【经验分享】STM32 时钟相关函数和类型
STMCU小助手 发布时间:2022-6-10 20:14
01. 概述
' z9 G- h. D& U5 u; h+ O& Y在 STM32F4 标准固件库里,时钟源的选择以及时钟使能等函数都是在 RCC 相关固件库文件 stm32f4xx_rcc.h 和 stm32f4xx_rcc.c 中声明和定义的。大家打开 stm32f4xx_rcc.h 文件可以看到文件开头有很多宏定义标识符,然后是一系列时钟配置和时钟使能函数申明。这些函数大致可以归结为三类,一类是外设时钟使能函数,一类是时钟源和分频因子配置函数,还有一类是外设复位函数。当然还有几个获取时钟源配置的函数。
5 j3 n* Y7 ^' u9 w$ z( ~0 e
) W) T) r, t) c8 B" l. b0 u
. B6 T+ d' R0 A. P7 M0 `' I02. 相关类型
. u5 w3 P+ L5 mRCC_ClocksTypeDef
  1. /* Exported types ------------------------------------------------------------*/$ x9 T# {1 n2 c4 O7 H( y8 ?# G
  2. typedef struct
    : S/ q' C! y- y* b3 S& |" ]
  3. {
    ' E+ s5 |! c5 ~% S8 e, e
  4.   uint32_t SYSCLK_Frequency; /*!<  SYSCLK clock frequency expressed in Hz */
    ( e& c0 u. w! I% X/ M
  5.   uint32_t HCLK_Frequency;   /*!<  HCLK clock frequency expressed in Hz   */; t% p+ ~+ X+ t; T: b
  6.   uint32_t PCLK1_Frequency;  /*!<  PCLK1 clock frequency expressed in Hz  */
    ! t7 Q( y" F2 w7 l& Z
  7.   uint32_t PCLK2_Frequency;  /*!<  PCLK2 clock frequency expressed in Hz  */6 Y5 M. w/ ?! Y7 {- _
  8. }RCC_ClocksTypeDef;
0 y' {& N. |/ X: R7 J  b0 r& P  S  @+ n
RCC_HSE_configuration3 L$ u' F9 _- M% u5 f/ I, Q
  1. /** @defgroup RCC_HSE_configuration
    : l! k/ q$ H& }2 B  Z, a" M
  2.   * @{
    ; m* d% N# z# ^, l; i! V
  3.   */1 [% x2 F2 e' J3 O# ~
  4. #define RCC_HSE_OFF                      ((uint8_t)0x00); ~7 u; }1 d: b  G3 v" ^7 q. c
  5. #define RCC_HSE_ON                       ((uint8_t)0x01)
    ! I! o! N4 [+ d
  6. #define RCC_HSE_Bypass                   ((uint8_t)0x05)
    2 o5 L! R* \0 H
  7. #define IS_RCC_HSE(HSE) (((HSE) == RCC_HSE_OFF) || ((HSE) == RCC_HSE_ON) || \+ j5 H2 ^1 _, q6 a; V% W. Z
  8.                          ((HSE) == RCC_HSE_Bypass))5 f# M6 [4 w) d" ~) U! J( O
- t( F  R' {. X) B& bRCC_LSE_Dual_Mode_Selection" G1 x* v* {, k$ l- @
  1. /** @defgroup RCC_LSE_Dual_Mode_Selection
    2 P2 q0 _& U7 w9 F
  2.   * @{7 J6 {5 g% E- `: z1 R2 s( x
  3.   */
      t: Y$ i! K% b& |
  4. #define RCC_LSE_LOWPOWER_MODE           ((uint8_t)0x00)
    ( d  c/ V* [. z! V
  5. #define RCC_LSE_HIGHDRIVE_MODE          ((uint8_t)0x01)
    ( Q" M5 @& a, p3 f1 @3 w, S/ \
  6. #define IS_RCC_LSE_MODE(MODE)           (((MODE) == RCC_LSE_LOWPOWER_MODE) || \8 ?8 k' n: v. K- S+ p9 ?
  7.                                          ((MODE) == RCC_LSE_HIGHDRIVE_MODE))
. m: m$ x0 A, M- pRCC_PLLSAIDivR_Factor% M# y3 L8 V; p) n4 K
  1. /** @defgroup RCC_PLLSAIDivR_Factor, b7 g: r4 u) b3 I# X& k
  2.   * @{
    % G: j6 y  K+ [& z6 j) q, y+ f
  3.   */1 n2 ]2 ?  @! r( p! u5 j9 R& b
  4. #define RCC_PLLSAIDivR_Div2                ((uint32_t)0x00000000)
    9 a* r0 q9 s! [9 c8 U
  5. #define RCC_PLLSAIDivR_Div4                ((uint32_t)0x00010000)  X" |; T- ~& `: c
  6. #define RCC_PLLSAIDivR_Div8                ((uint32_t)0x00020000)
    ) E9 ?6 [  \8 X  R# z! u8 E# P
  7. #define RCC_PLLSAIDivR_Div16               ((uint32_t)0x00030000)) s, e/ Y/ a+ f$ v. Y+ g
  8. #define IS_RCC_PLLSAI_DIVR_VALUE(VALUE) (((VALUE) == RCC_PLLSAIDivR_Div2) ||\) S& R4 F4 y% g5 |: ^
  9.                                         ((VALUE) == RCC_PLLSAIDivR_Div4)  ||\
    ( `# x- O9 _6 H# h$ C
  10.                                         ((VALUE) == RCC_PLLSAIDivR_Div8)  ||\
    2 W# e% \. t  H7 k0 K8 f
  11.                                         ((VALUE) == RCC_PLLSAIDivR_Div16))
    : U3 k% t6 g6 [. Q. F
1 `# f; X( |6 C, u6 N* e+ x& b5 b
5 Q& @( e: F3 ]* V; S$ uRCC_PLL_Clock_Source
. b6 E- J1 q5 O7 l0 Y
  1. /** @defgroup RCC_PLL_Clock_Source   h: U% h) A* c3 I9 u, [' \: v' @1 k& Q
  2.   * @{' O( n" s) z5 Q8 j( j/ j
  3.   */6 {2 v. ]+ _5 w
  4. #define RCC_PLLSource_HSI                ((uint32_t)0x00000000)/ x$ ]3 p( T" I, t. M( B. p
  5. #define RCC_PLLSource_HSE                ((uint32_t)0x00400000)/ a1 X8 u+ d6 j7 x8 g8 y
  6. #define IS_RCC_PLL_SOURCE(SOURCE) (((SOURCE) == RCC_PLLSource_HSI) || \4 t$ ]5 G" H* J& Q- a
  7.                                    ((SOURCE) == RCC_PLLSource_HSE))
    + z* R" a; F; I/ R
  8. #define IS_RCC_PLLM_VALUE(VALUE) ((VALUE) <= 63)
    7 Z' x+ f) n8 W* m' t
  9. #define IS_RCC_PLLN_VALUE(VALUE) ((50 <= (VALUE)) && ((VALUE) <= 432)), ~8 t0 P4 N+ @9 _
  10. #define IS_RCC_PLLP_VALUE(VALUE) (((VALUE) == 2) || ((VALUE) == 4) || + v' h8 c" a8 P/ [% a
  11. ((VALUE) == 6) || ((VALUE) == 8))- ]( q; s' |1 Z2 N7 H
  12. #define IS_RCC_PLLQ_VALUE(VALUE) ((4 <= (VALUE)) && ((VALUE) <= 15)). C$ S) [3 Q+ d; a+ K# ^. f& D3 w. Q8 c
  13. #if defined(STM32F410xx) || defined(STM32F412xG) || defined(STM32F413_423xx) 7 k2 i* c' Z* ?
  14.     || defined(STM32F446xx) || defined(STM32F469_479xx)
    2 |' x1 h% k2 Z# W* V1 l' b
  15. #define IS_RCC_PLLR_VALUE(VALUE) ((2 <= (VALUE)) && ((VALUE) <= 7))
    7 {/ E2 r- Y- _  V$ {8 }9 g0 B
  16. #endif /* STM32F410xx || STM32F412xG || STM32F413_423xx || STM32F446xx
    - @8 b9 T5 A! q% ]; m* i
  17. || STM32F469_479xx */6 i) t) o1 A$ M% J) z) C: {
  18. # e5 t2 e1 Q* C
  19. #define IS_RCC_PLLI2SN_VALUE(VALUE) ((50 <= (VALUE)) && ((VALUE) <= 432))
    % t% D( D9 ?: d+ E4 A
  20. #define IS_RCC_PLLI2SR_VALUE(VALUE) ((2 <= (VALUE))  && ((VALUE) <= 7))
    , H8 d) w% Y, D! J+ j6 D) D- z
  21. #define IS_RCC_PLLI2SM_VALUE(VALUE) ((2 <= (VALUE))  && ((VALUE) <= 63))/ `$ b- t1 i6 l7 s: w+ ?$ j- a( a; v/ w
  22. #define IS_RCC_PLLI2SQ_VALUE(VALUE) ((2 <= (VALUE))  && ((VALUE) <= 15))% X$ U0 r  H  W+ b1 g, f+ P
  23. #if defined(STM32F446xx) ) a9 V4 ^0 Q9 r. ?& G
  24. #define IS_RCC_PLLI2SP_VALUE(VALUE) (((VALUE) == 2) || ((VALUE) == 4)
    8 `# X0 M% ?' D) X4 q
  25.     || ((VALUE) == 6) || ((VALUE) == 8)); [- f9 u: {. _1 x8 ]1 Z
  26. #define IS_RCC_PLLSAIM_VALUE(VALUE) ((VALUE) <= 63)
    ( K5 D# I$ H) C/ b" w/ \
  27. #elif  defined(STM32F412xG) || defined(STM32F413_423xx)
    . H1 j/ Z3 i4 W2 F
  28. #define IS_RCC_PLLI2SP_VALUE(VALUE) (((VALUE) == 2) || ((VALUE) == 4)
    ) b" H; d: o$ n& M
  29.     || ((VALUE) == 6) || ((VALUE) == 8))2 D% O& \' \/ w% v
  30. #else
    4 D! Y. i  l$ T: }* N
  31. #endif /* STM32F446xx */- ?/ g  {6 d8 y, m
  32. #define IS_RCC_PLLSAIN_VALUE(VALUE) ((50 <= (VALUE)) && ((VALUE) <= 432))
    $ Z' L9 Z( N9 x( H8 R; ~& U
  33. #if defined(STM32F446xx) || defined(STM32F469_479xx)
    - j3 W' [# W9 k# j! K* U
  34. #define IS_RCC_PLLSAIP_VALUE(VALUE) (((VALUE) == 2) || ((VALUE) == 4) % p3 X3 }" `1 x% T
  35.     || ((VALUE) == 6) || ((VALUE) == 8))7 U2 a4 l( }! ^
  36. #endif /* STM32F446xx || STM32F469_479xx */$ w* ?) e4 o" w8 _
  37. #define IS_RCC_PLLSAIQ_VALUE(VALUE) ((2 <= (VALUE)) && ((VALUE) <= 15))
    ' l( C6 k- ]7 b* @
  38. #define IS_RCC_PLLSAIR_VALUE(VALUE) ((2 <= (VALUE)) && ((VALUE) <= 7))  # q! V$ H1 U) q, d) q) ^
  39. ; A* |- Y( N) s. K5 o" q
  40. #define IS_RCC_PLLSAI_DIVQ_VALUE(VALUE) ((1 <= (VALUE)) && ((VALUE) <= 32))4 S# G3 |- I8 m; ~8 H* O
  41. #define IS_RCC_PLLI2S_DIVQ_VALUE(VALUE) ((1 <= (VALUE)) && ((VALUE) <= 32))
    " v, T4 m& H; p& }1 s" n6 Z
  42. 6 C" Q) [) G5 R9 e
  43. #if defined(STM32F413_423xx)0 I/ V" Z0 ~  `6 k0 H: [9 o/ z9 \
  44. #define IS_RCC_PLLI2S_DIVR_VALUE(VALUE) ((1 <= (VALUE)) && ((VALUE) <= 32))
    1 {1 O2 `+ R6 q- c; ?* T5 f
  45. #define IS_RCC_PLL_DIVR_VALUE(VALUE)    ((1 <= (VALUE)) && ((VALUE) <= 32))
    & f* o4 F* D/ p  ]
  46. #endif /* STM32F413_423xx */# ?7 O' C1 g# |& ~1 C
" ]6 h4 O4 u! g1 M
RCC_System_Clock_Source
( S' w& P8 f* i- h* d
  1. /** @defgroup RCC_System_Clock_Source   n6 E7 d! m" r, M9 D
  2.   * @{
    . f0 F+ I( F8 A) b. M! s( h
  3.   */
    # B% x% P) a9 {! L' d8 `% M  w0 I
  4. / }3 p! O, h' G& v! N: h
  5. #if  defined(STM32F412xG) || defined(STM32F413_423xx) || defined(STM32F446xx)/ @4 m+ r; e3 N: q0 i
  6. #define RCC_SYSCLKSource_HSI             ((uint32_t)0x00000000)- J% I, J4 f% q5 I* L. `1 k% R4 N
  7. #define RCC_SYSCLKSource_HSE             ((uint32_t)0x00000001)6 s$ ~. |; E/ \8 q9 R. l/ U0 ~/ a
  8. #define RCC_SYSCLKSource_PLLPCLK         ((uint32_t)0x00000002)
    3 }( r) V2 Y$ t' A( [
  9. #define RCC_SYSCLKSource_PLLRCLK         ((uint32_t)0x00000003)
    # ]' S  Y8 U9 K0 o* A9 l
  10. #define IS_RCC_SYSCLK_SOURCE(SOURCE) (((SOURCE) == RCC_SYSCLKSource_HSI) || \
    ) r6 d' ]! _: x9 k* h
  11.                                       ((SOURCE) == RCC_SYSCLKSource_HSE) || \- ]9 p! P3 x% u1 U4 Z# M4 v. c8 C
  12.                                       ((SOURCE) == RCC_SYSCLKSource_PLLPCLK) || \
    * J& P6 J) l) w9 X0 F
  13.                                       ((SOURCE) == RCC_SYSCLKSource_PLLRCLK))  }5 @/ r; T3 \( a
  14. /* Add legacy definition */! K/ {/ b& z+ O0 ?
  15. #define  RCC_SYSCLKSource_PLLCLK    RCC_SYSCLKSource_PLLPCLK  : a- M# \7 z; y  k- _, T
  16. #endif /* STM32F446xx */. p) n1 C  L! @
  17. 8 u9 P# @: @% [
  18. #if defined(STM32F40_41xxx) || defined(STM32F427_437xx) || defined(STM32F429_439xx)   a$ |. v3 p) b, c
  19. || defined(STM32F401xx) || defined(STM32F410xx) || defined(STM32F411xE) 0 X; A5 t7 X& t* k0 F5 k! H6 a
  20.     || defined(STM32F469_479xx)
    : U1 ]/ P0 P' h1 q6 g
  21. #define RCC_SYSCLKSource_HSI             ((uint32_t)0x00000000)- P  _8 I/ q7 C+ p2 J+ L
  22. #define RCC_SYSCLKSource_HSE             ((uint32_t)0x00000001)9 O4 x. k7 a7 g6 B6 a; z8 I
  23. #define RCC_SYSCLKSource_PLLCLK          ((uint32_t)0x00000002)
    ) X# F: L; b+ L2 E/ r, e8 }: Q
  24. #define IS_RCC_SYSCLK_SOURCE(SOURCE) (((SOURCE) == RCC_SYSCLKSource_HSI) || \9 c! i: K# W6 w
  25.                                       ((SOURCE) == RCC_SYSCLKSource_HSE) || \' Q4 x/ D/ F) T% k" g
  26.                                       ((SOURCE) == RCC_SYSCLKSource_PLLCLK))
    ' f0 `& u3 w9 ]& H. M
  27. #endif /* STM32F40_41xxx || STM32F427_437xx || STM32F429_439xx || STM32F401xx
    . @5 u0 d, [7 R# }' W- p
  28. || STM32F410xx || STM32F411xE || STM32F469_479xx */ 7 {) R, V, [) C! W/ X/ G& L' n
$ K1 _; Z2 ]$ f1 y3 T; v) v1 c9 K
RCC_AHB_Clock_Source
# l" D7 x) R/ E1 z4 U
  1. /** @defgroup RCC_AHB_Clock_Source
    9 y. X/ }2 Q" _+ I& W. O, P# n1 F  g2 C
  2.   * @{( {7 a: x  X  ^
  3.   */1 z0 D; |) k6 ~7 P6 F- ]  j  z
  4. #define RCC_SYSCLK_Div1                  ((uint32_t)0x00000000): P5 q2 k& a6 T, |& T/ _
  5. #define RCC_SYSCLK_Div2                  ((uint32_t)0x00000080)
    - m( t! R1 Z8 x
  6. #define RCC_SYSCLK_Div4                  ((uint32_t)0x00000090)
    ; J7 Y: W* ^' v2 N4 t4 q, z
  7. #define RCC_SYSCLK_Div8                  ((uint32_t)0x000000A0)" q; v$ R* u! B8 y. k! L# j
  8. #define RCC_SYSCLK_Div16                 ((uint32_t)0x000000B0)
    8 q/ e3 A  s& f2 H- g
  9. #define RCC_SYSCLK_Div64                 ((uint32_t)0x000000C0)
    3 q# i' k* U) d6 _! S, u# U
  10. #define RCC_SYSCLK_Div128                ((uint32_t)0x000000D0)
    7 M. C) [8 ?! G; k5 N! E0 e
  11. #define RCC_SYSCLK_Div256                ((uint32_t)0x000000E0)4 U) V- d" w2 A( F3 O/ S$ j
  12. #define RCC_SYSCLK_Div512                ((uint32_t)0x000000F0)8 o7 }1 I, p! G5 F- W
  13. #define IS_RCC_HCLK(HCLK) (((HCLK) == RCC_SYSCLK_Div1) || ((HCLK) == RCC_SYSCLK_Div2) || \
    ! o) O  [& \5 r+ G
  14.                            ((HCLK) == RCC_SYSCLK_Div4) || ((HCLK) == RCC_SYSCLK_Div8) || \' ^! O/ e3 P8 B' D/ C4 }2 `, |
  15.                            ((HCLK) == RCC_SYSCLK_Div16) || ((HCLK) == RCC_SYSCLK_Div64) || \  |. a; r0 @$ {. Q8 Z2 f$ J4 w8 Y
  16.                            ((HCLK) == RCC_SYSCLK_Div128) || ((HCLK) == RCC_SYSCLK_Div256) || \( x3 [6 @' d7 ~, p/ |3 I. X$ M
  17.                            ((HCLK) == RCC_SYSCLK_Div512))
% z" j& B" _8 o: T$ e' e% _2 Y
RCC_APB1_APB2_Clock_Source
$ r; q/ H/ T% @5 t
  1. /** @defgroup RCC_APB1_APB2_Clock_Source
      [. ~- ?  i% K& w3 j
  2.   * @{
    & t$ R! E4 X9 g3 ]" z$ t, B$ ~
  3.   */. S3 I2 ~/ V+ d) Y& I4 w' Y: Q2 D
  4. #define RCC_HCLK_Div1                    ((uint32_t)0x00000000)
    . V7 E3 w$ Y3 F2 f5 I5 Z
  5. #define RCC_HCLK_Div2                    ((uint32_t)0x00001000)1 Z: t* R/ v7 l
  6. #define RCC_HCLK_Div4                    ((uint32_t)0x00001400)
    " w$ H* Z% o. x1 s2 ~4 V0 c
  7. #define RCC_HCLK_Div8                    ((uint32_t)0x00001800)
    - j: Q( k9 n% P
  8. #define RCC_HCLK_Div16                   ((uint32_t)0x00001C00)1 w0 V% N6 N% b
  9. #define IS_RCC_PCLK(PCLK) (((PCLK) == RCC_HCLK_Div1) || ((PCLK) == RCC_HCLK_Div2) || \5 Y& C$ O% B5 u" O
  10.                            ((PCLK) == RCC_HCLK_Div4) || ((PCLK) == RCC_HCLK_Div8) || \2 A# @& w8 u4 u" C) k
  11.                            ((PCLK) == RCC_HCLK_Div16))
    ! W- a' \" J. s; n6 p* c
- [+ f8 U! [& O0 Y6 G6 r* q: p
RCC_Interrupt_Source
0 d( _- Y* @2 T  H. h* a
  1. /** @defgroup RCC_Interrupt_Source " e* f6 g) r* Y
  2.   * @{
    & x. i+ c+ w" c
  3.   */
    + ^9 c- I7 Q. F. b6 B
  4. #define RCC_IT_LSIRDY                    ((uint8_t)0x01)
    / K# y/ n' M5 X- S0 ~, p  A" f; ~$ O
  5. #define RCC_IT_LSERDY                    ((uint8_t)0x02)  v# g  ?* X4 m+ q) e6 e! U% Q- A
  6. #define RCC_IT_HSIRDY                    ((uint8_t)0x04). F# F& E+ A8 O) K
  7. #define RCC_IT_HSERDY                    ((uint8_t)0x08)
    3 ?( S, U" o1 @$ t$ t
  8. #define RCC_IT_PLLRDY                    ((uint8_t)0x10)
    " |; K( K; g4 X9 c5 j$ W
  9. #define RCC_IT_PLLI2SRDY                 ((uint8_t)0x20) ! _& K3 `+ [& `. G1 m
  10. #define RCC_IT_PLLSAIRDY                 ((uint8_t)0x40)
    3 I9 f; k' u$ F8 D, o7 O) J
  11. #define RCC_IT_CSS                       ((uint8_t)0x80)' l1 g0 m1 Y) R0 y, H3 x5 R
  12. 4 J8 G# Z% X* j3 A2 G: H/ ]
  13. #define IS_RCC_IT(IT) ((((IT) & (uint8_t)0x80) == 0x00) && ((IT) != 0x00))
    ; r" R& H: {# ~0 q- P/ V
  14. #define IS_RCC_GET_IT(IT) (((IT) == RCC_IT_LSIRDY) || ((IT) == RCC_IT_LSERDY) || \4 h0 `0 W( s$ d; P1 X9 l# d. m8 U
  15.                            ((IT) == RCC_IT_HSIRDY) || ((IT) == RCC_IT_HSERDY) || \
    . U! E* e0 L5 w# b! {* V% ?
  16.                            ((IT) == RCC_IT_PLLRDY) || ((IT) == RCC_IT_CSS) || \! t- }, h( n5 e  K: R
  17.                            ((IT) == RCC_IT_PLLSAIRDY) || ((IT) == RCC_IT_PLLI2SRDY))
    ) g+ D! B! P# m6 d( L! g# P
  18. #define IS_RCC_CLEAR_IT(IT)((IT) != 0x00)6 ?' ?% c+ l( I- {
! Z2 N0 I) v4 U
RCC_LSE_Configuration
6 A0 C& h% C8 b0 R( I5 N$ e7 t
  1. /** @defgroup RCC_LSE_Configuration . Q6 W% ^9 z. C) @! p- a' \- r
  2.   * @{
    ' b- [, b0 k2 U9 Y- l
  3.   */
    / y1 L+ b3 e" v1 y6 m: K! T
  4. #define RCC_LSE_OFF                      ((uint8_t)0x00)
    , M  R3 `! n0 o( d# Z% b9 n
  5. #define RCC_LSE_ON                       ((uint8_t)0x01)
    7 @. M* _& s, \: w/ F
  6. #define RCC_LSE_Bypass                   ((uint8_t)0x04)
    ! E5 ?# P# m' F7 i3 P" y
  7. #define IS_RCC_LSE(LSE) (((LSE) == RCC_LSE_OFF) || ((LSE) == RCC_LSE_ON) || \
    / d) _; a" \: u) n5 r# H( R( l
  8.                          ((LSE) == RCC_LSE_Bypass))
* U, {" y+ N( R3 f: q$ F% ?- @
RCC_RTC_Clock_Source
7 ]+ n% _) C7 K
  1. /** @defgroup RCC_RTC_Clock_Source
    - ~$ Q& Y0 V& ]" f0 B8 U4 c
  2.   * @{
    ; {7 l, \! R8 [+ {3 B: ^! p
  3.   */
    2 d3 T1 P+ a6 O$ x
  4. #define RCC_RTCCLKSource_LSE             ((uint32_t)0x00000100)$ i8 r. U7 a0 \  ^8 P
  5. #define RCC_RTCCLKSource_LSI             ((uint32_t)0x00000200)$ Z" v+ ?& g8 c
  6. #define RCC_RTCCLKSource_HSE_Div2        ((uint32_t)0x00020300)
    - d! Y* J5 @. ^: U, V# e: @+ ^
  7. #define RCC_RTCCLKSource_HSE_Div3        ((uint32_t)0x00030300)* }, ?- h: p3 S8 m
  8. #define RCC_RTCCLKSource_HSE_Div4        ((uint32_t)0x00040300)
    9 \; l" o# d$ }, J" G) m
  9. #define RCC_RTCCLKSource_HSE_Div5        ((uint32_t)0x00050300)3 J# C, }9 z; H
  10. #define RCC_RTCCLKSource_HSE_Div6        ((uint32_t)0x00060300)' Q% J. J. M* _$ ^2 J4 f6 ?4 u
  11. #define RCC_RTCCLKSource_HSE_Div7        ((uint32_t)0x00070300)3 E6 A" L$ ^( a/ n6 z8 e
  12. #define RCC_RTCCLKSource_HSE_Div8        ((uint32_t)0x00080300)
    ! @' U0 Z3 J. c; Y, U$ [
  13. #define RCC_RTCCLKSource_HSE_Div9        ((uint32_t)0x00090300), K9 T8 {3 a' F9 n3 N
  14. #define RCC_RTCCLKSource_HSE_Div10       ((uint32_t)0x000A0300)
    , y8 u1 n# b. J* c2 l4 C* p; Y
  15. #define RCC_RTCCLKSource_HSE_Div11       ((uint32_t)0x000B0300)
    * Z( y( \- {; J, @  c9 }+ P. L
  16. #define RCC_RTCCLKSource_HSE_Div12       ((uint32_t)0x000C0300)
    / @. j; R# H: @# y8 ^9 z4 y
  17. #define RCC_RTCCLKSource_HSE_Div13       ((uint32_t)0x000D0300), z; n4 l* f# m2 r
  18. #define RCC_RTCCLKSource_HSE_Div14       ((uint32_t)0x000E0300)" u  j& Y" N; h0 j2 q
  19. #define RCC_RTCCLKSource_HSE_Div15       ((uint32_t)0x000F0300)& t$ Z2 A) d! D' k0 g
  20. #define RCC_RTCCLKSource_HSE_Div16       ((uint32_t)0x00100300)
    * d- T& B  ^' A: q: g% P6 m8 R6 c/ _
  21. #define RCC_RTCCLKSource_HSE_Div17       ((uint32_t)0x00110300)+ }; a0 y- r1 J5 F$ K
  22. #define RCC_RTCCLKSource_HSE_Div18       ((uint32_t)0x00120300)
    9 {+ w# y' ~5 e" T4 c( ]# ]
  23. #define RCC_RTCCLKSource_HSE_Div19       ((uint32_t)0x00130300)" T* l7 ~: z" b5 H' h
  24. #define RCC_RTCCLKSource_HSE_Div20       ((uint32_t)0x00140300)
    / s( o4 p% O/ Z* ^: [3 M8 _
  25. #define RCC_RTCCLKSource_HSE_Div21       ((uint32_t)0x00150300)4 z1 C, L' M/ Q3 y9 o% V
  26. #define RCC_RTCCLKSource_HSE_Div22       ((uint32_t)0x00160300)
    6 k8 Y0 O9 [2 U3 s1 ?- u
  27. #define RCC_RTCCLKSource_HSE_Div23       ((uint32_t)0x00170300)$ l, m0 j2 [% }9 H9 H& n. x
  28. #define RCC_RTCCLKSource_HSE_Div24       ((uint32_t)0x00180300)
    2 x9 e1 h" n) y: L1 X" a# H
  29. #define RCC_RTCCLKSource_HSE_Div25       ((uint32_t)0x00190300)
    $ U$ \; k& {* D6 c4 ?% v
  30. #define RCC_RTCCLKSource_HSE_Div26       ((uint32_t)0x001A0300)
    2 W# m* e- k9 S. Z. c! @
  31. #define RCC_RTCCLKSource_HSE_Div27       ((uint32_t)0x001B0300)
    ! a, s( b! ?1 [2 O* S
  32. #define RCC_RTCCLKSource_HSE_Div28       ((uint32_t)0x001C0300)- m- S* u1 R3 L& c8 ^
  33. #define RCC_RTCCLKSource_HSE_Div29       ((uint32_t)0x001D0300)6 l* g2 l; O4 X- ]9 Q% H
  34. #define RCC_RTCCLKSource_HSE_Div30       ((uint32_t)0x001E0300)
    ; x2 `) j+ w& q* d' B( E# [
  35. #define RCC_RTCCLKSource_HSE_Div31       ((uint32_t)0x001F0300)* f8 A) A$ _  Q
  36. #define IS_RCC_RTCCLK_SOURCE(SOURCE) (((SOURCE) == RCC_RTCCLKSource_LSE) || \
    9 e  w) `: _- `
  37.                                       ((SOURCE) == RCC_RTCCLKSource_LSI) || \, E1 l7 z3 t# u' R0 i/ `
  38.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div2) || \- ~9 d1 ~# A$ a' _) M
  39.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div3) || \
    ) T3 ?* l' M, {) e) Y3 \
  40.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div4) || \
    - I& I+ H% |5 D- k% j% s, R  h
  41.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div5) || \8 V& t* N# e- g/ j4 q
  42.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div6) || \
    4 m- ?5 c0 O- t& X/ W
  43.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div7) || \
    0 ?: q7 `/ j) m8 p) @$ b- [
  44.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div8) || \
      e5 m3 q4 j5 s0 C
  45.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div9) || \/ }- R! g( r6 K
  46.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div10) || \
    # ~# H0 @0 f5 C4 v# w1 g8 o: j6 B
  47.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div11) || \- H% B! v# ]4 C: V
  48.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div12) || \
    - K; X6 ~5 V. f! |0 X7 n; r  m* J6 n. q
  49.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div13) || \; O. s( r' K6 U
  50.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div14) || \
    $ S: x& R, {( y+ q
  51.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div15) || \( q5 O. ^) g5 }9 E3 g
  52.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div16) || \
    - M1 d5 d9 [2 {
  53.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div17) || \
    $ e. `6 N0 \4 z- o: ~6 a9 E9 ]. A7 F
  54.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div18) || \2 X( O3 P" F) \3 ?
  55.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div19) || \. `' a7 Y$ K, ]& k: v" B8 m
  56.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div20) || \1 t4 q. u- L6 Z, w% g
  57.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div21) || \
    $ x7 B1 n" p' U) r! D
  58.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div22) || \
    , m. X6 `1 ?) _* A! U
  59.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div23) || \& x# v  F3 K( p) B
  60.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div24) || \2 M' N4 ~5 P' K- O0 g* D- i; s
  61.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div25) || \
    - C/ K1 @6 E2 F+ B& C
  62.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div26) || \
    ( b# h, f' \; g, q
  63.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div27) || \& I, c3 }" V% J, ~& V. I0 r
  64.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div28) || \4 v7 j- u, X" d
  65.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div29) || \" L+ C- W: b0 ~$ S  W1 ^+ ?4 F
  66.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div30) || \7 |2 a- v( p/ V
  67.                                       ((SOURCE) == RCC_RTCCLKSource_HSE_Div31))
    ! E. M4 L) ~$ z3 M, F4 V
/ x/ O5 y  A2 @
RCC_SAI_BlockA_Clock_Source. u# \* U* {$ {! o3 F; U5 D
  1.   R' D4 P+ [# e* S; ~- m* P7 C
  2. /** @defgroup RCC_SAI_BlockA_Clock_Source
    * d2 }& A) j- t+ t7 n
  3.   * @{
    , h9 p% n! R$ A8 J+ d$ o2 Q2 r. a) @+ w( S
  4.   */
    ( ~' q2 j. a2 m- z6 r
  5. #define RCC_SAIACLKSource_PLLSAI             ((uint32_t)0x00000000)
    7 k3 V: m1 w* X& g2 t1 a7 y
  6. #define RCC_SAIACLKSource_PLLI2S             ((uint32_t)0x00100000)
    " U/ A5 M: l( v4 N) A/ |: e& i
  7. #define RCC_SAIACLKSource_Ext                ((uint32_t)0x00200000)0 g6 O0 i0 v& b6 N: g7 c
  8.   z8 t  a! A/ d! ?! A
  9. #define IS_RCC_SAIACLK_SOURCE(SOURCE) (((SOURCE) == RCC_SAIACLKSource_PLLI2S) ||\6 A- E5 z3 g1 E+ ^3 ?0 ?% H
  10.                                        ((SOURCE) == RCC_SAIACLKSource_PLLSAI) ||\9 _( N% D5 Y  O: m1 O/ o. v
  11.                                        ((SOURCE) == RCC_SAIACLKSource_Ext))
    , Z9 f6 f. A2 [7 q* `) v
, H9 N7 O# m: ?1 k3 b" Q
$ U! Y, i; f! W0 k! d/ [RCC_SAI_BlockB_Clock_Source
  1. /** @defgroup RCC_SAI_BlockB_Clock_Source2 @& {, S& m) F; k6 t
  2.   * @{
    9 x% l8 C% L" c/ u% q
  3.   */3 M6 E7 ?0 r) M* S& A! ?  M
  4. #define RCC_SAIBCLKSource_PLLSAI             ((uint32_t)0x00000000)* u. z. ~, P( K2 _- H0 W
  5. #define RCC_SAIBCLKSource_PLLI2S             ((uint32_t)0x00400000)
    1 a+ }  q: m* z
  6. #define RCC_SAIBCLKSource_Ext                ((uint32_t)0x00800000)
    : E0 |- @& e% u$ W7 Q
  7. / A  O5 r3 q. c; n' f
  8. #define IS_RCC_SAIBCLK_SOURCE(SOURCE) (((SOURCE) == RCC_SAIBCLKSource_PLLI2S) ||\
    $ g2 Z/ t5 b: N9 f
  9.                                        ((SOURCE) == RCC_SAIBCLKSource_PLLSAI) ||\
    5 s- Z6 e6 Z% M9 p
  10.                                        ((SOURCE) == RCC_SAIBCLKSource_Ext))
8 Y7 U: t) G0 }5 _. Q
RCC_TIM_PRescaler_Selection1 u( S/ x) k) w
  1. /** @defgroup RCC_TIM_PRescaler_Selection
    0 Z9 R  x2 e7 _1 Z- X
  2.   * @{7 l0 o; K. M- q: \% T+ E
  3.   */& a5 }0 |0 j4 A" F
  4. #define RCC_TIMPrescDesactivated             ((uint8_t)0x00)' D5 |: r5 L' F1 Y- c0 q. b3 O
  5. #define RCC_TIMPrescActivated                ((uint8_t)0x01)
    ! D  E+ s4 t. x% M; O# ~
  6. 5 V# U. @$ c; V  V
  7. #define IS_RCC_TIMCLK_PRESCALER(VALUE) (((VALUE) == RCC_TIMPrescDesactivated) : O  Y/ }1 A5 l' U' q
  8. || ((VALUE) == RCC_TIMPrescActivated))6 _0 y8 F* S  x# y4 s7 C5 B
5 s2 M/ w% F% i$ }. `1 N( V2 R
RCC_AHB1_Peripherals
7 d5 F4 o& y  b1 K
  1. /** @defgroup RCC_AHB1_Peripherals
    6 Q3 ^/ ]& G& z" h
  2.   * @{" u3 I) O, h! k  W; p: D* V
  3.   */ " h- `7 |$ m, N* K
  4. #define RCC_AHB1Periph_GPIOA             ((uint32_t)0x00000001)
    - S) c9 H. u; ~& O$ L5 `" ^
  5. #define RCC_AHB1Periph_GPIOB             ((uint32_t)0x00000002)# [& U& I# l' x: t+ ^( R; S( _
  6. #define RCC_AHB1Periph_GPIOC             ((uint32_t)0x00000004)0 W7 I" z0 W" N  m
  7. #define RCC_AHB1Periph_GPIOD             ((uint32_t)0x00000008)% m  j! r. E2 S, @$ @
  8. #define RCC_AHB1Periph_GPIOE             ((uint32_t)0x00000010)4 P4 E3 u2 e* ^
  9. #define RCC_AHB1Periph_GPIOF             ((uint32_t)0x00000020)3 x1 S2 L: t, g/ n
  10. #define RCC_AHB1Periph_GPIOG             ((uint32_t)0x00000040)
    ; o7 j: u/ c5 x
  11. #define RCC_AHB1Periph_GPIOH             ((uint32_t)0x00000080), Q% @8 x( T+ r' i. I$ W
  12. #define RCC_AHB1Periph_GPIOI             ((uint32_t)0x00000100)
    1 U1 Z- X, i: u3 \6 D' q" |) F: ~
  13. #define RCC_AHB1Periph_GPIOJ             ((uint32_t)0x00000200)
    4 z$ k1 `" o7 O: g4 ~
  14. #define RCC_AHB1Periph_GPIOK             ((uint32_t)0x00000400)
    . }9 _# e' k6 d+ R
  15. #define RCC_AHB1Periph_CRC               ((uint32_t)0x00001000)
    0 e& R  j  u3 j
  16. #define RCC_AHB1Periph_FLITF             ((uint32_t)0x00008000)
    # ^: Q) i2 E# i( p  Q
  17. #define RCC_AHB1Periph_SRAM1             ((uint32_t)0x00010000)
    ; r3 l& b5 O- m* d
  18. #define RCC_AHB1Periph_SRAM2             ((uint32_t)0x00020000)* ^; `4 r& Q- n% }
  19. #define RCC_AHB1Periph_BKPSRAM           ((uint32_t)0x00040000)
    ' f5 v" M$ H" h/ H4 N) ^' a( v
  20. #define RCC_AHB1Periph_SRAM3             ((uint32_t)0x00080000)( {4 O! G$ Y, Z
  21. #define RCC_AHB1Periph_CCMDATARAMEN      ((uint32_t)0x00100000)! s  _8 f$ c% {- D2 _- V. `# l
  22. #define RCC_AHB1Periph_DMA1              ((uint32_t)0x00200000)  L7 f( Q: l. f  J# p
  23. #define RCC_AHB1Periph_DMA2              ((uint32_t)0x00400000)9 Q+ O4 d. ]& B" W  i+ O6 E
  24. #define RCC_AHB1Periph_DMA2D             ((uint32_t)0x00800000)
    * y. n/ d% u7 _% F6 K
  25. #define RCC_AHB1Periph_ETH_MAC           ((uint32_t)0x02000000)
    % P2 Y9 {  W. p+ N' y6 \6 o, ~+ |3 Q
  26. #define RCC_AHB1Periph_ETH_MAC_Tx        ((uint32_t)0x04000000)! D! O! J7 U/ L8 q; \& L9 s
  27. #define RCC_AHB1Periph_ETH_MAC_Rx        ((uint32_t)0x08000000)
    , D! l2 f  u' z$ }( e7 @* }
  28. #define RCC_AHB1Periph_ETH_MAC_PTP       ((uint32_t)0x10000000)
    ! Z7 q8 R5 p) t4 O
  29. #define RCC_AHB1Periph_OTG_HS            ((uint32_t)0x20000000): j+ V/ _5 B, @
  30. #define RCC_AHB1Periph_OTG_HS_ULPI       ((uint32_t)0x40000000)
    * G) r' b, [+ u8 D8 q
  31. * D( y3 k  D" }9 U2 _% ~8 B9 ^
  32. #define IS_RCC_AHB1_CLOCK_PERIPH(PERIPH)
    + h0 ~- I+ `5 V; n
  33.         ((((PERIPH) & 0x010BE800) == 0x00) && ((PERIPH) != 0x00))
    & p0 k& X" P( L2 ]5 S! }" X
  34. #define IS_RCC_AHB1_RESET_PERIPH(PERIPH) * m$ [' ]" [" N8 Q1 @2 p
  35.         ((((PERIPH) & 0x51FE800) == 0x00) && ((PERIPH) != 0x00))0 [  |! \/ M& A( ?' i7 U
  36. #define IS_RCC_AHB1_LPMODE_PERIPH(PERIPH) $ j: Y1 p- {0 h( e; e2 R, u
  37.         ((((PERIPH) & 0x01106800) == 0x00) && ((PERIPH) != 0x00))
    $ v+ U, C( h3 Q. P* ?: Q
: z' H1 U' K3 w' i1 L
RCC_AHB2_Peripherals
7 z/ ]* L- L6 A
  1. /** @defgroup RCC_AHB2_Peripherals % k- h, I+ h/ x- B( w& x& D. P, m
  2.   * @{
    0 a, P* u* @2 x
  3.   */  ' T5 X. I* v& i5 M4 f( V. q
  4. #define RCC_AHB2Periph_DCMI              ((uint32_t)0x00000001)
    : A6 ?5 L. g, c$ n' y
  5. #define RCC_AHB2Periph_CRYP              ((uint32_t)0x00000010)
    + m. Z* X( ]" K2 ^! ]: O! Y; [1 Z& i
  6. #define RCC_AHB2Periph_HASH              ((uint32_t)0x00000020)
    ; P) d$ i2 r. r& i# @& A
  7. #define RCC_AHB2Periph_OTG_FS            ((uint32_t)0x00000080)4 |! |3 A, m, [* L0 ~0 @
  8. #define IS_RCC_AHB2_PERIPH(PERIPH)
    ' V7 L6 X* h% \5 z
  9.         ((((PERIPH) & 0xFFFFFF0E) == 0x00) && ((PERIPH) != 0x00))
  H, C. F$ X5 l8 P- w" }
RCC_APB1_Peripherals
8 G- w4 d, ~/ v7 O, [/ I$ ^
  1. /** @defgroup RCC_APB1_Peripherals
    / H, l9 v% J. \* D
  2.   * @{
    ; |( u8 e4 X# {! Y% e) s9 M
  3.   */
    ! j6 c0 r" J6 v$ h, t1 @( t
  4. #define RCC_APB1Periph_TIM2              ((uint32_t)0x00000001)
    & O% T2 E2 n4 M: n& m0 U: `" E
  5. #define RCC_APB1Periph_TIM3              ((uint32_t)0x00000002)$ K* o  a4 @% k
  6. #define RCC_APB1Periph_TIM4              ((uint32_t)0x00000004)) J+ \! R% n/ N% @% d4 J3 a( E5 G5 ~
  7. #define RCC_APB1Periph_TIM5              ((uint32_t)0x00000008)$ c5 @; _/ I  G$ y( Q& n
  8. #define RCC_APB1Periph_TIM6              ((uint32_t)0x00000010): O- V/ b, u) }8 z  [; `+ |
  9. #define RCC_APB1Periph_TIM7              ((uint32_t)0x00000020)
    3 I! N; p2 P% S/ ]7 p4 y
  10. #define RCC_APB1Periph_TIM12             ((uint32_t)0x00000040)( D8 w8 d( `3 v, i
  11. #define RCC_APB1Periph_TIM13             ((uint32_t)0x00000080)
    ! K+ ^; {! @# W5 i6 |( l# j0 e
  12. #define RCC_APB1Periph_TIM14             ((uint32_t)0x00000100)
    ; ?- I' Y- i  F) A- U4 N6 v/ z
  13. #if defined(STM32F410xx) || defined(STM32F413_423xx)
    ' B5 z8 N( f( k) q3 W1 n; a& [4 Y
  14. #define RCC_APB1Periph_LPTIM1            ((uint32_t)0x00000200); z" ^, n; Z0 p7 r. c
  15. #endif /* STM32F410xx || STM32F413_423xx */
    " |/ k' I5 E6 }, z  u; n
  16. #define RCC_APB1Periph_WWDG              ((uint32_t)0x00000800)
    3 `6 Z, F* a# o& K0 i" X2 V
  17. #define RCC_APB1Periph_SPI2              ((uint32_t)0x00004000)
    0 B7 s7 p, g- F1 d) J6 p
  18. #define RCC_APB1Periph_SPI3              ((uint32_t)0x00008000)
    7 |; Z  P% K2 i$ e0 q) W
  19. #if defined(STM32F446xx)+ |/ D* G2 g2 ?6 m$ @
  20. #define RCC_APB1Periph_SPDIFRX           ((uint32_t)0x00010000). C$ o/ F+ `, [/ R# i
  21. #endif /* STM32F446xx */ * ]* d  \* f% @2 D" r  f& k
  22. #define RCC_APB1Periph_USART2            ((uint32_t)0x00020000). p2 `! U' K2 b4 F
  23. #define RCC_APB1Periph_USART3            ((uint32_t)0x00040000)1 m) U- w  z& b, P7 I
  24. #define RCC_APB1Periph_UART4             ((uint32_t)0x00080000)2 {7 }7 V  e4 V3 P( G
  25. #define RCC_APB1Periph_UART5             ((uint32_t)0x00100000)
    9 s! M6 T+ D2 l3 Z! I! g
  26. #define RCC_APB1Periph_I2C1              ((uint32_t)0x00200000)
    , z1 t, T; n# T' |
  27. #define RCC_APB1Periph_I2C2              ((uint32_t)0x00400000)
    2 E$ y" K* {: Z
  28. #define RCC_APB1Periph_I2C3              ((uint32_t)0x00800000)3 d# P, A) N1 X. f3 z. Z0 O. Y3 p
  29. #if defined(STM32F410xx) || defined(STM32F412xG) & Z" ]' }8 \' c5 q) d7 G
  30. || defined(STM32F413_423xx) || defined(STM32F446xx)1 |6 e& i8 u) S/ U, S
  31. #define RCC_APB1Periph_FMPI2C1           ((uint32_t)0x01000000)
    0 v" C1 p9 s2 U% E' k1 Z7 F" y" x
  32. #endif /* STM32F410xx || STM32F446xx || STM32F413_423xx*/ + V3 V; i* o+ p+ T$ I4 T. E4 ]* ]
  33. #define RCC_APB1Periph_CAN1              ((uint32_t)0x02000000)
    3 J9 x6 R: s( I4 t: B! y4 |4 J0 e, H
  34. #define RCC_APB1Periph_CAN2              ((uint32_t)0x04000000)
    + z$ s: [; C8 c' V, E" B
  35. #if defined(STM32F413_423xx)8 v' W8 D0 l. u& ]; e6 G$ j/ e' A
  36. #define RCC_APB1Periph_CAN3              ((uint32_t)0x08000000)+ E2 X7 m( {5 O% Q# s& t& j6 q& W
  37. #endif /* STM32F413_423xx */
    3 G8 ?: [$ `6 G( L# [! K( f
  38. #if defined(STM32F446xx)
    / H8 ?. _2 S, t  S) Z1 B
  39. #define RCC_APB1Periph_CEC               ((uint32_t)0x08000000)) F8 _" u0 {0 j( @6 p& }3 P. O
  40. #endif /* STM32F446xx */
    5 _8 ^4 N" K0 H+ T
  41. #define RCC_APB1Periph_PWR               ((uint32_t)0x10000000): Y0 ?  V: y( E1 X  D
  42. #define RCC_APB1Periph_DAC               ((uint32_t)0x20000000)9 E+ I8 Z0 R- H- f
  43. #define RCC_APB1Periph_UART7             ((uint32_t)0x40000000)3 f5 q2 L8 ]6 r& ?' y* k
  44. #define RCC_APB1Periph_UART8             ((uint32_t)0x80000000)2 L# c! w7 `/ w
  45. #define IS_RCC_APB1_PERIPH(PERIPH)
    8 R1 @; A# k. V/ \2 |
  46.     ((((PERIPH) & 0x00003600) == 0x00) && ((PERIPH) != 0x00))4 k1 z" x4 u6 c0 a0 t% _
3 V; o8 [% r- M( `# g% ORCC_APB2_Peripherals! ?0 n+ [) m# t* Q1 l1 L7 h
  1. /** @defgroup RCC_APB2_Peripherals - Q' H, I- ]: p" I  A6 x, p* m
  2.   * @{) B) h: b7 J/ ]; P8 r" s7 q
  3.   */ 4 N4 h8 G+ i0 Z4 o% l: X3 N$ q
  4. #define RCC_APB2Periph_TIM1              ((uint32_t)0x00000001)- x7 t' `2 v9 L4 o% O2 d: h. ~# X! M
  5. #define RCC_APB2Periph_TIM8              ((uint32_t)0x00000002)# e! p: l" h5 p( W3 s* s0 Y
  6. #define RCC_APB2Periph_USART1            ((uint32_t)0x00000010)
    # E. D  D& \4 E3 V; B* x
  7. #define RCC_APB2Periph_USART6            ((uint32_t)0x00000020)
    " \  o3 s; K  A* [# A
  8. #define RCC_APB2Periph_ADC               ((uint32_t)0x00000100)
    7 Q7 H) f6 x; \* R
  9. #define RCC_APB2Periph_ADC1              ((uint32_t)0x00000100)* w/ R6 q# e' q/ n/ [
  10. #define RCC_APB2Periph_ADC2              ((uint32_t)0x00000200)( x# l4 j" p9 V- T
  11. #define RCC_APB2Periph_ADC3              ((uint32_t)0x00000400)
    0 h# G4 u2 s$ d1 n. s
  12. #define RCC_APB2Periph_SDIO              ((uint32_t)0x00000800)9 M+ k9 K5 k' ^! \- Z- e
  13. #define RCC_APB2Periph_SPI1              ((uint32_t)0x00001000)
    0 j( x; v) k, E- H7 ~/ E% g( m
  14. #define RCC_APB2Periph_SPI4              ((uint32_t)0x00002000)
    5 ^/ \& `4 o3 b0 ^6 ]
  15. #define RCC_APB2Periph_SYSCFG            ((uint32_t)0x00004000)% R6 x2 `. l' E# c% ]; @6 W
  16. #define RCC_APB2Periph_EXTIT             ((uint32_t)0x00008000)
    6 V6 Z. a& u7 L! ~8 E
  17. #define RCC_APB2Periph_TIM9              ((uint32_t)0x00010000); l9 \* Y( p: u- F+ N0 C5 A( X
  18. #define RCC_APB2Periph_TIM10             ((uint32_t)0x00020000)
    # C9 n& v% N! |% r+ }
  19. #define RCC_APB2Periph_TIM11             ((uint32_t)0x00040000)
    $ \5 E7 \6 J. a: a: U6 W
  20. #define RCC_APB2Periph_SPI5              ((uint32_t)0x00100000)1 V8 a1 b. M7 \  ]( m& N
  21. #define RCC_APB2Periph_SPI6              ((uint32_t)0x00200000)
    + x8 {* U- F. d8 n$ S
  22. #define RCC_APB2Periph_SAI1              ((uint32_t)0x00400000)3 ]: i$ _: q2 Q. z4 m
  23. #if defined(STM32F446xx) || defined(STM32F469_479xx)1 }  b* Q: L0 t3 f
  24. #define RCC_APB2Periph_SAI2              ((uint32_t)0x00800000)( }" E1 }1 Z! f  Z( e
  25. #endif /* STM32F446xx || STM32F469_479xx */
    & r7 Z7 @/ B3 g. t# L+ G
  26. #define RCC_APB2Periph_LTDC              ((uint32_t)0x04000000)
    * p; ~. f  h4 U* K0 {: w
  27. #if defined(STM32F469_479xx)
    2 X, i+ ^; j8 g; r0 D7 G3 f
  28. #define RCC_APB2Periph_DSI               ((uint32_t)0x08000000)) G2 G: v+ A/ S
  29. #endif /* STM32F469_479xx */. ~8 x: p: K/ ]6 Z
  30. #if defined(STM32F412xG) || defined(STM32F413_423xx)
    " V/ O1 A# J9 J% M0 p6 w- k2 e* {
  31. #define RCC_APB2Periph_DFSDM1            ((uint32_t)0x01000000)
    * ^4 [/ X) K- f. ^
  32. #endif /* STM32F412xG || STM32F413_423xx */# b8 V# E9 _+ u# S& W. p
  33. #if defined(STM32F413_423xx)) `% S5 k1 G: X7 ]
  34. #define RCC_APB2Periph_DFSDM2            ((uint32_t)0x02000000)
    9 |, m& M) X) }* J  {
  35. #define RCC_APB2Periph_UART9             ((uint32_t)0x02000040)) t) F' r* ?6 J! c& T
  36. #define RCC_APB2Periph_UART10            ((uint32_t)0x00000080)
    7 R" J- x# P; L# V. F" [0 u
    6 t! m7 m( |5 a9 j) T
  38. / ]1 ^" r9 a: Q
  39. /* Legacy Defines */+ e7 T" c- S; o+ D$ [# K: ^3 t
  40. #define RCC_APB2Periph_DFSDM              RCC_APB2Periph_DFSDM1
    ) e$ x1 J$ f( `7 b& k5 m: Y% c1 D
  41. 5 p* ]& n. k9 F  J* q( t' ?" @
  42. #define IS_RCC_APB2_PERIPH(PERIPH)
    5 p: l% u/ g+ e8 [7 ?" H6 I
  43.         ((((PERIPH) & 0xF008000C) == 0x00) && ((PERIPH) != 0x00))
    " W6 c7 z& S9 x' b7 T$ B+ d5 V. W% n
  44. #define IS_RCC_APB2_RESET_PERIPH(PERIPH) - V( k! T% c- U$ z9 ~
  45.         ((((PERIPH) & 0xF208860C) == 0x00) && ((PERIPH) != 0x00))
9 f% ?: `- N% N7 T# l
RCC_MCO1_Clock_Source_Prescaler4 G# d0 ?0 X" r( R8 u( N
  1. /** @defgroup RCC_MCO1_Clock_Source_Prescaler8 j1 f" b" _4 Z3 l8 z
  2.   * @{
    0 m! C8 C5 }5 l, j4 j
  3.   */
    , q9 x0 @) d$ x% V( Z7 D$ a
  4. #define RCC_MCO1Source_HSI               ((uint32_t)0x00000000)
    ! g1 `7 q# x4 B) o
  5. #define RCC_MCO1Source_LSE               ((uint32_t)0x00200000)
    6 s% w6 z6 u$ k6 r6 }
  6. #define RCC_MCO1Source_HSE               ((uint32_t)0x00400000)
    3 r$ {) H* X: X. V, b
  7. #define RCC_MCO1Source_PLLCLK            ((uint32_t)0x00600000)
    $ K' u9 Q  _. b# ?  c( ^
  8. #define RCC_MCO1Div_1                    ((uint32_t)0x00000000), T( ~4 I, p# {1 i! h. ^8 x7 Z+ I
  9. #define RCC_MCO1Div_2                    ((uint32_t)0x04000000)
    ) s) n, A1 |" N6 [
  10. #define RCC_MCO1Div_3                    ((uint32_t)0x05000000)% J* x0 B: f9 |7 E; o
  11. #define RCC_MCO1Div_4                    ((uint32_t)0x06000000)9 c8 x% d1 P6 C: G
  12. #define RCC_MCO1Div_5                    ((uint32_t)0x07000000). P4 f8 S. k# {, x+ p
  13. #define IS_RCC_MCO1SOURCE(SOURCE) (((SOURCE) == RCC_MCO1Source_HSI)
    7 m/ D+ d4 D1 K3 G
  14. || ((SOURCE) == RCC_MCO1Source_LSE) || \& Y' R1 Y6 H. Z4 h; ~& t$ y. k
  15. ((SOURCE) == RCC_MCO1Source_HSE) || ((SOURCE) == RCC_MCO1Source_PLLCLK))
    8 J. S- w6 T4 @
  16.
    + P+ Z5 S) F+ U! x- D; w. H0 W
  17. #define IS_RCC_MCO1DIV(DIV) (((DIV) == RCC_MCO1Div_1) || ((DIV) == RCC_MCO1Div_2) || \- d. e9 b5 u7 ?& r& _
  18.                              ((DIV) == RCC_MCO1Div_3) || ((DIV) == RCC_MCO1Div_4) || \
    & H/ K" `  _& h/ x7 {
  19.                              ((DIV) == RCC_MCO1Div_5))
! d$ Y, f7 w" Z! W3 Z$ zRCC_MCO2_Clock_Source_Prescaler6 `- p% e. u) l
  1. /** @defgroup RCC_MCO2_Clock_Source_Prescaler
    & S2 m' h" p0 f" b7 M1 U
  2.   * @{
    4 H( i- o2 O1 N( t
  3.   */
    ) f+ _( N0 a) u& x  M% k0 k9 D9 s
  4. #define RCC_MCO2Source_SYSCLK            ((uint32_t)0x00000000)
    $ Q. ?% z8 S2 o3 ^" w. V4 n
  5. #define RCC_MCO2Source_PLLI2SCLK         ((uint32_t)0x40000000)9 X! I- c+ v% B( O5 ^
  6. #define RCC_MCO2Source_HSE               ((uint32_t)0x80000000)
    ( |& Q, ~7 [/ t+ k* p, x+ i& ^& m: d
  7. #define RCC_MCO2Source_PLLCLK            ((uint32_t)0xC0000000)2 U8 H, O. o$ u; Q
  8. #define RCC_MCO2Div_1                    ((uint32_t)0x00000000)
    ! _1 ?& ]6 m6 `  V, T( T8 q" R
  9. #define RCC_MCO2Div_2                    ((uint32_t)0x20000000)
    % x9 @* X! Q6 ?
  10. #define RCC_MCO2Div_3                    ((uint32_t)0x28000000), H( k" T" q5 ]6 a
  11. #define RCC_MCO2Div_4                    ((uint32_t)0x30000000)4 |6 R: N( P0 b2 A0 u1 B; G& z
  12. #define RCC_MCO2Div_5                    ((uint32_t)0x38000000)7 y, f$ B9 J3 o3 B
  13. #define IS_RCC_MCO2SOURCE(SOURCE) (((SOURCE) == RCC_MCO2Source_SYSCLK)
    1 U  h" C- ?! F# h) K7 ^
  14. || ((SOURCE) == RCC_MCO2Source_PLLI2SCLK)|| \
    9 w4 S9 c$ L- e8 `; H' b
  15.                                    ((SOURCE) == RCC_MCO2Source_HSE) , f0 o8 ^6 V2 e# S* g
  16.     || ((SOURCE) == RCC_MCO2Source_PLLCLK))5 \7 z$ U' r; L3 @* u, w
  17.                                    $ N3 p  C9 e; i$ T- Q$ b
  18. #define IS_RCC_MCO2DIV(DIV) (((DIV) == RCC_MCO2Div_1) || ((DIV) == RCC_MCO2Div_2) || \
    & v: `5 ?3 \% l/ v0 T4 B8 y; K
  19.                              ((DIV) == RCC_MCO2Div_3) || ((DIV) == RCC_MCO2Div_4) || \
    7 @5 Z2 L" i, u% e
  20.                              ((DIV) == RCC_MCO2Div_5))        9 H% [. H. r9 z5 a
6 g) K7 n# p2 u' c" X) t' C7 j
RCC_Flag
) d" h3 H+ P4 Z( O- r5 U
  1. /** @defgroup RCC_Flag 6 w6 M) M0 `9 b5 n' ^, c+ q
  2.   * @{* c5 S; \8 _9 q1 s, `/ A5 ^0 q& l* x
  3.   */) u& G# i  s/ G' j- b4 c
  4. #define RCC_FLAG_HSIRDY                  ((uint8_t)0x21)' k' \: I9 s2 u, D. P- b  Y: a% v
  5. #define RCC_FLAG_HSERDY                  ((uint8_t)0x31)
    ! R# e" n; `2 P  ^3 X! i& s- t2 P
  6. #define RCC_FLAG_PLLRDY                  ((uint8_t)0x39)
    - r, B9 {" d: G/ h
  7. #define RCC_FLAG_PLLI2SRDY               ((uint8_t)0x3B)2 s: w) G$ t4 m2 P
  8. #define RCC_FLAG_PLLSAIRDY               ((uint8_t)0x3D)0 l! \" }, P' f0 U( \9 X: r: }4 ^9 \
  9. #define RCC_FLAG_LSERDY                  ((uint8_t)0x41)% P& N; U8 a% c1 k
  10. #define RCC_FLAG_LSIRDY                  ((uint8_t)0x61)
    + `$ {! w$ [% \! t4 ^
  11. #define RCC_FLAG_BORRST                  ((uint8_t)0x79)
    ' S0 C, U3 [- \* C7 t
  12. #define RCC_FLAG_PINRST                  ((uint8_t)0x7A)
    4 N' u: m: g. a6 {
  13. #define RCC_FLAG_PORRST                  ((uint8_t)0x7B)9 K7 O/ p" m( _# p) @
  14. #define RCC_FLAG_SFTRST                  ((uint8_t)0x7C)
    2 N) {& }( H! V. Y8 ?% p
  15. #define RCC_FLAG_IWDGRST                 ((uint8_t)0x7D)
    , W+ m! h  ^1 V* R
  16. #define RCC_FLAG_WWDGRST                 ((uint8_t)0x7E); e5 w8 J2 V$ k
  17. #define RCC_FLAG_LPWRRST                 ((uint8_t)0x7F)7 r: g2 J5 q, f7 p
  18. % R% N, g/ U3 P0 N
  19. #define IS_RCC_FLAG(FLAG) (((FLAG) == RCC_FLAG_HSIRDY)   || ((FLAG) == RCC_FLAG_HSERDY) || \& F  J& i6 w# K- c9 [, q( z- p8 @
  20.                            ((FLAG) == RCC_FLAG_PLLRDY)   || ((FLAG) == RCC_FLAG_LSERDY) || \
    $ v3 u) R9 Y& I4 u
  21.                            ((FLAG) == RCC_FLAG_LSIRDY)   || ((FLAG) == RCC_FLAG_BORRST) || \
    1 M' e2 J6 A$ l" c' a" E% e
  22.                            ((FLAG) == RCC_FLAG_PINRST)   || ((FLAG) == RCC_FLAG_PORRST) || \
    2 f6 q8 X( c* J1 X$ f: o5 K' M6 T( n
  23.                            ((FLAG) == RCC_FLAG_SFTRST)   || ((FLAG) == RCC_FLAG_IWDGRST)|| \% I' W) i$ _1 ?. n5 P
  24.                            ((FLAG) == RCC_FLAG_WWDGRST)  || ((FLAG) == RCC_FLAG_LPWRRST)|| \
    8 ~  U' f# S2 P& ~: R! _( S
  25.                            ((FLAG) == RCC_FLAG_PLLI2SRDY)|| ((FLAG) == RCC_FLAG_PLLSAIRDY))
    : C/ U. h$ ~% h6 Q5 d
  26. * l# i( u7 ?: N, W1 ~
  27. #define IS_RCC_CALIBRATION_VALUE(VALUE) ((VALUE) <= 0x1F)
: P$ ~1 F8 V8 _* t% r1 I
03. 相关函数
, Z: ?- F  ^6 G
  1. /* Function used to set the RCC clock configuration to the default reset state */7 v+ a- D" n8 i5 ~* d6 `$ f
  2. void        RCC_DeInit(void);7 C6 D! G% W& F6 T3 Q& o
  3. # v  ^& h3 n2 U% I3 i, H
  4. /* Internal/external clocks, PLL, CSS and MCO configuration functions *********/
    9 W- }3 {8 y) h
  5. void        RCC_HSEConfig(uint8_t RCC_HSE);# I0 E2 e- L- u% D
  6. ErrorStatus RCC_WaitForHSEStartUp(void);0 w1 Z+ @* ?( f: u
  7. void        RCC_AdjustHSICalibrationValue(uint8_t HSICalibrationValue);0 D5 s1 [1 q- h7 Y
  8. void        RCC_HSICmd(FunctionalState NewState);- G1 H6 [& l: I7 @: P
  9. void        RCC_LSEConfig(uint8_t RCC_LSE);
      u) U# q. d) S" c
  10. void        RCC_LSICmd(FunctionalState NewState);4 \& m; s; _1 M+ s
  11.   |3 x" P1 L: d% T; D" I. y* I
  12. void        RCC_PLLCmd(FunctionalState NewState);0 k/ L: C1 B/ T+ N" B8 o
  13. $ _6 ^0 b6 {( Q1 ^% D3 A
  14. void        RCC_PLLConfig(uint32_t RCC_PLLSource, uint32_t PLLM, uint32_t PLLN,
    ) t2 y) D7 a4 w
  15.                           uint32_t PLLP, uint32_t PLLQ);" _3 \" c. `- u; o3 H
  16. . l) x6 h! s0 e% X" g
  17. void        RCC_PLLI2SCmd(FunctionalState NewState);8 X" }2 n" ~( L+ c! N( `
  18. * X& z5 @! h2 d% j
  19. void        RCC_PLLI2SConfig(uint32_t PLLI2SN, uint32_t PLLI2SR);  m- E0 `. [" N. L2 ]
  20. * N$ P; ^) R+ b( l% J5 F
  21. + H& Y* r6 f2 j! ^4 r% D
  22. void        RCC_PLLSAICmd(FunctionalState NewState);7 P1 _7 j+ W9 i: a6 u# R5 f
  23. $ K& @) A/ l6 `' Y
  24. void        RCC_PLLSAIConfig(uint32_t PLLSAIN, uint32_t PLLSAIQ, uint32_t PLLSAIR);5 |5 Z- }2 F+ |" _, Z
  25. void        RCC_ClockSecuritySystemCmd(FunctionalState NewState);
    ' B- ^& T7 Q0 Z6 U
  26. void        RCC_MCO1Config(uint32_t RCC_MCO1Source, uint32_t RCC_MCO1Div);, h; o6 \+ l8 ^1 {$ c9 ?
  27. void        RCC_MCO2Config(uint32_t RCC_MCO2Source, uint32_t RCC_MCO2Div);
    / N" N2 o5 @/ t# @
  28. , Y7 j; R1 {' j3 ?8 t9 c& t- b. K( s
  29. ' A: x6 V8 P9 t
  30. /* System, AHB and APB busses clocks configuration functions ******************/
    $ x! n" K: M* i: K
  31. void        RCC_SYSCLKConfig(uint32_t RCC_SYSCLKSource);. b% \7 J/ ^1 B8 a/ T
  32. uint8_t     RCC_GetSYSCLKSource(void);
    6 h5 ^: C# ]# |5 z/ o! }* [
  33. void        RCC_HCLKConfig(uint32_t RCC_SYSCLK);7 t4 a6 B9 ?! E9 u8 q" h3 {
  34. void        RCC_PCLK1Config(uint32_t RCC_HCLK);& ]: l& j/ o6 I, i( Z# b
  35. void        RCC_PCLK2Config(uint32_t RCC_HCLK);
    7 b' O, F* v$ R
  36. void        RCC_GetClocksFreq(RCC_ClocksTypeDef* RCC_Clocks);) }5 H8 L/ V4 M# A( R% g7 e
  37. 8 a9 p% b. H- a4 X8 K
  38. /* Peripheral clocks configuration functions **********************************/
      A$ i" Z, ]; G+ F( Y# C5 h" d
  39. void        RCC_RTCCLKConfig(uint32_t RCC_RTCCLKSource);8 V5 k% c7 I8 K6 @
  40. void        RCC_RTCCLKCmd(FunctionalState NewState);
    + l+ I. Q! e+ t+ \3 E0 S- v* b
  41. void        RCC_BackupResetCmd(FunctionalState NewState);
    5 n: E- e* F) X
  42. 8 Q2 g7 X+ ?4 S# @6 j" y& o
  43. 7 S$ i4 C0 m) Z: `. R
  44. void        RCC_I2SCLKConfig(uint32_t RCC_I2SCLKSource);
    : Y3 x9 q5 T4 }
  45. 7 K. \; g2 o* ^/ G
  46. % L( s& l4 X- K0 T1 |) X- D
  47. void        RCC_SAIBlockACLKConfig(uint32_t RCC_SAIBlockACLKSource);; q0 O* C8 ~0 L( `. H% u3 \
  48. void        RCC_SAIBlockBCLKConfig(uint32_t RCC_SAIBlockBCLKSource);2 D! `: m% \- C! b2 i2 k
  49. 9 t, ~1 g! Y$ a) c  Z
  50. ! G  @' K& k' G' Q+ P
  51. void        RCC_SAIPLLI2SClkDivConfig(uint32_t RCC_PLLI2SDivQ);- ?2 B2 J2 S% A; Q- W; n" x
  52. void        RCC_SAIPLLSAIClkDivConfig(uint32_t RCC_PLLSAIDivQ);, R' `) h  ^  i/ T: d8 r
  53. / p' G( H. C8 L5 u+ L
  54. - O* \( d1 z; U
  55. void        RCC_LTDCCLKDivConfig(uint32_t RCC_PLLSAIDivR);. i2 o/ K5 F" i' e+ u5 V
  56. void        RCC_TIMCLKPresConfig(uint32_t RCC_TIMCLKPrescaler);6 U! }. S4 _, h3 Y9 r4 s& y0 ]
  57. ; J" t% s/ J; |9 {/ r; U
  58. void        RCC_AHB1PeriphClockCmd(uint32_t RCC_AHB1Periph, FunctionalState NewState);
    ; A$ l0 R8 p! ~0 P* Y
  59. void        RCC_AHB2PeriphClockCmd(uint32_t RCC_AHB2Periph, FunctionalState NewState);- S4 U* X0 o& L" g/ m- U
  60. void        RCC_AHB3PeriphClockCmd(uint32_t RCC_AHB3Periph, FunctionalState NewState);
    + K) n. H% s9 T  b
  61. void        RCC_APB1PeriphClockCmd(uint32_t RCC_APB1Periph, FunctionalState NewState);6 G9 U) ]6 M2 K( I# ]; e7 r
  62. void        RCC_APB2PeriphClockCmd(uint32_t RCC_APB2Periph, FunctionalState NewState);
    8 e3 Y& Q& O. t* L) X" q
  63. 8 T3 w4 b7 j, P7 ]' E8 a+ z
  64. void        RCC_AHB1PeriphResetCmd(uint32_t RCC_AHB1Periph, FunctionalState NewState);
    2 J$ H& f5 ?' s7 G, q) ^7 u3 F: f1 G
  65. void        RCC_AHB2PeriphResetCmd(uint32_t RCC_AHB2Periph, FunctionalState NewState);
    * y1 X+ y+ q( S! Y& X
  66. void        RCC_AHB3PeriphResetCmd(uint32_t RCC_AHB3Periph, FunctionalState NewState);
    , w. g- i* l" [; {3 h- v
  67. void        RCC_APB1PeriphResetCmd(uint32_t RCC_APB1Periph, FunctionalState NewState);
    5 S4 Y# C8 C7 Y" P) ~
  68. void        RCC_APB2PeriphResetCmd(uint32_t RCC_APB2Periph, FunctionalState NewState);
    : \6 j0 D8 Y) ?9 G
  69. ' z1 _. {' x4 J) [' s# v' n' O1 x
  70. void        RCC_AHB1PeriphClockLPModeCmd(uint32_t RCC_AHB1Periph, FunctionalState NewState);
    9 \$ {, {3 c5 ?6 D3 k( d
  71. void        RCC_AHB2PeriphClockLPModeCmd(uint32_t RCC_AHB2Periph, FunctionalState NewState);
    & I/ ~% y$ Z2 [6 ]- b
  72. void        RCC_AHB3PeriphClockLPModeCmd(uint32_t RCC_AHB3Periph, FunctionalState NewState);" F" z9 J; \$ d  z5 Y' {
  73. void        RCC_APB1PeriphClockLPModeCmd(uint32_t RCC_APB1Periph, FunctionalState NewState);
    * S" L# p* k& y) E0 o7 }
  74. void        RCC_APB2PeriphClockLPModeCmd(uint32_t RCC_APB2Periph, FunctionalState NewState);) z# }9 {" J. T9 u5 E
  75. / |0 L& d1 w- T  n0 q' `
  76. 3 P6 Z" o, I" \7 m: G" B1 ^3 `
  77. /* Interrupts and flags management functions **********************************/
    2 x' r# M- b8 T3 H% I2 B
  78. void        RCC_ITConfig(uint8_t RCC_IT, FunctionalState NewState);
    : u2 D  x+ S, j0 a6 n
  79. FlagStatus  RCC_GetFlagStatus(uint8_t RCC_FLAG);
    , m- N$ z! b* u4 d: A* u
  80. void        RCC_ClearFlag(void);7 {) M" }, @! r( W  {( H
  81. ITStatus    RCC_GetITStatus(uint8_t RCC_IT);
    * m$ j0 S1 L. I9 {* Z
  82. void        RCC_ClearITPendingBit(uint8_t RCC_IT);
    2 O, |3 m/ Z2 k/ `9 s
# d9 [" j- p8 ^" ~
0 d: C2 J0 d5 x: J2 h; Z04. 结构体封装
+ Q# a7 y* Y, b2 {9 B% G
  1. /**
    $ c4 i- _5 L+ \4 h
  2.   * @brief Reset and Clock Control
    * S6 J5 i1 o  Q
  3.   */
    + }8 T' e+ A1 _# B
  4. 3 k! e  ?; {9 A: a
  5. typedef struct
    $ \0 e: F! @8 I, g8 y
  6. {
      z# F# ~  u3 @9 Q* z8 S
  7.   __IO uint32_t CR;            /*!< RCC clock control register,                                  Address offset: 0x00 */
    1 W. X: s0 r+ g+ K* ^
  8.   __IO uint32_t PLLCFGR;       /*!< RCC PLL configuration register,                              Address offset: 0x04 */' K6 j/ m4 W* L9 b% F- f
  9.   __IO uint32_t CFGR;          /*!< RCC clock configuration register,                            Address offset: 0x08 */
    6 p; y; C: ~/ {$ c$ m" A
  10.   __IO uint32_t CIR;           /*!< RCC clock interrupt register,                                Address offset: 0x0C */$ R; y" _( m/ P  G7 w2 v9 f
  11.   __IO uint32_t AHB1RSTR;      /*!< RCC AHB1 peripheral reset register,                          Address offset: 0x10 */
    , L: P  ^" T* ]0 x
  12.   __IO uint32_t AHB2RSTR;      /*!< RCC AHB2 peripheral reset register,                          Address offset: 0x14 */8 \0 }2 |" @0 E- X; {4 `. P! h) D% X
  13.   __IO uint32_t AHB3RSTR;      /*!< RCC AHB3 peripheral reset register,                          Address offset: 0x18 */9 l4 E8 \! E; S  b- ?. a
  14.   uint32_t      RESERVED0;     /*!< Reserved, 0x1C        */
    + M/ x: g( G1 O2 c' ]+ D
  15.   __IO uint32_t APB1RSTR;      /*!< RCC APB1 peripheral reset register,                          Address offset: 0x20 */5 v8 B" A% t: Q+ ]# z+ o! y: X2 P
  16.   __IO uint32_t APB2RSTR;      /*!< RCC APB2 peripheral reset register,                          Address offset: 0x24 */
    , {1 D9 l; f4 O/ L+ ]0 D
  17.   uint32_t      RESERVED1[2];  /*!< Reserved, 0x28-0x2C                                                               */. ]+ t4 q1 L4 w
  18.   __IO uint32_t AHB1ENR;       /*!< RCC AHB1 peripheral clock register,                          Address offset: 0x30 */" g) B5 [( R! J0 A
  19.   __IO uint32_t AHB2ENR;       /*!< RCC AHB2 peripheral clock register,                          Address offset: 0x34 */2 R: e3 X2 Z( n8 M+ u0 C: F% @  B! w- A
  20.   __IO uint32_t AHB3ENR;       /*!< RCC AHB3 peripheral clock register,                          Address offset: 0x38 */
    3 p% ?/ O9 {# n5 J
  21.   uint32_t      RESERVED2;     /*!< Reserved, 0x3C        */
    * \& z3 g. \4 o9 b. N+ q
  22.   __IO uint32_t APB1ENR;       /*!< RCC APB1 peripheral clock enable register,                   Address offset: 0x40 */
    7 i; M( x) d: ~' s$ _# `2 z- g% N' b
  23.   __IO uint32_t APB2ENR;       /*!< RCC APB2 peripheral clock enable register,                   Address offset: 0x44 */8 z' i6 b7 Q. X' ^# ^
  24.   uint32_t      RESERVED3[2];  /*!< Reserved, 0x48-0x4C                                                               */: T" r- k: \4 S) N! n+ s5 C/ r) G1 n
  25.   __IO uint32_t AHB1LPENR;     /*!< RCC AHB1 peripheral clock enable in low power mode register, Address offset: 0x50 */% m/ t2 p) a/ |1 u' ]
  26.   __IO uint32_t AHB2LPENR;     /*!< RCC AHB2 peripheral clock enable in low power mode register, Address offset: 0x54 */
    $ j/ m" h* B3 ^# A+ m% G5 `
  27.   __IO uint32_t AHB3LPENR;     /*!< RCC AHB3 peripheral clock enable in low power mode register, Address offset: 0x58 */' U1 F/ c4 g% h+ z- F! h( `
  28.   uint32_t      RESERVED4;     /*!< Reserved, 0x5C        */7 _3 S; g4 H7 f; l# ^/ @' d
  29.   __IO uint32_t APB1LPENR;     /*!< RCC APB1 peripheral clock enable in low power mode register, Address offset: 0x60 */: w9 A1 {  p; M9 U
  30.   __IO uint32_t APB2LPENR;     /*!< RCC APB2 peripheral clock enable in low power mode register, Address offset: 0x64 */
    * R5 g' ^( ]3 [6 D: T+ z
  31.   uint32_t      RESERVED5[2];  /*!< Reserved, 0x68-0x6C                                                               */8 h. a1 k( ^8 J- k* [3 W
  32.   __IO uint32_t BDCR;          /*!< RCC Backup domain control register,                          Address offset: 0x70 */
    1 ]5 P; f0 |8 B7 t* E2 t
  33.   __IO uint32_t CSR;           /*!< RCC clock control & status register,                         Address offset: 0x74 */
    " \5 x8 _; d) @5 l
  34.   uint32_t      RESERVED6[2];  /*!< Reserved, 0x78-0x7C                                                               */% A$ Z, B9 W' e1 d( G
  35.   __IO uint32_t SSCGR;         /*!< RCC spread spectrum clock generation register,               Address offset: 0x80 */2 c9 V5 A. k4 d- X4 b" M6 Q6 S7 y
  36.   __IO uint32_t PLLI2SCFGR;    /*!< RCC PLLI2S configuration register,                           Address offset: 0x84 */
    ! R/ s) V' u  @- L" G: g$ v7 D! K
  37.   __IO uint32_t PLLSAICFGR;    /*!< RCC PLLSAI configuration register,                           Address offset: 0x88 */
    $ n9 P6 h" C/ _* L, D9 {" @' F
  38.   __IO uint32_t DCKCFGR;       /*!< RCC Dedicated Clocks configuration register,                 Address offset: 0x8C */8 B2 r+ S* ?& M( x9 a8 F& R
  39.   __IO uint32_t CKGATENR;      /*!< RCC Clocks Gated Enable Register,                            Address offset: 0x90 */ /* Only for STM32F412xG, STM32413_423xx and STM32F446xx devices */
    ) S5 Y( z9 t# U! I9 ^+ V
  40.   __IO uint32_t DCKCFGR2;      /*!< RCC Dedicated Clocks configuration register 2,               Address offset: 0x94 */ /* Only for STM32F410xx, STM32F412xG, STM32413_423xx and STM32F446xx devices */: f* [: [' a% k) P
  41. * x% e3 H( b5 y, B" z+ S: T
  42. } RCC_TypeDef;
    1 O, [0 P" M  `& c/ A9 B
" Z) v( ~+ a/ _  v# F$ Z) ]! m
. J& I+ G+ S; Q0 D5 A
05. 其它: \" l1 T4 D- G/ l2 y
  1. /******************************************************************************/
    ! D/ i/ o# A/ \! X( A& I
  2. /*        */
    ' K; D; ^, L3 c- q3 l! d
  3. /*                         Reset and Clock Control                            */
    + i8 `7 I* N. N) `8 O) {
  4. /*        */% {9 T) ~6 T( D* N" }2 `& Y" A; b
  5. /******************************************************************************/+ `9 o. G+ @# ~3 p' y7 N2 ^
  6. /********************  Bit definition for RCC_CR register  ********************/
    2 D6 ?( ~4 l# j
  7. #define  RCC_CR_HSION                        ((uint32_t)0x00000001)
      k# j& U7 H) g4 @
  8. #define  RCC_CR_HSIRDY                       ((uint32_t)0x00000002)/ d: F4 Z. r% Y
  9. 4 r  [1 e) W  e* f) a' a. f$ ]
  10. #define  RCC_CR_HSITRIM                      ((uint32_t)0x000000F8)
    7 E( C4 u7 R* Z, _
  11. #define  RCC_CR_HSITRIM_0                    ((uint32_t)0x00000008)/*!<Bit 0 */
      i/ I1 R& W7 P6 h, W
  12. #define  RCC_CR_HSITRIM_1                    ((uint32_t)0x00000010)/*!<Bit 1 */
    6 t/ F% ^. g6 ~; L
  13. #define  RCC_CR_HSITRIM_2                    ((uint32_t)0x00000020)/*!<Bit 2 */8 b; Z" l5 [' m/ S3 a! K, e- \
  14. #define  RCC_CR_HSITRIM_3                    ((uint32_t)0x00000040)/*!<Bit 3 */
    , }- B& g. o+ a. g" z
  15. #define  RCC_CR_HSITRIM_4                    ((uint32_t)0x00000080)/*!<Bit 4 */
    2 j7 O9 u0 b, `9 l) v! P5 v% ~
  16. / ?0 C$ ?1 W" W+ Z$ v% \7 p/ k" ^
  17. #define  RCC_CR_HSICAL                       ((uint32_t)0x0000FF00)
    + A2 E& Y) @+ Q/ f  a4 ~
  18. #define  RCC_CR_HSICAL_0                     ((uint32_t)0x00000100)/*!<Bit 0 */
    * q. i. @' K  l
  19. #define  RCC_CR_HSICAL_1                     ((uint32_t)0x00000200)/*!<Bit 1 */& p  j! q  s7 \: A7 |; f+ }
  20. #define  RCC_CR_HSICAL_2                     ((uint32_t)0x00000400)/*!<Bit 2 */  W9 ^- o3 W' \/ K. U
  21. #define  RCC_CR_HSICAL_3                     ((uint32_t)0x00000800)/*!<Bit 3 */0 R) C: F; _2 O% N; ?
  22. #define  RCC_CR_HSICAL_4                     ((uint32_t)0x00001000)/*!<Bit 4 */
      N) ]# v* g2 J( ?: n
  23. #define  RCC_CR_HSICAL_5                     ((uint32_t)0x00002000)/*!<Bit 5 */
    / B% A. c( X& x" d7 h2 W2 Q$ g4 u
  24. #define  RCC_CR_HSICAL_6                     ((uint32_t)0x00004000)/*!<Bit 6 */
    3 I" c( s3 W$ H$ B
  25. #define  RCC_CR_HSICAL_7                     ((uint32_t)0x00008000)/*!<Bit 7 */. N' G$ L. `4 ^- @$ q! o, h
  26. $ K7 }6 v  s( Q' `
  27. #define  RCC_CR_HSEON                        ((uint32_t)0x00010000)
    3 Y# z# [* `/ {% k9 c# ^
  28. #define  RCC_CR_HSERDY                       ((uint32_t)0x00020000)' R; J# [, d3 Z) B0 V0 b
  29. #define  RCC_CR_HSEBYP                       ((uint32_t)0x00040000)
    6 f9 z: W3 H: r; M
  30. #define  RCC_CR_CSSON                        ((uint32_t)0x00080000)
    ) K. g5 D$ t+ \6 M3 S8 `
  31. #define  RCC_CR_PLLON                        ((uint32_t)0x01000000)
    * g" a5 S/ d; O* d: i8 F+ {
  32. #define  RCC_CR_PLLRDY                       ((uint32_t)0x02000000)4 T. V. b1 P& }9 [% D) U. G# e4 f) u
  33. #define  RCC_CR_PLLI2SON                     ((uint32_t)0x04000000)( m; h) c. @; j! E6 }& Z) F; @
  34. #define  RCC_CR_PLLI2SRDY                    ((uint32_t)0x08000000)
    4 Z0 G! W$ d6 B
  35. #define  RCC_CR_PLLSAION                     ((uint32_t)0x10000000)
    ( [  {- w% q, t5 U) B) U
  36. #define  RCC_CR_PLLSAIRDY                    ((uint32_t)0x20000000)
    ) E0 y0 [) V4 c: ~- U" y7 o
  37. 2 L+ L' L, P" z4 [/ A
  38. /********************  Bit definition for RCC_PLLCFGR register  ***************/
    3 W3 T0 i! l; r* M" N* V+ o
  39. #define  RCC_PLLCFGR_PLLM                    ((uint32_t)0x0000003F)
    - t$ o/ p! C/ l6 k
  40. #define  RCC_PLLCFGR_PLLM_0                  ((uint32_t)0x00000001)/ c' S' p& G4 v( ~
  41. #define  RCC_PLLCFGR_PLLM_1                  ((uint32_t)0x00000002)4 t4 H$ A% E- X) c/ B
  42. #define  RCC_PLLCFGR_PLLM_2                  ((uint32_t)0x00000004)
    ; e+ j: Y' X5 f' t, z& O* R: x
  43. #define  RCC_PLLCFGR_PLLM_3                  ((uint32_t)0x00000008)7 }) r! \/ v- h3 r& w
  44. #define  RCC_PLLCFGR_PLLM_4                  ((uint32_t)0x00000010)
    ; ~' k5 W: {: N0 m) @# i
  45. #define  RCC_PLLCFGR_PLLM_5                  ((uint32_t)0x00000020)
    6 n; K; p$ d  G* z( F% a
  46. 1 S$ T5 Y; C: v) ?; |  [
  47. #define  RCC_PLLCFGR_PLLN                     ((uint32_t)0x00007FC0)
    - M: O0 N  ^+ M  R
  48. #define  RCC_PLLCFGR_PLLN_0                   ((uint32_t)0x00000040)
    6 A% `3 j: l8 i; O
  49. #define  RCC_PLLCFGR_PLLN_1                   ((uint32_t)0x00000080)
      p) s' ^. N) n" s
  50. #define  RCC_PLLCFGR_PLLN_2                   ((uint32_t)0x00000100)# q; \4 |7 S# Q! v
  51. #define  RCC_PLLCFGR_PLLN_3                   ((uint32_t)0x00000200)% {( B( ^  s( U: x. ^" W
  52. #define  RCC_PLLCFGR_PLLN_4                   ((uint32_t)0x00000400)
    " X+ `/ Y2 k; E9 I) @2 j6 n  r
  53. #define  RCC_PLLCFGR_PLLN_5                   ((uint32_t)0x00000800)
    - v6 x/ l# m; ~7 m; ]8 w  L. @
  54. #define  RCC_PLLCFGR_PLLN_6                   ((uint32_t)0x00001000); x2 Q- z& Y. f- D9 \/ [; [* [4 K
  55. #define  RCC_PLLCFGR_PLLN_7                   ((uint32_t)0x00002000)
    + |9 A8 L2 [3 ]* i$ o
  56. #define  RCC_PLLCFGR_PLLN_8                   ((uint32_t)0x00004000)
    ( J, L# o- b0 L, a
  57. 3 j) j7 S! ~& z/ s
  58. #define  RCC_PLLCFGR_PLLP                    ((uint32_t)0x00030000)! m2 h/ ^9 b8 O  v& ~$ V
  59. #define  RCC_PLLCFGR_PLLP_0                  ((uint32_t)0x00010000)9 e' X9 G" G9 \; I! X  V
  60. #define  RCC_PLLCFGR_PLLP_1                  ((uint32_t)0x00020000)( u  {3 ^: d* c9 |7 G& Y! z
  61. # O# s9 m2 p# I9 w$ H  J
  62. #define  RCC_PLLCFGR_PLLSRC                  ((uint32_t)0x00400000)
    & E, B3 B8 Y# _! Q
  63. #define  RCC_PLLCFGR_PLLSRC_HSE              ((uint32_t)0x00400000)
    4 W" G) _( w; M" s
  64. #define  RCC_PLLCFGR_PLLSRC_HSI              ((uint32_t)0x00000000)3 L. d1 s7 ?% d- _, W* V/ o+ E3 P
  65.   g& v$ O- j3 w# M- n5 Q: v) f
  66. #define  RCC_PLLCFGR_PLLQ                    ((uint32_t)0x0F000000)
    ; a0 E- m; m' L# ]
  67. #define  RCC_PLLCFGR_PLLQ_0                  ((uint32_t)0x01000000)6 L" t9 i: X: ~5 s
  68. #define  RCC_PLLCFGR_PLLQ_1                  ((uint32_t)0x02000000)
    ( S0 h5 N! T# e: @
  69. #define  RCC_PLLCFGR_PLLQ_2                  ((uint32_t)0x04000000)9 \3 [, M& [3 y! t  q3 E  H
  70. #define  RCC_PLLCFGR_PLLQ_3                  ((uint32_t)0x08000000)3 I& i, y- p. v$ h
  71. ' n+ R  a* [8 B' ]: Y) }3 |4 c  u
  72. #if defined(STM32F412xG) || defined(STM32F413_423xx) || defined(STM32F446xx) || defined(STM32F469_479xx)
    / _" R$ f5 Z# J3 I- r; a4 }0 C; F7 x
  73. #define  RCC_PLLCFGR_PLLR                    ((uint32_t)0x70000000)
    ; n6 l% r  W9 C( X; f6 l
  74. #define  RCC_PLLCFGR_PLLR_0                  ((uint32_t)0x10000000)
    : J! g) R; [; d6 Z+ B
  75. #define  RCC_PLLCFGR_PLLR_1                  ((uint32_t)0x20000000)4 K* c, m7 f5 c- T" M4 d
  76. #define  RCC_PLLCFGR_PLLR_2                  ((uint32_t)0x40000000)/ T0 o( ]% Z6 J8 K8 x: m, [/ e
  77. #endif /* STM32F412xG || STM32F413_423xx || STM32F446xx || STM32F469_479xx */
    " x6 S) D9 J6 e* U( F3 y
  78. , \3 L+ d. G% H/ Y/ H; D
  79. /********************  Bit definition for RCC_CFGR register  ******************/4 ?! h# G* h1 t! U* @5 m" x
  80. /*!< SW configuration */
    * c* \4 v$ ?% X2 v3 T. `5 q% ]! G
  81. #define  RCC_CFGR_SW                         ((uint32_t)0x00000003)        /*!< SW[1:0] bits (System clock Switch) */, p- d% Z$ d, G# U1 T4 q
  82. #define  RCC_CFGR_SW_0                       ((uint32_t)0x00000001)        /*!< Bit 0 */
    : b! _: H; o8 t) G0 L0 E! x
  83. #define  RCC_CFGR_SW_1                       ((uint32_t)0x00000002)        /*!< Bit 1 */# z( X! R' W( t" Z$ D9 @7 ?
  84. 7 v: {9 q4 |# b8 n0 J
  85. #define  RCC_CFGR_SW_HSI                     ((uint32_t)0x00000000)        /*!< HSI selected as system clock */& P) b& B7 u/ r2 R
  86. #define  RCC_CFGR_SW_HSE                     ((uint32_t)0x00000001)        /*!< HSE selected as system clock */" V4 @* {- F1 Y$ \" e
  87. #define  RCC_CFGR_SW_PLL                     ((uint32_t)0x00000002)        /*!< PLL/PLLP selected as system clock */
    & [* f+ D: b! c6 ]
  88. #if defined(STM32F412xG) || defined(STM32F413_423xx) || defined(STM32F446xx) || defined(STM32F469_479xx)
    9 ~: q6 J- Q, ^# D4 o
  89. #define  RCC_CFGR_SW_PLLR                    ((uint32_t)0x00000003)        /*!< PLL/PLLR selected as system clock */
    5 U% `. q  u- P' s& e  q
  90. #endif /* STM32F412xG || STM32F413_423xx || STM32F446xx || STM32F469_479xx */
    4 K' F; B7 S2 A! J. n
  91. ' E, F% q+ l) H& F8 L
  92. /*!< SWS configuration */
    # M! }# n; w- g' K- z. @2 k6 X
  93. #define  RCC_CFGR_SWS                        ((uint32_t)0x0000000C)        /*!< SWS[1:0] bits (System Clock Switch Status) */5 l  v( b4 i, Q0 c2 R
  94. #define  RCC_CFGR_SWS_0                      ((uint32_t)0x00000004)        /*!< Bit 0 */
    9 _. z+ q2 k4 i* s+ Z) W, N
  95. #define  RCC_CFGR_SWS_1                      ((uint32_t)0x00000008)        /*!< Bit 1 */! X* s( m! f8 r3 v4 D  `
  96. 9 S2 c- ^& N2 [
  97. #define  RCC_CFGR_SWS_HSI                    ((uint32_t)0x00000000)        /*!< HSI oscillator used as system clock */
    / i- e4 Q& r& c# G
  98. #define  RCC_CFGR_SWS_HSE                    ((uint32_t)0x00000004)        /*!< HSE oscillator used as system clock */
    * d  k# ]6 b! v% x2 C# h
  99. #define  RCC_CFGR_SWS_PLL                    ((uint32_t)0x00000008)        /*!< PLL/PLLP used as system clock       */
    , d! x4 ?  n& J4 |9 e* H; E, @
  100. #if defined(STM32F412xG) || defined(STM32F413_423xx) || defined(STM32F469_479xx) || defined(STM32F446xx)8 j9 a" q) [) Q
  101. #define  RCC_CFGR_SWS_PLLR                   ((uint32_t)0x0000000C)        /*!< PLL/PLLR used as system clock       */
    # v& ^& g! m8 i' z  l' I& p
  102. #endif /* STM32F412xG || STM32F413_423xx || STM32F446xx || STM32F469_479xx */
    # G) Q! E' g% n. K3 S5 u! G* m' G
  103. ( [3 K% @, @% k
  104. /*!< HPRE configuration */8 x7 K# m- m3 P9 a- T
  105. #define  RCC_CFGR_HPRE                       ((uint32_t)0x000000F0)        /*!< HPRE[3:0] bits (AHB prescaler) */+ z+ P. W4 r1 |, g" g7 u& @0 C* c
  106. #define  RCC_CFGR_HPRE_0                     ((uint32_t)0x00000010)        /*!< Bit 0 */
      B8 j6 B8 u9 p
  107. #define  RCC_CFGR_HPRE_1                     ((uint32_t)0x00000020)        /*!< Bit 1 */3 z- V% o" M. D, K1 ?
  108. #define  RCC_CFGR_HPRE_2                     ((uint32_t)0x00000040)        /*!< Bit 2 */* }. `0 z7 f" l8 H
  109. #define  RCC_CFGR_HPRE_3                     ((uint32_t)0x00000080)        /*!< Bit 3 */: G9 D' d7 X: [/ P
  110. " f* @4 _- S  M! B3 B8 }; t8 m
  111. #define  RCC_CFGR_HPRE_DIV1                  ((uint32_t)0x00000000)        /*!< SYSCLK not divided */
    $ w! _& [) }' v% @' b
  112. #define  RCC_CFGR_HPRE_DIV2                  ((uint32_t)0x00000080)        /*!< SYSCLK divided by 2 */' k* S! k+ o+ _- g
  113. #define  RCC_CFGR_HPRE_DIV4                  ((uint32_t)0x00000090)        /*!< SYSCLK divided by 4 */
    ) S1 C/ K  t: N# S
  114. #define  RCC_CFGR_HPRE_DIV8                  ((uint32_t)0x000000A0)        /*!< SYSCLK divided by 8 */7 x; j0 w/ h, w2 c) J3 u& s, n
  115. #define  RCC_CFGR_HPRE_DIV16                 ((uint32_t)0x000000B0)        /*!< SYSCLK divided by 16 */$ a+ ^2 U! k& H9 w/ _
  116. #define  RCC_CFGR_HPRE_DIV64                 ((uint32_t)0x000000C0)        /*!< SYSCLK divided by 64 */
    $ Q& F/ |5 ?1 k8 O9 U- f: m
  117. #define  RCC_CFGR_HPRE_DIV128                ((uint32_t)0x000000D0)        /*!< SYSCLK divided by 128 */" e6 i% J5 Y1 S$ r5 o
  118. #define  RCC_CFGR_HPRE_DIV256                ((uint32_t)0x000000E0)        /*!< SYSCLK divided by 256 */' t# n' K" |. h6 Z2 q1 K! z
  119. #define  RCC_CFGR_HPRE_DIV512                ((uint32_t)0x000000F0)        /*!< SYSCLK divided by 512 */' G9 K6 d& y+ b6 c: y/ Y* E$ W( ^7 ?
  120. - W9 ^! ]+ s, Y" C% p/ j& `
  121. #if defined(STM32F410xx)
    0 ]; d( A, l1 o* ]8 r
  122. /*!< MCO1EN configuration */
    1 x+ B) F5 B# w
  123. #define  RCC_CFGR_MCO1EN                     ((uint32_t)0x00000100)        /*!< MCO1EN bit */
    # s3 v. Z6 {* ^3 h; s" K. p
  124. /*!< MCO1EN configuration */, ^% e& b# V" X: R4 q, @
  125. #define  RCC_CFGR_MCO2EN                     ((uint32_t)0x00000200)        /*!< MCO2EN bit */
    ! `4 I5 h: n3 T5 m$ P
  126. #endif /* STM32F410xx */, j9 H$ _5 _7 D7 Y2 `( _5 q4 L7 g
  127. /*!< PPRE1 configuration */
    # n9 X8 U6 S5 E! R; W! x7 y
  128. #define  RCC_CFGR_PPRE1                      ((uint32_t)0x00001C00)        /*!< PRE1[2:0] bits (APB1 prescaler) */
    - v4 B* @; u" _& K7 j( K' ^8 t
  129. #define  RCC_CFGR_PPRE1_0                    ((uint32_t)0x00000400)        /*!< Bit 0 */
    ' }% }. O' J* H$ F! R
  130. #define  RCC_CFGR_PPRE1_1                    ((uint32_t)0x00000800)        /*!< Bit 1 */9 [6 x4 _* c+ r1 G
  131. #define  RCC_CFGR_PPRE1_2                    ((uint32_t)0x00001000)        /*!< Bit 2 */4 y- O  N) l8 W; W2 Z1 R; S3 q: f
  132. ' S$ W& B" ?6 J2 ]9 V9 q
  133. #define  RCC_CFGR_PPRE1_DIV1                 ((uint32_t)0x00000000)        /*!< HCLK not divided */. I: N; ]7 |! x* X/ [# U7 v
  134. #define  RCC_CFGR_PPRE1_DIV2                 ((uint32_t)0x00001000)        /*!< HCLK divided by 2 */
    + b# S4 Z/ J4 ?, u2 C  A) P
  135. #define  RCC_CFGR_PPRE1_DIV4                 ((uint32_t)0x00001400)        /*!< HCLK divided by 4 */) }! f3 l0 h, j' S) A4 z
  136. #define  RCC_CFGR_PPRE1_DIV8                 ((uint32_t)0x00001800)        /*!< HCLK divided by 8 */% h, ^5 [8 m) V) y; P: p
  137. #define  RCC_CFGR_PPRE1_DIV16                ((uint32_t)0x00001C00)        /*!< HCLK divided by 16 */7 |& Z0 W) p3 q$ n/ N
  138. 7 `6 r; s1 b! u: W" P. l$ {# \
  139. /*!< PPRE2 configuration */
    7 Q9 D' M3 l6 w
  140. #define  RCC_CFGR_PPRE2                      ((uint32_t)0x0000E000)        /*!< PRE2[2:0] bits (APB2 prescaler) */
    $ y/ h# R# |( [/ u, P& m
  141. #define  RCC_CFGR_PPRE2_0                    ((uint32_t)0x00002000)        /*!< Bit 0 */7 M" `0 e, Q( f6 {
  142. #define  RCC_CFGR_PPRE2_1                    ((uint32_t)0x00004000)        /*!< Bit 1 */# L& X; v3 L- k" x$ j4 S) p
  143. #define  RCC_CFGR_PPRE2_2                    ((uint32_t)0x00008000)        /*!< Bit 2 */
    8 H  g! W( A! X
  144. 2 {3 K3 j, n! V4 y6 Q6 C
  145. #define  RCC_CFGR_PPRE2_DIV1                 ((uint32_t)0x00000000)        /*!< HCLK not divided */
    1 p% A, J2 j( R& y$ N/ j
  146. #define  RCC_CFGR_PPRE2_DIV2                 ((uint32_t)0x00008000)        /*!< HCLK divided by 2 */
    7 t8 B( G2 s; Q' m) a/ x2 T3 b) ]5 Z
  147. #define  RCC_CFGR_PPRE2_DIV4                 ((uint32_t)0x0000A000)        /*!< HCLK divided by 4 */# t+ b# i0 x# O, @
  148. #define  RCC_CFGR_PPRE2_DIV8                 ((uint32_t)0x0000C000)        /*!< HCLK divided by 8 */
    ! N* R4 H9 T, @0 N; Y  t  i
  149. #define  RCC_CFGR_PPRE2_DIV16                ((uint32_t)0x0000E000)        /*!< HCLK divided by 16 */, O4 h& \. Z9 P) d0 K7 l. X' [7 A* y
  150. + b# T# N; W  a! F/ A  d
  151. /*!< RTCPRE configuration */! ^1 U0 `- e. u- @  c9 W3 a
  152. #define  RCC_CFGR_RTCPRE                     ((uint32_t)0x001F0000)
    1 Z/ G9 k9 g6 U7 s% M
  153. #define  RCC_CFGR_RTCPRE_0                   ((uint32_t)0x00010000)
    1 F; _7 j* B$ ^8 K- U7 F0 j+ l
  154. #define  RCC_CFGR_RTCPRE_1                   ((uint32_t)0x00020000)
    ( X0 }# J& i% G
  155. #define  RCC_CFGR_RTCPRE_2                   ((uint32_t)0x00040000)% }! D$ b! [8 p0 |+ J3 T: J
  156. #define  RCC_CFGR_RTCPRE_3                   ((uint32_t)0x00080000)1 D( ]% E; k! u7 M% a+ K
  157. #define  RCC_CFGR_RTCPRE_4                   ((uint32_t)0x00100000), P: n, R8 n5 S9 p
  158. % J( f4 S" g' f! @1 R
  159. /*!< MCO1 configuration */
    : E  e# C% |1 ~* L! ^3 t
  160. #define  RCC_CFGR_MCO1                       ((uint32_t)0x00600000)- }8 {- v& E! f+ i. q. }' H1 x7 s
  161. #define  RCC_CFGR_MCO1_0                     ((uint32_t)0x00200000)$ a& ?; A: I. f* a2 k5 \+ [
  162. #define  RCC_CFGR_MCO1_1                     ((uint32_t)0x00400000)  y! p% S% Z7 O3 h
  163. 2 X0 u7 a  q9 J
  164. #define  RCC_CFGR_I2SSRC                     ((uint32_t)0x00800000)
    0 K7 _' s. h  ^: ^" e0 X; R1 f
  165. / Q) E  r* g2 Z1 k' j
  166. #define  RCC_CFGR_MCO1PRE                    ((uint32_t)0x07000000)& ~1 ~% ]1 Y9 V" z3 V2 Y
  167. #define  RCC_CFGR_MCO1PRE_0                  ((uint32_t)0x01000000)
    8 G2 r! E$ n) K# _3 O9 h: l: V
  168. #define  RCC_CFGR_MCO1PRE_1                  ((uint32_t)0x02000000), w6 {% O" c  G$ a. @( E
  169. #define  RCC_CFGR_MCO1PRE_2                  ((uint32_t)0x04000000)
    ' S. {$ z) Q. W; c
  170. 0 C8 Z7 a+ J, j* m" |- J' v2 d9 b
  171. #define  RCC_CFGR_MCO2PRE                    ((uint32_t)0x38000000)
    ( K5 m  {7 H4 B
  172. #define  RCC_CFGR_MCO2PRE_0                  ((uint32_t)0x08000000)$ J0 W& \7 U0 H1 q6 |& t6 e& J0 V
  173. #define  RCC_CFGR_MCO2PRE_1                  ((uint32_t)0x10000000)
    . m! d7 x2 K, ~. u
  174. #define  RCC_CFGR_MCO2PRE_2                  ((uint32_t)0x20000000)8 }: _* Q7 O% o$ o7 m+ Y* _
  175. ! b. D& `/ f2 d8 B2 m* s) r
  176. #define  RCC_CFGR_MCO2                       ((uint32_t)0xC0000000)# G8 t& k% D' \8 P* a
  177. #define  RCC_CFGR_MCO2_0                     ((uint32_t)0x40000000)0 O1 X8 [9 J( n. q+ D
  178. #define  RCC_CFGR_MCO2_1                     ((uint32_t)0x80000000)  V/ j) j7 g0 K# S) R
  179. 7 b+ d) h, q, k; s& o0 Z
  180. /********************  Bit definition for RCC_CIR register  *******************/
    ( ~3 V- L  S7 ^# N
  181. #define  RCC_CIR_LSIRDYF                     ((uint32_t)0x00000001)
    1 A/ L5 I, m' {4 [5 L9 Q3 Z$ P8 w) N
  182. #define  RCC_CIR_LSERDYF                     ((uint32_t)0x00000002), W4 g2 k9 N  d$ ]* f, f  G
  183. #define  RCC_CIR_HSIRDYF                     ((uint32_t)0x00000004)
    8 O; ~- ]' ~# b+ p& F  B
  184. #define  RCC_CIR_HSERDYF                     ((uint32_t)0x00000008)8 x0 _* l. P. {7 n$ v& l9 q/ W
  185. #define  RCC_CIR_PLLRDYF                     ((uint32_t)0x00000010)
    1 v/ `. A% Z- N. B- v: N3 i1 N
  186. #define  RCC_CIR_PLLI2SRDYF                  ((uint32_t)0x00000020)
    ; l( I  j: \. `  {  k0 D) k
  187. #define  RCC_CIR_PLLSAIRDYF                  ((uint32_t)0x00000040)
      Y4 M  z2 P9 z  R. c) b/ l
  188. #define  RCC_CIR_CSSF                        ((uint32_t)0x00000080)
    % a, g3 [3 m  h" r( o2 M- y3 e! x$ M8 v6 e4 I
  189. #define  RCC_CIR_LSIRDYIE                    ((uint32_t)0x00000100)
    , B( O# D1 Z8 {! @8 I: l. h
  190. #define  RCC_CIR_LSERDYIE                    ((uint32_t)0x00000200)
    & i, ?+ F& o% k
  191. #define  RCC_CIR_HSIRDYIE                    ((uint32_t)0x00000400)3 ~% P0 v/ }- t: I+ d7 W
  192. #define  RCC_CIR_HSERDYIE                    ((uint32_t)0x00000800)% }" ]2 N" A4 v
  193. #define  RCC_CIR_PLLRDYIE                    ((uint32_t)0x00001000)- I8 W3 E7 S' h, ?: b
  194. #define  RCC_CIR_PLLI2SRDYIE                 ((uint32_t)0x00002000)
    ! m2 ?0 l7 P' v1 o: C. E1 \
  195. #define  RCC_CIR_PLLSAIRDYIE                 ((uint32_t)0x00004000)
    , \5 I9 R( I. S# ^, _4 O- n
  196. #define  RCC_CIR_LSIRDYC                     ((uint32_t)0x00010000)$ l! D; ~: q; f  P+ r
  197. #define  RCC_CIR_LSERDYC                     ((uint32_t)0x00020000)
    7 s2 T6 `3 J3 u- Y6 Y) [) @
  198. #define  RCC_CIR_HSIRDYC                     ((uint32_t)0x00040000)
    4 b( l& K3 d/ ~
  199. #define  RCC_CIR_HSERDYC                     ((uint32_t)0x00080000)
    5 G9 r4 Q0 L, P3 ~9 c" ^
  200. #define  RCC_CIR_PLLRDYC                     ((uint32_t)0x00100000)5 g3 B* ^9 j5 g) u$ k
  201. #define  RCC_CIR_PLLI2SRDYC                  ((uint32_t)0x00200000)0 m. [( d" R- L+ @* p% T2 q; \
  202. #define  RCC_CIR_PLLSAIRDYC                  ((uint32_t)0x00400000)2 L; V. ?$ d- y
  203. #define  RCC_CIR_CSSC                        ((uint32_t)0x00800000). _2 T" t) K0 v5 \/ Z9 b
  204. 3 X( ]' ^0 r3 R) h  y' `
  205. /********************  Bit definition for RCC_AHB1RSTR register  **************/
    1 j: A5 W- R) E6 ^4 O
  206. #define  RCC_AHB1RSTR_GPIOARST               ((uint32_t)0x00000001)
    + P8 \4 ]7 {6 z
  207. #define  RCC_AHB1RSTR_GPIOBRST               ((uint32_t)0x00000002)
    . E+ r/ {+ ~% R7 L+ L; m1 ]
  208. #define  RCC_AHB1RSTR_GPIOCRST               ((uint32_t)0x00000004)
      ?% |+ m; t. c: o  b" p1 l
  209. #define  RCC_AHB1RSTR_GPIODRST               ((uint32_t)0x00000008)
    * h& P: P9 T: N* c
  210. #define  RCC_AHB1RSTR_GPIOERST               ((uint32_t)0x00000010)
    " C3 A9 Y. }8 h6 R* ?
  211. #define  RCC_AHB1RSTR_GPIOFRST               ((uint32_t)0x00000020), d" N4 H" b9 _% c6 ?! u
  212. #define  RCC_AHB1RSTR_GPIOGRST               ((uint32_t)0x00000040)! @, O* P# D% N& o
  213. #define  RCC_AHB1RSTR_GPIOHRST               ((uint32_t)0x00000080)' S4 l. ]4 J. _
  214. #define  RCC_AHB1RSTR_GPIOIRST               ((uint32_t)0x00000100)
    1 m, f9 o3 P5 P
  215. #define  RCC_AHB1RSTR_GPIOJRST               ((uint32_t)0x00000200)
    ; G$ z7 b0 t. z; q; E5 q1 v
  216. #define  RCC_AHB1RSTR_GPIOKRST               ((uint32_t)0x00000400); f3 D- ~5 e3 m, @+ C# A+ s# e2 n$ X
  217. #define  RCC_AHB1RSTR_CRCRST                 ((uint32_t)0x00001000)# V0 @+ b3 m7 s. H
  218. #define  RCC_AHB1RSTR_DMA1RST                ((uint32_t)0x00200000)1 L, n; C; @1 W# a7 ~4 P
  219. #define  RCC_AHB1RSTR_DMA2RST                ((uint32_t)0x00400000)2 T$ M6 p0 n# u8 K6 H; n
  220. #define  RCC_AHB1RSTR_DMA2DRST               ((uint32_t)0x00800000)
    ; {9 ^' ]; X4 F& k! O( x
  221. #define  RCC_AHB1RSTR_ETHMACRST              ((uint32_t)0x02000000)
    # u+ l+ j, V, g( k, a' W& {8 R
  222. #define  RCC_AHB1RSTR_OTGHRST                ((uint32_t)0x10000000)2 p; T; p) X' b. h; V
  223. % O4 j" w* R8 [; V5 K
  224. /********************  Bit definition for RCC_AHB2RSTR register  **************/0 g9 d+ [/ _: ]+ \) r
  225. #define  RCC_AHB2RSTR_DCMIRST                ((uint32_t)0x00000001)
    6 a* N/ O4 ~( a& O9 m0 `
  226. #define  RCC_AHB2RSTR_CRYPRST                ((uint32_t)0x00000010)
    . r1 ^% G# q8 g+ a
  227. #define  RCC_AHB2RSTR_HASHRST                ((uint32_t)0x00000020)
    9 C2 g' m! r" j0 }# u, R) p0 K" y
  228. /* maintained for legacy purpose */# l7 s9 B+ O2 i" ^5 {7 _( A$ w
  229. #define  RCC_AHB2RSTR_HSAHRST                RCC_AHB2RSTR_HASHRST
    & n) h$ \$ O; o% m; {9 M- Z
  230. #define  RCC_AHB2RSTR_RNGRST                 ((uint32_t)0x00000040)' i% A/ o4 d) Q" B5 L* l/ v
  231. #define  RCC_AHB2RSTR_OTGFSRST               ((uint32_t)0x00000080)" T9 q( H, @2 Z. m
  232. 6 ~: U& F5 o1 z3 C7 v6 n7 s* x1 D
  233. /********************  Bit definition for RCC_AHB3RSTR register  **************/3 D5 G& u# W4 F( R6 ^
  234. #if defined(STM32F40_41xxx) || defined(STM32F412xG) || defined(STM32F413_423xx)/ Q) P  I1 O) f0 w6 C
  235. #define  RCC_AHB3RSTR_FSMCRST                ((uint32_t)0x00000001); h+ g8 l9 H: `) y( [7 \/ m
  236. #endif /* STM32F40_41xxx || STM32F412xG || STM32F413_423xx */& Y6 G! u1 s# X' P: M: _! \
  237. " y% L* Y9 q* G8 L
  238. #if defined(STM32F427_437xx) || defined(STM32F429_439xx) || defined(STM32F446xx) || defined(STM32F469_479xx)" F, y9 y% [2 K0 D5 x- ^' T
  239. #define  RCC_AHB3RSTR_FMCRST                ((uint32_t)0x00000001)
    * s/ m* S$ v3 |* d
  240. #endif /* STM32F427_437xx ||  STM32F429_439xx || STM32F446xx || STM32F469_479xx */
      w5 J9 ~7 T# t" H4 v  s, J
  241. #if defined(STM32F412xG) || defined(STM32F413_423xx) || defined(STM32F446xx) || defined(STM32F469_479xx)4 l; p, F5 n$ K  [/ `/ R  a! e
  242. #define  RCC_AHB3RSTR_QSPIRST               ((uint32_t)0x00000002)) z3 ?$ E" F0 a( s; k7 \# o" |
  243. #endif /* STM32F412xG || STM32F413_423xx || STM32F446xx || STM32F469_479xx */; C6 @. I, O( I" K
  244. ( N  i4 \, w  x( m4 m
  245. /********************  Bit definition for RCC_APB1RSTR register  **************/( v  a8 Q) y9 ^! `' Z
  246. #define  RCC_APB1RSTR_TIM2RST                ((uint32_t)0x00000001)" K* `$ G0 j1 Z3 @" S7 L
  247. #define  RCC_APB1RSTR_TIM3RST                ((uint32_t)0x00000002)
    1 |8 d. O' ?- e* ^! `
  248. #define  RCC_APB1RSTR_TIM4RST                ((uint32_t)0x00000004)
    & n3 {" h9 b2 S* }( ?. ~
  249. #define  RCC_APB1RSTR_TIM5RST                ((uint32_t)0x00000008)- Q3 D% ^' F. l: z) |3 I+ W
  250. #define  RCC_APB1RSTR_TIM6RST                ((uint32_t)0x00000010)) `' O- D/ ~1 Q$ @' n% G3 k5 c' [0 {
  251. #define  RCC_APB1RSTR_TIM7RST                ((uint32_t)0x00000020); l$ |1 A: r! o0 w' a! h
  252. #define  RCC_APB1RSTR_TIM12RST               ((uint32_t)0x00000040)
    # B5 a/ E; i' m6 i7 k/ [9 Z
  253. #define  RCC_APB1RSTR_TIM13RST               ((uint32_t)0x00000080)3 B2 q% m  @8 ^8 k6 ~2 e3 `( e( W
  254. #define  RCC_APB1RSTR_TIM14RST               ((uint32_t)0x00000100)
    ! N/ t6 H) j% f: s; _, e
  255. #if defined(STM32F410xx) || defined(STM32F413_423xx)
    ) R% Z7 T, P$ T8 V4 Z$ ^8 ]4 E3 x
  256. #define  RCC_APB1RSTR_LPTIM1RST              ((uint32_t)0x00000200)
    8 }, E/ n, G4 m) ]
  257. #endif /* STM32F410xx || STM32F413_423xx */
    % Q( ^) s! A2 N& D  e: p/ H
  258. #define  RCC_APB1RSTR_WWDGRST                ((uint32_t)0x00000800)* N$ L9 o: ~, I5 Q; v3 L: P" p2 W8 @
  259. #define  RCC_APB1RSTR_SPI2RST                ((uint32_t)0x00004000)3 Q2 H% c+ j$ t! m$ h4 F1 K  E6 `
  260. #define  RCC_APB1RSTR_SPI3RST                ((uint32_t)0x00008000)3 ]. t$ y  D4 t' x. t# J
  261. #if defined(STM32F446xx)! J" ^  T& h' Z. y1 S& F/ w# W
  262. #define  RCC_APB1RSTR_SPDIFRXRST             ((uint32_t)0x00010000)
    & t% {7 ~( g. {+ s4 N; H
  263. #endif /* STM32F446xx */% z  Z/ C/ X3 x, M5 e
  264. #define  RCC_APB1RSTR_USART2RST              ((uint32_t)0x00020000)
    0 H5 w4 N8 U8 y% |0 X
  265. #define  RCC_APB1RSTR_USART3RST              ((uint32_t)0x00040000)7 `8 V8 B8 J; b! d# C
  266. #define  RCC_APB1RSTR_UART4RST               ((uint32_t)0x00080000)# ?+ J7 {( o- q. D. X; L$ |4 c% u
  267. #define  RCC_APB1RSTR_UART5RST               ((uint32_t)0x00100000)
    ; g- B3 ]( I( d! z4 {
  268. #define  RCC_APB1RSTR_I2C1RST                ((uint32_t)0x00200000)! D8 t( j! _- s! `
  269. #define  RCC_APB1RSTR_I2C2RST                ((uint32_t)0x00400000). u+ {% {+ |2 I2 k" o6 n, k
  270. #define  RCC_APB1RSTR_I2C3RST                ((uint32_t)0x00800000)* n3 Q1 Z; L* D4 a6 o
  271. #if defined(STM32F410xx) || defined(STM32F412xG) || defined(STM32F413_423xx) || defined(STM32F446xx)' R5 H5 o# X0 D) b# y: I$ X. r
  272. #define  RCC_APB1RSTR_FMPI2C1RST             ((uint32_t)0x01000000)
    ! b- r+ m/ e( T+ K
  273. #endif /* STM32F410xx || STM32F412xG || STM32F413_423xx || STM32F446xx */
    ' M* B6 U9 `; t9 L
  274. #define  RCC_APB1RSTR_CAN1RST                ((uint32_t)0x02000000)' J- Q1 ]/ M6 y8 b$ O+ Y6 `
  275. #define  RCC_APB1RSTR_CAN2RST                ((uint32_t)0x04000000)
    , u2 K  V2 y. ]% O" X; r+ L* ^1 }
  276. #if defined(STM32F446xx)
    $ w9 U7 A3 R' G: [- D4 w  e+ s$ c
  277. #define  RCC_APB1RSTR_CECRST                 ((uint32_t)0x08000000)# b. c$ `" |$ Q6 O' U) ^# R3 B
  278. #endif /* STM32F446xx */
    " |; C/ b: V- {; S: C
  279. #define  RCC_APB1RSTR_PWRRST                 ((uint32_t)0x10000000)
    1 S2 J2 O% D/ C7 [, Y
  280. #define  RCC_APB1RSTR_DACRST                 ((uint32_t)0x20000000), R* S& q5 {3 I) R. ]( g9 _
  281. #define  RCC_APB1RSTR_UART7RST               ((uint32_t)0x40000000), X7 l. u) G+ v$ G7 M5 V7 v7 b4 G$ r
  282. #define  RCC_APB1RSTR_UART8RST               ((uint32_t)0x80000000), z% i7 H, K0 ~% F6 X
  283. 1 s1 y- a2 s5 n; a, x9 O7 h7 |7 w
  284. /********************  Bit definition for RCC_APB2RSTR register  **************/) X6 X7 T. s+ Q+ i- S  O
  285. #define  RCC_APB2RSTR_TIM1RST                ((uint32_t)0x00000001)
    8 i0 W) l9 x0 T  ^5 `6 K
  286. #define  RCC_APB2RSTR_TIM8RST                ((uint32_t)0x00000002)+ a# {* P9 r* r$ c
  287. #define  RCC_APB2RSTR_USART1RST              ((uint32_t)0x00000010)
    ; g* ?$ H- D# B1 g3 O. m" z4 ~
  288. #define  RCC_APB2RSTR_USART6RST              ((uint32_t)0x00000020)  I, `/ Y$ t: f/ ]+ k" K/ B3 [2 k
  289. #define  RCC_APB2RSTR_UART9RST               ((uint32_t)0x00000040)# i! a& r# F+ a3 W' A2 @4 A; f
  290. #define  RCC_APB2RSTR_UART10RST              ((uint32_t)0x00000080)  S" W) p. P& `" ?! V3 f+ ]! Y% B( p$ B
  291. #define  RCC_APB2RSTR_ADCRST                 ((uint32_t)0x00000100)4 m! l2 A9 F' v% l# P3 U
  292. #define  RCC_APB2RSTR_SDIORST                ((uint32_t)0x00000800)
    8 O+ }- S) p2 ^( e: G$ s# c
  293. #define  RCC_APB2RSTR_SPI1RST                ((uint32_t)0x00001000)  s6 m6 e/ u% s) J2 }  w# C
  294. #define  RCC_APB2RSTR_SPI4RST                ((uint32_t)0x00002000); r- e2 ?# |( H" F3 Q
  295. #define  RCC_APB2RSTR_SYSCFGRST              ((uint32_t)0x00004000)
    / A$ d$ y5 }# g/ f, d+ r
  296. #define  RCC_APB2RSTR_TIM9RST                ((uint32_t)0x00010000)0 A% p& X& l+ O- z' O
  297. #define  RCC_APB2RSTR_TIM10RST               ((uint32_t)0x00020000)$ }, [2 @# X9 s: f
  298. #define  RCC_APB2RSTR_TIM11RST               ((uint32_t)0x00040000)
    / a" }9 D) V( p0 D7 N* z1 Q6 R
  299. #define  RCC_APB2RSTR_SPI5RST                ((uint32_t)0x00100000)
    - j3 q9 ^9 Q/ g, _$ _* }
  300. #define  RCC_APB2RSTR_SPI6RST                ((uint32_t)0x00200000)
    , n% g, v' t: z  f
  301. #define  RCC_APB2RSTR_SAI1RST                ((uint32_t)0x00400000)
      S, F$ D3 G  y$ B7 e
  302. #if defined(STM32F446xx)
    6 F" `* Y9 C$ |) z
  303. #define  RCC_APB2RSTR_SAI2RST                ((uint32_t)0x00800000)5 d: k/ W/ W/ g  H* K8 V
  304. #endif /* STM32F446xx *// \) n; V; e8 L9 }! {
  305. #define  RCC_APB2RSTR_LTDCRST                ((uint32_t)0x04000000)
    4 U% k8 B- u: l3 y
  306. #if defined(STM32F469_479xx)( @# V! ]. r' d5 L  T
  307. #define  RCC_APB2RSTR_DSIRST                 ((uint32_t)0x08000000)- Q6 K4 s% W. @) i; {
  308. #endif /* STM32F469_479xx */4 K1 f. T/ X! Z9 L
  309. #if defined(STM32F412xG) || defined(STM32F413_423xx)
    5 c2 N9 y  E1 R+ z3 r! D, D7 F$ [9 \
  310. #define  RCC_APB2RSTR_DFSDM1RST              ((uint32_t)0x01000000)' Z$ D3 H: t7 T
  311. #endif /* STM32F412xG || STM32F413_423xx */
    5 O6 X1 f: G! _5 t( y
  312. ' o8 S% {; D  S/ x
  313. #if defined(STM32F413_423xx)
    5 D: W1 P* @6 X: L
  314. #define  RCC_APB2RSTR_DFSDM2RST              ((uint32_t)0x02000000)
    6 Q6 F, e& X- Z9 Q6 x1 |
  315. #endif /* STM32F413_423xx */% N! }, X' S# u
  316. /* Old definitions, maintained for legacy purpose */; v& h+ ]- C+ ^) V  ^. D6 N4 F* Q/ u
  317. #define  RCC_APB2RSTR_SPI1                   RCC_APB2RSTR_SPI1RST  R) R6 |8 ?- i- G& |: h$ F
  318. #define  RCC_APB2RSTR_DFSDMRST               RCC_APB2RSTR_DFSDM1RST
    7 H( w# a8 D) S8 g* z4 P
  319. 3 g+ b( B6 }% k, w1 B1 ]
  320. /********************  Bit definition for RCC_AHB1ENR register  ***************/
    $ h5 r  J# N% a0 A, `! d
  321. #define  RCC_AHB1ENR_GPIOAEN                 ((uint32_t)0x00000001)
    ' [. X4 o% g' {: S2 {1 _( G
  322. #define  RCC_AHB1ENR_GPIOBEN                 ((uint32_t)0x00000002)3 C4 V7 f, q) Q1 n% R( l7 B+ O
  323. #define  RCC_AHB1ENR_GPIOCEN                 ((uint32_t)0x00000004)
    8 q1 X( J! r! m& N
  324. #define  RCC_AHB1ENR_GPIODEN                 ((uint32_t)0x00000008): ~7 B9 S$ t. \+ @
  325. #define  RCC_AHB1ENR_GPIOEEN                 ((uint32_t)0x00000010)
    0 x8 R$ Q. K( k, l7 h  e% ?
  326. #define  RCC_AHB1ENR_GPIOFEN                 ((uint32_t)0x00000020)
    2 d! n: A1 Z( M$ P, j
  327. #define  RCC_AHB1ENR_GPIOGEN                 ((uint32_t)0x00000040)9 w% z4 g+ U$ V( {. k; h; d" h5 R
  328. #define  RCC_AHB1ENR_GPIOHEN                 ((uint32_t)0x00000080)
    7 E6 |- O8 {4 k6 f, E
  329. #define  RCC_AHB1ENR_GPIOIEN                 ((uint32_t)0x00000100)
    * C/ ~5 l5 x7 |8 u+ i: _
  330. #define  RCC_AHB1ENR_GPIOJEN                 ((uint32_t)0x00000200)2 B, q8 r4 |9 T1 \3 M
  331. #define  RCC_AHB1ENR_GPIOKEN                 ((uint32_t)0x00000400)
    . e; ~& N0 {  f8 C" V
  332. #define  RCC_AHB1ENR_CRCEN                   ((uint32_t)0x00001000)2 D  a4 t: @4 n
  333. #define  RCC_AHB1ENR_BKPSRAMEN               ((uint32_t)0x00040000)
    " a& X, _# C) @6 O" I  P
  334. #define  RCC_AHB1ENR_CCMDATARAMEN            ((uint32_t)0x00100000)
    ( a  o! x4 C6 a) D& A
  335. #define  RCC_AHB1ENR_DMA1EN                  ((uint32_t)0x00200000)
    ; E4 f2 M7 G4 {: S: W+ R% h
  336. #define  RCC_AHB1ENR_DMA2EN                  ((uint32_t)0x00400000)
    , s! [+ ]4 I2 r) H% E8 B2 Q! f
  337. #define  RCC_AHB1ENR_DMA2DEN                 ((uint32_t)0x00800000)  W+ A+ [$ K1 j$ T1 P
  338. #define  RCC_AHB1ENR_ETHMACEN                ((uint32_t)0x02000000)  T; t! P6 x3 Y! g) M5 \8 P- b6 [
  339. #define  RCC_AHB1ENR_ETHMACTXEN              ((uint32_t)0x04000000). A' I/ [. L" H
  340. #define  RCC_AHB1ENR_ETHMACRXEN              ((uint32_t)0x08000000)& J$ n9 L7 m( O5 O7 P% K$ C  k
  341. #define  RCC_AHB1ENR_ETHMACPTPEN             ((uint32_t)0x10000000)
    , w8 Y0 z- e( V' }1 o- G' D4 p
  342. #define  RCC_AHB1ENR_OTGHSEN                 ((uint32_t)0x20000000)  u8 ~" o6 [& m7 F7 j8 @, q3 p
  343. #define  RCC_AHB1ENR_OTGHSULPIEN             ((uint32_t)0x40000000)
    " E, Z( i8 O8 M
  344. 1 x- H# h! Z: T2 V# J
  345. /********************  Bit definition for RCC_AHB2ENR register  ***************/
    1 g: D: M3 l6 b+ ?1 S# x. E
  346. #define  RCC_AHB2ENR_DCMIEN                  ((uint32_t)0x00000001)
    5 f2 J2 x2 m0 P3 j8 i
  347. #define  RCC_AHB2ENR_CRYPEN                  ((uint32_t)0x00000010)
    9 y& x1 y/ \; R& z& Y+ D! p9 v5 y% Z
  348. #define  RCC_AHB2ENR_HASHEN                  ((uint32_t)0x00000020)
    $ V9 j. F( l  Z5 o! \
  349. #define  RCC_AHB2ENR_RNGEN                   ((uint32_t)0x00000040)
    0 T- n  G3 Y  }, u6 g! M4 [
  350. #define  RCC_AHB2ENR_OTGFSEN                 ((uint32_t)0x00000080)5 j9 H2 Z  F  ?4 C  z% h' b
  351. ( `2 C7 ]  }* S- H5 x
  352. /********************  Bit definition for RCC_AHB3ENR register  ***************/  P8 ?+ `- w! {$ N1 A" C" Z, R
  353. ! @  H/ _0 `4 l8 N0 i( Q; t3 s
  354. #if defined(STM32F40_41xxx) || defined(STM32F412xG) || defined(STM32F413_423xx)
    & J% G- Y9 x6 K
  355. #define  RCC_AHB3ENR_FSMCEN                  ((uint32_t)0x00000001)) f8 _: c; L& z- M0 z
  356. #endif /* STM32F40_41xxx || STM32F412xG || STM32F413_423xx */
    + n7 W$ ]. R2 o( K
  357. ) M- e- v4 {3 D
  358. #if defined(STM32F427_437xx) || defined(STM32F429_439xx) || defined(STM32F446xx) || defined(STM32F469_479xx)
    , T* O8 M6 \3 l( _# B8 `: ]" F6 ?
  359. #define  RCC_AHB3ENR_FMCEN                  ((uint32_t)0x00000001)
    $ N3 o3 L/ c9 i3 O: S# m8 Z1 t
  360. #endif /* STM32F427_437xx ||  STM32F429_439xx || STM32F446xx || STM32F469_479xx */' a% i2 a: |! z. W
  361. " B0 j3 w3 ^2 e, P' K- k
  362. #if defined(STM32F412xG) || defined(STM32F413_423xx) || defined(STM32F446xx) || defined(STM32F469_479xx)
    - K9 b2 q0 I2 u4 T4 ?  P4 I$ [  p
  363. #define  RCC_AHB3ENR_QSPIEN                 ((uint32_t)0x00000002)( L; f0 e; F  y& G
  364. #endif /* STM32F412xG || STM32F413_423xx || STM32F446xx || STM32F469_479xx */
    3 I( C0 e4 |, s( C
  365. + h# p+ Y' T- u3 a; o1 i
  366. /********************  Bit definition for RCC_APB1ENR register  ***************/( u1 u  V! y0 x: J+ F' P
  367. #define  RCC_APB1ENR_TIM2EN                  ((uint32_t)0x00000001)& A9 d" J: }4 A: O
  368. #define  RCC_APB1ENR_TIM3EN                  ((uint32_t)0x00000002)9 Y7 `( A' l, T7 l; K4 }
  369. #define  RCC_APB1ENR_TIM4EN                  ((uint32_t)0x00000004)2 A- A+ Q  ?5 ^* p4 l9 f: K( V, t
  370. #define  RCC_APB1ENR_TIM5EN                  ((uint32_t)0x00000008)
    ) O  c% ^1 a. W, E
  371. #define  RCC_APB1ENR_TIM6EN                  ((uint32_t)0x00000010)+ Q9 d7 W+ l8 D/ g( I
  372. #define  RCC_APB1ENR_TIM7EN                  ((uint32_t)0x00000020)
    3 n' @9 P! n# z
  373. #define  RCC_APB1ENR_TIM12EN                 ((uint32_t)0x00000040)- r4 S# c$ u9 S
  374. #define  RCC_APB1ENR_TIM13EN                 ((uint32_t)0x00000080)
    * V* ~% ?% B. |- a2 V+ F
  375. #define  RCC_APB1ENR_TIM14EN                 ((uint32_t)0x00000100)& ^  c# q9 V; ]) I' ^% c6 z( s2 h. o
  376. #if defined(STM32F410xx) || defined(STM32F413_423xx)2 i3 w2 E6 X* Y; R: F
  377. #define  RCC_APB1ENR_LPTIM1EN                ((uint32_t)0x00000200)
    9 U  S5 e3 m# Z& T+ Z$ [' r
  378. #endif /* STM32F410xx || STM32F413_423xx */
    ( J) E1 |  U7 l% o0 ]( s5 A% h
  379. #define  RCC_APB1ENR_WWDGEN                  ((uint32_t)0x00000800)
    0 ]1 V3 @. w5 ^; a  C; V+ |
  380. #define  RCC_APB1ENR_SPI2EN                  ((uint32_t)0x00004000)$ h$ T% g. s  `% b6 G! v$ g
  381. #define  RCC_APB1ENR_SPI3EN                  ((uint32_t)0x00008000): Q/ v3 r% v5 G6 E- T1 ^
  382. #if defined(STM32F446xx)8 w7 ~$ ^" E6 i, \
  383. #define  RCC_APB1ENR_SPDIFRXEN               ((uint32_t)0x00010000)5 V# Y# f* ]; P  t7 n
  384. #endif /* STM32F446xx */
    0 e  g1 @! y" l. w1 ~) t
  385. #define  RCC_APB1ENR_USART2EN                ((uint32_t)0x00020000)
    9 P, |$ r" E% R4 H* W; q9 `! V
  386. #define  RCC_APB1ENR_USART3EN                ((uint32_t)0x00040000)4 d8 a  w0 m4 D
  387. #define  RCC_APB1ENR_UART4EN                 ((uint32_t)0x00080000)
    ( N' q1 b2 b1 y  f
  388. #define  RCC_APB1ENR_UART5EN                 ((uint32_t)0x00100000)
    : y7 z) a4 A% I. B; s' V4 z) ~. m
  389. #define  RCC_APB1ENR_I2C1EN                  ((uint32_t)0x00200000)
    $ u* t" Y8 h; i" x% l
  390. #define  RCC_APB1ENR_I2C2EN                  ((uint32_t)0x00400000)
    8 H" R) G, P7 s% N+ e* n9 A; R
  391. #define  RCC_APB1ENR_I2C3EN                  ((uint32_t)0x00800000)) O( B! v0 V2 ^  G( _( {
  392. #if defined(STM32F410xx) || defined(STM32F412xG) || defined(STM32F413_423xx) || defined(STM32F446xx)6 g- y3 i1 ~! z& c/ q; P! s
  393. #define  RCC_APB1ENR_FMPI2C1EN               ((uint32_t)0x01000000)
    1 F6 o4 U" G& T9 ~% i* W
  394. #endif /* STM32F410xx || STM32F412xG || STM32F413_423xx || STM32F446xx */
    1 |; I) C- B  r* @
  395. #define  RCC_APB1ENR_CAN1EN                  ((uint32_t)0x02000000)
    7 A, |+ Q( `! ^7 ?
  396. #define  RCC_APB1ENR_CAN2EN                  ((uint32_t)0x04000000); E$ p% d# e/ c% j
  397. #if defined(STM32F446xx)
    * a- n3 k! k: Q6 X* v! C
  398. #define  RCC_APB1ENR_CECEN                   ((uint32_t)0x08000000)8 b/ S+ Y: @2 J: @1 ^
  399. #endif /* STM32F446xx */
    7 q& U5 ?& m6 d) _$ @$ Y8 e) b
  400. #define  RCC_APB1ENR_PWREN                   ((uint32_t)0x10000000)
    ' O1 y/ x5 U. x0 z0 w
  401. #define  RCC_APB1ENR_DACEN                   ((uint32_t)0x20000000)4 K  w4 ^' @; a
  402. #define  RCC_APB1ENR_UART7EN                 ((uint32_t)0x40000000)8 Y" `! H4 b+ r3 u9 s
  403. #define  RCC_APB1ENR_UART8EN                 ((uint32_t)0x80000000)' T/ }& y) W& D  Z: h
  404. * I8 t/ Y! j6 R" l
  405. /********************  Bit definition for RCC_APB2ENR register  ***************/
    : `! c( E) q0 m4 C& s
  406. #define  RCC_APB2ENR_TIM1EN                  ((uint32_t)0x00000001): Q8 w1 F. B% Y, D) j: ]. N  Y! i
  407. #define  RCC_APB2ENR_TIM8EN                  ((uint32_t)0x00000002)
    % K( |* ?9 U1 W( @; v9 z  l
  408. #define  RCC_APB2ENR_USART1EN                ((uint32_t)0x00000010)
    4 t0 I3 v, j- C" g
  409. #define  RCC_APB2ENR_USART6EN                ((uint32_t)0x00000020)
    ) @$ n" Q/ }4 @9 S2 x0 y
  410. #define  RCC_APB2ENR_UART9EN                 ((uint32_t)0x00000040)
    7 z" M1 l' D: k+ g/ A' r: I
  411. #define  RCC_APB2ENR_UART10EN                ((uint32_t)0x00000080)
    ; X/ K8 j, u4 s6 r- _. Z
  412. #define  RCC_APB2ENR_ADC1EN                  ((uint32_t)0x00000100)
    ; w, x( G5 c, u5 h! z# N
  413. #define  RCC_APB2ENR_ADC2EN                  ((uint32_t)0x00000200)0 b, J! ~1 v. v6 C0 N4 `) S
  414. #define  RCC_APB2ENR_ADC3EN                  ((uint32_t)0x00000400)$ H! Q" r) r# C3 k! [# w
  415. #define  RCC_APB2ENR_SDIOEN                  ((uint32_t)0x00000800)
    ; ^  R' R2 P/ u1 q
  416. #define  RCC_APB2ENR_SPI1EN                  ((uint32_t)0x00001000)" k4 |% v# c' |! }: P' m
  417. #define  RCC_APB2ENR_SPI4EN                  ((uint32_t)0x00002000)8 h) K" }1 G) l8 a1 U& I# _+ R
  418. #define  RCC_APB2ENR_SYSCFGEN                ((uint32_t)0x00004000)
    , J! \$ C  C1 G4 s# T
  419. #define  RCC_APB2ENR_EXTIEN                  ((uint32_t)0x00008000)
    0 [9 S% A8 o5 t4 X; W  ?" X
  420. #define  RCC_APB2ENR_TIM9EN                  ((uint32_t)0x00010000)
    " j( L8 a7 w- b& d5 t' C6 X+ N6 n1 I
  421. #define  RCC_APB2ENR_TIM10EN                 ((uint32_t)0x00020000)  n* n7 Z, b' t  i' _1 f, R
  422. #define  RCC_APB2ENR_TIM11EN                 ((uint32_t)0x00040000)
    % D, n+ v( c" {% m) E
  423. #define  RCC_APB2ENR_SPI5EN                  ((uint32_t)0x00100000)
    " t2 b- D+ j9 W- R- O5 K: M2 p
  424. #define  RCC_APB2ENR_SPI6EN                  ((uint32_t)0x00200000)
    0 l2 Q  G6 C8 F- I+ R1 M  k
  425. #define  RCC_APB2ENR_SAI1EN                  ((uint32_t)0x00400000)
    ; v2 v5 K4 z, Y. S' @+ x
  426. #if defined(STM32F446xx)
    4 n0 e4 {: S" X
  427. #define  RCC_APB2ENR_SAI2EN                  ((uint32_t)0x00800000); ~! F& |: e0 h* V; ^# c7 }! c
  428. #endif /* STM32F446xx */: n( Z/ k$ P- H$ }! h& v4 [1 C. w# v
  429. #define  RCC_APB2ENR_LTDCEN                  ((uint32_t)0x04000000)$ A- p: Y+ E, j: v1 m' _3 N1 V
  430. #if defined(STM32F469_479xx)
    ; y0 x3 M/ |3 s
  431. #define  RCC_APB2ENR_DSIEN                   ((uint32_t)0x08000000)
    ; A; M; b1 z7 p) \0 F2 A
  432. #endif /* STM32F469_479xx */
    & f) J9 x$ J/ @
  433. #if defined(STM32F412xG) || defined(STM32F413_423xx)
    ) _4 ^2 V' w0 D0 R( c! T
  434. #define  RCC_APB2ENR_DFSDM1EN                ((uint32_t)0x01000000)' P5 w0 F& ^7 c
  435. #endif /* STM32F412xG || STM32F413_423xx */2 c$ J, I2 F* r3 A2 z% g& C  @
  436. #if defined(STM32F413_423xx)
    ; ^6 I4 F" V2 ]# T3 P- x
  437. #define  RCC_APB2ENR_DFSDM2EN                ((uint32_t)0x02000000)
    0 P, M  o. M. d) V5 F
  438. #endif /* STM32F413_423xx */
    7 s6 }9 y; h. B
  439. /********************  Bit definition for RCC_AHB1LPENR register  *************/
    ) p# [3 ?5 u8 N. A' O2 o
  440. #define  RCC_AHB1LPENR_GPIOALPEN             ((uint32_t)0x00000001)* b4 F% F5 ~$ X) J+ Z
  441. #define  RCC_AHB1LPENR_GPIOBLPEN             ((uint32_t)0x00000002)" ]% G0 A/ X- W- h. C0 _
  442. #define  RCC_AHB1LPENR_GPIOCLPEN             ((uint32_t)0x00000004)
    & @9 M1 n0 I( J% d
  443. #define  RCC_AHB1LPENR_GPIODLPEN             ((uint32_t)0x00000008)/ z) v7 z5 K1 H  ^: O
  444. #define  RCC_AHB1LPENR_GPIOELPEN             ((uint32_t)0x00000010)
    , P; o" k* n2 r  V) H# M" p4 m
  445. #define  RCC_AHB1LPENR_GPIOFLPEN             ((uint32_t)0x00000020)0 w. @( B/ c# x1 v) h1 O
  446. #define  RCC_AHB1LPENR_GPIOGLPEN             ((uint32_t)0x00000040)
    $ D1 a# V% k$ D9 K7 g
  447. #define  RCC_AHB1LPENR_GPIOHLPEN             ((uint32_t)0x00000080)4 ]# O$ }+ `7 T  l+ p6 x
  448. #define  RCC_AHB1LPENR_GPIOILPEN             ((uint32_t)0x00000100)4 A7 K) ?- G8 \) X, P; X, w) _
  449. #define  RCC_AHB1LPENR_GPIOJLPEN             ((uint32_t)0x00000200)" L1 v% e% F" Z/ M6 j/ b' Z
  450. #define  RCC_AHB1LPENR_GPIOKLPEN             ((uint32_t)0x00000400)7 d1 g: |7 y6 K0 b4 D
  451. #define  RCC_AHB1LPENR_CRCLPEN               ((uint32_t)0x00001000)' S. e. r% X$ k1 s0 a
  452. #define  RCC_AHB1LPENR_FLITFLPEN             ((uint32_t)0x00008000)6 q- D2 I8 B9 p2 K7 y8 x0 u
  453. #define  RCC_AHB1LPENR_SRAM1LPEN             ((uint32_t)0x00010000)) l& N7 h5 u. t  @/ U. M2 q. m1 p! m
  454. #define  RCC_AHB1LPENR_SRAM2LPEN             ((uint32_t)0x00020000)' F" A% l* f8 Z6 o6 M; A6 D
  455. #define  RCC_AHB1LPENR_BKPSRAMLPEN           ((uint32_t)0x00040000)
    ' Q8 y, k- a" @( _
  456. #define  RCC_AHB1LPENR_SRAM3LPEN             ((uint32_t)0x00080000)$ Z  q- p/ i4 B. \& I% `9 {% v* T
  457. #define  RCC_AHB1LPENR_DMA1LPEN              ((uint32_t)0x00200000)# p" U! ?# W* G- R3 O. D
  458. #define  RCC_AHB1LPENR_DMA2LPEN              ((uint32_t)0x00400000)1 N2 y0 ^# c/ X
  459. #define  RCC_AHB1LPENR_DMA2DLPEN             ((uint32_t)0x00800000)
    0 P5 X) G: z% k3 C4 R) Q' y
  460. #define  RCC_AHB1LPENR_ETHMACLPEN            ((uint32_t)0x02000000)9 r6 o- ~( [0 Z' b, y9 v
  461. #define  RCC_AHB1LPENR_ETHMACTXLPEN          ((uint32_t)0x04000000)
    6 L" C  V8 ]8 u6 G
  462. #define  RCC_AHB1LPENR_ETHMACRXLPEN          ((uint32_t)0x08000000)
    ) a" q: v1 l. w  X9 v$ V  O
  463. #define  RCC_AHB1LPENR_ETHMACPTPLPEN         ((uint32_t)0x10000000)
    + z5 {$ t' f! c# \
  464. #define  RCC_AHB1LPENR_OTGHSLPEN             ((uint32_t)0x20000000)8 l5 ?% q, @- E' A% T9 N0 @
  465. #define  RCC_AHB1LPENR_OTGHSULPILPEN         ((uint32_t)0x40000000)* ^( l" m3 ^: L, \7 m
  466. " g6 }3 a0 E* b# ~- t; {  y
  467. /********************  Bit definition for RCC_AHB2LPENR register  *************/
    $ i, I0 x* ?; `: E( B$ i/ |$ y
  468. #define  RCC_AHB2LPENR_DCMILPEN              ((uint32_t)0x00000001)
    $ ?: O# P9 J& @5 c$ u- C
  469. #define  RCC_AHB2LPENR_CRYPLPEN              ((uint32_t)0x00000010), F. V, t$ l" d) ^) x6 v
  470. #define  RCC_AHB2LPENR_HASHLPEN              ((uint32_t)0x00000020)1 }7 V4 J4 C/ Y- U8 l% a9 x& C0 D
  471. #define  RCC_AHB2LPENR_RNGLPEN               ((uint32_t)0x00000040)
    ' C% I4 a" x1 H6 @5 _% ?- y
  472. #define  RCC_AHB2LPENR_OTGFSLPEN             ((uint32_t)0x00000080)$ v6 H0 O4 P$ |. r5 D5 p
  473. 9 E5 m2 @$ [* Q0 {' K% i* T$ P3 r' c9 j
  474. /********************  Bit definition for RCC_AHB3LPENR register  *************/: {; {7 o) H+ `4 t" @) s$ B) R
  475. #if defined(STM32F40_41xxx) || defined(STM32F412xG) || defined(STM32F413_423xx)* W/ G8 s) z+ c( r- b8 Q" C5 x. D+ s
  476. #define  RCC_AHB3LPENR_FSMCLPEN              ((uint32_t)0x00000001)% ~1 S& x% V: q$ `
  477. #endif /* STM32F40_41xxx || STM32F412xG || STM32F413_423xx */
    1 [0 M: D( y2 ]. M- _3 w
  478. + x. W+ i3 b9 [& `2 w/ w4 M
  479. #if defined(STM32F427_437xx) || defined(STM32F429_439xx) || defined(STM32F446xx) || defined(STM32F469_479xx)7 `; G. Q) c6 `5 I& l( J
  480. #define  RCC_AHB3LPENR_FMCLPEN              ((uint32_t)0x00000001)
    # u: D, p* W, D0 H3 c3 v
  481. #endif /* STM32F427_437xx ||  STM32F429_439xx  || STM32F446xx || STM32F469_479xx */
    ) P  t7 J4 Z$ Z+ q
  482. #if defined(STM32F412xG) || defined(STM32F413_423xx) || defined(STM32F446xx) || defined(STM32F469_479xx)$ N9 M6 c/ V; I% }* c# Z
  483. #define  RCC_AHB3LPENR_QSPILPEN             ((uint32_t)0x00000002)
    , w$ g$ }  f$ o
  484. #endif /* STM32F412xG || STM32F413_423xx || STM32F469_479xx || STM32F446xx */% `: G+ o+ o& Q" s$ \& W6 b$ `5 V
  485. 6 v! T' [  z' p, A# A
  486. /********************  Bit definition for RCC_APB1LPENR register  *************/
    ' I, ?* P) D# k( Q/ w, S2 F: E
  487. #define  RCC_APB1LPENR_TIM2LPEN              ((uint32_t)0x00000001)
    4 |, I6 c2 i* e6 r9 w  f  W
  488. #define  RCC_APB1LPENR_TIM3LPEN              ((uint32_t)0x00000002)1 z" W$ }" u9 `4 d6 z. h
  489. #define  RCC_APB1LPENR_TIM4LPEN              ((uint32_t)0x00000004)
    9 @7 P5 p! l& j; \
  490. #define  RCC_APB1LPENR_TIM5LPEN              ((uint32_t)0x00000008)3 \3 C) e0 b* v6 |% v8 W5 z
  491. #define  RCC_APB1LPENR_TIM6LPEN              ((uint32_t)0x00000010)8 D& t( `# {% S  D
  492. #define  RCC_APB1LPENR_TIM7LPEN              ((uint32_t)0x00000020)
    : ~; Y, p5 L9 {$ {
  493. #define  RCC_APB1LPENR_TIM12LPEN             ((uint32_t)0x00000040)  b; i1 r+ Z, p  D9 G7 \" L  C
  494. #define  RCC_APB1LPENR_TIM13LPEN             ((uint32_t)0x00000080)
    , ^) |& Y' M/ f/ r0 q6 U7 L- W; |1 q+ m
  495. #define  RCC_APB1LPENR_TIM14LPEN             ((uint32_t)0x00000100)
    , n% d% M9 ^" |0 M* Y0 o  `7 G
  496. #if defined(STM32F410xx) || defined(STM32F413_423xx). t0 P/ S2 k: L3 M$ K3 W; Y+ S
  497. #define  RCC_APB1LPENR_LPTIM1LPEN            ((uint32_t)0x00000200)2 ~+ h/ |% x+ o5 ^" E( j' B& x% E; c
  498. #endif /* STM32F410xx || STM32F413_423xx */
    # N6 t% W5 J5 }- e2 i( Z8 ?' v; Y
  499. #define  RCC_APB1LPENR_WWDGLPEN              ((uint32_t)0x00000800): k% I0 R' J# C' ~3 k0 D& `
  500. #define  RCC_APB1LPENR_SPI2LPEN              ((uint32_t)0x00004000)
    6 ~8 |/ D: h2 p! W
  501. #define  RCC_APB1LPENR_SPI3LPEN              ((uint32_t)0x00008000): l, Z* S, Q) n. s: }* L& ^. Q0 N8 E
  502. #if defined(STM32F446xx)! N7 Z" ~7 D9 f) n! [
  503. #define  RCC_APB1LPENR_SPDIFRXLPEN           ((uint32_t)0x00010000)
    3 Q7 X$ i2 j( ~, I  e
  504. #endif /* STM32F446xx */( @1 X3 @1 k' Y8 ]9 }
  505. #define  RCC_APB1LPENR_USART2LPEN            ((uint32_t)0x00020000)- Z, O! E( x' \
  506. #define  RCC_APB1LPENR_USART3LPEN            ((uint32_t)0x00040000)+ t3 k& Z5 F) o
  507. #define  RCC_APB1LPENR_UART4LPEN             ((uint32_t)0x00080000)6 c/ Z; Q7 R* l: I  }
  508. #define  RCC_APB1LPENR_UART5LPEN             ((uint32_t)0x00100000)8 n1 ?. l' `' h! a! X9 E
  509. #define  RCC_APB1LPENR_I2C1LPEN              ((uint32_t)0x00200000)
    6 M# I% d  a9 R: }( y2 O
  510. #define  RCC_APB1LPENR_I2C2LPEN              ((uint32_t)0x00400000)
    1 g# p+ D0 k2 E" w
  511. #define  RCC_APB1LPENR_I2C3LPEN              ((uint32_t)0x00800000)
    # b" E( W$ d; D
  512. #if defined(STM32F410xx) || defined(STM32F412xG) || defined(STM32F413_423xx) || defined(STM32F446xx)8 l- v+ {' H4 r5 D3 h5 d" U' p
  513. #define  RCC_APB1LPENR_FMPI2C1LPEN           ((uint32_t)0x01000000)* @: A* {' c8 f; `' J6 @
  514. #endif /* STM32F410xx || STM32F412xG || STM32F413_423xx || STM32F446xx */% v( m1 b* k$ O) b$ \
  515. #define  RCC_APB1LPENR_CAN1LPEN              ((uint32_t)0x02000000)1 v" c# E. X# y7 ^. _3 `8 [0 j
  516. #define  RCC_APB1LPENR_CAN2LPEN              ((uint32_t)0x04000000)
      ^: ?- p( h) C2 j, r& c9 r
  517. #if defined(STM32F446xx)  K& f% D6 v- x' F/ j* r/ n
  518. #define  RCC_APB1LPENR_CECLPEN               ((uint32_t)0x08000000)
    6 `# x; B1 Z! c
  519. #endif /* STM32F446xx */% \; L" L" e6 C5 a6 t
  520. #define  RCC_APB1LPENR_PWRLPEN               ((uint32_t)0x10000000)5 C3 L# |5 F! G
  521. #define  RCC_APB1LPENR_DACLPEN               ((uint32_t)0x20000000)
    ( ~4 L2 X1 v6 {# g& R
  522. #define  RCC_APB1LPENR_UART7LPEN             ((uint32_t)0x40000000). m1 T+ R) ]" [5 E: \6 o
  523. #define  RCC_APB1LPENR_UART8LPEN             ((uint32_t)0x80000000)
    3 w) `/ b! S/ s- U5 A
  524. 2 W$ U  [/ Z. g- a6 Z
  525. /********************  Bit definition for RCC_APB2LPENR register  *************/# T/ S3 Y2 P- E! u3 C  H
  526. #define  RCC_APB2LPENR_TIM1LPEN              ((uint32_t)0x00000001)
    : B3 L! w# @$ I" y$ i
  527. #define  RCC_APB2LPENR_TIM8LPEN              ((uint32_t)0x00000002)
    - }/ ^1 Q6 V' P' d9 p& A* D
  528. #define  RCC_APB2LPENR_USART1LPEN            ((uint32_t)0x00000010)4 N3 N6 C9 U" Z2 p( ~
  529. #define  RCC_APB2LPENR_USART6LPEN            ((uint32_t)0x00000020)3 n" S; ^: ^; \5 W& T
  530. #define  RCC_APB2LPENR_UART9LPEN             ((uint32_t)0x00000040)
    " y/ ~1 a4 y2 m' i1 F
  531. #define  RCC_APB2LPENR_UART10LPEN            ((uint32_t)0x00000080)! G$ t  d0 c4 f( s" ?. U1 _( C# G7 g
  532. #define  RCC_APB2LPENR_ADC1LPEN              ((uint32_t)0x00000100)
    - d) y0 Y0 p0 ~2 ?' i# E" o
  533. #define  RCC_APB2LPENR_ADC2PEN               ((uint32_t)0x00000200)( j1 F% U" I! N
  534. #define  RCC_APB2LPENR_ADC3LPEN              ((uint32_t)0x00000400)* X# r; }+ a, E% b7 |1 d2 f
  535. #define  RCC_APB2LPENR_SDIOLPEN              ((uint32_t)0x00000800)
    : @3 w1 t* Z* Q- b5 F1 ~) s
  536. #define  RCC_APB2LPENR_SPI1LPEN              ((uint32_t)0x00001000)! o2 C, b' }4 p5 b' r$ x# a; t' i
  537. #define  RCC_APB2LPENR_SPI4LPEN              ((uint32_t)0x00002000)
    ; g. C% t6 i5 N  ?8 @# R
  538. #define  RCC_APB2LPENR_SYSCFGLPEN            ((uint32_t)0x00004000)
    # M& k  u# r* v1 V9 ]
  539. #define  RCC_APB2LPENR_TIM9LPEN              ((uint32_t)0x00010000)1 h8 K+ r( ?% V3 t  N; y' W$ Z
  540. #define  RCC_APB2LPENR_TIM10LPEN             ((uint32_t)0x00020000)
    / U6 u. P1 {# ^3 l# g  G
  541. #define  RCC_APB2LPENR_TIM11LPEN             ((uint32_t)0x00040000)( d( [3 o/ N; k- R& h( L# d
  542. #define  RCC_APB2LPENR_SPI5LPEN              ((uint32_t)0x00100000)6 ]9 X/ ~/ y% B! b' K1 s* P, v
  543. #define  RCC_APB2LPENR_SPI6LPEN              ((uint32_t)0x00200000)7 {' z) w' ^8 s/ m9 K2 O# C
  544. #define  RCC_APB2LPENR_SAI1LPEN              ((uint32_t)0x00400000)
    - B8 L8 e% Y4 h- G9 x
  545. #if defined(STM32F446xx)
    5 t% C/ H3 Y6 B
  546. #define  RCC_APB2LPENR_SAI2LPEN              ((uint32_t)0x00800000)
    ) @9 N& @$ P- Y0 m) v7 }: J
  547. #endif /* STM32F446xx */* l, |# f; [: u) @1 q0 S
  548. #define  RCC_APB2LPENR_LTDCLPEN              ((uint32_t)0x04000000)& ]6 W5 D4 I5 F; J
  549. #if defined(STM32F469_479xx)" M; V+ ^/ q! d5 u. J$ K
  550. #define  RCC_APB2LPENR_DSILPEN               ((uint32_t)0x08000000)# k/ O3 A* Z5 W6 t
  551. #endif /* STM32F469_479xx */# C* W5 i8 N; S
  552. #if defined(STM32F412xG) || defined(STM32F413_423xx)  u% O4 u: T8 k5 ?8 a! [
  553. #define  RCC_APB2LPENR_DFSDM1LPEN            ((uint32_t)0x01000000)
    . @. R  R& d2 a) Y: f
  554. #endif /* STM32F412xG || STM32F413_423xx */" o: B1 S; t3 u2 _0 s  U* ?
  555. #if defined(STM32F413_423xx)
    9 i: _/ j- I& l  q$ E
  556. #define  RCC_APB2LPENR_DFSDM2LPEN            ((uint32_t)0x02000000)" C3 r5 e' p6 j- w% J+ U* }- P
  557. #endif /* STM32F413_423xx */1 t. b5 X$ D8 V( ]
  558. # ^: r6 _( E6 Z4 ^  p+ E
  559. /********************  Bit definition for RCC_BDCR register  ******************// I1 Y4 G9 N- w6 D
  560. #define  RCC_BDCR_LSEON                      ((uint32_t)0x00000001)
    3 P6 Y" [0 p5 p& A
  561. #define  RCC_BDCR_LSERDY                     ((uint32_t)0x00000002)
    ! x( Z+ c. g, e0 J
  562. #define  RCC_BDCR_LSEBYP                     ((uint32_t)0x00000004). p: X8 }# R$ h7 R  _' P8 R9 H5 g1 _
  563. #define  RCC_BDCR_LSEMOD                     ((uint32_t)0x00000008)$ f: k- U! B+ F! V/ E$ Q
  564. 3 G( m2 D' q$ G
  565. #define  RCC_BDCR_RTCSEL                    ((uint32_t)0x00000300)9 P1 Q9 X. B* |6 U" x% @" t5 e
  566. #define  RCC_BDCR_RTCSEL_0                  ((uint32_t)0x00000100)
    " C& [" p% u( \
  567. #define  RCC_BDCR_RTCSEL_1                  ((uint32_t)0x00000200)$ d1 [& M% g" G) [) F* {/ c# _
  568. 4 _# e8 A" P3 O
  569. #define  RCC_BDCR_RTCEN                      ((uint32_t)0x00008000)
    ' x; Z  c( b* e( y) E
  570. #define  RCC_BDCR_BDRST                      ((uint32_t)0x00010000)
    ! y/ p: B0 K0 l4 q
  571.   q9 X6 N/ Q4 r
  572. /********************  Bit definition for RCC_CSR register  *******************/& x3 E. w. x" `& z# f% D
  573. #define  RCC_CSR_LSION                       ((uint32_t)0x00000001)
    . p& h: w. `: h/ k1 T
  574. #define  RCC_CSR_LSIRDY                      ((uint32_t)0x00000002)# L4 p& [7 P( Q" y
  575. #define  RCC_CSR_RMVF                        ((uint32_t)0x01000000)( h' R2 L, Z) K! b
  576. #define  RCC_CSR_BORRSTF                     ((uint32_t)0x02000000)
    4 ^9 Z, M! B4 W, A
  577. #define  RCC_CSR_PADRSTF                     ((uint32_t)0x04000000)
    : G- T/ X& C* L1 L% F- B1 N
  578. #define  RCC_CSR_PORRSTF                     ((uint32_t)0x08000000)) P. {# R" t2 c% S* V! g
  579. #define  RCC_CSR_SFTRSTF                     ((uint32_t)0x10000000)
    7 t+ T7 d4 o! V
  580. #define  RCC_CSR_WDGRSTF                     ((uint32_t)0x20000000)
    % G5 r' `; {1 k; P6 `
  581. #define  RCC_CSR_WWDGRSTF                    ((uint32_t)0x40000000)+ H4 A0 y. R$ d7 c1 P
  582. #define  RCC_CSR_LPWRRSTF                    ((uint32_t)0x80000000). A9 V0 m. Q8 B
  583. 6 d2 i1 [/ J- p1 M
  584. /********************  Bit definition for RCC_SSCGR register  *****************/; `! @! G/ p7 v6 ~. e, z- d
  585. #define  RCC_SSCGR_MODPER                    ((uint32_t)0x00001FFF)
    0 c  M- k5 n, P. |5 T+ s2 S2 M
  586. #define  RCC_SSCGR_INCSTEP                   ((uint32_t)0x0FFFE000)7 g2 @. R7 y6 P5 r" e
  587. #define  RCC_SSCGR_SPREADSEL                 ((uint32_t)0x40000000)' N$ i/ o+ `( }/ I
  588. #define  RCC_SSCGR_SSCGEN                    ((uint32_t)0x80000000)
    9 y6 a2 X# x1 J/ D$ N7 B/ X
  589. 7 i' S# L& l2 E! I# v
  590. /********************  Bit definition for RCC_PLLI2SCFGR register  ************/
    - H: q, Z4 \9 r* p: J
  591. #define  RCC_PLLI2SCFGR_PLLI2SM              ((uint32_t)0x0000003F); @2 |  @3 K& G
  592. #define  RCC_PLLI2SCFGR_PLLI2SM_0            ((uint32_t)0x00000001)' f! T- o6 \$ S/ |2 \- o/ I
  593. #define  RCC_PLLI2SCFGR_PLLI2SM_1            ((uint32_t)0x00000002)3 O7 C& I+ \1 J& S
  594. #define  RCC_PLLI2SCFGR_PLLI2SM_2            ((uint32_t)0x00000004)% D+ E; L% k9 o. s7 Y3 r
  595. #define  RCC_PLLI2SCFGR_PLLI2SM_3            ((uint32_t)0x00000008)
    ( B0 ^5 ~- c8 [* \% v0 R
  596. #define  RCC_PLLI2SCFGR_PLLI2SM_4            ((uint32_t)0x00000010)
    : ^0 q) g* W! V" t& y
  597. #define  RCC_PLLI2SCFGR_PLLI2SM_5            ((uint32_t)0x00000020); c+ s' L, ?) X, G- ^
  598. : e. Z7 C9 }; S7 T7 {, ~
  599. #define  RCC_PLLI2SCFGR_PLLI2SN              ((uint32_t)0x00007FC0)
    0 s2 G2 F) T; j6 n% l
  600. #define  RCC_PLLI2SCFGR_PLLI2SN_0            ((uint32_t)0x00000040)  t# i' x2 O0 S: J) N
  601. #define  RCC_PLLI2SCFGR_PLLI2SN_1            ((uint32_t)0x00000080). c  @8 u  z3 j- h: u" w9 f; }
  602. #define  RCC_PLLI2SCFGR_PLLI2SN_2            ((uint32_t)0x00000100), R% Z4 J% V) E, B+ c* e- J
  603. #define  RCC_PLLI2SCFGR_PLLI2SN_3            ((uint32_t)0x00000200)
    6 q$ m5 Q% d" g/ {
  604. #define  RCC_PLLI2SCFGR_PLLI2SN_4            ((uint32_t)0x00000400)) {) Q2 Y, H1 r2 e) L- p" O
  605. #define  RCC_PLLI2SCFGR_PLLI2SN_5            ((uint32_t)0x00000800)
    . J0 @( O! n; n/ E1 r- Z
  606. #define  RCC_PLLI2SCFGR_PLLI2SN_6            ((uint32_t)0x00001000). i4 C0 |) ~% b) t
  607. #define  RCC_PLLI2SCFGR_PLLI2SN_7            ((uint32_t)0x00002000)$ F; B6 S2 d7 L
  608. #define  RCC_PLLI2SCFGR_PLLI2SN_8            ((uint32_t)0x00004000)& I% |4 P2 f# f8 |
  609. 5 o9 `* ?4 v: [9 `1 ?, j
  610. #if defined(STM32F412xG) || defined(STM32F413_423xx)  @/ Q! ]+ b% E- i5 ?
  611. #define  RCC_PLLI2SCFGR_PLLI2SSRC            ((uint32_t)0x00400000)
    # o$ B0 @* v, I7 h- h( ~% F
  612. #endif /* STM32F412xG || STM32F413_423xx */
    8 e* A6 i' m& G/ t4 H( W
  613. " k+ B. V( b& Y; {
  614. #if defined(STM32F446xx)
      Y8 ~% z; e0 f/ s# Q7 q8 D
  615. #define  RCC_PLLI2SCFGR_PLLI2SP              ((uint32_t)0x00030000)( }/ [4 L. g9 s$ ?
  616. #define  RCC_PLLI2SCFGR_PLLI2SP_0            ((uint32_t)0x00010000)' S; ^3 V6 A( c
  617. #define  RCC_PLLI2SCFGR_PLLI2SP_1            ((uint32_t)0x00020000)
    : u7 P$ D" K- C, ?: q
  618. #endif /* STM32F446xx */" P5 M( a) V, w4 l4 C- x$ d2 a
  619. , @+ g; v' {5 x. j$ C" ~$ B" J
  620. #define  RCC_PLLI2SCFGR_PLLI2SQ              ((uint32_t)0x0F000000)
    " w7 X1 A) n. A5 E$ Y, ^
  621. #define  RCC_PLLI2SCFGR_PLLI2SQ_0            ((uint32_t)0x01000000)
    . l& E1 j3 o. X8 G+ B+ D
  622. #define  RCC_PLLI2SCFGR_PLLI2SQ_1            ((uint32_t)0x02000000)
    : D) m; V% u# K& l( Z. c! e+ [
  623. #define  RCC_PLLI2SCFGR_PLLI2SQ_2            ((uint32_t)0x04000000)
    6 D! C, [& `+ _6 o
  624. #define  RCC_PLLI2SCFGR_PLLI2SQ_3            ((uint32_t)0x08000000)
    " {# F# N6 A" }
  625. ' ~! m) E, a0 K0 Q6 u+ t# c
  626. #define  RCC_PLLI2SCFGR_PLLI2SR              ((uint32_t)0x70000000)
    2 `3 Q& z7 h1 m  k. |
  627. #define  RCC_PLLI2SCFGR_PLLI2SR_0            ((uint32_t)0x10000000)
    / H% @0 T; ~6 q& |# c
  628. #define  RCC_PLLI2SCFGR_PLLI2SR_1            ((uint32_t)0x20000000)
    2 r  R8 _* \7 C+ Y( u
  629. #define  RCC_PLLI2SCFGR_PLLI2SR_2            ((uint32_t)0x40000000)
    8 Y: N  e4 _9 q$ o
  630. " I' }; F  O3 o8 b6 ?
  631. /********************  Bit definition for RCC_PLLSAICFGR register  ************/- Y: M) @! H. Y, V+ c' A$ H6 X
  632. #if defined(STM32F446xx)7 V) q. _2 g. q/ \
  633. #define  RCC_PLLSAICFGR_PLLSAIM              ((uint32_t)0x0000003F)' p) R' F3 W: q7 g" W) Q
  634. #define  RCC_PLLSAICFGR_PLLSAIM_0            ((uint32_t)0x00000001); B" D' z- Z* ~3 s0 S4 x" G
  635. #define  RCC_PLLSAICFGR_PLLSAIM_1            ((uint32_t)0x00000002)
    / b. Z& i' \1 q0 `6 r
  636. #define  RCC_PLLSAICFGR_PLLSAIM_2            ((uint32_t)0x00000004)
    3 `  ]2 b0 g! u, M. E
  637. #define  RCC_PLLSAICFGR_PLLSAIM_3            ((uint32_t)0x00000008)4 p5 j6 G$ t' q5 @7 U
  638. #define  RCC_PLLSAICFGR_PLLSAIM_4            ((uint32_t)0x00000010)
    7 C& k0 e2 R1 H1 k
  639. #define  RCC_PLLSAICFGR_PLLSAIM_5            ((uint32_t)0x00000020)0 \9 S5 w# Z) r
  640. #endif /* STM32F446xx */, f; M/ @* v" [. u* X
  641. 2 o! d8 b; e  c7 Z; X0 h
  642. #define  RCC_PLLSAICFGR_PLLSAIN              ((uint32_t)0x00007FC0)
    + u6 t- A- x8 k) S& `( X# ]5 q
  643. #define  RCC_PLLSAICFGR_PLLSAIN_0            ((uint32_t)0x00000040)
    1 W8 Y; \" Z9 p# ^- d( o1 U5 s9 W* Y
  644. #define  RCC_PLLSAICFGR_PLLSAIN_1            ((uint32_t)0x00000080)2 |7 z) \$ Y" s1 {8 M6 f
  645. #define  RCC_PLLSAICFGR_PLLSAIN_2            ((uint32_t)0x00000100)9 r$ T) U# Q0 ]0 u9 o) B
  646. #define  RCC_PLLSAICFGR_PLLSAIN_3            ((uint32_t)0x00000200)
    1 m  V9 v9 j: ?) y  [- R2 F% a
  647. #define  RCC_PLLSAICFGR_PLLSAIN_4            ((uint32_t)0x00000400)
    ' `: U/ x! t$ B, n0 I0 G3 H
  648. #define  RCC_PLLSAICFGR_PLLSAIN_5            ((uint32_t)0x00000800)
    ' X4 c7 O8 `5 {
  649. #define  RCC_PLLSAICFGR_PLLSAIN_6            ((uint32_t)0x00001000)/ j. A8 X5 i5 i; H6 [. u
  650. #define  RCC_PLLSAICFGR_PLLSAIN_7            ((uint32_t)0x00002000)7 P+ g, Q( k# F4 t1 S
  651. #define  RCC_PLLSAICFGR_PLLSAIN_8            ((uint32_t)0x00004000)
    & C% k" p* P9 B8 J( m# S2 x- E
  652. + U3 E& E+ o! v7 C( F# x- q* P! t
  653. #if defined(STM32F446xx) || defined(STM32F469_479xx)
    / f& Y: _, g. x6 l( }$ I
  654. #define  RCC_PLLSAICFGR_PLLSAIP              ((uint32_t)0x00030000)
    / r" X) B  v6 z6 y2 {5 ]
  655. #define  RCC_PLLSAICFGR_PLLSAIP_0            ((uint32_t)0x00010000)
    9 a- q" g3 g9 _) D7 U! L% [, e6 A( @
  656. #define  RCC_PLLSAICFGR_PLLSAIP_1            ((uint32_t)0x00020000)0 D' N' G+ H9 T
  657. #endif /* STM32F446xx || STM32F469_479xx */
    ' x. o8 ]' C6 }+ e5 _" q
  658. * U1 D! @1 Z4 _
  659. #define  RCC_PLLSAICFGR_PLLSAIQ              ((uint32_t)0x0F000000)# p: k# h- m1 W) i5 H
  660. #define  RCC_PLLSAICFGR_PLLSAIQ_0            ((uint32_t)0x01000000)
    * T* q( t! J6 T* J+ b* ]0 [/ @. l* H' [# _
  661. #define  RCC_PLLSAICFGR_PLLSAIQ_1            ((uint32_t)0x02000000)" R) @$ Z: T' j! F% P
  662. #define  RCC_PLLSAICFGR_PLLSAIQ_2            ((uint32_t)0x04000000)
    : z5 H! v, m$ i3 V1 v3 g
  663. #define  RCC_PLLSAICFGR_PLLSAIQ_3            ((uint32_t)0x08000000)
    ( D0 O, B1 h3 ?( f
  664. 6 ?3 y9 S/ u; N9 p- @7 }
  665. #define  RCC_PLLSAICFGR_PLLSAIR              ((uint32_t)0x70000000)
    3 O. E: q7 j  }7 f5 m/ Z
  666. #define  RCC_PLLSAICFGR_PLLSAIR_0            ((uint32_t)0x10000000)
    8 q4 T5 k$ |/ g" w' B  @( N
  667. #define  RCC_PLLSAICFGR_PLLSAIR_1            ((uint32_t)0x20000000)* o3 q* z* Y: }* b6 @, W$ W
  668. #define  RCC_PLLSAICFGR_PLLSAIR_2            ((uint32_t)0x40000000)
    3 G1 w# \7 Z1 i7 C/ Z, m
  669. : h" G  I7 U- @, r3 H
  670. /********************  Bit definition for RCC_DCKCFGR register  ***************/
    ( H! [0 {* O9 j1 L! T: l! K4 {
  671. #define  RCC_DCKCFGR_PLLI2SDIVQ              ((uint32_t)0x0000001F)
    / V* A- I' C) F* g6 v' M; n
  672. #define  RCC_DCKCFGR_PLLSAIDIVQ              ((uint32_t)0x00001F00)# w+ @- U. ]" Q! R9 o
  673. #define  RCC_DCKCFGR_PLLSAIDIVR              ((uint32_t)0x00030000)
    ; S' l+ A  \3 A2 c9 a
  674. 1 w4 {4 l; x: q3 w9 b
  675. #if defined(STM32F412xG) || defined(STM32F413_423xx). ]& E9 X$ Y( R2 v) \) d! k3 c& K
  676. #define  RCC_DCKCFGR_CKDFSDM1SEL             ((uint32_t)0x80000000)  A3 K1 B. d0 B1 ^  c. [1 i
  677. #define  RCC_DCKCFGR_CKDFSDM1ASEL            ((uint32_t)0x00008000)
    ' M/ b3 U  x" W2 n; Q
  678. #endif /* STM32F412xG || STM32F413_423xx */6 _3 {$ y4 O. w
  679. + v" ^7 i% W/ q
  680. #if defined(STM32F413_423xx)
    : W: d% Q( N3 H' o" g3 _' S7 i5 f
  681. #define  RCC_DCKCFGR_PLLI2SDIVR              ((uint32_t)0x0000001F)
    7 Q# f+ p6 S9 @) K
  682. #define  RCC_DCKCFGR_PLLI2SDIVR_0            ((uint32_t)0x00000001)7 o9 h" ?. t" o; V
  683. #define  RCC_DCKCFGR_PLLI2SDIVR_1            ((uint32_t)0x00000002): H' e2 R: H7 U7 \
  684. #define  RCC_DCKCFGR_PLLI2SDIVR_2            ((uint32_t)0x00000004)% |9 D" s' i# Q
  685. #define  RCC_DCKCFGR_PLLI2SDIVR_3            ((uint32_t)0x00000008)
    / f( }2 m: d6 n- n3 H6 S
  686. #define  RCC_DCKCFGR_PLLI2SDIVR_4            ((uint32_t)0x00000010)
    1 z! u0 ~, a1 ~
  687. 1 b6 g& n/ Y1 `6 ^! Z  t
  688. #define  RCC_DCKCFGR_PLLDIVR                 ((uint32_t)0x00001F00)- }3 i8 ~4 j2 {
  689. #define  RCC_DCKCFGR_PLLDIVR_0               ((uint32_t)0x00000100); z; w* r6 c" y$ O: T
  690. #define  RCC_DCKCFGR_PLLDIVR_1               ((uint32_t)0x00000200)
    ; x  e+ e+ p( [6 \, ~' |& T( m
  691. #define  RCC_DCKCFGR_PLLDIVR_2               ((uint32_t)0x00000400)5 q3 q. W3 T, m
  692. #define  RCC_DCKCFGR_PLLDIVR_3               ((uint32_t)0x00000800)
    $ t; U& t7 w3 v
  693. #define  RCC_DCKCFGR_PLLDIVR_4               ((uint32_t)0x00001000)
    , B9 A, q% i& b! K6 ?% L
  694. #define  RCC_DCKCFGR_CKDFSDM2ASEL            ((uint32_t)0x00004000)0 v- y( P. h6 n
  695. #endif /* STM32F413_423xx */. |, f- H, ^2 q5 z0 x7 B) E
  696. 9 y  s( R5 r8 y6 f- M0 T4 ]: T
  697. #define  RCC_DCKCFGR_SAI1ASRC                ((uint32_t)0x00300000)1 x  U. V0 Z- ^# s: n
  698. #define  RCC_DCKCFGR_SAI1ASRC_0              ((uint32_t)0x00100000)- c- }* c: d$ U
  699. #define  RCC_DCKCFGR_SAI1ASRC_1              ((uint32_t)0x00200000)
    : h2 Y4 T( e0 A' X: X& o# q0 Y
  700. #if defined(STM32F446xx)' P9 s5 V" i0 y1 e4 |
  701. #define  RCC_DCKCFGR_SAI1SRC                 ((uint32_t)0x00300000), [8 B/ Z! f& z8 \/ w# q) p
  702. #define  RCC_DCKCFGR_SAI1SRC_0               ((uint32_t)0x00100000)3 z9 y2 z1 |; X1 U- t  l" L& X; k
  703. #define  RCC_DCKCFGR_SAI1SRC_1               ((uint32_t)0x00200000)
    3 Z. d- E' t: }" Y
  704. #endif /* STM32F446xx */" q5 C+ w2 L" K% K& z
  705. / G8 s; c* F4 D3 o4 |
  706. #define  RCC_DCKCFGR_SAI1BSRC                ((uint32_t)0x00C00000)
    * f9 A, {  U$ I
  707. #define  RCC_DCKCFGR_SAI1BSRC_0              ((uint32_t)0x00400000)( ~' G7 k/ ]" a) F$ n4 w
  708. #define  RCC_DCKCFGR_SAI1BSRC_1              ((uint32_t)0x00800000)
    $ s9 V( ]0 e0 c6 |# c
  709. #if defined(STM32F446xx)) s, Q4 D8 A9 D
  710. #define  RCC_DCKCFGR_SAI2SRC                 ((uint32_t)0x00C00000)- C6 d0 Y$ O. N: ?! X
  711. #define  RCC_DCKCFGR_SAI2SRC_0               ((uint32_t)0x00400000)# }- V; `; m& b: m
  712. #define  RCC_DCKCFGR_SAI2SRC_1               ((uint32_t)0x00800000)  ^+ [1 w/ U; F# l
  713. #endif /* STM32F446xx */# L9 J. T- H& g
  714. 9 h2 Q6 |" \2 i8 w" D
  715. #define  RCC_DCKCFGR_TIMPRE                  ((uint32_t)0x01000000)( N/ h! a" Q" x8 \0 p
  716. #if defined(STM32F469_479xx)
    / T8 e/ Z& [# Q7 Q4 l$ `
  717. #define  RCC_DCKCFGR_CK48MSEL                ((uint32_t)0x08000000)* [1 U  @( s$ p( \+ s7 o7 @, P& y5 G
  718. #define  RCC_DCKCFGR_SDIOSEL                 ((uint32_t)0x10000000)
    / D; A! K6 f5 O5 M
  719. #define  RCC_DCKCFGR_DSISEL                  ((uint32_t)0x20000000)
    3 g; Z- Q! m+ w2 d5 s
  720. #endif /* STM32F469_479xx */( J, L& I5 z) s' {- ?5 @% N1 s
  721. 5 o$ `5 j& V. Z8 n
  722. #if defined(STM32F412xG) || defined(STM32F413_423xx) || defined(STM32F446xx)
    / l& N' ^& ^8 S7 Y  U; d
  723. #define  RCC_DCKCFGR_I2S1SRC                 ((uint32_t)0x06000000)3 j' u. ~1 u7 b
  724. #define  RCC_DCKCFGR_I2S1SRC_0               ((uint32_t)0x02000000)5 E1 t1 B: P' w0 `' U6 J. a
  725. #define  RCC_DCKCFGR_I2S1SRC_1               ((uint32_t)0x04000000)! L  a# I4 U7 b1 m% u
  726. #define  RCC_DCKCFGR_I2S2SRC                 ((uint32_t)0x18000000)% R6 t! K$ r: T* r
  727. #define  RCC_DCKCFGR_I2S2SRC_0               ((uint32_t)0x08000000)
      J: G% B$ }+ P* C* h- [2 c0 P9 a
  728. #define  RCC_DCKCFGR_I2S2SRC_1               ((uint32_t)0x10000000)
    4 i, r8 z4 Q# q
  729. / h6 G0 I9 F# q6 |( R2 c; L: l0 j9 t
  730. /********************  Bit definition for RCC_CKGATENR register  ***************/
    , c6 _) s9 ^1 A# n9 P
  731. #define  RCC_CKGATENR_AHB2APB1_CKEN          ((uint32_t)0x00000001)7 Y  f, Q; U; U9 [1 ]
  732. #define  RCC_CKGATENR_AHB2APB2_CKEN          ((uint32_t)0x00000002); r$ e+ U: a  B$ U! ?
  733. #define  RCC_CKGATENR_CM4DBG_CKEN            ((uint32_t)0x00000004)
    1 @. @+ U& a/ r8 O* _
  734. #define  RCC_CKGATENR_SPARE_CKEN             ((uint32_t)0x00000008)$ b" p6 B7 x' _- T4 k
  735. #define  RCC_CKGATENR_SRAM_CKEN              ((uint32_t)0x00000010)
    * M2 F& r9 s: B) i0 g" i$ ?
  736. #define  RCC_CKGATENR_FLITF_CKEN             ((uint32_t)0x00000020)4 u: I5 D1 o# Z& Y8 T( i- H1 A  `
  737. #define  RCC_CKGATENR_RCC_CKEN               ((uint32_t)0x00000040)2 y2 g/ a3 f2 u! W5 V: ?* J) {
  738. #if defined(STM32F412xG) || defined(STM32F413_423xx)
    0 I% [5 \$ M. H  m/ c+ @0 l; K; Q
  739. #define  RCC_CKGATENR_RCC_EVTCTL             ((uint32_t)0x00000080)
    % W' ~5 g, L7 P; c2 ~  s: L
  740. #endif /* STM32F412xG || STM32F413_423xx */) c% q# T: I+ i: |
  741. 5 Q' a3 b2 z! t8 |: }
  742. /********************  Bit definition for RCC_DCKCFGR2 register  ***************/; x! |. C$ f2 K
  743. #define  RCC_DCKCFGR2_FMPI2C1SEL             ((uint32_t)0x00C00000)
    4 ~$ n6 g; W3 h4 W% V
  744. #define  RCC_DCKCFGR2_FMPI2C1SEL_0           ((uint32_t)0x00400000)
    # Z8 B+ U0 Q# _' r4 d: o
  745. #define  RCC_DCKCFGR2_FMPI2C1SEL_1           ((uint32_t)0x00800000)
    # k# G7 I: I6 O
  746. #define  RCC_DCKCFGR2_CECSEL                 ((uint32_t)0x04000000)
    . s3 C! h4 P9 x; s8 k/ ^* J
  747. #define  RCC_DCKCFGR2_CK48MSEL               ((uint32_t)0x08000000)
    1 b( I" c$ y+ H4 v  ?, ]$ C8 d
  748. #define  RCC_DCKCFGR2_SDIOSEL                ((uint32_t)0x10000000)
    * @5 ?" a, C" o
  749. #if defined(STM32F446xx)
    3 n0 m+ B- E4 `1 m
  750. #define  RCC_DCKCFGR2_SPDIFRXSEL             ((uint32_t)0x20000000)/ _; ]& R5 N& @1 }' K. g
  751. #endif /* STM32F446xx */
    7 K- C+ s% Z6 V8 D0 X3 ?4 a6 Q
  752. #if defined(STM32F413_423xx)5 w; C5 L" \" Q7 p; J
  753. #define  RCC_DCKCFGR2_LPTIM1SEL              ((uint32_t)0xC0000000)
    9 ]( ~8 z2 Z3 r+ T# V8 \1 ^
  754. #define  RCC_DCKCFGR2_LPTIM1SEL_0            ((uint32_t)0x40000000)5 `& x$ B, f% D" {( `" c
  755. #define  RCC_DCKCFGR2_LPTIM1SEL_1            ((uint32_t)0x80000000)  g$ t$ A7 o& D9 j2 Y
  756. #endif /* STM32F413_423xx */
    * R; A0 x. F: H% a$ \- Y
  757. #endif /* STM32F412xG || STM32F413_423xx || STM32F446xx */" f* L% z- Y. `3 Y7 X
  758. 6 N7 u8 P% }' X& g/ X
  759. #if defined(STM32F410xx)
    . }+ _* z. l" I7 w) ?
  760. #define  RCC_DCKCFGR_I2SSRC                  ((uint32_t)0x06000000)+ B5 |4 I/ ^7 ^" ^
  761. #define  RCC_DCKCFGR_I2SSRC_0                ((uint32_t)0x02000000)
    / X' V7 Y  V- G/ i/ V+ {
  762. #define  RCC_DCKCFGR_I2SSRC_1                ((uint32_t)0x04000000)
    " S+ C6 y: F* N
  763. #endif /* STM32F410xx */( a3 [7 E0 J1 _* ?: O! [* `  @
  764. ' [3 O' j& @" o0 ]8 j/ h# [9 |2 c
  765. #if defined(STM32F410xx), c7 y) e+ L, l
  766. /********************  Bit definition for RCC_DCKCFGR2 register  **************/+ e( I6 g) _1 \
  767. #define  RCC_DCKCFGR2_FMPI2C1SEL             ((uint32_t)0x00C00000)2 U0 c2 C9 W3 {8 |1 Y$ ~3 E8 p
  768. #define  RCC_DCKCFGR2_FMPI2C1SEL_0           ((uint32_t)0x00400000)
    - k( d( Z% a4 t: j7 p/ Q
  769. #define  RCC_DCKCFGR2_FMPI2C1SEL_1           ((uint32_t)0x00800000)
    7 S6 x9 L+ p  N; w/ f$ O% Y( T
  770. #define  RCC_DCKCFGR2_LPTIM1SEL              ((uint32_t)0xC0000000)
    3 ?7 y* w! u% V
  771. #define  RCC_DCKCFGR2_LPTIM1SEL_0            ((uint32_t)0x40000000)# i4 }4 f. T3 a+ e$ a
  772. #define  RCC_DCKCFGR2_LPTIM1SEL_1            ((uint32_t)0x80000000)
    / f3 ?0 Z6 N6 c6 P
  773. #endif /* STM32F410xx */
    3 x) [7 [6 V9 d3 a# N& `
3 q" t3 A+ f) T/ b  f  S) D
; K8 g' v3 P" V
赞 收藏 评论0 发布时间:2022-6-10 20:14
