一、实验前期准备
' f* U3 F; s) K" T) {本次实验的 MCU 是 STM32F103C8T6 芯片,通过 SPI 通信实现 W25Q128 的读写操作。
* ?( `2 R/ v* o6 S- v2 V* b
) H2 |; y5 M+ D# }7 a: {+ U2 U/ {* W1. 原理图6 F& w+ o% l' k! w8 @; H
1 H7 z4 `5 b4 ^( _/ j3 J3 U
0 M0 M2 F' ^: }" C
) P) k2 s# a- m) T2. 引脚连接
' n0 m5 x( E0 W0 X
* Q6 L3 k5 g' C. J. p! p
: {+ W5 v+ U! a) U; k: `
3 L, |# Y9 @! x* t' ~& I
二、SPI 底层驱动# W# [9 r5 @' h
SPI.c
% K7 G7 T) p) {+ `+ s0 l- #include "SPI.h"
& `6 h1 ~2 B2 D" F
& w8 L3 w* u. P, {3 h- /*
( x! S' [1 B. u/ p, `6 k - SPI引脚初始化配置
( g7 \9 H- u @) b! @ X. _: B - **PA4------CS! H) y1 a6 C3 A5 B( q( o6 C
- **PA5------SCLK
" J1 Y ^6 F) i. c* J) B - **PA6------MISO$ z9 E" s3 R3 z
- **PA7------MOSI3 j$ @& _" r7 g
- */' ?' A6 Q1 Q: s& Q- L$ j& F) z
- 6 N- N8 T& h" W" {8 H
- static void SPI1_GPIO_Config(void) $ \" k8 @* K" n [. V; R3 b
+ b# }4 l2 F+ k- @ - GPIO_InitTypeDef GPIO_InitStructure;
# W5 g6 ]( f; c3 O' ]) Z - 0 b& v8 S" I, }, w
- RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE );//PORTA时钟使能
, `6 F+ g8 a$ T$ C - 2 i9 q( Z0 J2 r @. b0 c9 X
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5| GPIO_Pin_6|GPIO_Pin_7;
% L) W( i. B) Z6 N" R - GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //PA5/6/7复用推挽输出
1 W t4 R m7 x - GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
' V3 I i1 X+ X, {/ t - GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化GPIOA. v5 W% J2 {8 D8 F* S
. z% K) @! T+ V4 S1 D - GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;3 f8 b, b2 l$ l
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //PA4推挽输出5 J/ I+ U8 {# H9 E4 ~8 k
' v) g% E7 H% X! O& Q: h6 R* O5 D - GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化GPIOA. T# f U/ `7 F. x8 {" Q
- 7 N3 s0 Y4 F) H1 R) i+ s+ m% f; Q: a) h
- GPIO_SetBits(GPIOA,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); //初始上拉输出
9 e3 s' J$ P0 ^5 s6 v0 U - * x; p/ Y! B5 w1 N1 I
. f/ K: m$ i& g8 U1 C7 |
; i% s5 v. g9 a- //SPI1初始化函数
. \5 M, c: l* a - void SPI1_Init(void)3 N; ~0 ]2 e% P4 j2 k E6 d# A1 {
- {6 a0 c# p" }" D8 r( ]6 |7 L" L
- SPI1_GPIO_Config();//SPI引脚初始化配置
& D p5 c. p& _* S: g; O: B. Q& r% Z
% O1 X1 K2 D: c9 M- SPI_InitTypeDef SPI_InitStructure;
# G5 O: K8 A# e4 K' ~8 M: y0 F: ]7 F( i - _' z0 r& y& E3 H
- RCC_APB2PeriphClockCmd( RCC_APB2Periph_SPI1, ENABLE );//SPI1时钟使能
) |) e8 k" q7 K0 Z* a -
# y+ e0 d) O3 P* Q; t" V, _ - SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工
, f5 i5 W* f" C2 t - SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置SPI工作模式:设置为主SPI
4 M1 K) @! M6 r$ t9 o3 | - SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //设置SPI的数据大小:SPI发送接收8位帧结构# a) s) J9 i5 u+ i- A' R
- SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //串行同步时钟的空闲状态为高电平
# ? k* x5 G* x+ N - SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
8 z- S7 f. [1 t" V8 ^$ m - SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制! V$ C; S6 s7 p3 w, @! w( p
- SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; //定义波特率预分频的值:波特率预分频值为256
# A" D" R1 p- n* X" o - SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始2 `" q. |+ P9 x( t4 z6 j
- SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式
8 o# X7 k9 G" L, g - SPI_Init(SPI1, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
$ O4 w, T2 C; n - : U( S w0 A7 }4 k' f( R
- SPI_Cmd(SPI1, ENABLE); //使能SPI外设1 H$ \: ~0 w* h. A2 T- `
- SPI1_ReadWriteByte(0xFF);//启动传输
8 X9 R% d2 C" P2 S4 `6 V* X2 J - }
) z& b9 c$ N+ W8 d" I - * o2 R$ L, ]# R6 v5 M* {, ^
- /*& E+ V! k6 N- K+ U
- SPI的读写操作) `/ f O `8 ~$ F9 R
- **TxData:要写入的字节
( \# R2 X; [6 e5 r& x# h - **返回值:读取到的字节& E" O0 n L& W( l) }
, S3 h2 W# P( F# J/ ^* u- g9 t - uint8_t SPI1_ReadWriteByte(uint8_t TxData)* ^+ g/ x' D! U$ H; x
- { 5 s% D/ A5 X3 L1 {! D: g5 t/ U
- while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET) //检查指定的SPI标志位设置与否:发送缓存空标志位, h a7 J2 L3 N7 N3 Z
- {0 R, m/ ^" {0 `; \0 q
- //等待发送完成
( P* s. M- z5 m, e$ p" p9 s - }
) a* ~' I8 n# v+ E6 I( m P - SPI_I2S_SendData(SPI1, TxData); //通过外设SPIx发送一个数据: I- g/ [9 [, J. P$ N# V
- while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET) //检查指定的SPI标志位设置与否:接受缓存非空标志位
) V/ K3 w7 S- L9 a4 j1 c+ q' V* u - {
! N; Z: z8 {+ G/ r - //等待接收完成- R S" H. Z* g& [' l( X) C
% S. G: Y5 g- W6 ^/ d - return SPI_I2S_ReceiveData(SPI1); //返回通过SPIx最近接收的数据
$ n/ b: N. _5 Z8 R. T! T% U - }
复制代码 % n7 k- X4 r( s `- g$ I) {7 q
SPI.h
6 {' r7 E6 Z6 U+ ]- F- #ifndef __SPI_H
: l2 X- w* i. Z4 Q1 e) P - #define __SPI_H
/ D& l: }" [( @ T- W8 y - & t6 `1 O/ ]2 b3 u& s% Y0 K6 g; V9 ?( f0 D
- #include "stm32f10x.h"
8 G" B: ~" v' N8 w7 d, k - 5 U9 [: g+ r" D3 l. H1 N
- #define SPI_CS(a) if (a) \! p+ e6 O, G% V! ?; E& Q7 G! U
- GPIO_SetBits(GPIOA,GPIO_Pin_4);\
2 y6 A8 {. {7 c/ @* A; s" s - else \
# }: D) z+ L0 y. ~7 h; D - GPIO_ResetBits(GPIOA,GPIO_Pin_4)
" N8 N' B6 V! [
1 c$ T7 ~3 j, X6 V( z- void SPI1_Init(void);//SPI1初始化函数0 h+ G4 _; H$ F3 L; j" a. M+ n
- uint8_t SPI1_ReadWriteByte(uint8_t TxData);//SPI1读写函数
. B4 A% a( Y0 \" @6 V" R
5 w! F0 q0 k( D) Y& }# ?1 G! h- #endif
+ z/ ^ G# N3 J# V7 R. B! f- V三、读取 W25Q128 设备 ID: S, x- f) `( T- {' a. r7 M
本次实验是:读取 W25Q128 设备 ID,然后通过串口1打印出来。
* s' t. D. F; \通过简单的实验来调试,有利于发现问题。+ r$ j3 V( ^) O$ W
通过W25Q128的数据手册可知其设备ID如下图所示:
" `) ?2 }. n* @# z
2 y( P J, f5 y
* \6 G! H$ T4 v% v! Y" W1 A6 Z0 D: P: o( o5 X2 r' S
W25Q128.c
7 v+ v B, Y) C, p4 H- #include "W25Q128.h"
& f: E7 V$ }0 u - #include "SPI.h"
8 F. V; Y5 `! d. ?$ h* V9 w - ) y+ X/ X6 w" k' L
- 0 \$ i! e8 X# A L+ C
- uint8_t W25Q128_ReadWriteByte(uint8_t TxData)//函数包装一下
" V3 k: y% X9 q# m" S# U" `' F - {
. u7 \/ }7 t3 `% L/ w - return SPI1_ReadWriteByte(TxData); 4 Z2 t# A6 V( ^
: V3 x& Y$ y1 f# q
+ X' E P/ j# E# N6 d$ O- uint16_t W25Q128_ReadID(void)//读取芯片ID
9 O' `8 V& }! O- j# y" S - {# b- m/ |0 \9 ]/ h3 e
- uint16_t Temp = 0;
4 E$ H3 ?5 N+ B0 |3 l, w& F$ E - W25Q128_CS(0); 4 q8 h$ ?( l4 o' U
- W25Q128_ReadWriteByte(W25X_ManufactDeviceID);//发送读取ID命令 6 h/ e+ J. \; s$ v7 h) F
- W25Q128_ReadWriteByte(0x00);
1 {& {1 t- ^$ a1 H3 s* N - W25Q128_ReadWriteByte(0x00); " t2 c, G2 k: U4 i W# r7 `
$ g" }6 Z# Z1 X' Q - Temp|=W25Q128_ReadWriteByte(0xFF)<<8; 2 z; y: J6 l* q7 c
- Temp|=W25Q128_ReadWriteByte(0xFF); 4 S* ]2 }) [ J6 p/ X
- W25Q128_CS(1); O" i% d: j7 d3 p
- return Temp; E. @3 S3 H3 X+ j3 X
& n$ \8 t/ b* B1 N* A! r. xW25Q128.h
$ G( {+ g. m3 F+ E- #ifndef __W25Q128_H
* H2 [5 w S0 n: w r - #define __W25Q128_H7 X$ y0 P$ f1 F
8 a4 X1 ~# H- F2 z* j0 n4 M- #include "stm32f10x.h"2 X* K( t; r# A: D7 S7 u
! v& U; G# A( R4 O% [7 q2 \- //操作指令表
5 @8 `4 t8 | r$ q1 f; q( p - #define W25X_ManufactDeviceID 0x90 //制造商+设备ID# F' _& q. h( R, H6 e' Y5 S
- 6 J& k- m! e/ [9 \6 a8 \9 c) U! H
- #define W25Q128_CS(a) SPI_CS(a)
|7 u; I; w/ o" H2 A! @6 r, H
+ M ?7 y; ~# u# s+ r- uint8_t W25Q128_ReadWriteByte(uint8_t TxData);//函数包装一下
( {9 m* u2 w9 W$ d5 | - uint16_t W25Q128_ReadID(void);//读取芯片ID( z. c) |" p s: f! d+ k0 N
+ Z- J$ H6 h( j+ p- #endif
" Y9 h4 T- { T( ?% |5 Z5 D/ qmain.c( X) d B/ @ m: [% l$ I8 N4 ]! Q
- #include <stdio.h>
W8 U" W4 a( N9 `8 f - #include "Uart1.h"/ x( ?# P3 B+ h2 |; [
- #include "delay.h"( z; o: o' o6 _$ i# @- d
- #include "SPI.h"7 c% d7 I( H( a5 ^8 O4 P) j$ c
7 Z7 ]/ P) J; h0 x e/ \; z F - & w6 O* F9 h( Z) u2 o; }
- uint16_t W25Q128_ID=0;+ c, C6 _- E$ {9 M* x8 P% U: v
; t6 \& {5 U7 i* d& o- int main (void)
) X# O# v8 D& Y/ h. @- F) m - {
6 c7 }- y) `. c. M7 |* [: f- [: Y0 y - Uart1_init();
; p2 W7 `" X3 i: F8 s - SPI1_Init();
- I/ G8 O' F" A$ B& I9 ` N -
0 y0 {( m( B# J6 g6 b8 B - W25Q128_ID = W25Q128_ReadID();
2 j4 m( A3 N5 D - while(1)
/ u- L Y2 g; c2 g' Z, I9 M4 z0 P. t: z2 q - {
% [: v4 m$ G- T - printf("\nW25Q128_ID=0x%X\n",W25Q128_ID);
* |0 F- f/ T1 F$ U: p' k* t - delay_ms(500);8 Z5 X& ?: F9 [7 _1 }
- }2 v& |5 q$ O4 d* h! O
1 h7 a, b/ a h# W实验结果
% z: Q+ J5 G2 P9 P& _
q. k7 q9 H1 D& [4 y3 j$ a7 X. ?- o: P2 Y
接收到 W25Q128 设备ID 为0xEF17
0 Y# T1 `9 i6 f) T/ m
0 c, u" H* e& X2 N9 c四、读写 W25Q128 外部 Flash6 d# Y- [1 O: Q; n; f# \" R* g
W25Q128.c
( M5 h4 l% y, g0 v- #include "W25Q128.h"
: H! }9 x9 T* q Y9 L - #include "SPI.h"
) d \0 W; }( P. P0 _" \ e# ~0 R
. V: ^. W3 g& S( c$ P$ i
}; m/ V; x4 V0 _% s- uint8_t W25Q128_ReadWriteByte(uint8_t TxData)//函数包装一下3 C, M. @/ b8 f7 X
- { 4 H9 v5 i$ j) ?2 f0 W i: O3 m: Z
- return SPI1_ReadWriteByte(TxData); 6 ?$ f$ f, @! j
. e3 I9 J, B' _$ Y J
1 }; {/ V: v5 A2 e$ f0 }
9 T) `* n0 s8 a# _! N9 Q7 w' j- uint16_t W25Q128_ReadID(void)//读取芯片ID" t: a; F9 V& g1 c) w
( k2 S( g3 ~6 Y1 Y5 w - uint16_t Temp = 0; 1 j' |9 p5 X+ V$ T) Y
- W25Q128_CS(0);
$ z& Q+ t# S" C - W25Q128_ReadWriteByte(W25X_ManufactDeviceID);//发送读取ID命令
+ Y2 S3 m9 G' |$ u# e" R% Z: K' b - W25Q128_ReadWriteByte(0x00); ' R4 K" [% x7 }! a6 E+ ~1 w
- W25Q128_ReadWriteByte(0x00); 6 _/ `" K# O# E1 h7 `, Z( K5 e
, z. _( ?9 h0 B; L& e6 Q0 P - Temp|=W25Q128_ReadWriteByte(0xFF)<<8; + p! I: J. A5 M- n. b6 }" Y
- Temp|=W25Q128_ReadWriteByte(0xFF); & P* [! o$ A: J7 ^( y
- W25Q128_CS(1); . I; s) t8 {! ^3 M
- return Temp;
7 e' P- R" S+ t2 u6 b" A - }
/ K# v6 c7 T$ \8 m, b3 i
- J7 F: ?# t W' g3 d) G- //读取W25Q128的状态寄存器
2 f" l" a2 Q+ U: b% u) o3 ] - //BIT7 6 5 4 3 2 1 0! Q, I8 k* {- q0 Y
- //SPR RV TB BP2 BP1 BP0 WEL BUSY
6 v( A6 X0 H! A8 n4 Q( M, ` - //SPR:默认0,状态寄存器保护位,配合WP使用0 ?( w# m" G) Q3 K1 x+ i5 S
- //TB,BP2,BP1,BP0:FLASH区域写保护设置# q3 O2 i5 I. K1 U& S* J
- //WEL:写使能锁定
/ M% }% d+ N# @* d6 C - //BUSY:忙标记位(1,忙;0,空闲)
; d# b! A: M. f+ ?2 j9 z, I( X - //默认:0x00
" r6 |" X% j3 q7 ]7 ? - uint8_t W25Q128_ReadSR(void)//读取状态寄存器# J9 y" `4 J/ t& v& q
- {4 O& N/ z% c8 P& y6 U4 {
- uint8_t byte=0;
* R T' g' i: Q; x3 @/ e - W25Q128_CS(0); //使能器件& g$ C" |& Z5 u
- W25Q128_ReadWriteByte(W25X_ReadStatusReg1); //发送读取状态寄存器命令; b2 d6 q* ~' Y& K
- byte=W25Q128_ReadWriteByte(0Xff); //读取一个字节* t7 h2 c8 \6 |1 Q# Q
- W25Q128_CS(1); //取消片选5 M- {7 d) \! A/ z& i& b* v
- return byte;3 T% R( R. q/ B @
% l( S9 K2 e. |7 d% I' F0 Y - : R% e- E% ]: }1 K$ f& o
- //写W25Q128状态寄存器
' \2 b7 c4 o5 D& W8 L$ ~ - //只有SPR,TB,BP2,BP1,BP0(bit 7,5,4,3,2)可以写!!!
3 ]9 f/ ]8 c0 ]% n: t' B - void W25Q128_WriteSR(uint8_t sr)//写状态寄存器
6 j/ D( P( ]1 { - {$ l- i! ?: M$ a ^6 T- s! ^4 G
- W25Q128_CS(0); //使能器件& D2 i+ |! o5 x0 Q2 X: ]
- W25Q128_ReadWriteByte(W25X_WriteStatusReg1); //发送写取状态寄存器命令7 G4 e1 y n1 ?3 ]6 c3 ]' \' g
- W25Q128_ReadWriteByte(sr); //写入一个字节% \, d! w: _2 Z
# T% R. q9 o2 } `4 d4 a - }# \/ H7 ^7 h6 ` ~
- . V. k2 } }2 ^( {; T7 D
- void W25Q128_Write_Enable(void) //写使能
0 {0 L6 K1 ]$ Q2 { - {" o- `2 P5 V9 S( m# H
- W25Q128_CS(0); ! Z0 t) [4 @/ |; ^$ ^
- W25Q128_ReadWriteByte(W25X_WriteEnable);
& W5 S5 g' ]- j+ F; r4 Z+ v - W25Q128_CS(1);
+ ~( m; \9 b" ^* x' D$ u7 p; U. x4 L - }
6 w0 ^7 f7 F: t- a9 n0 b3 ?9 X
# S- P/ K! B* p- T, x$ c- void W25Q128_Write_Disable(void) //禁止写入 7 ~5 G. k2 M. f5 L5 y, B- r
- {5 t+ u2 m j& i: i" A0 A* ~/ v
- W25Q128_CS(0);
$ O( R! I4 n2 h7 o' P+ e8 r - W25Q128_ReadWriteByte(W25X_WriteDisable);. }5 n4 P+ B( A8 S0 w/ P
- W25Q128_CS(1);
5 Y! ?+ B9 J* n: m - }
. d) o2 I3 T: M; G3 I
) r. _/ X. V( K( \# K8 k I# @# l- void W25Q128_Read(uint8_t* pBuffer,uint32_t ReadAddr,uint16_t NumByteToRead) ' n% I) o! R) X4 d L- K# F
# O$ d. E( I- H7 {1 i - W25Q128_CS(0); //使能器件 + F: b* P; ^* t5 J# E
- W25Q128_ReadWriteByte(W25X_ReadData); //发送读取命令 $ X+ Y! s4 U' y9 U% w6 t' K% P
- W25Q128_ReadWriteByte((uint8_t)((ReadAddr)>>16)); //发送24bit地址
) G" A0 F8 C; X, J - W25Q128_ReadWriteByte((uint8_t)((ReadAddr)>>8));
; n: O% i" y6 t" d" J - W25Q128_ReadWriteByte((uint8_t)ReadAddr); 6 w$ ]% p1 N/ S" U) H: c) u6 ~) C
- for(uint16_t i=0;i<NumByteToRead;i++)! P: E" ^6 A! ?5 l0 I A: e# n
7 m# \5 k6 T# O8 p# D$ `& v* D% q - pBuffer<i>=W25Q128_ReadWriteByte(0XFF); //循环读数
' h& T( A7 [9 G - }% H& P O# a0 R- N5 l7 M6 [* }# N
- W25Q128_CS(1); + W* A' Y9 f) d! @ c$ c' u, Y6 T# {
7 T, S5 O9 d! c$ t6 Q7 c6 U+ q5 a
7 \4 E4 u6 p4 n( k! F2 ~0 c9 l- , b0 ?' U) s7 n* l- o& L
- void W25Q128_Write_Page(uint8_t* pBuffer,uint32_t WriteAddr,uint16_t NumByteToWrite)
4 @, l2 @' t) ` - {
0 _ P- W, W- }/ Q1 L* O- q$ d! M - 3 z2 U1 u) g6 A j+ ^
- W25Q128_Write_Enable(); //SET WEL
( t) @% z! P$ X7 m5 S" I) B+ S5 Y+ E - W25Q128_CS(0); //使能器件
8 R) G" Z H5 S; X9 [9 k - W25Q128_ReadWriteByte(W25X_PageProgram); //发送写页命令
1 N! h! d% K$ b6 g' }$ v - - {$ v% _- U, H/ ?, U$ r1 U9 x1 V: c
- W25Q128_ReadWriteByte((uint8_t)((WriteAddr)>>16)); //发送24bit地址
" F9 [5 v- C0 G7 k! C - W25Q128_ReadWriteByte((uint8_t)((WriteAddr)>>8));
; b, P. s1 ?& t( R - W25Q128_ReadWriteByte((uint8_t)WriteAddr);
3 W2 l. u& u; n7 G, Z* V- H" N - for(uint16_t i=0;i<NumByteToWrite;i++)* v4 x# O8 Q, W! t5 b
- {/ W3 k# h* m1 I
- W25Q128_ReadWriteByte(pBuffer<i>);//循环写数
; @9 ]& _4 Z$ S/ [/ g( d - }
3 }* l+ B6 j" H2 n$ `3 r* @5 P0 @ - W25Q128_CS(1); //取消片选 * ^# ]* H1 |9 N3 j" R
- W25Q128_Wait_Busy(); //等待写入结束
5 V: j9 E: ]7 o# Z9 f3 i - }
5 J4 U3 h4 y% O- L- R - * u' X1 i2 r6 M3 {+ E
- //无检验写SPI FLASH
* t( p: j' c0 I" g6 X - //必须确保所写的地址范围内的数据全部为0XFF,否则在非0XFF处写入的数据将失败!/ {: l* e8 Q* |9 a! ~! X
- //具有自动换页功能 6 Q( O2 e% X' \4 y
- void W25Q128_Write_NoCheck(uint8_t* pBuffer,uint32_t WriteAddr,uint16_t NumByteToWrite)
* q, m5 i$ I: [# }9 S& @$ E - {
+ u6 w, |3 x# k& |1 T9 c - uint16_t pageremain=256-WriteAddr%256; //单页剩余的字节数
$ m: ~* w p; K5 Y( j/ R - if(NumByteToWrite<=pageremain)pageremain=NumByteToWrite;//不大于256个字节
3 ? \( Q& ^2 J* v - while(1)
8 Q; G3 i& d5 p- a: h - {
6 z/ [3 {" y P4 O% Q3 j, S f - W25Q128_Write_Page(pBuffer,WriteAddr,pageremain);
. J- O. m8 R+ S" F0 U - if(NumByteToWrite==pageremain) break;//写入结束了
, |6 s( h& z/ y' M9 X% g2 | - else
5 m! C2 a2 Q% b4 R# Y; R! I4 ]" o - {
* Q. r7 `$ X' s - pBuffer+=pageremain;
- d) [9 i/ p2 c6 ? |0 r" \ - WriteAddr+=pageremain; 1 }( }- |* }; K* H9 R7 O6 d o
- NumByteToWrite-=pageremain; //减去已经写入了的字节数
2 t. |: T( b+ ^1 C( h% f - if(NumByteToWrite>256)pageremain=256; //一次可以写入256个字节
. y2 r2 g) I% |% @ - else pageremain=NumByteToWrite; //不够256个字节了7 u2 \. K" ^! y5 f5 I$ D! g
" i1 H7 T: K: n- E6 c% N x, Q - } 9 `, ^6 R$ D+ s K1 R) i
- } / R: E2 G' k* d' v0 M6 c% y2 e7 G( D
/ D2 Z, D. i+ B5 p7 G$ m3 Q- //写SPI FLASH / {. ?1 Z7 N L8 g3 h5 v
- //在指定地址开始写入指定长度的数据& S" U+ F6 K( j) U9 O# e( q
- //该函数带擦除操作! e" _* g, v% q- {
- //pBuffer:数据存储区
8 r0 P7 O% T0 Q. x: I - //WriteAddr:开始写入的地址(24bit)
& A) w; T( s8 ? - //NumByteToWrite:要写入的字节数(最大65535) ; w* }- t, [3 t! x
- uint8_t W25Q128_BUFFER[4096];
8 H2 p0 W2 b5 X - void W25Q128_Write(uint8_t* pBuffer,uint32_t WriteAddr,uint16_t NumByteToWrite)
' z* A9 k' F6 q3 i$ i, P - { 9 E- [: [. ]1 |5 ?" B
- uint16_t i; $ m+ M: P, m& z1 q: F7 U
- uint8_t * W25Q128_BUF; 6 ^8 ~- ]- m% Y7 M d5 T8 Y0 p
- W25Q128_BUF=W25Q128_BUFFER;
5 D5 g( q, O& t/ e& d/ k0 Z - uint32_t secpos = WriteAddr/4096;//扇区地址
* K8 o: n& ~2 ~9 V - uint16_t secoff = WriteAddr%4096;//在扇区内的偏移
: o. L) I3 X) d8 ]6 t - uint16_t secremain = 4096-secoff;//扇区剩余空间大小
0 b0 G; }+ a4 A; @+ d' T - ; h3 z+ v! Y# ~7 t8 |( p( N
- if(NumByteToWrite<=secremain) secremain=NumByteToWrite;//不大于4096个字节
0 @ W" \, Q8 |6 j! F- z - while(1) 6 c6 X. d; r- U6 K
- { 1 _/ b2 i0 }' @+ E1 z9 w
- W25Q128_Read(W25Q128_BUF,secpos*4096,4096);//读出整个扇区的内容& n9 Q) Z9 _& I* }* m* }
- for(i=0;i<secremain;i++)//校验数据
2 d2 |; r9 v- y( t* `6 I - {
4 [; K4 [1 ]5 J$ j+ H. z - if(W25Q128_BUF[secoff+i]!=0XFF) break;//需要擦除 , G" I7 s0 B8 N @% C
8 V& }% f9 O. X2 E t' u - if(i<secremain)//需要擦除# U) s6 T2 I$ E( X3 t' G* N& X) {1 b
- {4 {9 e' c. @0 S4 z
- W25Q128_Erase_Sector(secpos*4096);//擦除这个扇区2 j4 P. y: V& c% {4 m9 Q. ~" ?
- for(i=0;i<secremain;i++) //复制
5 c6 x; y0 k. P; f( E% D$ Q1 t - {, Y1 V2 ~' }7 R! q; Y7 A
- W25Q128_BUF[i+secoff]=pBuffer<i>; # H1 g4 d/ d( ], A s9 z; t; F
8 c8 c3 l4 c( c3 t, b - W25Q128_Write_NoCheck(W25Q128_BUF,secpos*4096,4096);//写入整个扇区
, Z" r% B9 U h( F4 d8 x
" ]/ E4 f5 h6 p" [3 J3 ^" T- }else W25Q128_Write_NoCheck(pBuffer,WriteAddr,secremain);//写已经擦除了的,直接写入扇区剩余区间.
; ]+ G, e# \" s$ F1 w - if(NumByteToWrite==secremain) break;//写入结束了1 Q: T: C! I6 t
- else//写入未结束) Q- B [- o6 }! m0 Y
% I) ]2 @$ K1 W' O - secpos++;//扇区地址增1: Q3 R8 L R4 a; ?, z/ \' q" j
- secoff=0;//偏移位置为0 5 _7 Y) ` J" j$ \; B9 T
- f4 ?$ h2 ]+ [5 {5 t0 ^- pBuffer+=secremain; //指针偏移
' `: a+ e a9 R2 p - WriteAddr+=secremain;//写地址偏移 J& w" u& A/ ~2 ^* [
- NumByteToWrite-=secremain; //字节数递减+ z5 Z! O) K5 d$ j/ r: V) _
- if(NumByteToWrite>4096) secremain=4096; //下一个扇区还是写不完
0 u" g% n! |; y( `( y - else secremain=NumByteToWrite; //下一个扇区可以写完了; P2 a& C p3 q- B0 h! F
8 F N# G4 c }7 a) ^" s+ y - }
1 t+ @& T- R0 S( c0 e' ]) ^ - }* m/ ~& T# K+ j5 ~4 k+ J$ b
- / M$ E1 U5 d. R7 \# p. G+ K
- //擦除一个扇区4 g; `5 B, S; Z9 k
- //Dst_Addr:扇区地址 根据实际容量设置
1 B) P2 ]% V+ Z- T5 }1 C - //擦除一个扇区的最少时间:150ms
, |% w4 ^( x' C7 ^5 @
; V4 Q, E {8 J) a4 Z( y2 M- void W25Q128_Erase_Sector(uint32_t Dst_Addr)
% i0 P1 F: L" J) W - { . E% l* ^# a6 T; K* F6 D
& y: s4 K6 ?/ M3 g - W25Q128_Wait_Busy();
: W/ p- B, |8 N) [ - W25Q128_CS(0); //使能器件 ( c* Z/ @! k. f
- W25Q128_ReadWriteByte(W25X_SectorErase); //发送扇区擦除指令
0 r# N( y' B9 o - W25Q128_ReadWriteByte((uint8_t)((Dst_Addr)>>16)); //发送24bit地址
% _- z% `3 D3 J+ S0 t - W25Q128_ReadWriteByte((uint8_t)((Dst_Addr)>>8)); ( c* l& c$ A& n' d/ l- _3 X+ ~
- W25Q128_ReadWriteByte((uint8_t)Dst_Addr);
8 s/ X6 {; d+ a8 F# B3 T+ V- ^ - W25Q128_CS(1); //取消片选
! r: j+ ?! {8 y( p6 P - W25Q128_Wait_Busy(); //等待擦除完成
! K; Z' O9 @6 Z* Z - } - e5 u6 j# f' v) Y0 N+ |
7 e S5 q2 R$ Z) y- //擦除整个芯片 ' p* z2 X$ h' e5 A S" [) _0 Q8 c6 `
- //等待时间超长...
* |0 z, Y x' W - void W25Q128_Erase_Chip(void) 9 e5 C, J" D7 v8 g* p1 G4 b
- { 8 N3 f4 l" q9 X8 D+ t7 ]5 q
- W25Q128_Write_Enable(); //SET WEL . p2 b1 _$ v& g" v. P& O
1 w$ j* A! a3 C7 s$ P2 ~& X% A - W25Q128_CS(0); //使能器件
4 z- j$ n9 e; F- C ?$ A - W25Q128_ReadWriteByte(W25X_ChipErase); //发送片擦除命令 ; |2 d# m+ v( E/ U
, r5 N7 |/ W8 N1 T: N8 D3 p - W25Q128_Wait_Busy(); //等待芯片擦除结束
. @5 k0 a9 S$ Y3 j/ I* \& _ U - }
% Z! w& \7 Q+ a- {2 ~# _+ G
( A& Q, O7 B- [; t" c: i4 i- p- ! i& L8 L9 R! T% P5 h- G3 U
- //等待空闲
( o: T8 T0 |2 ^ - void W25Q128_Wait_Busy(void)
2 x4 _8 H* k; i- ~ - { 4 a' q& H% s2 P" {
- while((W25Q128_ReadSR()&0x01)==0x01); // 等待BUSY位清空
( Z# x& t( \1 C6 ~. r8 i - } + W# f$ F8 L/ R' Q
- 6 s$ l8 v- b0 p4 y; k4 v
- //进入掉电模式
3 d N" a+ Y4 v3 \5 l% j! o - void W25Q128_PowerDown(void) ' o5 ?- U z5 \+ ^% T/ H8 E
t$ m/ H( I% B/ e# x1 ^) z: | - W25Q128_CS(0); //使能器件
2 u5 ?8 \) Y9 x' ~1 S! t - W25Q128_ReadWriteByte(W25X_PowerDown); //发送掉电命令
/ z y& T. t: R7 b - W25Q128_CS(1); //取消片选
' D3 J: m! @4 x' m$ {" F! p - } + k' \$ x! w3 s1 i* v
- //掉电唤醒
( p+ [8 Z. J- B9 k+ K& o. y - void W25Q128_WAKEUP(void)
9 {# e9 F% {) G) a( h - { 9 C$ q0 i7 m5 P% n$ V6 X
" |! G1 q5 l+ v5 c/ A) M6 Z- f - W25Q128_ReadWriteByte(W25X_ReleasePowerDown); # e/ s" G& I- ~: a7 T! b
. B7 }% \2 s6 N6 l' \ - } </i></i></i>
复制代码 V( V8 A, I& D. u# v4 q
W25Q128.h4 Z' v4 x6 a9 l- G) C& c
#ifndef __W25Q128_H; X) j1 K* x( t) _
#define __W25Q128_H; i) U" n6 x) w# u$ P
: C( r( r# i9 @3 r4 \2 J' R- z#include "stm32f10x.h"$ _1 p ?& {/ H- y" |
- _- h* `. X+ t- I7 o5 n, b4 A5 y& }# x//操作指令表$ }* f- l$ K5 g9 G0 ^5 [
#define W25X_WriteEnable 0x06 //写使能
. o3 o' i: k" L5 C# g#define W25X_WriteDisable 0x04 //写禁止
& K; F- i a2 x0 e1 R/ f) q9 Y' w* j#define W25X_ReadStatusReg1 0x05 //读状态寄存器1( |1 i& F7 f/ `6 t6 C. ?7 |
#define W25X_ReadStatusReg2 0x35 //读状态寄存器2
1 c5 W/ G( {+ `1 H; s#define W25X_ReadStatusReg3 0x15 //读状态寄存器3
3 I7 T9 _' L+ u E3 K#define W25X_WriteStatusReg1 0x01 //写状态寄存器1; O9 S0 k$ P3 r+ H
#define W25X_WriteStatusReg2 0x31 //写状态寄存器2; L" w, e! g* u$ f/ c5 v
#define W25X_WriteStatusReg3 0x11 //写状态寄存器3
3 B8 u# l8 t3 ^' l1 a4 |. T: ~- h#define W25X_ReadData 0x03 //读数据" A; O5 f: j* U" d
#define W25X_FastReadData 0x0B //快读1 r2 s) m x2 [4 ?5 Y
#define W25X_FastReadDual 0x3B //双输出快读* \& Y5 l; @9 r% w, _1 t8 Q
#define W25X_PageProgram 0x02 //页编程
8 l. t2 p5 g. w% i- ^% B' L#define W25X_BlockErase 0xD8 //块擦除(64K)
9 H9 t! }% c) {7 a5 X9 ^$ Y! r0 R#define W25X_SectorErase 0x20 //扇区擦除(4K)
0 h. M0 E' n' r1 w#define W25X_ChipErase 0xC7 //芯片擦除$ @% v7 H) b+ q, C3 K
#define W25X_PowerDown 0xB9 //掉电
5 O" t' R: z6 u5 b' L#define W25X_ReleasePowerDown 0xAB //释放掉电
! q# D4 J: W6 F#define W25X_DeviceID 0xAB //器件ID Y# I$ @5 [, D5 j: N
; D' x8 ~) f d& k. k v* o! `#define W25X_JedecDeviceID 0x9F //电子元件ID5 s" a( L" r# S/ j$ e
( {( Q; [5 Z1 L4 H. D8 d/ K! R: `
/ h, y2 m1 q+ S1 v
#define W25Q128_CS(a) SPI_CS(a) 3 Y' c _" |+ X- c
- O4 ~: V- c5 a$ ^2 Y) I/ F- i' ^
6 g% X9 C y( U; g( p' ]. }uint8_t W25Q128_ReadWriteByte(uint8_t TxData);//函数包装一下8 G! u$ m3 y6 A) z! T2 q; b& m- T
6 ]# B* W& x8 s. w" s. I% K8 e: p
7 g; D: Z5 p3 I5 L: z
+ h n. O: V; S7 Z! P. {uint8_t W25Q128_ReadSR(void);//读取状态寄存器9 l. Y, D5 q- `6 L/ q2 {
void W25Q128_WriteSR(uint8_t sr);//写状态寄存器
. f2 E) W1 J2 i9 E3 ?( A( [/ B R3 C8 C3 n0 \ s" s- P
void W25Q128_Write_Enable(void);//写使能# a8 e R1 L* G C0 ]
void W25Q128_Write_Disable(void);//禁止写入 7 K+ k& @! j9 {! f ]: s
& w* @5 t5 b- q6 X0 lvoid W25Q128_Read(uint8_t* pBuffer,uint32_t ReadAddr,uint16_t NumByteToRead); //读取数据
+ F" }+ D& [& X. q1 ^# W, mvoid W25Q128_Write_Page(uint8_t* pBuffer,uint32_t WriteAddr,uint16_t NumByteToWrite);//页写
! W( e4 P9 s& Y! r) `8 {1 B1 qvoid W25Q128_Write_NoCheck(uint8_t* pBuffer,uint32_t WriteAddr,uint16_t NumByteToWrite);//无检验写数据,可自动翻页' G6 t' u2 h" P" m: K
void W25Q128_Write(uint8_t* pBuffer,uint32_t WriteAddr,uint16_t NumByteToWrite);//写入数据,带擦写功能0 }/ q: U& B( m+ k) W/ V
4 c1 Z/ |6 v& mvoid W25Q128_Erase_Sector(uint32_t Dst_Addr);//擦除扇区# ^- j- @2 a( n- u3 Z
void W25Q128_Erase_Chip(void);//擦除整个芯片 7 |8 n' p0 w( S5 i' u
) Y" M! {- X% d; k0 j( c( n" Bvoid W25Q128_Wait_Busy(void);//等待空闲$ F0 u8 O0 D$ s" a, ]
void W25Q128_PowerDown(void); //进入掉电模式0 J2 |) L: {6 [. s+ c# t
void W25Q128_WAKEUP(void);//掉电唤醒
" K9 v+ w4 B j5 z3 V# W/ z
- \% c! h# m1 p T% E0 J& R#endif
, c: }8 Y- X+ W/ _/ e* p2 j7 f: k/ ]' c! k8 k9 g( W
1
) w# [6 A) p' Q24 c( ?, `3 Y8 G% c3 ~, B
3 L4 g4 T# o; i
45 t; V* t ~% u* h
5
y1 L, X" X7 o5 i6$ s! p3 P7 D* J
7
8 {. x: D+ S6 z- W' Y6 a9 }8, m: {% ?3 o* P( Y) \! V6 ~# i
9
7 y& ~2 l' {% D ^( m107 k, o/ ]( x+ L1 v3 H& g x# o3 _
11( b# p2 `! H; h
12
9 w, s1 d* D7 f13; i5 |3 x# u+ I; g8 B/ j! z( `+ s
14
# t; |- {8 \, V+ P5 a15
# F2 N. ?4 T% `0 p, }16
6 p( [( [0 S, x- A17
; j2 H" b' K2 W1 `186 n) J, l8 \! _8 m2 M! \+ e
19 x, z) J! @+ V. B V6 ^! D
20
; n' b% A8 C2 B+ U; \21
: ^+ k3 @% D% s D1 y# J! r22
$ u+ Q L, M* k2 [" {23
( Q/ D4 b' t& X5 r24
7 j$ b, x/ T( Y25" F# f2 M3 C4 d0 ^
26
2 B$ x" l Q" S7 l4 \# `274 r" x; {; w- T" _
286 z7 x: L' P, d
29
. p( ~) s1 H2 i30
& b: e5 ^4 \/ {# C7 h5 |: s) I5 D31
, [( h& m6 Z2 r; \' o32% A" ~0 i! g% z) D* J
33* K6 q4 F9 j8 F
34 M$ ?; m- X% K3 i# I1 N# V
35; j4 Z, Q3 R- d- M
36
: D6 H! `, D( C5 |37
* b, W: e7 C5 n) b7 R38' e: d( A. S: b/ K
39% k0 F# u) \& }! x# Z
409 F% Z E* G. B& N
41
& O: J8 z7 Q9 }9 |. t7 Q42& M- M- J$ Y7 x6 W+ l
43- M9 s; W- _5 d5 x
44 z# O& @# R9 v7 r. ^2 ]2 e ~: ]- C3 h
45
0 |+ b- C n8 {/ @. s46
2 Z( h7 a1 s; H( x7 X47) G. m2 U9 D& ]1 ^. ^' p$ h
48" B% f# u7 J) _. L
49& u' m' A" b5 B, ?9 f$ m
50
6 k& E0 ~7 y0 Q; l( E( Q& K51" W- _( v R5 S( D: ~5 I# [
52
5 a' C! O0 _5 W: h& a53; t; D& Y$ g. p4 h |
54
( C1 t. \8 M! K, ?main.c
/ t$ f$ P8 s2 U- ]7 H#include <stdio.h>8 ^+ u9 |3 [& b- B) J0 Z
#include "Uart1.h"
2 U+ Q# L! N7 x! J* {#include "delay.h"
/ o* Q% y Q6 F- w3 @3 ~( Y% }( Y#include "SPI.h"
% W2 h6 H7 {/ R$ a: l1 [1 C#include "W25Q128.h"
, ]+ n9 J: s( K9 H8 P3 |" T+ S! }7 K) F- O2 b
uint16_t W25Q128_ID=0; N1 h% I% F# Q3 K- m
uint8_t Write_data[20]={1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20};5 |( `% G0 @; I1 o$ B' q" f
uint8_t Read_data[100];
0 ?: C8 l7 _' I! u% q% g, T* m2 j4 c- O) c
int main (void)7 X1 _, n; Z2 Z/ ~: ?4 M, o% ^
{% `4 L" ^) c, o4 k8 s$ Y% Q( I. W: S
Uart1_init();$ C2 m5 X( I- }5 d: F
SPI1_Init();
7 H+ ]; k5 Z8 L# q+ j: w
; z2 I! b. O3 E7 b W25Q128_ID=W25Q128_ReadID();
3 M; K# G9 c$ @0 L% h W25Q128_Write_Page(Write_data,0x01,20);
+ x& I- A3 V& g! I1 X; J" |6 r
( M0 _ E' w7 w0 J; I3 w( @7 f2 V while(1)
) C* E7 ~- e: }3 r) E3 n {
0 l5 k7 u+ L7 Y e2 \ W25Q128_Read(Read_data,0x00,100);- T+ J, x# n7 @
for(int i=0;i<100;i++)
8 M/ G: Y( C- s3 B& @% f; Y5 k Y {
% J$ x" n- P p0 ? G& ]) Q& _ printf(" 0x%X ",Read_data);
D& w3 p- I& T; t* q% c% ]- B4 V }, j& A( V b5 Q+ x0 f1 T! E7 @ @
! N3 ~. S- A* m delay_ms(500);5 s* D0 ?, }" ]7 I; {9 x
}' n- z* l3 S& t3 [( l: T
}# Q8 s# G9 D; a. M( w; H- r
" @) K9 I, v3 O" S% m: f1 B( j1# u8 u0 o9 S, k5 [/ I
2
3 J" u9 m; n: z) n9 u* U3! I) X; `0 A# e5 \, l7 F! K
4
& M/ Q3 |# W" u5 Y0 Y5
8 w. J% V: `* ^0 m6
) i" Y6 X( _0 V5 a* g7
( g2 d1 w, J {6 ?8 }) V8
/ m) g2 j4 q* Q) W0 ]! H- E2 w93 p2 Q9 K# W+ M% [
10
5 d7 q5 y1 r7 ]1 o- |* p11
- G* Q; V# u4 J6 P5 a- ^126 D9 J' b1 x' `; m
13
9 g8 F! D/ V8 e6 k8 d. m3 M14
# R# N" C6 x1 |0 _15
U5 j8 A z; y2 {* F( ]16
& T, h, p1 F$ t, q! d: r t17
/ M: [7 v: v( J. ^$ u18
. T4 U& `& h) L4 w& Y19* P& Y# G( I- Q* j9 O5 @ m
20: i! S' V6 e! v# B9 \+ G/ U$ t
210 W6 ?& Z7 L9 k1 I# s3 f) `: C
22
) H% G( k3 z4 g2 W3 s! V6 o v23
B8 y8 J8 h- J: n2 S5 s24
+ W( g+ A/ F& z9 g7 a) u+ }253 @+ G: ^ B1 T4 [' z# b5 l' j
26" h H0 H6 m$ E, H7 R- a. @! b
27
" J3 `2 |8 M1 l6 L: v; J28
; b* Y# y9 ~$ V; f9 c1 r291 n* O. s9 Q: B
实验结果6 Q0 V6 ?7 W3 j8 L7 G5 {( }# d: d
- S* I1 u! W8 ~0 K5 z————————————————7 t$ c2 u' T1 H
版权声明:根号五/ A7 `6 j" e q5 R0 m
1 V$ O Q9 N! C9 Y
2 C5 s$ A7 p/ \: h# J1 q$ x0 L# s |
