STM32F103V NOKIA5110液晶
STMCU小助手 发布时间:2023-1-7 11:59
% r3 Y: k8 Q8 l! w1 _
/ p+ E( u4 X" U+ G* T9 S; I
Nokia_5110.h头文件
<span]Nokia_5110.h头文件
<span]
& \! e! U, i8 d8 C* X$ q- J2 {) l
#ifndef]#ifndef]
! l) I1 q6 p& r- f( p9 `% n#include"HZ_12x12_pixel.h"
9 m4 N; e0 W. x8 M2 z6 i: ~#include"english_6x8_pixel.h"4 r9 b0 G6 O! P
#define uchar unsigned char
' L  V8 n0 A2 E4 [9 a$ m#define uint unsigned int/ I5 g! C+ ^) x7 i4 ~: O
#define ulong unsigned long
& S$ ^/ C) B+ C! B: M* g0 h7 R#define true 1
$ O7 @: W: r# N* A#define flase 0
/////////////引脚定义//////////////
<span]/////////////引脚定义//////////////
<span]void Delay_1uS(void);
) F& _6 H# ]; y7 S/ @7 B  ?; Mvoid LCD_Init(void);1 |3 m7 U$ C' I: s. Z$ B; K5 y
void LCD_set_XY(unsigned char X, unsigned char Y);$ E3 U$ h$ I1 p
  `2 G' l3 A9 Y- R- ULCD_write_english_String  : 英文字符串显示函数
输入参数:*s]输入参数:*s]-----------------------------------------------------------------------*/
* y  T3 e- i' h9 Qvoid LCD_write_english_string(unsigned char X,unsigned char Y,char *s);
# x) J3 u" `8 Gvoid TestLCD_Nokia5110(void);
unsigned]unsigned]
8 t  v% P# K  A* V6 u# N- ]( f- Bvoid displayonechar1212(uchar row,uchar page,uchar dd); //显示 12*12 点阵
. s0 n. [/ h3 g0 ^' O9 N; \void write_byte(uchar dd,uchar a); //写数据或指令 0:指令 1:数据
#define]#define]#define c_LCD_Max_Dot_X 84
: W- c) e, Y9 {' X#define c_LCD_Max_Dot_Y 48
9 d, f! z$ C0 L: P0 T
#define]
! X* d* O" v+ ^8 w7 ?5 j% S; Z, g9 p7 Y#define]
0 j* \, U3 R: N6 wvoid delay_1us(void)                 //1us延时函数
9 y4 d+ e# o' D; k  {( u, W" K8 P0 O% ~- @! j
   unsigned int i;
  ~! @7 y" F1 A8 ~8 X4 f  for(i=0;i<1000;i++);
" b* b+ F  e7 g" P  }
! k5 y) [3 A. ?  pLCD_write_byte]/*-----------------------------------------------------------------------8 K; y: c4 X4 ]6 d
LCD_write_byte]输入参数:data    :写入的数据;
  V2 p& n! B4 U# T/ E+ Z" i: x          command :写数据/命令选择;
. f% i' ^% W! F2 z' G$ F/ |% Tvoid]-----------------------------------------------------------------------*/
& X1 {. `  l0 m- hvoid]    //SCE = 0;4 f6 X! X3 B3 t
    //DC = 0;1 c" ^& V: ~5 B* t
    GPIO_ResetBits(GPIOD, NOKIA_SCE);, Y" ]7 m& }2 e( b6 D
    GPIO_ResetBits(GPIOD, NOKIA_DC);
]]   //SCE = 1;: h+ N( r# D7 t
         GPIO_SetBits(GPIOD, NOKIA_SCE);
+ M* }) D1 t& D4 _! X}
6 D) ]& R  s, r3 s) ]' rLCD_write_byte]/*-----------------------------------------------------------------------
+ E6 v: ~& A% A( `9 K" MLCD_write_byte]输入参数:data    :写入的数据;- \. y3 ?5 y- r* K
          command :写数据/命令选择;-------------------------*/8 Q6 r! h3 n' c& c+ f
void LCD_write_Data(unsigned char ucWriteData)' V  E) T6 v. E! f+ l
{- R% r5 s* y( N1 m6 L
    unsigned char uci;
]] for(uci=0;uci<8;uci++)! y% l) Q5 L5 p  T
{8 v$ I8 }# W: ^4 t
  if(ucWriteData & 0x80)/ `2 }. f0 u3 r% z- E
- ^" d1 `: ?( z' X   //SDIN = 1;4 |) G' p  }% U; [3 m* }. j5 q
                        GPIO_SetBits(GPIOD, NOKIA_SDIN);& |5 z5 A; B, g) O" x) Q
    }: y9 t& m6 [  C+ k1 }
  else
8 Y" z* V4 X- B3 J  {
! h* J9 G# H- j) U+ l% r0 v   //SDIN = 0;
- L5 r0 o" H0 i/ l3 M& q  h! G                        GPIO_ResetBits(GPIOD, NOKIA_SDIN);4 b7 [6 O6 H6 L& x+ r3 m/ r
8 Z$ x( t2 d1 S6 k- t8 k  //SCLK = 0;$ x: i/ l& \" P
                GPIO_ResetBits(GPIOD, NOKIA_SCLK);( c2 h9 ?! G% E1 [; ?2 r
  ucWriteData = ucWriteData << 1;
* C6 |0 X: J* q- g, t  //SCLK = 1;4 a! N2 p3 J3 G0 o8 K$ n  P1 _
                 GPIO_SetBits(GPIOD, NOKIA_SCLK);% k& M0 ?* z+ U2 R( C
]]}: `& v8 q' Y( W/ Q( k6 O7 `
/*-----------------------------------------------------------------------2 U5 C; c3 E5 W' G2 Q! }# T
LCD_set_XY        : 设置LCD坐标函数
输入参数:X]输入参数:X]( y, @% w( }# i' n7 e
void setadd(unsigned char a,unsigned char d)//设定地址
3 k9 W, ]! r: \2 o; [' K{: _$ e& t8 A1 b+ S$ h3 G7 _
write_byte((a|0x80),0);3 ]0 ?% a; i9 [4 a1 o1 z9 o+ A* W
write_byte((d|0x40),0);" e& W1 ?& {; m- |8 a! S9 c
% N- z. @& Z  h$ a/ K9 l/*-----------------------------------------------------------------------
3 p/ j) x7 E7 O0 S, `& KLCD_clear         : LCD清屏函数
1 R0 H: ?8 C  H! q+ O9 E9 vvoid]-----------------------------------------------------------------------*/2 F7 Y" ]5 ~' D
void]// LCD_write_CMD(0x0c);5 i2 s, z0 P) V
// LCD_write_CMD(0x80);
3 n" |7 F7 O/ \' B: \
void]
. t# s+ \' W1 o5 X5 U1 tvoid]
; R4 K$ W& x; Y  // 产生一个让LCD复位的低电平脉冲, b# [# z  S9 V, E# I
//RST = 0;
& J7 _- z+ W" S        GPIO_ResetBits(GPIOD, NOKIA_RST);5 w! I& L% e  O1 s
    7 ?2 d, }4 G- L
    delay_1us();  u  H+ V# Z9 a5 O, ]' f
    //RST = 1;+ n! G* D5 s- J: \" W
        GPIO_SetBits(GPIOD, NOKIA_RST);
. c. B) n) N" s3 l5 h' j- x    //SCE = 0;. k3 E/ ?  B7 u
    //DC = 0;9 _8 q4 H0 _( p3 L7 W% [- p% F9 N
     GPIO_ResetBits(GPIOD, NOKIA_SCE);6 ]0 Y' ]- c( q# M/ P  A& N
]]    LCD_write_CMD(0x21); // 使用扩展命令设置LCD模式,PD=0,V=0,H=1
7 B% D8 e  M2 L! q7 w    LCD_write_CMD(0xc0); // 设置偏置电压& n, r9 L0 {, u. V0 f
    LCD_write_CMD(0x06); // 温度校正& |( x4 o& t0 ~' I0 w
    LCD_write_CMD(0x13); // 1:48
]]  //  LCD_write_CMD(Nokia5110_DispMode_Reverse);0 V3 l* z  j/ n
           // 关闭LCD
7 Z8 r6 b9 R3 M# v. C8 y/*-----------------------------------------------------------------------3 C' T- R* ?, Q% h" u5 G4 E; g3 T
LCD_write_char    : 显示英文字符
输入参数:c]输入参数:c]    c -= 32;
]]void write_byte(uchar dd,uchar a)//写一字节 0:指令 1:数据
! B) x7 F( O- E{# ~9 J, n/ f5 N( Q5 n$ P# P: C& K: q' n7 C
char i;
. f$ p, V7 L% c' j* G& x//SCE=0;7 b* b1 b* i  R
//DC=a;- a2 u2 c& V& G- V$ r
GPIO_ResetBits(GPIOD, NOKIA_SCE);# v& b2 j' ^& P% k% ^3 b+ v1 E( o- X8 z1 v
   if(a==0)GPIO_ResetBits(GPIOD, NOKIA_DC);+ g- u) m+ d- g% o, t% {2 f/ K
   if(a==1)GPIO_SetBits(GPIOD, NOKIA_DC);        0 f# P  s: ?1 W9 W) q1 I& S) i  Q
for(i=0;i<8;i++)
& J+ ^$ x7 L& J; x: `0 E- P{& d2 r/ }- Z. W/ B& j7 F9 \* L; y6 J
if(dd&mask_table)
7 I9 |3 b3 w2 e7 s//SDIN=1;0 {0 @9 v5 ?% O1 a# o( @
        GPIO_SetBits(GPIOD, NOKIA_SDIN);& N1 S$ u  p* n  {5 f
else0 a) b* [6 k6 D! N5 F% f/ J
//SDIN=0;
; {/ p1 o! u) \! v- E//SCLK=0;+ u2 o- [# C/ A5 F0 ~' R% [
//SCLK=1;, }# X( `. z& i
! K5 J# u- b* Q! [6 O        GPIO_ResetBits(GPIOD, NOKIA_SCLK);) H+ R3 K6 J. D0 U, {
]]* t+ L( ?& J: D. R
) q/ _$ j$ o% }' ]LCD_write_english_String  : 英文字符串显示函数
输入参数:*s]输入参数:*s]-----------------------------------------------------------------------*/! R! b0 T/ k; n
void LCD_write_english_string(unsigned char X,unsigned char Y,char *s)( L$ Q. f9 J0 P0 l; ~( l' j
{% m4 W" [% K3 c5 s4 ^
    LCD_set_XY(X,Y);, w0 w! G' x; G( |6 P8 f9 C6 Q$ `
    while (*s)
( M% O4 f" L* T2 l    {; ^. j3 ~% L+ \/ V" t7 `8 j
   LCD_write_char(*s);
* m+ Z6 ]# q3 _# y; Q$ g( H   s++;* ~4 L: b% T+ w: ~. ]
8 X) [. S* W7 w$ X}
5 Y6 Q$ a$ a2 c( I/ n//****************************************************/
$ P2 p4 A( F4 f% D6 C( d  A  f//显示12(宽)*12(高)点阵列汉字
" `& s, i, ]) T! P$ z0 r1 gvoid displayonechar1212(uchar row, uchar page,uchar dd) //row:列 page:页 dd:字符: |. v6 r$ h, V5 S+ p: n4 F
7 M$ f+ l4 }& E2 [uchar row_i,xx,num=0;, L# k  ~1 H5 V: Y
for(xx=0;xx<2;xx++)
' Z# G" R4 M2 F& W+ T6 R{
5 B: k6 g) I: R0 isetadd(row,page);// 列,页
* `  a) l# A. Bfor(row_i=num; row_i<num+12;row_i++) write_byte(hzk1212[dd][row_i],1);- Z: ~+ w' C1 s' k1 U. f
num=num+12;page++;
% r3 }+ `( v8 x1 F: T1 P( _}
5 ~' M0 g: M1 Y3 O}
#endif
; D3 ]8 D" _# f" D, f3 {6 X2 h5 j
转载自:eefocus0 n9 |6 r3 Y8 ?: q9 c
赞 收藏 评论0 发布时间:2023-1-7 11:59
