EC20 4G模块可以通过串口和USB去驱动,但是串口速度比较慢,所以通过USB驱动才能提高通信速率。
; S, v" j; \ T$ I/ Q( R3 {' t% a ^$ W& ?% u4 |$ A) x1 H; m
硬件连接:# g& [5 f7 {" T4 s3 N' L1 w
STM32F407:
/ L- N7 @% ~% L& f8 {& H1 m! ~2 D2 F4 n# X% b( j$ |) M
: t. T5 D/ x: t/ ~3 V
& o7 Y: o% e; kEC20模块:+ [$ N: I o1 m" q0 |; ?7 u
, q! @. u0 n' o, ]- e I; G/ i! O
! U7 }8 o! g& A0 h$ k+ F b Z
6 M2 [) p( \# j3 ~. C8 g3 K部分参考代码:/ s: J4 M3 b/ S' [# V
( V7 `. A) W; ~- j" B3 J. ~* \
: c# W7 }: B e7 @/ K t$ r6 K- /* USER CODE END Header */% D$ F- k# d, P% t. L2 H5 @+ {! S- L
- /* Includes ------------------------------------------------------------------*/" m5 u% V- |* F% g. J
- #include "main.h"
& y7 _6 }- w* { - #include "usb_host.h", V3 p7 |! X% t$ W
- #include "usbh_def.h" w, ^! I; p9 L7 J+ ?, c- a1 u
- #include "usbh_cdc.h"9 t; U' x0 I9 m8 G9 h6 _
- #include "string.h") U8 i2 R) I5 S; f: ?* L8 L: K
- 1 `+ S4 C3 N' x1 l7 l- T
- UART_HandleTypeDef huart1;
9 k6 J2 Y X9 l
- v5 N/ M [& T4 n- /* USER CODE BEGIN PV */) w4 ]; X' A% l1 v) Y) t( G
- ' f" L$ G+ m. Q z
- /* USER CODE END PV */
7 N! t# F m1 K; V0 e - 8 ^7 T/ ?' U2 m; R7 h/ L
- /* Private function prototypes -----------------------------------------------*/
& U( P, B, ?9 ^4 u( e' `- U) K - void SystemClock_Config(void);
2 `& R' ]/ l9 {, u7 n% L6 O - static void MX_GPIO_Init(void);% h1 A. c. a) X
- static void MX_USART1_UART_Init(void);
# q# V. Z, ?# j- O, M7 L$ w - void MX_USB_HOST_Process(void);
# S& P9 _0 p/ E
f. K- R) i3 u! o. L ?- 1 k! P9 ?, h, `
- unsigned char recData[100];
. i" v- _" z/ P - unsigned int recLen;
/ z# S: a5 m- R6 V. \ - 3 g$ R! E( W. m" d# k4 f
- void delay_ums(unsigned int i)( S3 U& `0 b n7 R
- {: L8 @+ a! W, d& h& E W
- unsigned int cnt;
r5 ?: k, c" Y5 V+ J, I; D - while(i--)3 s- k- G/ T) \* a- T3 p
- {; o6 X5 l- q( p2 K) v6 Z: F2 y2 i7 }
- cnt=33500;
% C% O* Q" t' Z& {3 A5 ?* J& D - while(cnt--);
; [. a% h7 N2 Y) X9 T' O" l T - }! R- }8 ] ]- I5 [! S$ v
. h3 \) w- {6 o! L$ \5 f
% k3 I. ], r3 n+ c e' H/ w- extern USBH_HandleTypeDef hUsbHostFS; $ G: ]8 y6 g" ~
- int main(void)+ R1 t9 K3 z- Q) v0 H
- {7 _8 j, Q/ G# ^
- unsigned int a;( N- y# S* Q# ~2 v2 @1 Q
- HAL_Init();
' Z: g% K( ?5 `0 h0 a4 ` - SystemClock_Config();
& p# f q* Z- U" S& | - MX_GPIO_Init();6 P6 g4 X N4 ?: v1 J
- MX_USART1_UART_Init(); D. L. _/ I8 T, [
- MX_USB_HOST_Init();3 r" ^' n- a. k& n+ g6 R
- MX_GPIO_Init();
0 P( A) a/ ^ k( C9 t- B; a
, e/ N/ H" J# z' h% W) A" Z! _- HAL_GPIO_WritePin(GPIOC, GPIO_PIN_0, GPIO_PIN_SET); 3 [( r& g X+ ]1 F' C
; Q: x L$ Z% {5 u4 a- delay_ums(1000);
" q2 E7 H0 v1 k# f8 j% H+ ~ - HAL_GPIO_WritePin(GPIOC, GPIO_PIN_0, GPIO_PIN_RESET); ) W) p% Z1 g7 i, ~! M: g
- / B V# S3 e7 Y) A& P. {3 ~
- while (1)
* g, V0 `1 C% A - {
{. m K& L+ t& T - /* USER CODE END WHILE */
& N1 X) T b' q) V% y- @ - MX_USB_HOST_Process();5 G% H0 k; M9 I5 ]. k8 n
- delay_ums(1);: ^) n+ @) @+ n/ F$ `2 o; Z3 w
- a++;
0 U$ Q4 B- [8 U7 v, X3 N2 d2 z - if(a>1000)6 b' a: R& |8 h# l. s- S% ~
& |7 p" w0 p# k% y1 B. ?/ _0 _* J - a=0;. a9 l) Y: M$ [# ^! b
- USBH_CDC_Transmit(&hUsbHostFS, "AT\r\n", strlen("AT\r\n"));! T9 ]9 ?1 e; b1 H
- }' z; j' Q$ d. j
- /* USER CODE BEGIN 3 */ D- b$ j7 A; W6 \
- }7 d% k% ~6 o) L* Y" B% R: h/ m% s
- /* USER CODE END 3 */
1 Y6 x& ^5 c. ?8 z% w9 F+ s - }
4 h/ R! \1 `" W$ |7 @ - L$ o6 a3 N$ Q0 M2 m
( w4 D6 `& k0 X0 l - * @brief System Clock Configuration
0 n' P8 D5 x( x& D# |! f- p" m" W - * @retval None, E7 i) d; O- Z: b
- */ J# q+ F {- B+ t. j
- void SystemClock_Config(void), R2 d7 @* `( p, g8 \
5 R0 w" `( h6 m - RCC_OscInitTypeDef RCC_OscInitStruct = {0};% u1 N6 @: a2 x% h) y
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
, s g; b6 X7 S5 M) k G. `. _ - " r( w. E2 n5 V" \
- /** Configure the main internal regulator output voltage3 @ ?+ I4 B8 l; k" w7 K+ x
- */# I2 B* l7 s, \# G% F, k- d
- __HAL_RCC_PWR_CLK_ENABLE();
/ c* u* ?, x3 R3 q9 y - __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);3 \8 |/ F( t0 j. w* J
- /** Initializes the RCC Oscillators according to the specified parameters
3 {; T) G( B$ j. }+ c6 H1 d - * in the RCC_OscInitTypeDef structure.8 D) V6 C4 O* z' a* L
_: P) E w( U: M - RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
1 B+ _6 x. W9 @: J4 O6 a8 U - RCC_OscInitStruct.HSEState = RCC_HSE_ON;
" m" C( B" [' K" x - RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;" d7 {# w2 ~ T" x9 Q, r/ q
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;; Y4 y6 D% Q8 ` A$ ~7 t, D
- RCC_OscInitStruct.PLL.PLLM = 4;
; w5 \3 X' j2 Z+ ~ - RCC_OscInitStruct.PLL.PLLN = 168;
$ `0 ]! }5 U5 b1 S - RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;) M" I( s& E+ }6 ~; b! E$ J" w
- RCC_OscInitStruct.PLL.PLLQ = 7;3 D' p8 m7 E# e+ x- v
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)0 s1 n( o# j9 ~# j1 z5 @
% a' `: B* l( r" E - Error_Handler();
5 V( j9 i" @# C7 A) S% w - }! O* ~: ?, q; n
- /** Initializes the CPU, AHB and APB buses clocks% i: x/ V, o7 r) W6 B* |+ k# D
- */( h- q9 @. D% C4 [( Y1 R. m" X1 k8 c
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK* E. ^7 U1 I# U6 i4 p- Y
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
, `0 `1 \* ^7 {* y3 u - RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;' k" U. {4 P5 L9 k6 t
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
2 t0 c4 \1 {0 O - RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;4 n7 E8 r9 x% u R( ]6 @9 m
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;/ z0 Y/ g5 y/ f% X% M
- C) E8 \9 j- h
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
6 x2 p8 _8 Y3 l/ D5 J- f: q% h V: U - {
0 P- f; K) H: _: c* x: X6 e0 h' [* o - Error_Handler();- x7 Q: V! k4 _$ e! B
( u; e: {: G- s# [' p - }
2 w2 b" g7 m! Q
" o( a1 t6 z4 q7 S7 f- u4 t/ G: C- /**
" Q- p0 _0 U5 m( W2 Y0 e - * @brief USART1 Initialization Function
8 a2 X, E8 O4 p" R/ l - * @param None
* Q; z, b; m+ w - * @retval None, L" `# C! _, V* `/ V `4 B% Y
5 t) u0 s5 C; C U4 D0 D' @! V - static void MX_USART1_UART_Init(void)/ m6 a( W' {8 B5 o$ F
; D! ]3 b2 c% E+ w/ A- i0 b' A - I" R$ O' r& a' ^
- /* USER CODE BEGIN USART1_Init 0 */- c, f! U7 B" D- q8 Z
% P% W% f: L' `; a3 |$ B- /* USER CODE END USART1_Init 0 */5 P- ~) f& j- J
3 {5 `" M' i" U* b$ _- m4 H4 k- /* USER CODE BEGIN USART1_Init 1 */
4 M P) c/ \/ r - 4 U; B; ~1 a3 A& f8 {+ \+ b
- /* USER CODE END USART1_Init 1 */
6 M) Q7 f& i7 K7 Y/ D - huart1.Instance = USART1;4 Y# ], l1 n% k/ @7 A
- huart1.Init.BaudRate = 115200;
% s' w2 }2 I. Z( m) n( Q6 ] - huart1.Init.WordLength = UART_WORDLENGTH_8B;2 \( V; G8 B; e* i9 }' N; n
- huart1.Init.StopBits = UART_STOPBITS_1;
. Q+ C! [& y# T8 z; W - huart1.Init.Parity = UART_PARITY_NONE;
" P O* [0 h* E X, B - huart1.Init.Mode = UART_MODE_TX_RX;: Y1 [' U7 U% u: S) l
- huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
2 Q3 y! X) n* Y# ]: M- N, Y4 E7 T - huart1.Init.OverSampling = UART_OVERSAMPLING_16;& V3 n7 W) O. @
- if (HAL_UART_Init(&huart1) != HAL_OK)+ p' f) s% I3 v h( f- e
- {' j$ W' l! l+ r- G5 K
- Error_Handler();
; E& b: b ]2 u: m) y - }3 n8 L& S/ n; |0 S( b( `& R
- /* USER CODE BEGIN USART1_Init 2 */
9 Y9 V) x3 \. _' f
# @/ ?8 n" q4 d( _ X9 B- /* USER CODE END USART1_Init 2 */
8 L5 i, w. F2 c. o - + X$ Z$ o. e0 k. d0 [: l
- h F2 {; K3 `& k+ N' C9 v0 c" v+ K
3 w% z7 a' g8 c1 A; N% F- /**
' n- a2 N0 B. ?' n E - * @brief GPIO Initialization Function/ ]# g1 ~; p9 ^0 I& O
- * @param None
" A2 E4 ^; w9 n; e1 e4 e0 w( n - * @retval None
* L& T( R* l. f p- {! j" o - */
/ ^8 I6 I7 _4 g5 d4 r9 F0 i - static void MX_GPIO_Init(void)
+ ]% a$ a: c4 A- j, j - {
9 Y% i l8 K' ?# U9 A - GPIO_InitTypeDef GPIO_InitStruct = {0};3 H5 X" Z Z6 }* k7 M5 v
' d! t. b) W7 P" Z1 ^- /* GPIO Ports Clock Enable */
" [0 q- O' a7 ]6 C( m, h - __HAL_RCC_GPIOH_CLK_ENABLE();
/ _; N2 S) K3 o. g* G - __HAL_RCC_GPIOA_CLK_ENABLE();( Q# K6 j7 y5 i$ G! W4 r" Z
- __HAL_RCC_GPIOC_CLK_ENABLE();
6 v2 B5 _- I0 H4 | - /*Configure GPIO pin Output Level */
5 O/ c. R3 i0 Y' {
0 R. m) m$ a' s
& e/ D, e p* L N- /*Configure GPIO pin : PA15 */* i/ L* ]" e7 Q5 r: R/ ~1 t, ]
- GPIO_InitStruct.Pin = GPIO_PIN_15;
; a$ t' m4 I2 }: e! T% S - GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
2 n. I, @" @% u; E - GPIO_InitStruct.Pull = GPIO_NOPULL;0 n1 ~& ?2 `# ?8 ^
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;8 K, w5 u8 c8 ]4 [3 T
- HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
9 w! R0 w5 E; m* m$ j - HAL_GPIO_WritePin(GPIOA, GPIO_PIN_15, GPIO_PIN_SET);! _% [$ W2 l. E
% X/ j8 ^& g% ]1 S2 }
* P2 n- W/ e" `7 e& X
! r2 D' k9 W: U# y- O" R- /*Configure GPIO pin : PA15 */
+ ]5 K& x8 k& o - GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_2;$ V. u8 f' H7 q" d
- GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;# g9 F! r1 |( I+ S$ h
- GPIO_InitStruct.Pull = GPIO_NOPULL;: m2 Z# Q/ R- ?9 F5 c
* E$ ?1 d" H2 ]3 i( Z$ p - HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
$ L& E1 [1 O8 F" s# } - HAL_GPIO_WritePin(GPIOC, GPIO_PIN_0|GPIO_PIN_2, GPIO_PIN_RESET); 5 K" v2 P: n' H" r* }6 W
- }. V1 I) f. K! |+ \* s5 N( n
+ \. V* K4 U% ^& L) B( h; l- /* USER CODE BEGIN 4 */
% n( W9 `4 ?: S9 |1 u1 J8 w3 v, L7 p - ( X% E4 q, U5 j) f( B
- /* USER CODE END 4 */% j' ?, V; e$ V T
2 B5 `9 E: _9 M8 ^, I, H9 E- /**! X/ U" i5 Y( `. g
- * @brief This function is executed in case of error occurrence.. `; U5 }$ K" @8 ^, n4 h) c/ E
- * @retval None
% y( K1 L& P- }9 R0 R) i5 C1 T - */
8 e; W$ y7 v# w' T1 _ - void Error_Handler(void)
7 f; S5 R7 q: y5 l( B: p; R - {& ]$ Z0 h4 k8 h( b
- /* USER CODE BEGIN Error_Handler_Debug */+ ?0 `, L* E# R+ A, c
- /* User can add his own implementation to report the HAL error return state */4 V p" U0 P; u* @# J8 X
- [+ d3 {0 Y4 r1 J- W/ T
- /* USER CODE END Error_Handler_Debug */
% g ]' X) N0 C. O7 J7 k - }
* j: h% K) n# X, ]& }4 N; L$ t - . k8 ~5 G3 O3 b, B1 x
- #ifdef USE_FULL_ASSERT9 V0 T# B( k9 U5 U, o+ h8 F
4 _ N2 G4 c$ S$ K' i! `0 u - * @brief Reports the name of the source file and the source line number
2 y( E+ |6 Z2 D3 | - * where the assert_param error has occurred.
0 p: v8 Y B% h! g: P - * @param file: pointer to the source file name
: U& y" `0 H4 o) M - * @param line: assert_param error line source number
' s$ |0 \" T7 g' ~. n - * @retval None# y! u1 N; g2 y' Y
- */' s9 n+ a5 n4 O) n1 m0 \% [
- void assert_failed(uint8_t *file, uint32_t line)/ } R L5 L. f$ A" G/ n, G5 U
- {/ _5 K- r* n |6 i: U- W
- /* USER CODE BEGIN 6 */
2 Z& [# n) p/ N9 q# W - /* User can add his own implementation to report the file name and line number,8 a3 z3 b2 n0 h8 A
- tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
# n" H0 y- S3 n% |: d D - /* USER CODE END 6 */
! c$ S7 p. A8 r) R# i+ m) B0 |6 g! L - }
6 u5 r6 J; k) @/ L& J+ i8 l - #endif /* USE_FULL_ASSERT */! l" [) c( O# x# ~) p- L
- . i: l% Y9 r$ _3 V% l
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
. O( N' x6 `& i! A6 }( ^ - void USBH_CDC_ReceiveCallback(USBH_HandleTypeDef *phost)
, T0 ~, f2 E' t3 w& o$ p5 n - {( B/ I+ S; v* Y9 N: {2 g3 r
- recLen = USBH_CDC_GetLastReceivedDataSize(phost); , n; X8 ~. Y& f2 _& }7 g+ t
* g8 u0 {" s5 P5 Z- v - HAL_UART_Transmit_IT(&huart1 ,(uint8_t*)recData,recLen);
, s+ q2 M5 ^3 y6 ` - while(__HAL_UART_GET_FLAG(&huart1,UART_FLAG_TC)!=SET); //等待发送结束 " K# j9 t: H$ D4 R6 W
# {. s, M R* t- R9 i - memset(recData,0x00,sizeof(recData));5 M1 z8 n" v k9 B1 f
1 O- `+ l4 O1 W" x" Z+ d
; t2 T1 @* d1 L. a
复制代码 3 [# r/ x. V: ]; {% {3 s( A$ E
4 q, y+ `; f9 R
