STM32F0 WINDOW WATCHDOG EWI PROBLEM
hellonsn 提问时间:2018-7-24 16:23 /
WWDG HAS an EWI (early wakeup interrupt) that we can use ? the question is can we refresh the downcounter in the EWI interrupt handler function to avoid system reset ??
I tried to do it ,but seems it doesn't work , and after the interrupt , the WWDG triggerred a system reset even the downcounter has been refreshed in the interrtupt handler.
So could anyone give some advice on that situation?? thanks a lot.
收藏 1 评论3 发布时间:2018-7-24 16:23
3个回答
奏奏奏 回答时间:2018-7-24 18:01:29
Use a timer to feed.
hellonsn 回答时间:2018-7-25 09:10:12
That is from the user mannual:
In some applications, the EWI interrupt can be used to manage a software system check
and/or system recovery/graceful degradation, without generating a WWDG reset. In this
case, the corresponding interrupt service routine (ISR) should reload the WWDG counter to avoid the WWDG reset, then trigger the required actions.
But I tried to reload the counter in ISR , but a system reset happened after the interrupt.
奏奏奏 回答时间:2018-7-25 09:23:22
In some applications, the EWI interrupt can be used to manage a so ...
You can upload your project.
Then we can know what your problem is.
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
