STM32F107+LWIP---如何检查tcp通讯断开?并重新连接
有没有用过数字式mems麦克风的,想问下SPI通讯的问题
stm32f103 CAN通讯多帧发送问题?
STM32F107作为USB主机模拟串口通讯不成功(采用PL2303芯片)
STM32F103C8 LIN通讯例程
求助,丐版J-Link通讯不上
ethernet可以与ethercat通讯吗?
STM32F373 CAN通讯问题CAN_FLAG_LEC
请教高手看看,STM32F1的多机通讯,地址匹配唤醒问题
CAN总线:如何利用程序(STM32)判断CAN总线的波特率/通讯协议?
我是在中断的时候给AD73360发送数据的。你看我的代码。
void EXTI0_IRQHandler(void)
if(RESET != EXTI_GetFlagStatus(EXTI_Line0))
if(exti0_cnt == 0)
{SPI_SendData( 0x8000 );} //CRA,Program Mode
else if(exti0_cnt == 1)
{SPI_SendData( 0x8104 );} //CRB,Decimation Rate£¬8KHz
else if(exti0_cnt == 2)
{SPI_SendData( 0x8261 );} //CRC
else if(exti0_cnt == 3)
{SPI_SendData( 0x8388 );} //CRD,open ADC1,ADC2
else if(exti0_cnt == 4)
{SPI_SendData( 0x8408 );} //CRE,open ADC3,close ADC4
else if(exti0_cnt == 5)
{SPI_SendData( 0x8500 );} //CRF,close ADC5,ADC6
else if(exti0_cnt == 6)
{SPI_SendData( 0x8600 );} //CRG
else if(exti0_cnt == 7)
{SPI_SendData( 0x8700 );} //CRH
else if(exti0_cnt == 8)
{SPI_SendData( 0x8001 );} //CRA,Data Mode
else if(exti0_cnt == 9)
{SPI_SendData( 0x7fff);} /*¹Ø±Õ¿ØÖÆ×Ö·¢ËÍ*/
else if(exti0_cnt >= 10)
while(SPI_ReceptionFIFOStatus_Empty != SPI_GetReceptionFIFOStatus(SPI3))
ADDataBuffer[SampleNum] = SPI_I2S_ReceiveData16(SPI3); //½ÓÊÕÊý¾Ý
SampleNum++;
if(SampleNum >= 320)
SampleNum = 0;
if(exti0_cnt > 250)
exti0_cnt = 10;
exti0_cnt++;
/** SPI3 GPIO Configuration
PC10 ------> SPI3_SCK
PC11 ------> SPI3_MISO
PC12 ------> SPI3_MOSI
/*Enable or disable the AHB peripheral clock */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
/*Configure GPIO pin : PC */
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_10; //SCK
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStruct.GPIO_OType = GPIO_OType_OD;
GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOC, &GPIO_InitStruct);
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_11; //MISO
GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_12; //MOSI
/*Configure GPIO pin alternate function */
GPIO_PinAFConfig(GPIOC, GPIO_PinSource10, GPIO_AF_6);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource11, GPIO_AF_6);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource12, GPIO_AF_6);
SPI_InitTypeDef SPI3_Param;
GPIO_SetBits(AD_SE_GPIO_PORT, AD_SE_PIN); //disable AD73360.
delay_ms(50);
SPI_I2S_DeInit(SPI3);
SPI_Cmd(SPI3, DISABLE); /*½ûÄÜSPI3*/
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
SPI3_Param.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI3_Param.SPI_Mode = SPI_Mode_Slave;
SPI3_Param.SPI_DataSize = SPI_DataSize_16b;
SPI3_Param.SPI_CPOL = SPI_CPOL_Low; //CPOL = 0
SPI3_Param.SPI_CPHA = SPI_CPHA_2Edge; //CPHA = 1
SPI3_Param.SPI_NSS = SPI_NSS_Soft;
SPI3_Param.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
SPI3_Param.SPI_FirstBit = SPI_FirstBit_MSB;
SPI3_Param.SPI_CRCPolynomial = 7;
SPI_Init(SPI3,&SPI3_Param);
SPI_NSSInternalSoftwareConfig(SPI3, SPI_NSSInternalSoft_Reset);//ÉèÖÃÄÚ²¿NSSΪµÍµçƽ
SPI_Cmd(SPI3, ENABLE); /*ʹÄÜSPI3*/
从模式可以主动发送数据吧。
我目前无法与AD73360通讯。我发送的控制字,都叠加在MISO这条数据线上,示波器看到是周期性的方波。最后将AD73360切换回数据模式后,CPU接收到的数据不是我想要的,而是我最后发送的控制字0x8001。 我不知道是哪边出现问题了
16.384M,输出的时钟SCK是2.048M
我的意思是,数据发送不是应该一次性的吗,发送完了后MISO上就不应该有波形啊,怎么会出现周期性的方波呢,然后后面还跟前面的叠加起来了。由于数据的叠加,让我无法确定我发送的数据是否正确,只能通过AD73360的表现来判断。目前判断结果就是,AD73360没有被正确设置。
SPI从机是不能主动发数据的 ,因为时钟是主机提供的。而你说AD73360持续在提供时钟,这个时候你的SPI从机是可以发数据的
恩。是的。但是我发送的数据却不是一次性的那种。在我发第一个控制字时还正常,发第二个时,数据在MISO上周期性连续。第三个叠加在第二个上,依次类推。但是发送完最后一个后,MISO线上就固定为一个周期性方波了。 好奇怪啊
不可以。。。
