小白求助STM32L476 将端口设为模拟输入后无法进入stop2模式
祥福 提问时间:2020-10-21 17:22 /
参考了STM32L476官方例程 在进入stop2模式前 将所有端口设置为模拟输入
  1. GPIO_InitTypeDef GPIO_InitStruct;
  2.     __HAL_RCC_GPIOA_CLK_ENABLE();
  3.     __HAL_RCC_GPIOB_CLK_ENABLE();
  4.     __HAL_RCC_GPIOC_CLK_ENABLE();
  5.     __HAL_RCC_GPIOD_CLK_ENABLE();
  6.     __HAL_RCC_GPIOE_CLK_ENABLE();
  7.     __HAL_RCC_GPIOF_CLK_ENABLE();
  8.     __HAL_RCC_GPIOG_CLK_ENABLE();
  9.     __HAL_RCC_GPIOH_CLK_ENABLE();
  10.     GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
  11.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  12.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  13.     GPIO_InitStruct.Pin = GPIO_PIN_All;
  14.     HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  15.     HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  16.     HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  17.     HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  18.     HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  19.     HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
  20.     HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
  21.     HAL_GPIO_Init(GPIOH, &GPIO_InitStruct);
  22.     __HAL_RCC_GPIOA_CLK_DISABLE();
  23.     __HAL_RCC_GPIOB_CLK_DISABLE();
  24.     __HAL_RCC_GPIOC_CLK_DISABLE();
  25.     __HAL_RCC_GPIOD_CLK_DISABLE();
  26.     __HAL_RCC_GPIOE_CLK_DISABLE();
  27.     __HAL_RCC_GPIOF_CLK_DISABLE();
  28.     __HAL_RCC_GPIOG_CLK_DISABLE();
  29.     __HAL_RCC_GPIOH_CLK_DISABLE();
发现单片机无法进入stop2,将这段程序删除在cubemx将空闲引脚设为低功耗模式,可以正常进入低功耗和唤醒,但是待机时的电流很大有400多微安,求各位大佬帮帮忙,看一下是那个地方出了问题。
收藏 评论13 发布时间:2020-10-21 17:22
13个回答
祥福 回答时间:2020-10-21 17:27:38
  1. int main(void)
  2. {
  3.   HAL_Init();
  4.   SystemClock_Config();
  5.   MX_RTC_Init();
  6.   while (1)
  7.   {
  8.   if(WakeUpState==1){
  9.     HAL_StatusTypeDef HAL_ADCEx_EnterADCDeepPowerDownMode(ADC_HandleTypeDef *hadc);// adc进入deeppowerdown模式
  10.     HAL_StatusTypeDef HAL_ADCEx_DisableVoltageRegulator(ADC_HandleTypeDef *hadc);
  11.                 NRF24L01_LowPower_Mode(); //nrf24l01进入standby1
  12.                 HAL_TIM_Base_Stop_IT(&htim2);//关闭定时器
  13.                 HAL_TIM_Base_Stop_IT(&htim8);
  14.                 HAL_TIM_Base_Stop_IT(&htim2);
  15.                 HAL_TIM_Base_Stop_IT(&htim8);
  16.                 WakeUpState=0;
  17.     }
  18.          HAL_RTCEx_DeactivateWakeUpTimer(&RTCHandle);//清除RTC计时器
  19.         __HAL_RCC_GPIOA_CLK_ENABLE();//端口设为模拟输入
  20.     __HAL_RCC_GPIOB_CLK_ENABLE();
  21.     __HAL_RCC_GPIOC_CLK_ENABLE();
  22.     __HAL_RCC_GPIOD_CLK_ENABLE();
  23.     __HAL_RCC_GPIOE_CLK_ENABLE();
  24.     __HAL_RCC_GPIOF_CLK_ENABLE();
  25.     __HAL_RCC_GPIOG_CLK_ENABLE();
  26.     __HAL_RCC_GPIOH_CLK_ENABLE();
  27.     GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
  28.     GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  29.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  30.     GPIO_InitStruct.Pin = GPIO_PIN_All;
  31.     HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  32.     HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  33.     HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  34.     HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  35.     HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  36.     HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
  37.     HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
  38.     HAL_GPIO_Init(GPIOH, &GPIO_InitStruct);
  39.     __HAL_RCC_GPIOA_CLK_DISABLE();
  40.     __HAL_RCC_GPIOB_CLK_DISABLE();
  41.     __HAL_RCC_GPIOC_CLK_DISABLE();
  42.     __HAL_RCC_GPIOD_CLK_DISABLE();
  43.     __HAL_RCC_GPIOE_CLK_DISABLE();
  44.     __HAL_RCC_GPIOF_CLK_DISABLE();
  45.     __HAL_RCC_GPIOG_CLK_DISABLE();
  46.     __HAL_RCC_GPIOH_CLK_DISABLE();
  47.          HAL_RTCEx_SetWakeUpTimer_IT(&RTCHandle, 10000, RTC_WAKEUPCLOCK_RTCCLK_DIV16);//中断
  48.          HAL_PWREx_EnterSTOP2Mode(PWR_STOPENTRY_WFI);//进入休眠
  49.    SystemClock_Config();//唤醒后
  50.          MX_GPIO_Init();//初始化
  51.          MX_DMA_Init();
  52.          MX_ADC1_Init();
  53.          MX_ADC2_Init();
  54.          MX_SPI2_Init();
  55.          MX_TIM2_Init();
  56.          MX_TIM8_Init();
  57.         adc_complete = 0;
  58.    while(NRF24L01_Check());
  59.          HAL_TIM_PWM_Start(&htim2,TIM_CHANNEL_4);     // 产生脉冲波
  60.          HAL_ADC_Start(&hadc2); //启动定时器2
  61.          HAL_ADCEx_Calibration_Start(&hadc1, ADC_SINGLE_ENDED);  // 对ADC进行校准,如果没有进行校准采集到的数据会有偏差
  62.    HAL_ADCEx_Calibration_Start(&hadc2, ADC_SINGLE_ENDED);
  63.          HAL_ADCEx_MultiModeStart_DMA(&hadc1, (uint32_t*)&ADC_Value,2048);  //ADC同步采样
  64.          HAL_ADCEx_MultiModeStart_DMA(&hadc2, (uint32_t*)&ADC_Value, 2048);
  65.          while(adc_complete == 0){HAL_Delay(5);}
  66.          HAL_ADCEx_Calibration_Start(&hadc1, ADC_SINGLE_ENDED);  // 对ADC进行校准,如果没有进行校准采集到的数据会有偏差
  67.    HAL_ADCEx_Calibration_Start(&hadc2, ADC_SINGLE_ENDED);
  68.   }
  69. }
祥福 回答时间:2020-10-21 17:29:20
主函数已经上传
祥福 回答时间:2020-10-21 19:12:10
有没有大佬帮帮忙
祥福 回答时间:2020-10-21 19:17:27
另外各位能否告诉我如何关闭DMA和ADC
祥福 回答时间:2020-10-21 20:22:38
有人吗
小歆-2051663 回答时间:2020-10-23 10:33:24
你不要关闭GPIO时钟试一下
小歆-2051663 回答时间:2020-10-23 10:42:47
HAL库有专门停止ADC和DMA采样的函数:
  1. HAL_StatusTypeDef HAL_ADC_Stop_DMA(ADC_HandleTypeDef* hadc)
以及关闭ADC外设的函数:
  1. HAL_StatusTypeDef HAL_ADC_DeInit(ADC_HandleTypeDef* hadc)
祥福 回答时间:2020-10-25 14:19:26
谢谢大佬 我试了一下关闭adc和dma的函数 电流从400微安降低到了100微安随后又变成了2微安,但是我初始化adc的方式可能不对导致 adc测得的数值存在问题 请问重新开启adc应该用哪个函数
小歆-2051663 回答时间:2020-10-26 09:29:21
lowpowerstudy 发表于 2020-10-25 14:19
谢谢大佬 我试了一下关闭adc和dma的函数 电流从400微安降低到了100微安随后又变成了2微安,但是我初始化ad ...
重新开启ADC相当于你再次初始化你的ADC,如果你是用CubeMX生成的代码,应该在main函数中有一个MX_ADC_Init调用的,再次调用MX_ADC_Init即可重启你的ADC。
祥福 回答时间:2020-10-26 11:02:59
小歆-2051663 发表于 2020-10-26 09:29
重新开启ADC相当于你再次初始化你的ADC,如果你是用CubeMX生成的代码,应该在main函数中有一个MX_ADC_Ini ...
谢谢大佬 我发现是台式万用表接入单片机后 导致单片机ADC示数不准 ,现在已经调整了,但是发现待机时候的电流从400微安降到280微安,我是否还应该关闭 SPI 和定时器 继续降低功耗
祥福 回答时间:2020-10-26 11:22:40
进入stop2前的函数如下
  1. if(WakeUpState==1)
  2.                 {
  3.                 NRF24L01_LowPower_Mode();
  6.                 HAL_TIM_Base_Stop_IT(&htim2);
  7.                 HAL_TIM_Base_Stop_IT(&htim8);
  8.                 WakeUpState=0;
  9.                 HAL_StatusTypeDef HAL_ADC_DeInit(ADC_HandleTypeDef* hadc);
  10.                 HAL_StatusTypeDef HAL_ADC_Stop_DMA(ADC_HandleTypeDef* hadc);
  11.     __HAL_SPI_DISABLE_IT(&hspi2, SPI_IT_RXNE);
  12. }
然后唤醒后初始化的函数如下
  1. SystemClock_Config();
  2.   MX_GPIO_Init();
  3.   MX_DMA_Init();
  4.   MX_ADC1_Init();
  5.   MX_ADC2_Init();
  6.   MX_SPI2_Init();
  7.   MX_TIM2_Init();
  8.   MX_TIM8_Init();
gpio我没有关断,因为在cubemx里面已经设置了空闲引脚为模拟输入 想问一下还有哪个部分可以继续降低功耗 谢谢大佬
小歆-2051663 回答时间:2020-10-26 11:33:26
lowpowerstudy 发表于 2020-10-26 11:02
谢谢大佬 我发现是台式万用表接入单片机后 导致单片机ADC示数不准 ,现在已经调整了,但是发现待机时候的 ...
这个要根据你的项目情况,关闭不需要外设。
祥福 回答时间:2020-10-26 16:20:22
大佬您好 我按照您说的将所有的GPIO端口关闭了,功耗的确降下来了
但是发现ADC测量不准了 这个应该如何调整唤醒后的操作为
  1. HAL_RTCEx_DeactivateWakeUpTimer(&RTCHandle);//清除RTC计时器
  2.         HAL_RTCEx_SetWakeUpTimer_IT(&RTCHandle, 10000, RTC_WAKEUPCLOCK_RTCCLK_DIV16);
  3.         HAL_PWREx_EnterSTOP2Mode(PWR_STOPENTRY_WFI);
  5.         MX_GPIO_Init();
  6.   MX_DMA_Init();
  7.   MX_ADC1_Init();
  8.   MX_ADC2_Init();
  9.   MX_SPI2_Init();
  10.   MX_TIM2_Init();
  11.         MX_TIM8_Init();
也按照cubemx的初始化了GPIO
