STM32F429 Discovery 与 ZSC31210 SPI 通讯
Aaron_0618 提问时间:2017-6-4 17:36 /
每3ms读取 SPI4_Read(ZSC,2);但是每次ZSC[0]与ZSC[1]两个値永远相同,清问问题点在哪边我设定错了?
void SysTick_Handler(void)  //1ms
   SPI_Delay++;
   if(SPI_Delay==3)
        SPI4_Read(ZSC,2);
        SPI_Delay=0;
static void SPI4_Init(void)
    SPI_InitTypeDef  SPI_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI4, ENABLE);
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE | RCC_AHB1Periph_GPIOE | RCC_AHB1Periph_GPIOE, ENABLE);
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
    GPIO_PinAFConfig(GPIOE, GPIO_PinSource12, GPIO_AF_SPI4);
    GPIO_PinAFConfig(GPIOE, GPIO_PinSource13, GPIO_AF_SPI4);
    GPIO_PinAFConfig(GPIOE, GPIO_PinSource14, GPIO_AF_SPI4);
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_DOWN;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
    GPIO_Init(GPIOE, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_13;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
    SPI_I2S_DeInit(SPI4);
    SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_128;   //ZSC31210 50K-800K
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
    SPI_InitStructure.SPI_CRCPolynomial = 7;
    SPI_Init(SPI4, &SPI_InitStructure);
    SPI_Cmd(SPI4, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
    GPIO_SetBits(GPIOE, GPIO_Pin_11);
void SPI4_Read(uint8_t* pBuffer, uint16_t NumByteToRead)
    GPIO_ResetBits(GPIOE, GPIO_Pin_11);
    while(NumByteToRead > 0x00)
       *pBuffer = SPI4_SendByte(0xFF);
        NumByteToRead--;
        pBuffer++;
static uint8_t SPI4_SendByte(uint16_t byte)
    SPI_I2S_SendData(SPI4, (uint16_t)byte);
    return (uint8_t)SPI_I2S_ReceiveData(SPI4);
赞 收藏 评论3 发布时间:2017-6-4 17:36
3个回答
Tcreat 回答时间:2017-6-4 18:40:16
亲 不要把社区当成了你们家的后院,看看你帖的代码,哪里是要请教问题的态度~
suoma 回答时间:2017-6-4 19:53:36
首先代码不全,
Aaron_0618 回答时间:2017-6-4 21:42:08
看过原文的各位抱歉....格式跑掉了
