STM32F070选择内部时钟后外部上电复位有时点亮不了灯求助
lmz11223380 提问时间:2019-7-25 08:39 /
STM32F070F6P6选择内部时钟后,外部上电复位,有时点亮不了灯(外部晶振拆了);(20次有1到2次会出现)使用外部晶振是没有问题的。
配置信息如下:
static void SetSysClock(void)
  __IO uint32_t StartUpCounter = 0, HSIStatus = 0;
  /* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/
/* Enable HSI*/ //使能内部时钟
  RCC->CR |= ((uint32_t)RCC_CR_HSION;
  /* Wait till HSI is ready and if Time out is reached exit */ //等待内部时钟起振
  do
   HSIStatus = RCC->CR & RCC_CR_HSIRDY;
    StartUpCounter++;
  } while((HSIStatus== 0) && (StartUpCounter != HSI_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSIRDY) != RESET)
  HSIStatus = (uint32_t)0x01;
  else
  HSIStatus = (uint32_t)0x00;
  if (HSIStatus == (uint32_t)0x01)
/* Enable Prefetch Buffer and set Flash Latency */ //flash总线时钟使能
    FLASH->ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
/* HCLK = SYSCLK *///外设AHB总线时钟等于系统时钟
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
/* PCLK = HCLK *///外设APB总线时钟等于系统时钟
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1;
   /* PLL configuration = HSI/2 * 12= 48 MHz */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSI_Div2 | RCC_CFGR_PLLMULL12); //RC时钟2分频后 进行12倍频</font>
/* Enable PLL *///使能锁相环倍频开关
    RCC->CR |= RCC_CR_PLLON;
/* Wait till PLL is ready *///等待锁相环就绪
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
/* Select PLL as system clock source *///选择锁相环输出时钟作为系统时钟
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
/* Wait till PLL is used as system clock source *///等待锁相环输出时钟已经成为系统时钟
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
  else
  { /* If HSI fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
有板子的朋友也可以下载HEX试试,PA10上电灯会亮。
STM32F070.zip
24.42 KB, 下载次数: 5, 下载积分: ST金币 -1
收藏 1 评论3 发布时间:2019-7-25 08:39
3个回答
ikxlf 回答时间:2019-7-26 10:17:15
似乎没有看到你对PA10管脚的配置,程序没有配置有时候亮也正常,硬件导致的比如电容充放电引起的或者是其它的原因,建议你加上PA10的控制代码,比如你就初始化灭,你再试试复位看会不会亮,如果在亮你先查程序有问题没,如果没问题 肯定就是你硬件有问题
ikxlf 回答时间:2019-7-26 10:17:59
还有就是你的代码背景一抹黑,基本看不清
lmz11223380 回答时间:2019-7-26 13:02:34
斯文人 发表于 2019-7-26 10:17
似乎没有看到你对PA10管脚的配置,程序没有配置有时候亮也正常,硬件导致的比如电容充放电引起的或者是其它 ...
是有控制代码的,只是时钟配置,基本配置还是有的
配置信息如下:
  do
    StartUpCounter++;
  else
  else
参与人数 1蝴蝶豆 +3 收起 理由
STMCU + 3
