我准备在官方的STM32L476+ST253993增加freertos,但是代码下进去系统运行时就卡住,单步调试,系统一直卡在prvCheckTasksWaitingTermination中。rtos使用systick,HAL_delay使用TIM7 freertos的两个任务,一个是LED闪烁,一个是RFID测试程序 第一次执行时,任务2的第一个测试代码完成后,到osdelay里就出不来了
RFID测试程序中发送只要屏蔽一行代码,系统就可以正常运行 基本可以判定是下面的代码跟osdelay发生了什么冲突,导致系统死在prvCheckTasksWaitingTermination函数中
继续屏蔽代码查找到冲突代码,下面的红线
到这就无法继续查找原因了,
继续屏蔽代码,发现HAL_SPI_TransmitReceive系统SPI函数这出现的问题
可,这个系统HAL函数跟osdelay由啥关系呢,两者不应该冲突啊?? 附上系统SPI函数 ************************************ HAL_StatusTypeDef HAL_SPI_TransmitReceive(SPI_HandleTypeDef *hspi, uint8_t *pTxData, uint8_t *pRxData, uint16_t Size, uint32_t Timeout) { uint16_t initial_TxXferCount; uint32_t tmp_mode; HAL_SPI_StateTypeDef tmp_state; uint32_t tickstart; /* Variable used to alternate Rx and Tx during transfer */ uint32_t txallowed = 1U; HAL_StatusTypeDef errorcode = HAL_OK; /* Check Direction parameter */ assert_param(IS_SPI_DIRECTION_2LINES(hspi->Init.Direction)); /* Process Locked */ __HAL_LOCK(hspi); /* Init tickstart for timeout management*/ tickstart = HAL_GetTick(); /* Init temporary variables */ tmp_state = hspi->State; tmp_mode = hspi->Init.Mode; initial_TxXferCount = Size; if (!((tmp_state == HAL_SPI_STATE_READY) || \ ((tmp_mode == SPI_MODE_MASTER) && (hspi->Init.Direction == SPI_DIRECTION_2LINES) && (tmp_state == HAL_SPI_STATE_BUSY_RX)))) { errorcode = HAL_BUSY; goto error; } if ((pTxData == NULL) || (pRxData == NULL) || (Size == 0U)) { errorcode = HAL_ERROR; goto error; } /* Don't overwrite in case of HAL_SPI_STATE_BUSY_RX */ if (hspi->State != HAL_SPI_STATE_BUSY_RX) { hspi->State = HAL_SPI_STATE_BUSY_TX_RX; } /* Set the transaction information */ hspi->ErrorCode = HAL_SPI_ERROR_NONE; hspi->pRxBuffPtr = (uint8_t *)pRxData; hspi->RxXferCount = Size; hspi->RxXferSize = Size; hspi->pTxBuffPtr = (uint8_t *)pTxData; hspi->TxXferCount = Size; hspi->TxXferSize = Size; /*Init field not used in handle to zero */ hspi->RxISR = NULL; hspi->TxISR = NULL; #if (USE_SPI_CRC != 0U) /* Reset CRC Calculation */ if (hspi->Init.CRCCalculation == SPI_CRCCALCULATION_ENABLE) { SPI_RESET_CRC(hspi); } #endif /* USE_SPI_CRC */ /* Check if the SPI is already enabled */ if ((hspi->Instance->CR1 & SPI_CR1_SPE) != SPI_CR1_SPE) { /* Enable SPI peripheral */ __HAL_SPI_ENABLE(hspi); } /* Transmit and Receive data in 16 Bit mode */ if (hspi->Init.DataSize == SPI_DATASIZE_16BIT) { if ((hspi->Init.Mode == SPI_MODE_SLAVE) || (initial_TxXferCount == 0x01U)) { hspi->Instance->DR = *((uint16_t *)hspi->pTxBuffPtr); hspi->pTxBuffPtr += sizeof(uint16_t); hspi->TxXferCount--; } while ((hspi->TxXferCount > 0U) || (hspi->RxXferCount > 0U)) { /* Check TXE flag */ if ((__HAL_SPI_GET_FLAG(hspi, SPI_FLAG_TXE)) && (hspi->TxXferCount > 0U) && (txallowed == 1U)) { hspi->Instance->DR = *((uint16_t *)hspi->pTxBuffPtr); hspi->pTxBuffPtr += sizeof(uint16_t); hspi->TxXferCount--; /* Next Data is a reception (Rx). Tx not allowed */ txallowed = 0U; #if (USE_SPI_CRC != 0U) /* Enable CRC Transmission */ if ((hspi->TxXferCount == 0U) && (hspi->Init.CRCCalculation == SPI_CRCCALCULATION_ENABLE)) { SET_BIT(hspi->Instance->CR1, SPI_CR1_CRCNEXT); } #endif /* USE_SPI_CRC */ } /* Check RXNE flag */ if ((__HAL_SPI_GET_FLAG(hspi, SPI_FLAG_RXNE)) && (hspi->RxXferCount > 0U)) { *((uint16_t *)hspi->pRxBuffPtr) = (uint16_t)hspi->Instance->DR; hspi->pRxBuffPtr += sizeof(uint16_t); hspi->RxXferCount--; /* Next Data is a Transmission (Tx). Tx is allowed */ txallowed = 1U; } if (((HAL_GetTick() - tickstart) >= Timeout) && (Timeout != HAL_MAX_DELAY)) { errorcode = HAL_TIMEOUT; goto error; } } } /* Transmit and Receive data in 8 Bit mode */ else { if ((hspi->Init.Mode == SPI_MODE_SLAVE) || (initial_TxXferCount == 0x01U)) { *((__IO uint8_t *)&hspi->Instance->DR) = (*hspi->pTxBuffPtr); hspi->pTxBuffPtr += sizeof(uint8_t); hspi->TxXferCount--; } while ((hspi->TxXferCount > 0U) || (hspi->RxXferCount > 0U)) { /* Check TXE flag */ if ((__HAL_SPI_GET_FLAG(hspi, SPI_FLAG_TXE)) && (hspi->TxXferCount > 0U) && (txallowed == 1U)) { *(__IO uint8_t *)&hspi->Instance->DR = (*hspi->pTxBuffPtr); hspi->pTxBuffPtr++; hspi->TxXferCount--; /* Next Data is a reception (Rx). Tx not allowed */ txallowed = 0U; #if (USE_SPI_CRC != 0U) /* Enable CRC Transmission */ if ((hspi->TxXferCount == 0U) && (hspi->Init.CRCCalculation == SPI_CRCCALCULATION_ENABLE)) { SET_BIT(hspi->Instance->CR1, SPI_CR1_CRCNEXT); } #endif /* USE_SPI_CRC */ } /* Wait until RXNE flag is reset */ if ((__HAL_SPI_GET_FLAG(hspi, SPI_FLAG_RXNE)) && (hspi->RxXferCount > 0U)) { (*(uint8_t *)hspi->pRxBuffPtr) = hspi->Instance->DR; hspi->pRxBuffPtr++; hspi->RxXferCount--; /* Next Data is a Transmission (Tx). Tx is allowed */ txallowed = 1U; } if ((((HAL_GetTick() - tickstart) >= Timeout) && ((Timeout != HAL_MAX_DELAY))) || (Timeout == 0U)) { errorcode = HAL_TIMEOUT; goto error; } } } #if (USE_SPI_CRC != 0U) /* Read CRC from DR to close CRC calculation process */ if (hspi->Init.CRCCalculation == SPI_CRCCALCULATION_ENABLE) { /* Wait until TXE flag */ if (SPI_WaitFlagStateUntilTimeout(hspi, SPI_FLAG_RXNE, SET, Timeout, tickstart) != HAL_OK) { /* Error on the CRC reception */ SET_BIT(hspi->ErrorCode, HAL_SPI_ERROR_CRC); errorcode = HAL_TIMEOUT; goto error; } /* Read CRC */ READ_REG(hspi->Instance->DR); } /* Check if CRC error occurred */ if (__HAL_SPI_GET_FLAG(hspi, SPI_FLAG_CRCERR)) { SET_BIT(hspi->ErrorCode, HAL_SPI_ERROR_CRC); /* Clear CRC Flag */ __HAL_SPI_CLEAR_CRCERRFLAG(hspi); errorcode = HAL_ERROR; } #endif /* USE_SPI_CRC */ /* Check the end of the transaction */ if (SPI_EndRxTxTransaction(hspi, Timeout, tickstart) != HAL_OK) { errorcode = HAL_ERROR; hspi->ErrorCode = HAL_SPI_ERROR_FLAG; goto error; } /* Clear overrun flag in 2 Lines communication mode because received is not read */ if (hspi->Init.Direction == SPI_DIRECTION_2LINES) { __HAL_SPI_CLEAR_OVRFLAG(hspi); } error : hspi->State = HAL_SPI_STATE_READY; __HAL_UNLOCK(hspi); return errorcode; } ************************************ 新人求助,求助,解惑,谢谢(小弟金币较少,见谅) |
FATFS 分区最大文件数量是多少
串口DMA收发出现ORE错误
请问各位一下stm32L431rct6这款芯片,官方有没有停产?
Discover Endless Word Challenges With Wordle Unlimited Every Day
STM32L496ZG 通过串口驱动 SIM7022 NB-IoT 模组无法注册网络
将 TIM2 用作 TIM5、TIM1 和 TIM8 的时序控制器
Pokerogue: A Browser-Based Roguelike Pokémon Game That Hooks You
STM32U5系列上电时序
STM32L476项目运行提示没有crypto.h
STM32生产产地和版本
时钟么有冲突,一个是sistick 一个是TIM7
问题现在解决了,重写了原来ST25RU3993_EVEL提供的源码里面写SPI部分的代码问题已经解决
