【经验分享】SPI读写函数寄存器版本(STM32F1xx,STM32F7xx实测完美)
STMCU小助手 发布时间:2021-12-11 12:00
  1. void SPI_ReadWriteByte(SPI_TypeDef *spi,unsigned char *pTxData, unsigned char  *pRxData, unsigned short  Size)//寄存器版本* C1 I- N1 M0 m% e/ O6 }+ a* R
  2. {        : o7 a/ X# t: \$ x# q
  3.         volatile unsigned char tmpreg;. @. c# ?- Q- g6 z
  4.         unsigned short TxXferCount,RxXferCount;) t- e) \3 S( w
  5.         unsigned char *pRxBuffPtr  = pRxData;
    4 w. i) Z- u& g, f
  6.         unsigned char *pTxBuffPtr  = pTxData;
    $ V$ Q$ A! B1 E4 z
  7.         unsigned char txallowed = 1U;
    6 K# ~# M$ j# A1 P. `0 k# o
  8.         unsigned int timeout=SPI_COMM_TIMEOUT;
      o: W6 y4 c3 u6 U& _7 x6 b6 L) U) F
  9.         __IO unsigned int tmpreg_ovr = 0x00U;
    $ w1 I2 n2 I1 u6 J; Y/ @
  10.         TxXferCount=RxXferCount=Size;
    3 C- b- ^. J& H. q4 W
  11. 5 a4 n5 I" a1 Q/ Q
  12.         //如果 FIFO 占用水平大于或等于 1/4(8 位),将生成 RXNE 事件0 u' q+ X  x/ c$ R
  13.         SET_BIT(spi->CR2, SPI_RXFIFO_THRESHOLD);+ e- z4 U# i" B  n( P- g& A
  14. # t$ H6 L4 U' D  q9 ]: f" a* P
  15.         while((TxXferCount > 0) || (RxXferCount > 0))0 C2 ]8 P# L) b. Y
  16.         {
    ) T" x* ]# Y& U1 x6 ^' _
  17.               // check TXE flag 3 p; l( {0 F& s0 F% z
  18.               if(txallowed && ((TxXferCount > 0) && ((spi->SR & SPI_FLAG_TXE) == SPI_FLAG_TXE)))
    # a5 x/ D& o$ _
  19.               {
      ^6 O, ^2 p  c3 j7 ^
  20.                         *(__IO unsigned char *)&spi->DR = (*pTxBuffPtr++);
    ; D, v/ |% v# B6 Y
  21.                         TxXferCount--;3 k( D6 a& u$ p' W# f+ I, Q
  22.   o1 V# K9 a2 J. v
  23.                         // Next Data is a reception (Rx). Tx not allowed
    4 T5 q4 Q  ^# ]( u7 H/ P
  24.                         if(TxXferCount==0); k4 a! L! J4 D. ]7 d  X/ g
  25.                                 txallowed = 0U;
      K: L5 G4 W, B, k. q* x
  26.               }2 E* B( X3 f2 c! |, F
  27. 6 h4 |: P* o, ?
  28.               /* Wait until RXNE flag is reset */
    1 A, v- x8 L( x$ u
  29.               if((RxXferCount > 0) && ((spi->SR & SPI_FLAG_RXNE) == SPI_FLAG_RXNE))6 J3 q5 Z/ d7 @; G
  30.               {# ^# E( W$ D! r# p; S: O6 H& H& _
  31.                         //改为1个字节接收,两个字节接收有的芯片会出问题
    ) u* K; k- F  _  F4 p, x
  32.                         (*pRxBuffPtr++) =  *(__IO unsigned char *)&spi->DR;) w& m1 _0 M/ p& `
  33.                         RxXferCount--;
    ! ^5 j+ D  }# N  @1 J, L( @+ n' ^
  34.                                 2 t+ T3 k" m+ [& T2 D
  35.                         if(RxXferCount <= 1)) ?: N& l% |* [4 P- D. B7 Z( U5 E' i
  36.                           {/ ?* p& y9 q7 ?* W% c& |
  37.                                     //如果 FIFO 占用水平大于或等于 1/4(8 位),将生成 RXNE 事件$ o2 H3 r0 e. B  @: \; c- c/ O
  38.                                     SET_BIT(spi->CR2, SPI_RXFIFO_THRESHOLD);5 H# E8 O) ]3 l* C# s( {' G
  39.                           }
    + A5 I$ S8 _$ q1 J# D
  40.                                   //Next Data is a Transmission (Tx). Tx is allowed
    ) U5 D9 v6 D( H0 E1 R0 N4 o
  41.                        if(RxXferCount==0)           0 W, P) D8 F8 W& J6 j
  42.                                   txallowed = 1U;
    ) q* _2 t) A, G9 D" k5 w9 H( F
  43.               } 8 X9 {& f$ o8 B! P
  44. % d8 c! r  q& \0 ]1 _; ?  v* R
  45.                 if((timeout--)==0)
    % S  c. o4 ?( ?- N- x
  46.                 {
    - H1 C6 X9 J+ Q
  47.                         if(spi==SPI1)
    # B% g5 P5 ^: U
  48.                         {
    $ Z! G! ~3 X1 `. t# l
  49.                                 SetBit(&STS,1,para.Alarm_Disable);//存储模块通信异常
    * J2 ~% k. g( z' g0 S* E4 V" j4 a' k* L3 H
  50.                                 break;( X2 v3 }2 z' j, h5 B! q
  51.                         }
    ) t! ~1 H+ T9 [2 R3 p! s
  52.                         else if(spi==SPI2)
    . K( f9 w# ]/ I" Y+ V% \9 }& _  a
  53.                         {        1 r5 M3 \! v# R/ n3 Q
  54.                                 SetBit(&STS,26,para.Alarm_Disable);//WK2124通信异常                $ T% V% ^' y! v, n% I4 A/ w: ^
  55.                                 break;1 \) T9 o7 v- t5 T
  56.                         }8 i/ v8 a, \0 _+ }3 i
  57.                         else
    & \; @! B* f& F6 {% W6 W; e/ Z
  58.                                 break;
    2 a3 o) _! B6 l/ ?
  59.                 }
    " n4 [4 F+ W& {2 C* N! M
  60.         }
    8 ~3 k4 R3 Y9 Z( K) n
  61. - `+ d8 r! \  S2 g  I+ u+ y5 {3 n
  62. * \+ S$ V$ a0 }, V' J* t% @& }$ r
  63. //带有32位收发缓冲区的MCU需添加,否则屏蔽///. q/ i/ A; M8 K8 i. a% a! b) k
  64.         timeout=SPI_COMM_TIMEOUT;: `0 Y) q9 E0 \
  65.         // Check the end of the transaction 2 ?. P' ^) f: K, y' k
  66.         while((spi->SR & SPI_FLAG_FTLVL) != SPI_FTLVL_EMPTY); G3 }! _8 o& \0 n! d8 d8 o. ?
  67.         {//发送FIFO非空时
    9 U& c0 R8 y0 P% x7 ?! L4 q. C
  68.                 if((SPI_FLAG_FTLVL == SPI_SR_FRLVL) && (SPI_FTLVL_EMPTY == SPI_FRLVL_EMPTY))
    & C, M# }" d9 h' m3 i8 f6 s' N
  69.                 {
    / d3 a! u& }3 D# t; Z& Z
  70.                           tmpreg = *((__IO unsigned char*)&spi->DR);
    8 }2 z$ ], D+ P& ?# v
  71.                 }: M# n/ G( d, [/ ]8 z
  72.
    5 M$ {4 C/ \  N/ B
  73.                 if((timeout--)==0)2 Q4 e0 G  ^0 E2 O% u1 W/ j
  74.                 {
    7 A5 z3 A2 f! [) E3 q5 y* P
  75.                         if(spi==SPI1)) Z) I) U8 A9 ~! [8 A
  76.                         {        $ I) {( B' L* c
  77.                                 SetBit(&STS,1,para.Alarm_Disable);//存储模块通信异常
    ( l0 Y- m9 Q" K/ `3 |
  78.                                 break;
    7 Z& A& ?* A/ C# v9 ?+ M; p( y3 G* `
  79.                         }0 m# a" ^) A  z9 X
  80.                         else if(spi==SPI2)& u- R/ H& a* p# Q- r7 E
  81.                         {        * u; E: M1 P) Z4 L' \. L% S
  82.                                 SetBit(&STS,26,para.Alarm_Disable);//WK2124通信异常                # s6 S* |9 H8 o: v& z) x" Y# d
  83.                                 break;
    , ]4 u+ D. f6 r, f: W/ ~
  84.                         }
    ! {; K; V  i( A. R& }% s* n) r% }
  85.                         else
    6 _- d6 u0 Y& \2 J
  86.                                 break;4 W- G, F) @6 y5 Z, K  k% n2 L
  87.                 }
    : ]5 R# {2 a/ e
  88.         }
    ) Y& Y/ b2 D5 q3 u0 O! |; Y" u
  89. 9 t" R3 E1 z8 [) Y8 t
  90.         timeout=SPI_COMM_TIMEOUT;
    3 p2 Q2 G3 H; S& A# B- y; {
  91.         while((spi->SR & SPI_FLAG_FRLVL) != SPI_FRLVL_EMPTY). r+ `! d. g5 F; f) U4 ]
  92.         {4 [( j. W1 L, F) F" j# h2 W7 ]6 ?
  93.                 if((SPI_FLAG_FRLVL == SPI_SR_FRLVL) && (SPI_FRLVL_EMPTY == SPI_FRLVL_EMPTY))$ u- i4 k% _( j1 B
  94.                 {
    + p- P$ e$ t9 N! T2 b/ z( b
  95.                         tmpreg = *((__IO unsigned char*)&spi->DR);. ~( r# `: E, @9 ~  c2 }
  96.                 }
    & M0 R1 B4 I, h: x5 }, w8 D2 B
  97.                 if((timeout--)==0)' t% V" S3 D, ^3 M1 B
  98.                 {5 y. s. N3 M6 f: j. |0 ^% U5 q
  99.                         if(spi==SPI1)
    & O+ e6 j5 |% l0 U* K( h
  100.                         {        1 G/ N" q5 H& G7 A
  101.                                 SetBit(&STS,1,para.Alarm_Disable);//存储模块通信异常 ! m/ W8 D- M6 u% N
  102.                                 break;
    / o- z, _# H' {3 q6 _; t
  103.                         }6 o+ X; G" b, B" j  ?# B
  104.                         else if(spi==SPI2)
    1 _0 C1 r! Q+ S( v: d( _0 M
  105.                         {
    2 w0 j( Y9 |1 S, E8 k
  106.                                 SetBit(&STS,26,para.Alarm_Disable);//WK2124通信异常                ' f5 [, b- x. R- `2 s5 g: w
  107.                                 break;0 B6 N. Q3 N' b! ?  q
  108.                         }
    ' T1 x- J2 O* D: S1 ~9 j
  109.                         else) n1 v  R) S* b2 O
  110.                                 break;                        2 r' b; x! V# G# s. [8 u- d
  111.                 }
    # U. C8 {4 Q1 p# Z3 X1 M
  112.         }+ X2 L, V5 y2 D* e! Q
  113. //带有32位收发缓冲区的MCU需添加,否则屏蔽///3 w' h# _4 w: T, ~7 }, \+ u! x/ F
  114. , s" z9 e* i$ ^0 ]& X% _
  115. 1 n& Y# k$ G5 U7 ^( x6 H
  116.         timeout=SPI_COMM_TIMEOUT;8 ^3 p4 b2 u5 W; M6 [
  117.         /* Control the BSY flag */
    6 h& e0 g( o- A' q/ Z
  118.         while((spi->SR & SPI_FLAG_BSY) != RESET)9 r5 W: e! Q  ~3 J: K0 `& V
  119.         {% T/ c6 X1 M( |
  120.                 if((timeout--)==0)
    , g% l, A% r- w) X
  121.                 {
    * F8 ~) ]% e- W1 n1 T# S
  122.                         if(spi==SPI1)* D/ s9 i/ A/ }2 w: a9 R/ ?
  123.                         {
    ! E8 D$ K/ r5 {5 `1 y9 {3 _- @
  124.                                 SetBit(&STS,1,para.Alarm_Disable);//存储模块通信异常
    / k0 Z, E- \' M6 Y" m4 u3 A
  125.                                 break;
    0 I& L# `, a& O2 z2 s3 {7 [) \
  126.                         }
    0 l, c* O3 }  [- [. M* K
  127.                         else if(spi==SPI2)* o( B, p( H: A5 V; b( ]8 Q
  128.                         {        , f- X" Q, H: C/ {( X
  129.                                 SetBit(&STS,26,para.Alarm_Disable);//WK2124通信异常                % p2 A- H+ `9 [  ^/ L
  130.                                 break;
    4 p+ Z$ t: v9 O% I) p
  131.                         }
    . ~2 U& j  M; g: v: n3 X2 g' a( U
  132.                         else& |# `0 \0 X) G' C! N8 E% v
  133.                                 break;                        ; A1 C0 J( |4 O
  134.                 }
    0 \% I  j8 X. J* ]4 M5 ?1 t' }' k
  135.         }        4 U1 w2 w0 [2 W( m7 W4 u
  136. & D, j+ m3 d5 P4 L8 \* s
  137.         //Clear overrun flag in 2 Lines communication mode because received is not read    0 {& ^) `2 V# `: n/ }
  138.         tmpreg_ovr=spi->DR;/ m3 b" k+ Y9 z; W* g, T3 c# P5 A
  139.         tmpreg_ovr=spi->SR;
    * E: E+ ^  b* D) ?7 c9 v
  140. }
    & D6 |; V! h" s/ y: ]3 R4 Z! h
  141. / L* E3 M5 A( T/ q7 y
, Q5 P" G) [& S# `
赞 收藏 评论1 发布时间:2021-12-11 12:00
tianqi911 回答时间:2021-12-14 10:25:35
MARK一下 看能否看到自己的标记 方便以后查找 学习
