采用STM32H7A3的MCU,主频设置为192MHz,跑rt-thread系统。代码在闪存下运行,软件功能正常,能够从外挂的spi flash的文件系统(littlefs)中播放wav和mp3文件。led灯闪烁正常。 这颗MCU的RAM比较,单AXI SRAM就有1MB,为了方便调试(内部闪存下载速率比较慢),考虑将代码置于sram中运行。进行如下步骤操作:
板子上电后,能够正常启动,LED灯闪烁正常。 但是在播放wav时,随机出现spi transfer error : 1,并在出错是产生噪音。 播放mp3文件时,产生严重的噪声,此时通过cpuu查看占用率cpu: 18。 开启MPU和DCache后,重新运行,led灯闪烁正常,播放wav正常。播放mp3文件时,还是存在严重的噪声。 请问是否操作步骤上有问题?把代码放置到ram中调试需要注意哪些细节? \ | /- RT - Thread Operating System / | \ 4.1.0 build Aug 26 2022 10:51:04 2006 - 2022 Copyright by RT-Thread team [251] I/SFUD: Find a Winbond flash chip. Size is 16777216 bytes. [258] I/SFUD: norflash0 flash device is initialize success. [264] I/SFUD: Probe SPI flash norflash0 by SPI device spi40 success. [D/FAL] (fal_flash_init:49) Flash device | norflash0 | addr: 0x00000000 | len: 0x01000000 | blk_size: 0x00001000 |initialized finish. [I/FAL] ==================== FAL partition table ==================== [I/FAL] | name | flash_dev | offset | length | [I/FAL] ------------------------------------------------------------- [I/FAL] | easyflash | norflash0 | 0x00000000 | 0x00100000 | [I/FAL] | filesystem | norflash0 | 0x00100000 | 0x00f00000 | [I/FAL] ============================================================= [I/FAL] RT-Thread Flash Abstraction Layer initialize success. [332] D/main: Systemclock : 192000000Hz [I/FAL] The FAL block device (filesystem) created successfully [343] D/main: Create a block device on the filesystem partition of flash successful. [353] I/main: Filesystem initialized! msh />found part[0], begin: 16384, size: 1.895GB ls Directory /: udisk <DIR> k1.mp3 2602271 2.wav 6737036 msh />wavplay -s 2.wav [18494] I/WAV_PLAYER: play start, uri=2.wav msh />[19744] I/drv.spi: spi transfer error : 1 [31743] I/drv.spi: spi transfer error : 1 [32748] I/drv.spi: spi transfer error : 1 [42730] I/drv.spi: spi transfer error : 1 [43735] I/drv.spi: spi transfer error : 1 [67744] I/drv.spi: spi transfer error : 1 [88674] I/WAV_PLAYER: play end msh />mp3play -s k1.mp3 [1015200] I/mp3 player: play start, uri=k1.mp3 ------------MP3 INFO------------ Title ![]() Artist ![]() Year ![]() Comment ![]() Genre:Blues Length:01:48 Bitrate:192 kbit/s Frequency:44100 Hz -------------------------------- msh />usage cpu: 18 msh /> |
mark,签到+1 |
请教下关于 stm32h7x5,7x7 系列双核 dsi ltdc 显示驱动的时钟频率配置 ?
stm32H747bit6 jlink , stlink 仿真都识别不到 ?
NanoEdgeAI Studio在keil5上出现的问题
求STM32H503或STMH723 SPI-DMA参考例程
STM32H7R7 CubeMX无配置问题
关于STM32H563的STlink-V3无法识别的问题咨询
stn32h725vgh3芯片,配置使用外部时钟必须先下载内部时钟的代码,然后再下载外部时钟的代码才可以正常使用,断电后需要重新这个流程,直接下载HSE外部时钟,功能不能使用。
stm32h563 无法完全整片擦除
STM32H745IGT6 温湿度等级
STM32H745IGT6芯片丝印
