STM32F030
Features
Core: ARM® 32-bit Cortex®-M0 CPU,
frequency up to 48
MHz
Memories
– 16 to 256 Kbytes of Flash memory
– 4 to 32 Kbytes of SRAM with HW parity
CRC calculation unit
Reset and power management
– Digital & I/Os supply: VDD = 2.4 V to 3.6 V
– Analog supply: VDDA = VDD to 3.6 V
– Power-on/Power down reset (POR/PDR)
– Low power modes: Sleep, Stop, Standby
Clock management
– 4 to 32 MHz crystal oscillator
– 32 kHz oscillator for RTC with calibration
– Internal 8 MHz RC with x6 PLL option
– Internal 40 kHz RC oscillator
Up to 55 fast I/Os
– All mappable on external interrupt vectors
– Up to 55 I/Os with 5V tolerant capability
5-channel DMA controller
One 12-bit, 1.0
μs ADC (up to 16 channels)
– Conversion range: 0 to 3.6 V
– Separate analog supply: 2.4 V to 3.6 V
Calendar RTC with alarm and periodic wakeup
from Stop/Standby
11 timers
– One 16-bit advanced-control timer for
six-channel PWM output
– Up to seven 16-bit timers, with up to four
IC/OC, OCN, usable for IR control
decoding
– Independent and system watchdog timers
– SysTick timer
Communication interfaces
– Up to two I2C interfaces
one supporting Fast Mode Plus
(1 Mbit/s) with 20 mA current sink,
one supporting SMBus/PMBus.
– Up to six USARTs supporting master
synchronous SPI and modem control; one
with auto baud rate detection
– Up to two SPIs (18 Mbit/s) with 4 to 16
programmable bit frames
Serial wire debug (SWD)
All packages ECOPACK®2
1、
2、STM32F103RCT6
The STM32F103RC performance line microcontroller incorporates the high-performance ARM® Cortex™-M3 32-bit RISC core operating at a 72 MHz frequency, high-speed embedded memories (Flash memory up to 256 Kbytes and SRAM up to 48 Kbytes), and an extensive range of enhanced I/Os and peripherals connected to two APB buses. The STM32F103RC offers three 12-bit ADCs, four general-purpose 16- bit timers plus two PWM timers, as well as standard and advanced communication interfaces: up to two I2Cs, three SPIs, two I2Ss, one SDIO, five USARTs, an USB and a CAN.
3、做过两轮平衡车
STM32F030
Features
frequency up to 48
MHz
Memories
Clock management
Up to 55 fast I/Os
One 12-bit, 1.0
from Stop/Standby
11 timers
decoding
– SysTick timer
用过的开发板是STM32F103ZET6开发板
这块板子的可扩展性端口特别强,并且价格便宜。
主要使用过以下型号的芯片:STM32F103C8T6/F107ZE
2.说明该STM32产品型号,列举其一项或者多项特性,同时附件上传一篇该型号产品的资料
STM32F103C8T6的特性:
1.内核:arm32位 最高72MHZ
2.存储 128KB的闪存程序存储器 + 20K的SRAM
3.低功耗、超短唤醒时间
4.2个12位ADC
5.7个DMA通道
6.支持定时器、SPI、ADC、I2C、usart等外设
3.基于STM32你做过哪些设计
本人特别熟悉STM32F1系列的产品,主要利用STM32F1系列做过以下项目:
1.CAN总线输出的高精度角度传感器(基于的MLX90316):分辨率能到0.02度
2.掉电多圈磁编码器(基于的ICHAUS旗下IC—PMX芯片):不需要外部供电也能记录转过的圈数
3.物联网通信(利用的是乐鑫公司的ESP8266 wifi soc芯片)
4.大学期间参加过电脑鼠比赛(产品用的STM32F103C8T6做的)
STM32F103C8T6åçæ°æ®æå.pdf-EasyDatasheet.pdf
2016-1-23 15:01 上传
点击文件名下载附件
下载积分: ST金币 -11.11 MB, 下载次数: 0, 下载积分: ST金币 -1
1、
2、STM32F103RCT6
3、做过两轮平衡车
STM32F103xBæ°æ®æå.pdf
2016-1-23 18:01 上传
点击文件名下载附件
下载积分: ST金币 -11.82 MB, 下载次数: 0, 下载积分: ST金币 -1
使用过STM32F103/107/407系列芯片做项目开发,开发板使用过的有奋斗V5开发板
2、 说明该STM32产品型号,列举其一项或者多项特性,同时附件上传一篇该型号产品的资料(官方文档或者网络上的文章分享均可,点击立刻下载官方文档)型号为STM32F103VEt6,
stm32F103VET6,arm Cortex-M3内核,512kB Flash, 64KB RAM,最高工作时钟72MHz/90MIPS(1.25DMIPS/MHz),LQFP 100脚封装(片上集成12Bit A/D、D/A、PWM、CAN、USB、SDIO、FSMC等资源)
3、 基于STM32你做过哪些设计?(如没有则不写)
单板测试系统,CAN总线控制,集成测试系统等
STM32F103xC STM32F103xD STM32F103xE æ°æ®æå.pdf
2016-1-23 21:41 上传
点击文件名下载附件
下载积分: ST金币 -12.77 MB, 下载次数: 0, 下载积分: ST金币 -1
STM32F469NI
资料
STM32F469I-DISCO用户手册
STM32F469NI数据手册
3、 基于STM32你做过哪些设计?
飞控、130电机驱动板等
这些都是自己的作品
型号是STM32F031K6T6。
型号是STM32F031K6T6。
心率计量
避障小车
PID电机调速
2、CPU : 32-bit
SRAM : 64kB
Flash : 512KB
FSMC : 1 Flexible Static Memory Controller for SRAM, PSRAM, NOR and NAND Flash,
PLL : 1 PLL,
RCC : Embedded Internal RC 8MHz and 32kHz,
RTC : 1 Real-Time Clock,
NVIC : 1 Nested Interrupt Controller, Power Saving Modes, JTAG and SWD,
TIM : 4 Synch. 16-bit Timers with Input Capture, Output Compare and PWM,
TIM : 2 16-bit Advanced Timer, 2 16-bit Basic Timer, 2 16-bit Watchdog Timers,
2 个16位带死区控制和 2 个16位基本定时器 独立型和窗口型
éç«è¿·ä½ å¼åæ¿
【2】板子主要特性
NUCLEO-L053R8 是ST公司推出的一款针对STM32L0系列设计的Cortex-M0+开发板,
具有 mbed 功能,
支持Arduino。
同时还提供 ST Morpho 扩展排针,可连接微控制器的所有周边外设。
1.65V~3.6V工作电压!
最低0.27微安超低功耗!
工作频率最高可达32MHz,
集成了存储器保护单元(MPU),高速嵌入存储器(64KB闪存,2KB数据EEPROM和8KB RAM),
工作温度-40 到125 ℃,
【3】设计:温湿度检查。
1:正点原子战舰开发板,用的是STM32F103ZET6。
2:STM32ZET6,144引脚,是F103系列引脚最多的芯片,当时是内存容量最大的芯片,不过后期出了容量更大的F,G系列。
CM3内核,144引脚,64K RAM, 512K FLASH。
3:目前在做个一个基于STM32F103的温度采集板,还没做完...
X宝淘的一块板子,很便宜
2:
简单说下这块板子特性好了:
1.CPU型号:STM32103VET6(LQFP 100封装)(兼容所有STM3210Vx 型号)FLASH 512KB RAM 64KB 空间够大了 能跑UCOS UCGUI LWIP UIP等等大型的协议栈
2.对外有3路 3.3V供电排针 一路5V供电排针 多个GND排针(方便调试外部器件,无需另配电源)
3.2路FSMC总线引出可以同时调试 2个TFT屏 也可以同时调试其他总线方式的外设 【 如TFT + DM9000网络模块(本店有)】
4.所有IO口的丝印全部标注【正面标注IO口 反面标注IO口和第2功能 方便调试 SPI IIC USART AD 等功能 无需对照PDF找IO功能】全镀金排针
5.多个定位孔,可以外挂 多种TFT(有多个定位孔预留 用户可以自行搭配)并兼容火牛开发板TFT接口以及定位孔。
6.CPU 引脚每10个用数字标识(某些情况用的到)
7.2路LED用户指示灯(红色),通过一个共用跳冒接地,这样单独调试LED功能,
当调试其他需要此IO口时 可以把跳冒取下,不容易干扰其他功能。
8.J04(TX1 RX1 3.3V GND)单独引出,方便连接外设串口设备,以及调试或者下载程序用。
数据手册:
3:基于STM32你做过哪些设计?(如没有则不写)
红外壁障(智能小车)、超声波壁障
支持LTDC功能,主频可高达180M
主要做继电器保护之类装置!
2.STM32F4DISCOVERY 提供如下个特点:
- STM32F407VGT6 微控制器有 1M 的 FLASH 存储器,192K 的 RAM,LQFP100 封装
- 板上的 ST-LINK/V2 可以使用选择的方式把套件切换成一个独立的 ST-LINK/V2 来使用(用 SWD 连接器来编程和调试)
- 板子电源:通过 USB 总线或者外部 5V 电源来供电
- 外部应用电源:3V 和 5V
- LIS302DL, ST MEMS 运动传感器,3 轴数字输出加速器
- MP45DT02,ST MEMS 音频传感器,全向数字麦克风
- CS43L22,音频 DAC 集成了 CLASS D 扬声器驱动器
- 8 个 LED 指示灯
- LD1(红/绿)用于 USB 通讯
- LD2(红)用于 3.3V 上电
- 4 个用户 LED 灯,LD3(橙),LD4(绿),LD5(红)和 LD6(蓝)
- 2 个 USB OTG 的 LED 灯,LD7(绿)VBus,LD8(红)过流指示
- 2 个按钮,(用户按键和复位健)
- USB OTG,micro-AB 连接器
LQFP100 IO 口的扩展头,可以快速连接成原型板,易于探测
3.开发过的项目:测试其他设备的GPIO,IIC,SPI等接口,并收集采集信息,将测试结果及收集信息通过USB上传
STM32F4_DISCOVERY(䏿).pdf
2016-1-25 09:15 上传
点击文件名下载附件
下载积分: ST金币 -14.6 MB, 下载次数: 0, 下载积分: ST金币 -1
STM32L476器件,最高频率可达80MHz,凭借带有DSP和浮点单元(FPU)的ARM® Cortex®-M4内核扩展了超低功耗产品系列及其性能。该系列提供USB(支持OTG 2.0全速、LPM和BCD),LCD驱动(4x44或8x40,带有升压转换器),还包括大量外设。
