首先,总结全文,设计步骤主要如下:. l/ K8 D$ E' b* `7 U# ]
1,初始化GPIO9 H: W4 Z% {/ ~' N1 j
2,初始化USART1
& {( X. e7 N1 w/ }3,初始化NVIC(嵌套向量中断控制器)
2 y5 ]! W8 j: o4,编写中断服务函数$ ^6 a# G2 ?! ^9 Y
5,编写主函数
2 [4 [) d! }: ~2 w9 e; z* c
6 D/ _' K# U/ T1 B/ Y详细步骤如下:
9 _+ n1 C2 X1 C* m/ s3 u6 y5 k( _& c- \ a( J$ u* m
1,初始化GPIO
) e/ F$ @# k. }# n4 I& D- void IO_Init() L! s! p- p6 Y9 ~2 s$ c& |
6 r4 K$ l3 L% N9 B, w$ b - GPIO_InitTypeDef Uart_A;. {4 z5 R# W, e/ I& s9 v7 k
- GPIO_InitTypeDef led;
8 ^- b- n2 Z. _! v! M& ^ - RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC| RCC_APB2Periph_AFIO,ENABLE);) i0 b# T f: \
+ D, |1 b8 t, n8 r) J2 I5 S - GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable|GPIO_Remap_SWJ_JTAGDisable,ENABLE);9 ]& R7 Y) W/ t7 G0 R$ E B+ S" [, G
, G) ]* m* ]1 m/ l2 h3 s1 y - led.GPIO_Pin = GPIO_Pin_13;//博主开发板上的LED灯接的GPIOC的13引脚9 N. l- ^$ B- m) k" o% u
- led.GPIO_Mode = GPIO_Mode_Out_PP;
+ D, P0 @5 y2 |( y. K - led.GPIO_Speed = GPIO_Speed_50MHz;
9 Z9 f/ ?" i# [ j, D4 z; @ - GPIO_Init(GPIOC,&led);" F, f9 h1 k `6 o2 P; N2 n: x
) B4 B2 i) t( g6 `/ w - Uart_A.GPIO_Pin = GPIO_Pin_9;8 D4 E4 U5 a- t& U8 w
- Uart_A.GPIO_Speed = GPIO_Speed_50MHz;6 _, n5 q& r+ \/ n. Z5 r" E; L
- Uart_A.GPIO_Mode = GPIO_Mode_AF_PP;
* A6 F' D. K3 [7 E$ o4 Y4 {) x - GPIO_Init(GPIOA,&Uart_A);+ x# i! W( J- y7 U" m
- ( [) ~9 d- b9 q0 A& v1 r/ b
- Uart_A.GPIO_Pin = GPIO_Pin_10;( x* D' D9 e) U. P4 A5 j: n
- Uart_A.GPIO_Speed = GPIO_Speed_50MHz;& u4 I% @" Q7 D$ X0 {; o9 A" A' a
- Uart_A.GPIO_Mode = GPIO_Mode_IN_FLOATING;
( [# u5 S! _& C. r8 s - GPIO_Init(GPIOA,&Uart_A);
k2 z7 q Z2 F. ^' i5 ~: x4 p7 a -
! j _3 Z* Y5 I - }
复制代码 6 u* V$ i# K1 x. P7 a$ \9 s
以上代码不在详细介绍,前参看STM32基础设计(1)---点亮LED灯、SEM32基础设计(2)---查询串口通信
: x) }/ `: |' O0 T( L7 h$ a+ R# a. u9 Z3 g* W: `! Z' i5 K
/ u- X& J2 }& Q2,初始化USART1
- h' X% e, R$ J, S) c% \8 f8 w- void Usart1_Init()
r% c/ m- L; Z5 f; R - {
; c3 w4 }1 x5 _# a - USART_InitTypeDef Uart;
M, W+ C/ w. R- G& R( M/ C( }* x -
2 J* D; i* g1 i. @. C( w4 T* Y - RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);: ~; l# q* o M' P5 q: p; d8 q
- Uart.USART_BaudRate = 115200;
, h' E, H8 y; A6 A - Uart.USART_HardwareFlowControl = USART_HardwareFlowControl_None;7 X) `6 k r! a$ r- ]+ d% Y9 i
- Uart.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;% c* y6 K6 a+ ~3 u8 `+ d! I& w
- Uart.USART_Parity = USART_Parity_No;
2 p2 y* }5 @ ?5 ?( \7 ] - Uart.USART_StopBits = USART_StopBits_1;
1 G- y( m8 [& d1 w3 U - Uart.USART_WordLength = USART_WordLength_8b;
4 ? M9 x S% H# Y* t - USART_Init(USART1,&Uart);
* {# z5 p) N7 J - 8 g6 E' ^$ U/ o4 D% Q: c
- USART_Cmd(USART1,ENABLE);' B# [1 Z/ j4 }7 u: a3 p) s
- USART_ClearFlag(USART1,USART_FLAG_TC);
+ f& N9 E+ z; e: L - }
1 z2 E& U. j7 q7 v$ k' h+ K+ n# P, Q) Y6 }' d- R
以上代码不在详细介绍,具体请参看STM32基础设计(2)---查询串口通信. ~, r$ g! |; D/ U7 R% f
: j3 W& Q' Q4 d p9 `
$ ~0 w ~" W5 A, k7 z3 [3,初始化NVIC. G+ y& o: @0 Z* w3 I
首先,让我们来了解库函数中的NVIC结构体:
0 W6 ` _ s: ?; ]* s- typedef struct# l* r. u( V6 X7 f0 U7 \7 i
- {//指明那个中断通道 z3 M* X( q# p7 I- w( \
- uint8_t NVIC_IRQChannel; /*!< Specifies the IRQ channel to be enabled or disabled.9 s B2 D% [) M: p t% n
- This parameter can be a value of @ref IRQn_Type
- _, b d0 {6 K6 C) l - (For the complete STM32 Devices IRQ Channels list, please7 y; A2 w% A Y4 {! q) `3 L
- refer to stm32f10x.h file) */- f2 B$ r- o/ `2 g) D4 I
- //抢占优先级
' v) X: T& ]4 x8 c; K; y8 p - uint8_t NVIC_IRQChannelPreemptionPriority; /*!< Specifies the pre-emption priority for the IRQ channel
f. n% J( M! a: c8 ] - specified in NVIC_IRQChannel. This parameter can be a value
+ H' T% r0 V' | N, x - between 0 and 15 as described in the table @ref NVIC_Priority_Table */
! V. `3 A) F9 s - //子优先级
# J3 i* ^9 m7 F. C - uint8_t NVIC_IRQChannelSubPriority; /*!< Specifies the subpriority level for the IRQ channel specified
1 u- Y4 j( k$ s9 I o& @- R - in NVIC_IRQChannel. This parameter can be a value
- n+ d. h% u" I( ~ - between 0 and 15 as described in the table @ref NVIC_Priority_Table */0 b$ `. B: t" \2 \
- //中断通道使能
7 |; Q ^& q' H# e8 Y/ w( ^ - FunctionalState NVIC_IRQChannelCmd; /*!< Specifies whether the IRQ channel defined in NVIC_IRQChannel
" O" W6 t" t0 }$ x - will be enabled or disabled. / c8 m Z; ~0 c# \& O
- This parameter can be set either to ENABLE or DISABLE */
* _. U6 T8 \: @ r# j - } NVIC_InitTypeDef;
复制代码 ! Q$ O+ l2 Y- J6 g
了解了这个结构体后,就可以在初始化函数中定义这个变量了
2 M' ^1 N) w8 ]8 Z. d4 U. P; W) i! x5 S4 k: `# ~6 b' @/ \
" G: k& }; U9 k5 c
另外在NVIC初始化中还设置优先级分组(哪怕只有一个中断也要分组,这是规定)。具体使用这个库函数:
( G7 V9 k6 N- {& C* q1 U, E! d* d6 z4 J. x
- void NVIC_PriorityGroupConfig(uint32_t NVIC_PriorityGroup)
2 L, G( g+ H6 `2 R! T - {+ W0 }; |9 Z8 }( S/ c
- /* Check the parameters */
- q$ x- l2 g1 S; ~' [ - assert_param(IS_NVIC_PRIORITY_GROUP(NVIC_PriorityGroup));3 r* L! n9 u5 b9 V1 K4 |
- $ V* f4 M! L, j* n! t5 P
- /* Set the PRIGROUP[10:8] bits according to NVIC_PriorityGroup value */
( ?* G3 a* [5 y8 H" _- Q) M - SCB->AIRCR = AIRCR_VECTKEY_MASK | NVIC_PriorityGroup;
! k0 r9 D1 D) h/ c5 |( X% \( j/ ?5 Y - }
复制代码 # z9 q+ G% C5 g
接下来,设置结构体中变量的值:
2 u% K( `% V7 H- nvic.NVIC_IRQChannelPreemptionPriority = 1;//抢占优先级2 ?3 Z( P+ N. }& k# T
- nvic.NVIC_IRQChannelSubPriority = 0;//子优先级
2 C+ ^- K" d) m" {( ?% j) H - nvic.NVIC_IRQChannel = USART1_IRQn;//中断通道' Q8 }2 ]. q8 h [
- nvic.NVIC_IRQChannelCmd = ENABLE;//通道使能. e+ ^0 a5 b. R9 q
- NVIC_Init(&nvic);//NVIC寄存器初始化
" c: @% O: ?5 L3 G4,编写中断服务函数
. J. g8 f- [/ U4 Y) V R1 a2 ]先贴代码,在解释
; i, V E2 ^8 p" q- void USART1_IRQHandler(void)//注意,这个函数名必须这样写,否则进不了USART1中断。详见库函数中的 IRQn_Type 结构体
( Y8 R o" b* h7 `# D - {8 {' {# L3 Y Q5 g j$ U, _5 C! X
- char temp= '0';0 e3 K' \' A! e' w, q" U2 p
- if(USART_GetFlagStatus(USART1,USART_FLAG_RXNE) == SET)//判断是否接收到数据
" O. S: |: h$ Q" U+ o9 ] - {% T7 `% I% q5 j2 Y+ h8 {
- temp = USART1->DR;//如果接收到数据,就将其读出,这样才可将RXNE寄存器清除
( ^$ V) F5 \6 c4 m - if(temp == 'G')//如果接收到G 则关灯1 }% K1 j8 Y6 C$ N/ f% q8 k
- {6 t+ `2 Y5 g6 g# r! w
- GPIOC->BRR = GPIO_Pin_13;
, N/ k; k: e d0 L - }else if(temp == 'K')//开灯
& F# ^9 a: G0 V/ I - {3 I9 c3 \: J- _2 Q7 d
- GPIOC->BSRR = GPIO_Pin_13;" }% n( H' q( r4 Y
- }: e! w; n1 m6 \- E! S& K3 y
7 f! V# x& g: W6 s - if(USART_GetFlagStatus(USART1,USART_FLAG_TXE) && temp != '0')//如果发送寄存器为空,即可以发送数据
: A+ j# {4 n: S) ~ - {
6 s4 N+ @9 g4 X; h5 Q$ ]7 E. |8 ^, E3 p - USART1->DR = temp;将接收到的数据再发送回去6 I7 u8 r8 S" m
- while(!USART_GetFlagStatus(USART1,USART_FLAG_TC));等待数据发送完毕! a3 h6 a& U. S. J7 N
: V1 k" W4 C4 `6 l - }
: L) t* S: _+ O! J7 q/ M4 ]: p5,编写主函数2 P+ T4 U0 o, V! i4 C7 F; W
老规矩,先贴代码再解释:
- N% t. \& o4 v8 T/ v3 j1 p- int main(), C, m' x; n0 i d! X( g# q
- {! n& ^1 U7 z) g- I5 E% ^2 J
- IO_Init();
$ ~+ Y4 F+ `. T* J' O, a - Usart1_Init();& W2 u6 n& j1 U7 X2 i4 ?+ C7 Z
- Nvic_Init();
$ `& M* `) Z D3 N/ u6 O - USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);//这里是打开串口的接收中断,以便在USART1收到数据时,进入中断函数。这里特别提一下,现在不用打开发送中断,只有在准备发送数据时才应打开,否则会直接进入中断函数。! n/ W# k$ J% C/ F7 d1 h/ g
- GPIOC->BSRR = GPIO_Pin_13;; U o* s7 z$ C- q" O
- while(1){}
9 L5 c$ K1 f" A( \, _ N6 _ - }
4 H& R3 C4 X1 s1 z; o额。。。突然发现没什么好解释的。7 D( K, F' k& T% O/ C9 \
0 _" j- a9 Z5 x+ A中断串口通信介绍到此完毕。6 K6 N, f: H0 l, i- ^/ K0 e' t7 j( F$ H
|: {: n) w: ?8 O' m$ b本文完整代码如下:4 b. |7 y0 m! e% f7 ]' e3 w
- #include<stm32f10x.h>8 z3 o& a1 y9 X. U
- #define uint unsigned int
2 r/ W$ J: c) P- j: |1 B - #define uchar unsigned char3 b7 C. r7 x# e! w; `
- void delay(uint n)/ B* p8 ^: @9 q1 R0 W3 Q, |
- {2 Q& f" S& e3 w& t+ l
- int i,j;
* q6 }3 p+ x% k6 h, u8 n/ A; A, q - for(i=0;i<n;i++)
1 {) J8 L. k! W: h* x4 I+ H3 i - for(j=0;j<8500;j++);
* e) W% @5 n1 o0 o7 |4 y) z: M - }' f |6 r4 H& b( F: ?3 I
- ( E, G, i3 E$ X! z
- void IO_Init()
( m. E3 k$ ^- b, ? - {
/ r5 f( ?3 N8 I2 B6 U - GPIO_InitTypeDef Uart_A;
# u9 Q" t. w3 e. `; q b1 X - GPIO_InitTypeDef led;
: S/ p8 r, e8 W - RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC| RCC_APB2Periph_AFIO,ENABLE);
6 S* L3 ]' c( o5 J$ W2 p# | - ) O Y1 O; ]& @" x
% ]+ M* G3 Y5 Y3 n# w1 j$ D4 _ -
% M* I* M/ r2 I0 S - led.GPIO_Pin = GPIO_Pin_13;
) m1 C& |0 r7 `# r! T/ b - led.GPIO_Mode = GPIO_Mode_Out_PP;4 K# o3 O$ F; ]7 k3 d2 W
/ H7 {. q/ R2 ^4 R$ b - GPIO_Init(GPIOC,&led);
* B/ x r1 T2 `# L h+ C; j -
$ W6 y, {- I7 G/ m! e. H4 h - Uart_A.GPIO_Pin = GPIO_Pin_9;# ?" k+ O1 E) z) c, d8 `
( k) t0 V! h/ r( ?# d! p - Uart_A.GPIO_Mode = GPIO_Mode_AF_PP;+ G4 K; X# d' `& P* E
" w; G+ q# O7 d4 R" h6 W M -
. F; W! i, S, ^7 g - Uart_A.GPIO_Pin = GPIO_Pin_10;
. E7 |5 P; q L5 d d& U - Uart_A.GPIO_Speed = GPIO_Speed_50MHz;
) X9 P& B6 S( V+ S, O0 J* X$ N - Uart_A.GPIO_Mode = GPIO_Mode_IN_FLOATING; //page 1105 @$ T4 t q* g: G
z$ q# M& K1 j - 3 A/ t9 g* A1 a; B* l
- }& l/ s7 `, h) u- Q
9 F* W" e, a! G8 C! p$ g+ v - {0 s9 C1 f& U3 U/ K1 _
- USART_InitTypeDef Uart;5 K, @$ }% M, W* m6 b& y
& d% w: H! n- \ - RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
# x, M( E, W* N `& Z9 i& @ - Uart.USART_BaudRate = 115200;! n% K- T- ~: v# | |3 }+ i
- Uart.USART_HardwareFlowControl = USART_HardwareFlowControl_None;, Z9 m" v! t7 F& S( h/ P
- Uart.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;5 V' U0 b7 g* Q- t' x
5 y; N/ r* I( ?9 I* n* n( v - Uart.USART_StopBits = USART_StopBits_1;. z4 W7 m; v8 n
v, Z" Q" G' C - USART_Init(USART1,&Uart);
G7 Y3 }8 o5 @ -
: P/ O4 J# M6 b9 |2 r - USART_Cmd(USART1,ENABLE); {: O- j+ ], w" p6 l" u
- USART_ClearFlag(USART1,USART_FLAG_TC); //page 540
) T" n9 H( L; M# k - }0 r7 ?4 A, n9 G5 i2 D* Y- f4 E
- void Nvic_Init()
8 A( N+ O l' d' g; I5 U - {" E" t; Y, l+ W# n! g0 a _
- NVIC_InitTypeDef nvic;
$ \. j! p8 L- X4 H/ C9 P# T - , X$ ^: p" ` M6 j: C! Z
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
8 ]1 E/ p; R) a' r+ g/ G - 0 a9 y6 Z/ F) }9 u$ [6 _
+ X# R% n* R5 K( X5 c+ A. f# f - nvic.NVIC_IRQChannelSubPriority = 0;
8 M! r) v( `8 T) d - nvic.NVIC_IRQChannel = USART1_IRQn;! N2 T7 k& |; D$ N
- nvic.NVIC_IRQChannelCmd = ENABLE;. p- r$ e, G( G- }% `' r% C, j) y
- NVIC_Init(&nvic);
- P" V5 y- f# `0 F6 h - }& o6 P2 @" W! ^0 F" Q* }% b
- ' o! x0 }; p. K
- int main()$ B, @2 x+ T# o, E
- {, K3 e, A0 D6 c6 R3 V$ F
- IO_Init();
9 ^3 j+ M. e; x; L W D5 a - Usart1_Init();- R& n/ m: p' g% Q i1 K, |
- Nvic_Init();
/ c" \' O$ V" n! a0 X. X- W - USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
: Q, Z" [4 O0 Z" ^$ |: s1 \' a - GPIOC->BSRR = GPIO_Pin_13;% y8 o, j8 a3 O1 l d
- while(1){}
& v$ ?* v8 u' u( b+ y$ g - }9 c. H* S/ j$ J+ @
- / {* v6 \0 x& _( q: c% J8 N
- void USART1_IRQHandler(void) p+ H2 r3 i; z G' v; \
- { F# t9 x" a) t/ j( Y8 \) ?6 K9 E
- char temp= '0';
/ O( g* n3 h( a* m/ c | - if(USART_GetFlagStatus(USART1,USART_FLAG_RXNE) == SET)0 C/ b# {# Y/ M2 ?8 Y
( G" t$ x) U& ~ - temp = USART1->DR;% L/ A7 ?# D: \* x1 o3 c+ |9 j
- if(temp == 'G')3 c2 D8 z5 o7 }% t
! ]8 A0 {( g$ ^. p0 \ - GPIOC->BRR = GPIO_Pin_13;
2 x% {4 D7 H; B% s - }else if(temp == 'K')( \8 p4 s( s9 f! b x8 l6 t2 o, w
+ Q( E+ b2 g/ s" c6 B( I - GPIOC->BSRR = GPIO_Pin_13;: P! Q9 G" a* u. h k' { m+ ^
- }6 p% D/ R+ m7 {$ A2 F; `! x
# e' L7 {+ _9 O" U, B, t - if(USART_GetFlagStatus(USART1,USART_FLAG_TXE) && temp != '0')
1 Y# B# F; ] x - {
p% S' F5 V+ o0 P+ x: m3 s+ ] - USART1->DR = temp;5 T1 X6 Y5 A1 Q4 [1 ]6 p
& T8 p1 A; ^$ [. l3 d: M: n4 c. q - }2 a4 M7 [+ b# G% V ^
9 F( i: Z. k* u$ B& W, P; ^3 y7 ] K
————————————————, |: w0 k6 \* _( \6 A* f
版权声明:家安& F$ Y7 r+ H6 k
, G5 f1 B8 U3 n' g7 x! h
3 [" x0 N {+ m9 g. u |
