STM32F4Cube库调试多通道ADC+DMA问题
亦轩阁 提问时间:2015-2-5 19:38 /
我定义了个uint32_t ADC_Value_arr[4]={0,0,0,0};接收四个通道的ADC,单通道+DMA读取数据没有问题,多通道读取是只有ADC_Value_arr[0]有数据,并且数据特别大,达到8位,还不断变化,显然错了,不知道是何原因,实在发现不了错在哪里?贴上代码,希望有人能指出错误,非常感谢!!!
void HAL_ADC_MspInit(ADC_HandleTypeDef *hadc)
  GPIO_InitTypeDef          GPIO_InitStruct;
  static DMA_HandleTypeDef  hdma_adc;
/*##-1- Enable peripherals and GPIO Clocks #################################*/
  /* Enable GPIO clock */
  ADCx_CHANNEL_GPIO_CLK_ENABLE();
  /* ADC1 Periph clock enable */
  ADCx_CLK_ENABLE();
  /* Enable DMA2 clock */
  DMAx_CLK_ENABLE();
  /*##-2- Configure peripheral GPIO ##########################################*/
  /* ADC1 Channel2,3,6,7 GPIO pin configuration */
  GPIO_InitStruct.Pin = ADCx_CHANNEL_PIN2|ADCx_CHANNEL_PIN3|ADCx_CHANNEL_PIN6|ADCx_CHANNEL_PIN7;
  GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(ADCx_CHANNEL_GPIO_PORT, &GPIO_InitStruct);
  /*##-3- Configure the DMA streams ##########################################*/
  /* Set the parameters to be configured */
  hdma_adc.Instance = ADCx_DMA_STREAM; //选择stream0
  hdma_adc.Init.Channel  = ADCx_DMA_CHANNEL;//通道0
  hdma_adc.Init.Direction = DMA_PERIPH_TO_MEMORY;//ÍâÉèµÀÄÚ´æ
  hdma_adc.Init.PeriphInc = DMA_PINC_DISABLE;//ÍâÉè²»Ôö
  hdma_adc.Init.MemInc = DMA_MINC_ENABLE;//内存增
  hdma_adc.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD; //
  hdma_adc.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
  hdma_adc.Init.Mode = DMA_CIRCULAR; //循环模式
  hdma_adc.Init.Priority = DMA_PRIORITY_HIGH;
  hdma_adc.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
  hdma_adc.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_HALFFULL;
  hdma_adc.Init.MemBurst = DMA_MBURST_SINGLE;
  hdma_adc.Init.PeriphBurst = DMA_PBURST_SINGLE;
  HAL_DMA_Init(&hdma_adc);
  /* Associate the initialized DMA handle to the the ADC handle */
  __HAL_LINKDMA(hadc, DMA_Handle, hdma_adc);
  /*##-4- Configure the NVIC for DMA #########################################*/
  /* NVIC configuration for DMA transfer complete interrupt */
  HAL_NVIC_SetPriority(ADCx_DMA_IRQn, 5, 0);
  HAL_NVIC_EnableIRQ(ADCx_DMA_IRQn);
void set_ADC(void)
        ADC_ChannelConfTypeDef sConfig;
  /* Configure the ADC peripheral */
  AdcHandle.Instance = ADCx;//ADC1
  AdcHandle.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV4;//21MHZ
  AdcHandle.Init.Resolution = ADC_RESOLUTION12b; //12位
  //AdcHandle.Init.ScanConvMode = DISABLE;
AdcHandle.Init.ScanConvMode = ENABLE;//扫描模式
  AdcHandle.Init.ContinuousConvMode = ENABLE;//连续模式
  AdcHandle.Init.DiscontinuousConvMode = DISABLE;//
  AdcHandle.Init.NbrOfDiscConversion = 0;
  AdcHandle.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  AdcHandle.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T1_CC1;
  AdcHandle.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  AdcHandle.Init.NbrOfConversion = 4;
  AdcHandle.Init.DMAContinuousRequests = ENABLE;
  AdcHandle.Init.EOCSelection = DISABLE;
  HAL_ADC_Init(&AdcHandle);
  /* Configure ADC regular channel */
  sConfig.Channel = ADCx_CHANNEL2;
  sConfig.Rank = 1;
  sConfig.SamplingTime = ADC_SAMPLETIME_480CYCLES;
  sConfig.Offset = 0;
  HAL_ADC_ConfigChannel(&AdcHandle, &sConfig);
         sConfig.Channel = ADCx_CHANNEL3;
   sConfig.Rank = 2;
   sConfig.Offset = 0;
   sConfig.Channel = ADCx_CHANNEL6;
   sConfig.Rank = 3;
   sConfig.Offset = 0;
   sConfig.Channel = ADCx_CHANNEL7;
   sConfig.Rank = 4;
   sConfig.Offset = 0;
  /* Start the conversion process and enable interrupt */
//  HAL_ADC_Start_DMA(&AdcHandle, (uint32_t*)&ADCConvertedValue, 1);
        HAL_ADC_Start_DMA(&AdcHandle, ADC_Value_arr, 4);
赞 收藏 1 评论14 发布时间:2015-2-5 19:38
14个回答
左岸右岸 回答时间:2015-3-23 18:42:05
没试过多通道采集呢
feiante 回答时间:2015-2-6 08:42:10
恩,我也是用ADC DMA方式,多通道时有问题,永远都是第一个通道可以采样,好像F4和F1都是这样,F0是可以的
feiante 回答时间:2015-2-6 08:43:54
还有就是
感觉应该定义为WORD的,因为HAL_ADC_Start_DMA(&AdcHandle, ADC_Value_arr, 4);中,ADC_Value_arr是uint32
亦轩阁 回答时间:2015-2-9 08:15:49
feiante 发表于 2015-2-6 08:43
还有就是
  hdma_adc.Init.MemDataAlig ...
按你说的我改了,就没问题了,准确度太差了……非常感谢
feiante 回答时间:2015-2-9 09:35:44
你是说可以采集多路了?能把工程发来看看吗
亦轩阁 回答时间:2015-2-9 19:02:21
ADC的代码,就是我上边贴的代码,我的工程涉及太多文件,太大了,就不上传了……
阿_P 回答时间:2015-3-23 00:32:26
feiante 发表于 2015-2-6 08:42
恩,我也是用ADC DMA方式,多通道时有问题,永远都是第一个通道可以采样,好像F4和F1都是这样,F0是可以的 ...
请改为
AdcHandle.Init.ScanConvMode = ADC_SCAN_ENABLE;//扫描模式
F1这个库有BUG
feiante 回答时间:2015-3-23 10:21:36
谢谢
wyxy163@126.com 回答时间:2015-3-23 17:13:08
veryzhou 回答时间:2016-9-20 13:29:59
另外楼主的程序还需要吧DMA中断给关掉    因为设置的是DMA连续ADC采集,这样也就是每0.428us 就生产一次DMA完成中断,太过频繁的中断会经常阻塞其他程序的执行。
zbber 回答时间:2016-9-20 19:26:14
电小龙 回答时间:2016-9-23 16:38:40
楼主问题解决了,原因是什么呢?是因为BUG吗?
11:493 回答时间:2016-12-16 22:32:35
我的也遇到同样的问题,但是用的不是cube
absdjko 回答时间:2018-11-9 08:57:46
hdma_adc.Init.Mode=DMA_CIRCULAR;为啥我写了这个进去,printf就无效了,
