 a8 N7 G' p1 ~GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //LED1-->PD.2 端口配置, 推挽输出  _1 X) t( a6 P' w' X3 A
" N0 K3 p' z) D" i0 J2 {2 r* q- uGPIO_SetBits(GPIOD,GPIO_Pin_2); //PD.2 输出高
' a% o' F1 e& F. V3 P% z7 a, \9 d}- E; Z- J. ~8 w) g5 U9 X' \
lovemingtian 回答时间:2014-12-1 22:02:31
void LED_Init(void)
3 X$ b- J2 @: T7 v4 K2 R% k9 U{
+ w; h' p$ s+ W0 D1 @2 I2 |  |4 `0 [2 R! H6 ]
GPIO_InitTypeDef GPIO_InitStructure;3 @  A3 h: _6 Z
: C, P5 |+ f. W0 u/ k
0 h9 c3 P& Y5 k
( P$ R# k, l( Y# }- ^% y- z: z- SGPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //LED0-->PA.8 端口配置
. x+ `5 H9 h- x5 N1 vGPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出6 e- O! ~/ ?. |1 Q
4 m7 E; I! |6 t4 s1 @8 JGPIO_Init(GPIOA, &GPIO_InitStructure); //根据设定参数初始化GPIOA.89 n) r8 i, o* V# j! @
3 j  b+ k5 s; R' }1 K8 K- R( u' r. w  d; n- |% X
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //LED1-->PD.2 端口配置, 推挽输出' \7 j1 @* B/ I/ \7 M
GPIO_Init(GPIOD, &GPIO_InitStructure); //推挽输出 ,IO口速度为50MHz( B: S/ m8 x( c
GPIO_SetBits(GPIOD,GPIO_Pin_2); //PD.2 输出高) G- {3 L7 S$ ?
}3 C$ V  h+ S3 {9 |% }+ x, ^0 }- \
荣丰宇 回答时间:2014-12-1 22:10:16
必须要来看看
lovemingtian 回答时间:2014-12-3 08:47:39
void LED_Init(void)6 H3 D+ L* m* {
{% T1 G$ X! |+ `
* l1 `$ o5 h, |  b, W! U/ h: y1 SGPIO_InitTypeDef GPIO_InitStructure;1 V1 V1 f. N( Z. W# e2 w3 H: E: v
1 |" J7 Q) F% k9 @0 sRCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOD, ENABLE); //使能PA,PD端口时钟
3 Q9 n2 g# x- K9 ]% T* f
1 B! _0 i. N0 A+ ]2 xGPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //LED0-->PA.8 端口配置4 c, E* L* g* V/ n
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出  Z4 D: C2 Y8 \; B1 g: Y
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz& g+ `6 @# a; K, \6 {) `
GPIO_Init(GPIOA, &GPIO_InitStructure); //根据设定参数初始化GPIOA.86 b0 b: c  s/ Y  i! B
/ r; N% S5 y# Z5 f" y" X' P+ G$ \$ P, U) P$ i9 I
- C3 A9 P: M2 Q( TGPIO_Init(GPIOD, &GPIO_InitStructure); //推挽输出 ,IO口速度为50MHz: C9 a2 _2 q5 T
- O6 {& m1 ?5 ~1 [5 M, t' H( V}$ F: B3 i6 y: W2 \7 r0 N2 x
lovemingtian 回答时间:2014-12-3 22:21:14
之前有学过单片机,但是感觉stm32还是有点难,一点也不习惯用自带的库函数写代码,自己写又那么多寄存器搞不明白。
wwwzfgcom 回答时间:2014-12-3 23:34:29
感觉板子买亏了,就一个模块花了400多。现在还放着
lovemingtian 回答时间:2014-12-4 08:06:30
楼主,一直等你上线,你都不上线,都被管理员警告了,文档中间的几个问题帮助解答呗
lovemingtian 回答时间:2014-12-4 16:29:51
void LED_Init(void)
  ?% A4 e( d8 o; U7 Z- p$ A$ p{
( q3 D3 V- |9 @* ]) Y
: `4 t4 ]" J1 ?0 h3 [: B7 @GPIO_InitTypeDef GPIO_InitStructure;
* l4 k: o3 n# ~+ k7 w  o, E
6 J. `3 i* }4 p' R, g0 ?RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOD, ENABLE); //使能PA,PD端口时钟( u& k( `' I6 ^- o* z
% K5 U0 ~! U- H' o+ M( ~( D$ b
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //LED0-->PA.8 端口配置# K8 z7 i' Y+ U9 D4 i9 D+ I% c
3 X" n/ A, N, _( XGPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz8 F# ?. X% |( s6 J+ B
( W; W4 }6 Y! F1 P" n0 dGPIO_SetBits(GPIOA,GPIO_Pin_8); //PA.8 输出高' F7 v) ^7 h2 c2 U
% ]8 y% G, |& m. O
% s0 M! Y4 V( l: fGPIO_Init(GPIOD, &GPIO_InitStructure); //推挽输出 ,IO口速度为50MHz
6 t: g- t: i7 X( sGPIO_SetBits(GPIOD,GPIO_Pin_2); //PD.2 输出高
8 M+ R" L2 J) t+ }}
) m; J+ C, F1 u先看第一个程序 程序试过 没啥问题 从第一个开始看起
逸风散人 回答时间:2014-12-5 09:57:33
这个很好啊,我想要买来玩玩! 方便的话发到我邮箱(rlingxing@hotmail.com)可否?
lovemingtian 回答时间:2014-12-5 13:54:54
不知道大家是怎么过来了,我的三年本科电子生涯,不算磕磕绊绊,考前突击一周,就差不多。面临毕业找工作,实在找不出自己的技术经验。
lovemingtian 回答时间:2014-12-6 18:25:00
云推送和域名解析
lovemingtian 回答时间:2014-12-6 22:17:50
lovemingtian 回答时间:2014-12-7 09:00:44
装一个无线路由,能自动登陆的更好拉,不用每天开笔记本共享wifi给手机和舍友,求详细教程,包括买什么路由器,刷什么固件,怎样刷。
