本帖最后由 feixiang20 于 2017-5-25 09:53 编辑 1 X- `: L; w: ?* ~' e$ m- l ] A7 A [ \( t& w: H3 C+ [& Y$ ` 1.硬件: A. TLE5012bE10003 |: s+ }2 f& e# I B. STM32F103 7 \; G% P1 e2 | V2 q 2.TLE5012B_E1000 接线说明:2 {9 f* ~% w3 R 1:NC+ Z' r0 F2 [6 P) ^9 T 2:SCK <= 120R => stm32f103 PA54 u. f, L: U' z$ Y8 N 3:CSQ (CS) <= 120R => stm32f103 PB0 4 ATA <= 120R => stm32f103 PA6DATA <= 120R => stm32f103 PA7 DATA <= 2.2K => Vdd 3.3V p7 p3 m: s2 z; ?8 U, z; I% g8 n PS:因是三线 SPI , MOSI , MISO 并线使用 6 @0 }) F! D9 X3 x7 M- D5 Z 5:NC, m6 w/ e+ b4 B2 S: r 6:Vdd 3.3V$ z6 ^0 F/ f2 X 7:GND 8:NC + ^. \" b" }+ [# T. j- H 3.源码说明:+ ^) F1 n5 C1 G % v+ R: \) I6 @ @) g A. 初始化 SPI5012B_Init(); 7 Y9 Z6 X8 A A& ? B. 得到 0~359 角度 ReadAngle() 或 角速度 ReadSpeed()6 q9 w( l9 z2 s7 P7 Z |
【福利三:雨露均沾·逢7狂欢】之三:AI帮我查BUG
基于STM32F103的I2C主从机通信
单片机:初学者该了解的STM32F103基础知识
2025软件工具兔哥知道
STM32之继电器模块
//磁铁,请用“径向充磁”的圆磁铁,如 直径 10 x 厚 2mm& z5 E* G# ^- b3 @4 ?
//SPI5012B_Init() 时钟需另外加上; P) _" g+ g& e7 |: k
//以下内容需按实际更改
#define SPI_TX_OFF {GPIOA->CRL&=0x0FFFFFFF;GPIOA->CRL|=0x40000000;}//把PA7(MOSI)配置成开漏--输入模式2 X! K: V8 l# k% G% j c9 P/ d9 o
#define SPI_TX_ON {GPIOA->CRL&=0x0FFFFFFF;GPIOA->CRL|=0xB0000000;}//把PA7(MOSI)配置成推挽--输出模式(50MHz)9 U2 D. ]6 |# v" o1 x: O
9 n& {+ k2 _% t) b) B6 p4 K |
#define GPIO_CS_Pin_Name GPIO_Pin_0- H# l0 s3 \2 K
#define GPIO_CS_Pin_Type GPIOB Z- _& w$ X& s
# [ m2 Y7 I6 o! _& r
//以下内容一般不需变动
#define SPI_CS_ENABLE GPIO_ResetBits(GPIO_CS_Pin_Type, GPIO_CS_Pin_Name) //片选脚电平拉低
#define SPI_CS_DISABLE GPIO_SetBits(GPIO_CS_Pin_Type, GPIO_CS_Pin_Name) //片选脚电平拉高
//#define INDEX_ENABLE GPIO_SetBits(GPIOA, GPIO_Pin_4)/* for incremental signal index */
//#define CLK_H GPIO_SetBits(GPIOA, GPIO_Pin_5) //时钟脚PA5电平拉高! ~: Y& p7 `0 G( K* W6 _( R
//#define CLK_L GPIO_ResetBits(GPIOA, GPIO_Pin_5) //时钟脚PA5电平拉低
//#define DATA_H GPIO_SetBits(GPIOA, GPIO_Pin_6) //PA6(MISO)电平拉高
//#define DATA_L GPIO_ResetBits(GPIOA, GPIO_Pin_6) //PA6(MISO)电平拉低
//#define READ_DATA GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_6)
/* SPI command for TLE5012 */* S5 t4 |- o) w3 D# p
#define READ_STATUS 0x8001 //8000
#define READ_ANGLE_VALUE 0x8021 //8020
#define READ_SPEED_VALUE 0x8031 //8030; A/ D; l4 L' X1 {
#define WRITE_MOD1_VALUE 0x5060 //0_1010_0_000110_0001
#define MOD1_VALUE 0x0001 c5 p- E1 \$ t7 c: @0 h9 p, `1 E
#define WRITE_MOD2_VALUE 0x5080 //0_1010_0_001000_0001& t1 N1 J# a' r* \+ r( r& Q% V) f
#define MOD2_VALUE 0x08011 t# c6 G3 r! m2 s4 r
+ N6 ~1 V. L) ^' U" }% N% M6 w
#define WRITE_MOD3_VALUE 0x5091 //0_1010_0_001001_0001
#define MOD3_VALUE 0x0000/ T( ?- d$ ]6 [) X R
. T& Z8 q8 O( o d& J1 {) `. |! q
#define WRITE_MOD4_VALUE 0x50E0 //0_1010_0_001110_0001
#define MOD4_VALUE 0x0098 //9bit 512& t8 q6 ]0 ?! u) C
#define WRITE_IFAB_VALUE 0x50B1
#define IFAB_VALUE 0x000D
/* Functionality mode */
#define REFERESH_ANGLE 0
{, ^) i. F) a! c
uint16_t retry = 0;5 t) B! {+ S* [8 y5 ^; @
while( (SPI1->SR&1<<1) == 0 )//发送缓冲区非空
if( ++retry > 200 )
return 0;//延迟一段时间后返回
}+ C& ^# F; }( Z. G5 x6 k) L! P3 B
SPI1->DR = byte; //发送数据* B3 z6 P4 Q+ {" x7 N" X2 E/ F4 b: ]
retry = 0;
while( (SPI1->SR&1<<0) == 0 ) //接收缓冲区为空. Z h# h. X1 W8 n
if( ++retry > 200 )
}+ K$ O8 g! ]! }, ~
return SPI1->DR; //读一下缓冲区,清标志
}- Q$ F4 ^& ?: }
$ j w5 }- m: | Q. P
' ]0 }% k5 Y9 t1 W! w
//得到 0~359 度
uint16_t ReadAngle(void)7 x6 Y- t+ z0 p8 h2 l2 i% z
return ( ReadValue(READ_ANGLE_VALUE) * 360 / 0x10000 );# c+ r7 E$ S2 i8 P9 K. S# _
}; A/ e. `( I8 r* a5 `' a. ^
//得到角速度0 N* Q7 c/ [. h' q( ~
uint16_t ReadSpeed(void)
return ReadValue(READ_SPEED_VALUE);) `4 g: x2 F7 E7 X: \2 g" U
}9 `; U5 N: V6 A) i% P
& |: G. \6 Y: @) M. ]
uint16_t ReadValue(uint16_t u16RegValue)/ w7 P3 p" w! ?; s% \7 r6 Z8 E
uint16_t u16Data;
SPI_CS_ENABLE;5 ], T+ W# O% m* g9 G6 m; l0 J, }/ Z
SPIx_ReadWriteByte(u16RegValue);
SPI_TX_OFF;
1 N7 |2 U. e' n2 J4 m U4 w B
//发送 0xFFFF 是无用的,可能是为了有时钟# r/ K9 o6 }' q; c6 T7 S( \
u16Data = ( SPIx_ReadWriteByte(0xffff) & 0x7FFF ) << 1;//0x12/0xff*100k
& ?- I8 ]1 C+ E/ J+ N0 Y
SPI_CS_DISABLE;
SPI_TX_ON;
return(u16Data);& a( k, p( |; w0 b" N
{( ?3 g2 {( n' J% Q
SPI_InitTypeDef SPI_InitStructure;
RCC_APB2PeriphClockCmd( RCC_APB2Periph_SPI1,ENABLE );/ S2 Q& R$ Q+ d0 {: y- f* {
//以下二句,在它处声明,请增加使用' H; J& y$ ^# Q9 c0 \! z" e) a3 E
//RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |RCC_APB2Periph_AFIO, ENABLE);9 Z* v% a, Y2 @$ y
//GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable,ENABLE);//使JTDO、JTDI、JTCK 当成普通IO口进行操作7 I7 t; q: I& ? c$ V
//GPIOB0 当成普通IO口进行操作: R2 t4 R- i5 q; V
7 ~( b6 G. i2 |' f
/*SPI: NSS,SCK,MISO and MOSI */ O$ J' V; U) \* `- p" k. D
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;2 ~4 O3 K1 p$ [: r1 D( r. V
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//PA5--CLK--复用推挽" o r$ B. @% }" a* F o/ s7 i
//GPIO_StructInit(&GPIO_InitStructure);
3 H# H3 r/ I! Q! X5 C% y
/* Configure PA6 as encoder input */. T& H' w' Y: _/ H5 a+ d' d
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;( x" G' Y" Q2 D5 C
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;//PA6--MISO--输入8 y( n4 e9 U) k$ K3 Y9 x+ `
. \. s f( @$ r+ Y. x
/* PA7*/! P* h4 d$ N0 B2 W' W
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;$ n) j4 P$ u0 D7 p. {
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//PA7--MOSI--推挽输出) ^0 x9 f0 l! N6 {$ X
; T% `# X( u' I" Q
GPIO_InitStructure.GPIO_Pin = GPIO_CS_Pin_Name;//PB0--CS--推挽输出 I& E, A3 b( y2 M r- j
GPIO_Init(GPIO_CS_Pin_Type, &GPIO_InitStructure);
/**********SPI****************/
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;//SPI1--双线全双工!!8 L! c3 H+ V% {- @! ^" y- X8 u
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;% X6 |7 h6 l1 h3 n" ~
SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;6 m# Y5 E2 t& L+ E3 [; X$ C
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;' x: d* ]$ G' ]6 X9 T0 y, x$ q, {
SPI_InitStructure.SPI_CRCPolynomial = 7;
, ^; k9 m! w) X6 p3 I
SPI_Init(SPI1, &SPI_InitStructure);
SPI_Cmd(SPI1, ENABLE);
8 y4 z1 d1 d, Q) X
' l2 c. `9 K& t. F& d/ v
5 _/ \0 S1 s6 N' i2 V! {/ \
, @. g8 Q! ^/ A6 {& |+ T% B
谢谢分享!!!
