【活动】庆祝STM32出货量超10亿颗,开发板送不停!
沐紫 提问时间:2016-1-4 13:06 /
赞 收藏 2 评论434 发布时间:2016-1-4 13:06
434个回答
mark0668 回答时间:2016-1-18 12:59:50
Core: ARM 32-bit Cortex™-M4 CPU with FPU,
Adaptive real-time accelerator (ART
Accelerator™) allowing 0-wait state execution
from Flash memory, frequency up to 168 MHz,
memory protection unit, 210 DMIPS/
1.25 DMIPS/MHz (Dhrystone 2.1), and DSP
instructions
■ Memories
– Up to 1 Mbyte of Flash memory
– Up to 192+4 Kbytes of SRAM including 64-
Kbyte of CCM (core coupled memory) data
RAM
– Flexible static memory controller
supporting Compact Flash, SRAM,
PSRAM, NOR and NAND memories
■ LCD parallel interface, 8080/6800 modes
Up to 15 communication interfaces
– Up to 3 × I 2 C interfaces (SMBus/PMBus)
– Up to 4 USARTs/2 UARTs (10.5 Mbit/s,
ISO 7816 interface, LIN, IrDA, modem
control)
– Up to 3 SPIs (37.5 Mbits/s), 2 with muxed
full-duplex I 2 S to achieve audio class
accuracy via internal audio PLL or external
clock
– 2 × CAN interfaces (2.0B Active)
– SDIO interface
STM32F407ZGT6.pdf
2.14 MB, 下载次数: 0, 下载积分: ST金币 -1
hello! 回答时间:2016-1-18 13:02:30
支持支持
圆点博士后 回答时间:2016-1-18 13:03:18
1.NUCLEO_STM32F334R8
2.产品特性
  • Core: ARM® Cortex®-M4 32-bit CPU with FPU (72 MHz max), single-cycle multiplication and HW division, DSP instruction
  • Memories
  • Up to 64 KB of Flash memory
  • Up to 12 KB of SRAM with HW parity check
  • Routine booster: 4 KB of SRAM on instruction and data bus with HW parity check (CCM)
  • CRC calculation unit
  • Reset and supply management
  • VDD,VDDA voltage range: 2.0 to 3.6 V
  • Power-on/Power-down reset (POR/PDR)
  • Programmable voltage detector (PVD)
  • Low-power modes: Sleep,Stop,Standby
  • VBATsupply for RTC and backup registers
  • Clock management
  • 4 to 32 MHz crystal oscillator
编程手册.pdf
1.74 MB, 下载次数: 0, 下载积分: ST金币 -1
sxdahss 回答时间:2016-1-18 13:05:17
过来看看
chen000000009 回答时间:2016-1-18 13:05:17
1、    microMsg.1450706811480.jpg ;
2、   说明该STM32产品型号:NUCLEO-F030R8
列举其一项或者多项特性:支持mbed\Arduino
同时附件上传一篇该型号产品的资料: DM00105925.pdf (641.5 KB, 下载次数: 16)
馕边子 回答时间:2016-1-18 13:49:16
1、现在在测试nucleo——L476RG和nucleoL152 图片见附件,单位打算从赛普拉斯芯片,转到意法的stm32上,找些板子在做测试。
2、这个476最主要的特性是极为省电和dsp功能,我们现在主要是测试功耗和iot系统。也发了些关于安装使用的小帖子。
3、测试中,提供的例程sleep,deepsleep,stop,以及stm32cubel4中大多数功耗模式都测试过,下一步是os。希望得到长期支持,也横希望有新的测试开发板,用于通讯模块测试。谢谢。
4、非常希望得到新的开发板用于测试通讯模块。
haiguanguan 回答时间:2016-1-18 13:56:55
1、   晒出你使用过的STM32开发板/芯片图片(如果还未使用过,可从官网寻找);NUCLEO-F072RB
2、   说明该STM32产品型号,列举其一项或者多项特性,同时附件上传一篇该型号产品的资料(官方文档或者网络上的文章分享均可,点击立刻下载官方文档)STM32F072xx系列主要特性:
Core: ARM® 32-bit Cortex®-M0 CPU, frequency up to 48 MHz 
Memories
– 64 to 128 Kbytes of Flash memory
– 16 Kbytes of SRAM with HW parity 
CRC calculation unit 
Reset and power management
– Digital & I/Os supply: VDD = 2.0 V to 3.6 V
– Analog supply: VDDA = VDD to 3.6 V
– Selected I/Os: VDDIO2 = 1.65 V to 3.6 V
– Power-on/Power down reset (POR/PDR)
– Programmable voltage detector (PVD)
– Low power modes: Sleep, Stop, Standby
– VBAT supply for RTC and backup registers 
Clock management
– 4 to 32 MHz crystal oscillator
– 32 kHz oscillator for RTC with calibration
– Internal 8 MHz RC with x6 PLL option
– Internal 40 kHz RC oscillator
– Internal 48 MHz oscillator with automatic trimming based on ext. synchronization 
Up to 87 fast I/Os
– All mappable on external interrupt vectors
– Up to 68 I/Os with 5V tolerant capability and 19 with independent supply VDDIO2 
7-channel DMA controller 
One 12-bit, 1.0 μs ADC (up to 16 channels)
– Conversion range: 0 to 3.6 V
– Separate analog supply: 2.4 V to 3.6 V 
One 12-bit D/A converter (with 2 channels) 
Two fast low-power analog comparators with programmable input and output 
Up to 24 capacitive sensing channels for touchkey, linear and rotary touch sensors 
Calendar RTC with alarm and periodic wakeup from Stop/Standby 
12 timers
– One 16-bit advanced-control timer for 6 channel PWM output
– One 32-bit and seven 16-bit timers, with up to 4 IC/OC, OCN, usable for IR control decoding or DAC control
– Independent and system watchdog timers
– SysTick timer 
Communication interfaces
– Two I2C interfaces supporting Fast Mode Plus (1 Mbit/s) with 20 mA current sink; one supporting SMBus/PMBus and wakeup
– Four USARTs supporting master synchronous SPI and modem control; two with ISO7816 interface, LIN, IrDA, auto baud rate detection and wakeup feature
– Two SPIs (18 Mbit/s) with 4 to 16 programmable bit frames, and with I2S interface multiplexed – CAN interface
– USB 2.0 full-speed interface, able to run from internal 48 MHz oscillator and with BCD and LPM support 
HDMI CEC wakeup on header reception 
Serial wire debug (SWD) 
STM32F072
F072数据手册DM00090510.pdf (1.7 MB, 下载次数: 0)
埃斯提爱慕 回答时间:2016-1-18 14:06:13
zh384407950 回答时间:2016-1-18 14:06:21
开发版图片
开发版图片
DM00231744.pdf (776.06 KB, 下载次数: 0)
123tango 回答时间:2016-1-18 14:21:02
STM32L476 低功耗,M4内核
基于STM32的环境监测系统
DM00108832.pdf
2.78 MB, 下载次数: 0, 下载积分: ST金币 -1
xuguomin 回答时间:2016-1-18 14:21:23
使用STM32F103RET6(串口转以太网),STM32F205RGT6(远程数据采集器)
大禹 回答时间:2016-1-18 14:32:45
2、STM32F030R8特性:
64K Flash
8K RAM
LQFP64封装
6个16bit 时钟
16个12bit 外部ADC通道
多达55个IO口
2个SPI接口
2个IIC接口
最多支持2个UART
支持电压2.4V至3.6V
低功耗模式3.4uA
运行模式250uA
工作温度-40至+85
STM32F030x8.pdf (1.63 MB, 下载次数: 3)
feiante 回答时间:2016-1-18 14:35:34
1、用过stm32F103R8T6,STM32F407 IMG_2524.JPG 2、内核: ARM 32位的Cortex™-M3 CPU
− 最高72MHz工作频率,在存储器的0等待周
期访问时可达1.25DMips/MHz(Dhrystone
2.1)
− 单周期乘法和硬件除法
■ 存储器
− 从64K或128K字节的闪存程序存储器
− 高达20K字节的SRAM
■ 时钟、复位和电源管理
− 2.0~3.6伏供电和I/O引脚
− 上电/断电复位(POR/PDR)、可编程电压监测
器(PVD)
− 4~16MHz晶体振荡器
− 内嵌经出厂调校的8MHz的RC振荡器
− 内嵌带校准的40kHz的RC振荡器
− 产生CPU时钟的PLL
− 带校准功能的32kHz RTC振荡器
■ 低功耗
− 睡眠、停机和待机模式
− VBAT为RTC和后备寄存器供电
■ 2个12位模数转换器, 1μs转换时间(多达16个
输入通道)
− 转换范围: 0至3.6V
− 双采样和保持功能
− 温度传感器
■ DMA:
− 7通道DMA控制器
− 支持的外设:定时器、 ADC、 SPI、 I2C和
USART
■ 多达80个快速I/O端口
− 26/37/51/80个I/O口,所有I/O口可以映像到
16个外部中断;几乎所有端口均可容忍5V信
号
■ 调试模式
− 串行单线调试(SWD)和JTAG接口
■ 多达7个定时器
− 3个16位定时器,每个定时器有多达4个用于
输入捕获/输出比较/PWM或脉冲计数的通道
和增量编码器输入
− 1个16位带死区控制和紧急刹车,用于电机
控制的PWM高级控制定时器
− 2个看门狗定时器(独立的和窗口型的)
− 系统时间定时器: 24位自减型计数器
■ 多达9个通信接口
− 多达2个I2C接口(支持SMBus/PMBus)
− 多达3个USART接口(支持ISO7816接口,
LIN, IrDA接口和调制解调控制)
− 多达2个SPI接口(18M位/秒)
− CAN接口(2.0B 主动)
− USB 2.0全速接口
■ CRC计算单元, 96位的芯片唯一代码
■ ECOPACK®封装
3、做过数据采集、仪表。
笑鸟007 回答时间:2016-1-18 14:36:58
2、   说明该STM32产品型号,stm32f469NI-DISCO。
Key Features
  • STM32F469NIH6 microcontroller featuring 2 Mbytes of Flash memory and 324 Kbytes of RAM in BGA216 package
  • On-board ST-LINK/V2-1 SWD debugger, supporting USB reenumeration capability:
  • Mbed-enabled (mbed.org)
  • USB functions: USB virtual COM port, mass storage, debug port
  • 4 inches 800x480 pixel TFT color LCD with MIPI DSI interface and capacitive touch screen
  • SAI Audio DAC, with a stereo headphone output jack
  • 3 MEMS microphones
  • MicroSD card connector
  • I2C extension connector
  • 4Mx32bit SDRAM
  • 128-Mbit Quad-SPI NOR Flash
  • Reset and wake-up buttons
  • 4 color user LEDs
  • USB OTG FS with Micro-AB connector
  • Three power supply options:
  • Expansion connectors and Arduino™ UNO V3 connectors
  • Comprehensive free software including a variety of examples, part of STM32Cube package
  • Supported by a wide choice of integrated development environment
  • STM32F469xx.pdf (2.94 MB, 下载次数: 0)
3、   基于STM32你做过哪些设计?
无线传感器网络节点
limale 回答时间:2016-1-18 15:02:13
  • STM32L476RGT6 in LQFP64 package
  • ARM®32-bit Cortex®-M4 CPU
  • Adaptive real-time accelerator (ART Accelerator™) allowing 0-wait state execution from Flash memory
  • 80 MHz max CPU frequency
  • VDD from 1.71 V to 3.6 V
  • 1 MB Flash
  • 128 KB SRAM
  • Quad SPI (1)
  • Timers General Purpose (7)
  • Timers Advanced-Control (2)
  • Timers Basic (2)
  • Timers LowPower (2)
  • Systick
  • Watchdog (2)
  • SPI (3)
  • I2S (3)
  • USART (3)
  • UART (2)
  • LPUART (1)
  • USB OTG Full Speed
  • CAN (1)
  • SAI (2)
  • SDMMC
  • SWPMI
  • LCD 8x28 or 4x32
  • GPIO (51) with external interrupt capability
  • Capacitive sensing with 12 channels
  • 12-bit ADC (3) with 16 channels
  • 12-bit DAC with 2 channels
  • Analog comparator (2)
  • Opamp (2)
  • DM00108832.pdf (2.57 MB, 下载次数: 0)
3、   基于STM32你做过哪些设计?(如没有则不写)
驱动oled显示、驱动电机、采集9轴传感器数据。
