【活动】庆祝STM32出货量超10亿颗,开发板送不停!
沐紫 提问时间:2016-1-4 13:06 /
赞 收藏 2 评论434 发布时间:2016-1-4 13:06
434个回答
STM32会员 回答时间:2016-1-18 17:08:36
1、这个是一个stm32f103zet6的开发板144个管脚。
2、Features
■ Core: ARM 32-bit Cortex™-M3 CPU
– 72 MHz maximum frequency,
1.25 DMIPS/MHz (Dhrystone 2.1)
performance at 0 wait state memory
access
– Single-cycle multiplication and hardware
division
■ Memories
– 256 to 512 Kbytes of Flash memory
– up to 64 Kbytes of SRAM
– Flexible static memory controller with 4
Chip Select. Supports Compact Flash,
SRAM, PSRAM, NOR and NAND memories
– LCD parallel interface, 8080/6800 modes
■ Clock, reset and supply management
– 2.0 to 3.6 V application supply and I/Os
– POR, PDR, and programmable voltage
detector (PVD)
– 4-to-16 MHz crystal oscillator
– Internal 8 MHz factory-trimmed RC
– Internal 40 kHz RC with calibration
– 32 kHz oscillator for RTC with calibration
■ Low power
– Sleep, Stop and Standby modes
– VBAT supply for RTC and backup registers
■ 3 × 12-bit, 1 µs A/D converters (up to 21
channels)
– Conversion range: 0 to 3.6 V
– Triple-sample and hold capability
– Temperature sensor
■ 2 × 12-bit D/A converters
■ DMA: 12-channel DMA controller
– Supported peripherals: timers, ADCs, DAC,
SDIO, I2Ss, SPIs, I2Cs and USARTs
■ Debug mode
– Serial wire debug (SWD) & JTAG interfaces
– Cortex-M3 Embedded Trace Macrocell™
■ Up to 112 fast I/O ports
– 51/80/112 I/Os, all mappable on 16
external interrupt vectors and almost all
5 V-tolerant
■ Up to 11 timers
– Up to four 16-bit timers, each with up to 4
IC/OC/PWM or pulse counter and
quadrature (incremental) encoder input
– 2 × 16-bit motor control PWM timers with
dead-time generation and emergency stop
– 2 × watchdog timers (Independent and
Window)
– SysTick timer: a 24-bit downcounter
– 2 × 16-bit basic timers to drive the DAC
■ Up to 13 communication interfaces
– Up to 2 × I2C interfaces (SMBus/PMBus)
– Up to 5 USARTs (ISO 7816 interface, LIN,
IrDA capability, modem control)
– Up to 3 SPIs (18 Mbit/s), 2 with I2S
interface multiplexed
– CAN interface (2.0B Active)
– USB 2.0 full speed interface
– SDIO interface
■ CRC calculation unit, 96-bit unique ID
■ ECOPACK® packages
STM32F103ZET6TR.pdf (1.66 MB, 下载次数: 0)
颩色四葉愺 回答时间:2016-1-18 17:22:13
补上补上
2.STM32F746NGH6微控制器具有1 MB的闪存和340 KB的RAM,在BGA216封装
板载ST-LINK / V2-1支持USB重新枚举功能
USB功能:虚拟COM端口,海量存储,调试端口
4.3英寸480×272彩色LCD-TFT电容式触摸屏
相机连接器
SAI音频编解码器
音频线路输入和线路输出插孔
立体声扬声器输出
两ST MEMS麦克风
SPDIF RCA输入接口
两个按钮(用户和重置)
128兆位四通道SPI闪存
128兆SDRAM(64兆比特访问)
连接器的microSD卡
RF-EEPROM子板连接器
USB OTG HS采用微型AB连接器
USB OTG FS带微型AB连接器
以太网连接器,兼容IEEE-802.3-2002
五电源选项:
ST LINK / V2-1
USB连接器FS
USB HS连接器
VIN从Arduino的连接器
外部5 V的连接器
电源输出的外部应用程序:3.3 V或5 V
Arduino的乌诺V3连接器
全面的免费软件,包括各种实例,部分STM32Cube包3.
基于stm32f411re的智能手表远程视屏监控
植物监管系统
netlhx 回答时间:2016-1-18 17:59:09
1. F4-DISCO
2. 主要特性
Core: ARM® 32-bit Cortex®-M4 CPU with FPU, Adaptive real-time accelerator (ART Accelerator™) allowing 0-wait state execution from Flash memory, frequency up to 168 MHz, memory protection unit, 210 DMIPS/1.25 DMIPS/MHz (Dhrystone 2.1), and DSP instructionsMemoriesUp to 1 Mbyte of Flash memoryUp to 192+4 Kbytes of SRAM including 64-Kbyte of CCM (core coupled memory) data RAMFlexible static memory controller supporting Compact Flash, SRAM, PSRAM, NOR and NAND memoriesLCD parallel interface, 8080/6800 modesClock, reset and supply management1.8 V to 3.6 V application supply and I/OsPOR, PDR, PVD and BOR4-to-26 MHz crystal oscillatorInternal 16 MHz factory-trimmed RC (1% accuracy)32 kHz oscillator for RTC with calibrationInternal 32 kHz RC with calibrationSleep, Stop and Standby modesVBATsupply for RTC, 20×32 bit backup registers + optional 4 KB backup SRAM3×12-bit, 2.4 MSPS A/D converters: up to 24 channels and 7.2 MSPS in triple interleaved mode2×12-bit D/A convertersGeneral-purpose DMA: 16-stream DMA controller with FIFOs and burst supportUp to 17 timers: up to twelve 16-bit and two 32-bit timers up to 168 MHz, each with up to 4 IC/OC/PWM or pulse counter and quadrature (incremental) encoder input
数据手册: DM00037051_DS.pdf (5.66 MB, 下载次数: 0)
加拿大 回答时间:2016-1-18 18:46:54
1、使用过开发板图片
2、STM32F103RB芯片特性:
内核: ARM 32位的Cortex™-M3 CPU
− 最高72MHz工作频率,在存储器的0等待周
期访问时可达1.25DMips/MHz(Dhrystone
2.1)
− 单周期乘法和硬件除法
■ 存储器
− 从64K或128K字节的闪存程序存储器
− 高达20K字节的SRAM
■ 时钟、复位和电源管理
− 2.0~3.6伏供电和I/O引脚
− 上电/断电复位(POR/PDR)、可编程电压监测
器(PVD)
− 4~16MHz晶体振荡器
− 内嵌经出厂调校的8MHz的RC振荡器
− 内嵌带校准的40kHz的RC振荡器
− 产生CPU时钟的PLL
− 带校准功能的32kHz RTC振荡器
■ 低功耗
− 睡眠、停机和待机模式
− VBAT为RTC和后备寄存器供电
■ 2个12位模数转换器, 1μs转换时间(多达16个
输入通道)
− 转换范围: 0至3.6V
− 双采样和保持功能
− 温度传感器
■ DMA:
− 7通道DMA控制器
− 支持的外设:定时器、 ADC、 SPI、 I2C和
USART
■ 多达80个快速I/O端口
− 26/37/51/80个I/O口,所有I/O口可以映像到
16个外部中断;几乎所有端口均可容忍5V信
号
■ 调试模式
− 串行单线调试(SWD)和JTAG接口
■ 多达7个定时器
− 3个16位定时器,每个定时器有多达4个用于
输入捕获/输出比较/PWM或脉冲计数的通道
和增量编码器输入
− 1 个16位带死区控制和紧急刹车,用于电机
控制的PWM高级控制定时器
− 2个看门狗定时器(独立的和窗口型的)
− 系统时间定时器: 24位自减型计数器
■ 多达9个通信接口
− 多达2个I2C接口 (支持SMBus/PMBus)
− 多达3个USART接口 (支持ISO7816接口,
LIN, IrDA接口和调制解调控制)
− 多达2个SPI接口 (18M位/秒)
− CAN接口 (2.0B 主动)
− USB 2.0全速接口
■ CRC计算单元, 96位的芯片唯一代码
■ ECOPACK®封装
3、做过设计有:
(1)STM32F103RB+DHT11温湿传感器 温湿测量
(2)基于STM32的二维码编码和显示(源代码)
STM32F103RB
STM32F103RB
STM32F103x8 STM32F103xB英文说明.pdf
1.62 MB, 下载次数: 0, 下载积分: ST金币 -1
STM32F103x8 STM32F103xB中文说明.pdf
1.77 MB, 下载次数: 0, 下载积分: ST金币 -1
电子信息港帐好 回答时间:2016-1-18 18:57:46
一、刚参加了圣诞活动。nucleo32_f031k6新版刚开始用。晒晒吧
1
1
二、板子的特性
STM32F031K6T6 in LQFP32 packageARM®32-bit Cortex®-M0 CPU48 MHz max CPU frequencyVDD from 2.0 V to 3.6 V32 KB Flash4 KB SRAMTimers Advanced Control (1)Timers General Purpose (5)SPI/I2S (1)I2C (1)USART (1)      12-bit ADC with 13 channels (1)
      GPIO (25) with external interrupt capability
      RTC
附件: DM00231744.pdf (776.06 KB, 下载次数: 1)
harvardx 回答时间:2016-1-18 18:59:27
1、   晒出你使用过的STM32开发板/芯片图片(如果还未使用过,可从官网寻找);
2、   说明该STM32产品型号,列举其一项或者多项特性,同时附件上传一篇该型号产品的资料 具体的资源如下:
STM32F746NGH6微控制器,采用BGA216封装
USB OTG HS,USB OTG FS
以太网10/100Mb、MicroSD卡、USART
SAI音频DAC立体声音频插孔输入和输出
MEMS数字麦克风
SDRAM、四通道SPI闪存
4.3英寸带电容屏的彩色LCD-TFT
SPDIF输入RCA
1用户LED、1用户按钮
Arduino UNO扩展接口
板载ST-LINK/ V2-1,提供了一个嵌入式调试器和编程的STM32微控制器
除了一开始就介绍过的4.3英寸LCD屏幕,STM32F7 Discovery开发板还带一个完整的音频输入输出电路(需要耳机或者音响配合),此外,板卡还搭载了一个高速USB OTG以及全速USB OTG接口,这两个接口是分开设计的,高速的USB OTG接口通过SMSC的USB3320收发器实现的。
3、   基于STM32你做过哪些设计?
答:  基于stm32F103的pid彩屏温控的设计. 基于stm32F030的电刺激器设计
2015-08 STM32F7评测.zip (1.87 MB, 下载次数: 0)
黑驴蹄子 回答时间:2016-1-18 19:41:47
1、用过STM32F410的nucleo开发板
2、  STM32F410RB
STM32F410系列是STM32 F4系列的入门级产品。它设计用于需要在小至2.553 x 2.579 mm的封装内实现均衡性能、高功效及高嵌入式存储器与外设集成度的医疗、工业和消费类应用。STM32F410拥有工作频率为100 MHz的Cortex-M4内核(具有浮点单元)的性能,同时还能在运行和停机模式下实现出色的低功耗性能。
在100 MHz频率下,从Flash存储器执行时,STM32F410能够提供125 DMIPS/339 CoreMark性能,并且利用意法半导体的ART加速器实现了FLASH零等待状态。DSP指令和浮点运算单元扩大了产品的应用范围。
该系列产品采用意法半导体90 nm工艺和ART加速器,具有动态功耗调整功能,能够在运行模式和从Flash存储器执行时实现低至89 µA/MHz的电流消耗。停机模式下,功耗低至6 µA(典型值)。
DM00107720.pdf (350.32 KB, 下载次数: 0)
felixqi 回答时间:2016-1-18 19:58:13
1.
大的是STM32F103ZET6 小的是STM32F103C8T6
2.
STM32F103ZET6特性
内核:ARM 32位的Cortex-M3 CPU,最高72MHz工作频率,在存储器的0等待周期访问时可达1.25DMips/MHz(Dhrystone 2.1)
单周期乘法和硬件除法
存储器从256K至512K字节的闪存程序存储器
高达64K 字节的SRAM
带4个片选的静态存储器控制器。支持CF卡、SRAM、PSRAM、NOR和NAND存储器
并行LCD接口,兼容8080/6800模式
时钟、复位和电源管理
2.0~3.6伏供电和I/O引脚
上电/ 断电复位(POR/PDR)、可编程电压监测器(PVD)
4~16MHz晶体振荡器
内嵌经出厂调校的8MHz 的RC振荡器
内嵌带校准的40kHz 的RC振荡器
带校准功能的32kHz RTC振荡器
低功耗
睡眠、停机和待机模式
VBAT为RTC和后备寄存器供电
3个12位模数转换器,1μs转换时间(多达21个输入通道)
转换范围:0至3.6V
三倍采样和保持功能
温度传感器
2通道12位D/A转换器
DMA:12通道DMA控制器
支持的外设:定时器、ADC、DAC、SDIO、I2S、SPI、I2C和USART
调试模式
串行单线调试(SWD) 和JTAG 接口
Cortex-M3内嵌跟踪模块(ETM)
多达112个快速I/O端口
51/80/112个多功能双向的I/O 口,所有I/O 口
可以映像到16个外部中断;几乎所有端口均可容忍5V信号
多达11个定时器
多达4个16位定时器,每个定时器有多达4个用于输入捕获/ 输出比较/PWM 或脉冲计数的
通道和增量编码器输入
2个16位带死区控制和紧急刹车,用于电机控制的PWM高级控制定时器
2个看门狗定时器(独立的和窗口型的)
系统时间定时器:24位自减型计数器
2个16位基本定时器用于驱动DAC
多达13个通信接口
多达2个I2C接口(支持SMBus/PMBus)
多达5个USART接口(支持ISO7816,LIN,IrDA接口和调制解调控制)
多达3个SPI接口(18M位/秒),2个可复用为I2S接口,CAN 接口(2.0B主动)
USB 2.0全速接口
SDIO接口
CRC计算单元,96位的芯片唯一代码
3.
做过的设计有ModbusTCP ModbusUART Modbus485 电力载波 等
STM32F103C8T6最小系统.pdf
486.56 KB, 下载次数: 0, 下载积分: ST金币 -1
STM32ZET6大容量手册_CN.pdf
2.77 MB, 下载次数: 0, 下载积分: ST金币 -1
harvardx 回答时间:2016-1-18 19:59:45
MEMS数字麦克风
SDRAM、四通道SPI闪存
4.3英寸带电容屏的彩色LCD-TFT
SPDIF输入RCA
1用户LED、1用户按钮
Arduino UNO扩展接口
3、   基于STM32你做过哪些设计?
DM00180213.pdf (461.09 KB, 下载次数: 0)
wamcncn 回答时间:2016-1-18 20:26:24
2、   说明该STM32产品型号,列举其一项或者多项特性,同时附件上传一篇该型号产品的资料(官方文档或者网络上的文章分享均可,点击立刻下载官方文档)
      STM32F746-DISCO:M7系列和其他的系列的不同主要应该在总线上区别以及M7添加了 L1-cache的优势,所以虽然主频提高不大但是性能依旧提升很多。要让STM32F7系类根据不同的用途发挥最大的性能就要配置好相应的总线接口了,比如该如何合适的使用AXIM, ITCM, DTCM, AHBS and AHBP。至于FLASH走ITCM接口使用ART加速还是走还是AXI接口利用L1-cache那要根据需要设置,64K的DTCM可以存放堆栈,16K的ITCM可以向F3的CCMRAM一样用于存放实时性要求较高的中断及数据处理函数。
STM32F7介绍.pdf (1.81 MB, 下载次数: 0)
谦 回答时间:2016-1-18 20:30:02
1、   我用的频率最多的STM32开发板:
2、   产品型号是STM32F030。
STM32F030R8特性如下:
64K Flash
8K RAM
LQFP64封装
6个16bit 时钟
16个12bit 外部ADC通道
多达55个IO口
2个SPI接口
2个IIC接口
最多支持2个UART
支持电压2.4V至3.6V
低功耗模式3.4uA
运行模式250uA
工作温度-40至+85
下面是F030R8的数据手册:
DM00088500.pdf (1.63 MB, 下载次数: 0)
阿莫西林 回答时间:2016-1-18 20:41:49
正在学习使用stm32F103中
STM32F10x常见应用解析.pdf
2.07 MB, 下载次数: 3, 下载积分: ST金币 -1
54chenjq 回答时间:2016-1-18 21:27:38
1,stm32f407是我最常用的MCU。2,目前在用F7的开发板进行学习与开发很有意思的东西,板上资源丰富,包括语音设备,以太网,触摸屏等!
3,我打算做一套OBD。
我用过的板子
我用过的板子
Getting started with STM32F746G-DISCO.pdf
818.55 KB, 下载次数: 0, 下载积分: ST金币 -1
杉树林-罗 回答时间:2016-1-18 21:32:51
1.晒出你使用过的STM32开发板/芯片图片
原子家的mini STM32,从网友手上淘回来的
2. 说明该STM32产品型号,列举其一项或者多项特性,同时附件上传一篇该型号产品的资料
芯片型号:STM32F103RCT6
特性:
芯体尺寸:32-位
速度:72MHz
连通性:CAN,I2C,IrDA,LIN,SPI,UART/USART,USB
外围设备:DMA,电机控制PWM,PDR,POR,PVD,PWM,WDT
输入/输出数:51
程序存储器容量:256KB
程序存储器类型:FLASH
RAM容量:48K
电压-电源(Vcc/Vdd):2 V ~ 3.6 V
振荡器型:内部
工作温度:-40°C ~ 85°C
封装/外壳:64-LQFP
附件:
STM32中断优先级与相关使用概念.pdf (139.04 KB, 下载次数: 1)
harvardx 回答时间:2016-1-18 21:35:41
MEMS数字麦克风
SDRAM、四通道SPI闪存
4.3英寸带电容屏的彩色LCD-TFT
SPDIF输入RCA
1用户LED、1用户按钮
Arduino UNO扩展接口
3、   基于STM32你做过哪些设计?
