用了 ADC1_IN10 ADC1_IN11 ADC1_IN15 只有10 和11 的adc值正确 IN15的值不正确, 模式选择的是 sequencer set to not fully configurable 求大佬看看 void MX_ADC1_Init(void) { ADC_ChannelConfTypeDef sConfig = {0}; /** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion) */ hadc1.Instance = ADC1; hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2; hadc1.Init.Resolution = ADC_RESOLUTION_12B; hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE; hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV; hadc1.Init.LowPowerAutoWait = DISABLE; hadc1.Init.LowPowerAutoPowerOff = DISABLE; hadc1.Init.ContinuousConvMode = DISABLE; hadc1.Init.NbrOfConversion =3; hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; hadc1.Init.DMAContinuousRequests = DISABLE; hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED; hadc1.Init.SamplingTimeCommon1 = ADC_SAMPLETIME_12CYCLES_5; hadc1.Init.OversamplingMode = DISABLE; hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH; sConfig.Channel = ADC_CHANNEL_10; sConfig.Rank = ADC_RANK_CHANNEL_NUMBER; if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK) { Error_Handler(); } sConfig.Channel = ADC_CHANNEL_11; sConfig.Rank = ADC_RANK_CHANNEL_NUMBER; if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK) { Error_Handler(); } sConfig.Channel = ADC_CHANNEL_15; sConfig.Rank = ADC_RANK_CHANNEL_NUMBER; if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK) { Error_Handler(); } } |
这块STM32G071 UBS TypeC Discovery Kit该如何玩?
STM32G0B1RBT6 上 I2C 通信中的信号缺失问题
STM32G071C8的ADC问题,测量6路交流信号,端口使用PA2-PA7,信号来自电流互感器次级用20欧电阻转为电压信号,并联T4,通过1K,104滤波后到ADC引脚,个别芯片出现PA3结果是固定值,即使直接把引脚对地短短接,结果也是2000多个数,可能是什么原因
STM32G030F6P6TR 48MHz下Flash擦写必HardFault?官方库疑似有坑,求勘误或替代方案
stm32g071的rtc初始化后会直接进入中断怎么办?
STM32G030死机问题
A Guide to Mastering Slope
STM32G0B1
无源晶振开关电路设计
STM32G031F8P6开启读保护后,数据全变成0?
谢谢 我去看看
而3个通道都使用:sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
结果就只转换1个通道而已
