我STM32F401RE-Nucleo 板上调试串口通讯,用CubeMX同时配置了USART1和USART2两个串口,然后用这两个串口发送数据,发现USART2不能发送数据,以下是初始化代码,请大家分析一下是什么问题?谢谢! /* USER CODE BEGIN 0 */ /* USER CODE END 0 */ UART_HandleTypeDef huart1; UART_HandleTypeDef huart2; /* USART1 init function */ void MX_USART1_UART_Init(void) { huart1.Instance = USART1; huart1.Init.BaudRate = 115200; huart1.Init.WordLength = UART_WORDLENGTH_8B; huart1.Init.StopBits = UART_STOPBITS_1; huart1.Init.Parity = UART_PARITY_NONE; huart1.Init.Mode = UART_MODE_TX_RX; huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE; huart1.Init.OverSampling = UART_OVERSAMPLING_16; if (HAL_UART_Init(&huart1) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } } /* USART2 init function */ void MX_USART2_UART_Init(void) { //HAL_UART_MspInit_self2(&huart2); huart2.Instance = USART2; huart2.Init.BaudRate = 115200; huart2.Init.WordLength = UART_WORDLENGTH_8B; huart2.Init.StopBits = UART_STOPBITS_1; huart2.Init.Parity = UART_PARITY_NONE; huart2.Init.Mode = UART_MODE_TX_RX; huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE; huart2.Init.OverSampling = UART_OVERSAMPLING_16; if (HAL_UART_Init(&huart2) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } } void HAL_UART_MspInit(UART_HandleTypeDef* uartHandle) { GPIO_InitTypeDef GPIO_InitStruct; if(uartHandle->Instance==USART1) { /* USER CODE BEGIN USART1_MspInit 0 */ /* USER CODE END USART1_MspInit 0 */ /* USART1 clock enable */ __HAL_RCC_USART1_CLK_ENABLE(); /**USART1 GPIO Configuration PA9 ------> USART1_TX PA10 ------> USART1_RX */ GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF7_USART1; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); /* USER CODE BEGIN USART1_MspInit 1 */ /* USER CODE END USART1_MspInit 1 */ } else if(uartHandle->Instance==USART2) { /* USER CODE BEGIN USART2_MspInit 0 */ /* Enable GPIO TX/RX clock */ //USARTx_TX_GPIO_CLK_ENABLE(); //USARTx_RX_GPIO_CLK_ENABLE(); /* Enable USARTx clock */ /* USER CODE END USART2_MspInit 0 */ /* USART2 clock enable */ __HAL_RCC_USART2_CLK_ENABLE(); /**USART2 GPIO Configuration PA2 ------> USART2_TX PA3 ------> USART2_RX */ //GPIO_InitStruct.Pin = USART_TX_Pin|USART_RX_Pin; GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; GPIO_InitStruct.Alternate = GPIO_AF7_USART2; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); /* USER CODE BEGIN USART2_MspInit 1 */ /* USER CODE END USART2_MspInit 1 */ } } void HAL_UART_MspDeInit(UART_HandleTypeDef* uartHandle) { if(uartHandle->Instance==USART1) { /* USER CODE BEGIN USART1_MspDeInit 0 */ /* USER CODE END USART1_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_USART1_CLK_DISABLE(); /**USART1 GPIO Configuration PA9 ------> USART1_TX PA10 ------> USART1_RX */ HAL_GPIO_DeInit(GPIOA, GPIO_PIN_9|GPIO_PIN_10); /* USER CODE BEGIN USART1_MspDeInit 1 */ /* USER CODE END USART1_MspDeInit 1 */ } else if(uartHandle->Instance==USART2) { /* USER CODE BEGIN USART2_MspDeInit 0 */ /* USER CODE END USART2_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_USART2_CLK_DISABLE(); /**USART2 GPIO Configuration PA2 ------> USART2_TX PA3 ------> USART2_RX */ //HAL_GPIO_DeInit(GPIOA, USART_TX_Pin|USART_RX_Pin); HAL_GPIO_DeInit(GPIOA, GPIO_PIN_2|GPIO_PIN_3); /* USER CODE BEGIN USART2_MspDeInit 1 */ /* USER CODE END USART2_MspDeInit 1 */ } } /* USER CODE BEGIN 1 */ |
STM32F107+LWIP---如何检查tcp通讯断开?并重新连接
有没有用过数字式mems麦克风的,想问下SPI通讯的问题
stm32f103 CAN通讯多帧发送问题?
STM32F107作为USB主机模拟串口通讯不成功(采用PL2303芯片)
STM32F103C8 LIN通讯例程
求助,丐版J-Link通讯不上
ethernet可以与ethercat通讯吗?
STM32F373 CAN通讯问题CAN_FLAG_LEC
请教高手看看,STM32F1的多机通讯,地址匹配唤醒问题
CAN总线:如何利用程序(STM32)判断CAN总线的波特率/通讯协议?
