STM32F103RCT6的UART5能收不能发
歹徒兄弟 提问时间:2020-7-24 11:50 /
最近有项目需要用到STM32F103RCT6的USART1,UART4,UART5。其中USART1和UART4采用DMA方式收发且都能正常工作,唯独这个UART5死活就是能收不能发。而更诡异的是总共焊了5块样板,相同的烧录文件其中有2块UART5可以正常收发另外3块UART5能收不能发。进一步查找原因发现将2块正常的样板和3块不正常的样板交换单片机IC后,发现问题出在单片机IC上,2台正常的样板现在不正常了,而换了IC的2块原来异常的板也正常了。
以下是我的初始化源代码:
  1. void UART45_Init(void)
  2. {
  3.         //GPIO端口设置
  4.         GPIO_InitTypeDef GPIO_InitStructure;
  5.         USART_InitTypeDef USART_InitStructure;
  6.         DMA_InitTypeDef DMA_InitStructure;
  7.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
  8.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4|RCC_APB1Periph_UART5, ENABLE);
  9.         USART_DeInit(UART4);
  10.          //UART45_TX
  11.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_12;
  12.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  13.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  14.     GPIO_Init(GPIOC, &GPIO_InitStructure);
  15.     //UART4_RX
  16.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  17.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  18.     GPIO_Init(GPIOC, &GPIO_InitStructure);
  19.     //UART5_RX
  20.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  21.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  22.         GPIO_Init(GPIOD, &GPIO_InitStructure);
  23.    //USART 初始化设置
  24.         USART_InitStructure.USART_BaudRate = 9600;
  25.         USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  26.         USART_InitStructure.USART_StopBits = USART_StopBits_1;
  27.         USART_InitStructure.USART_Parity = USART_Parity_No;
  28.         USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  29.         USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  30.     USART_Init(UART4, &USART_InitStructure);
  31.     USART_Init(UART5, &USART_InitStructure);
  32.     USART_ITConfig(UART4, USART_IT_IDLE, ENABLE);
  33.     USART_ITConfig(UART5, USART_IT_IDLE, ENABLE);
  34.     USART_ITConfig(UART5, USART_IT_RXNE, ENABLE);
  35.     USART_Cmd(UART4, ENABLE);
  36.     USART_Cmd(UART5, ENABLE);
  37.         DMA_DeInit(DMA2_Channel3);
  38.         DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&UART4->DR;
  39.         DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)(u4rxd_array);
  40.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  41.         DMA_InitStructure.DMA_BufferSize = sizeof(u4rxd_array);
  42.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  43.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  44.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  45.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  46.         DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  47.         DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
  48.         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  49.         DMA_Init(DMA2_Channel3, &DMA_InitStructure);
  50.         DMA_ITConfig(DMA2_Channel3, DMA_IT_TC, ENABLE);
  51.         USART_DMACmd(UART4, USART_DMAReq_Rx, ENABLE);
  52.         DMA_Cmd (DMA2_Channel3,ENABLE);
  53.     DMA_DeInit(DMA2_Channel5);
  54.         DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&UART4->DR;
  55.         DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)(u4txd_array);
  56.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  57.         DMA_InitStructure.DMA_BufferSize = 0;
  58.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  59.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  60.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  61.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  62.         DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  63.         DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
  64.         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  65.         DMA_Init(DMA2_Channel5, &DMA_InitStructure);
  66.         DMA_ITConfig(DMA2_Channel5, DMA_IT_TC, DISABLE);
  67.         USART_DMACmd(UART4, USART_DMAReq_Tx, ENABLE);
  68.         DMA_Cmd (DMA2_Channel5,DISABLE);
  69. }
debug发现不正常的样板向UART5->DR写数据其值不会发生变化,请高人指点一下@香水城
收藏 评论4 发布时间:2020-7-24 11:50
4个回答
butterflyspring 回答时间:2020-8-6 17:44:07
这就奇怪了,既然部分产品可以,说明软件大体上没问题。最好单独测试串口5,先测试IO引脚是否输出,确定硬件连接通过,再用单独测试串口5 的软件,保证配置寄存器内容正确
废鱼 回答时间:2020-8-7 08:55:07
uar5是直接连接到串口吗?还是过了232这类芯片。建议检测IO波形,如果波形正常,说明是后面的电路的问题,再一步一步的排查,可能是电平转换芯片那边有虚焊或者漏焊的。
Tcreat 回答时间:2020-8-7 13:23:03
话说会不是买到炸弹货了  有的芯片好 有的芯片坏的
歹徒兄弟 回答时间:2020-8-18 08:30:51
没办法最后还是放弃了UART5改用USART3就没有问题了
关于意法半导体
创新和工艺
招聘信息
