STM32G431RBTx 基本模块 TIM OC输出
STMCU小助手 发布时间:2023-3-1 20:55
1.CubeMx的配置步骤
' u2 u" C9 ?3 R1 v3 Z# w5 i1 d修改上一次IC捕获的ioc文件来生成工程
5 z; @0 _6 L3 o9 N! E) \1 B
7 [7 E. d+ }) }3 C$ N- U
2dc00d051c5c461e96277f98ebb603a4.png ; P: `/ s+ Z/ a. `7 f( g4 F) _9 K
( A  \+ H& t+ q& _% G) C9 T
修改PA2,PA3为定时器15的通道1和通道2。
' u+ i+ X& i( Z& L& V
$ R& {# D; J2 b: _( k5 w
0 D: C  s- _3 }( ^8 U) ]" X( ?% b7 y. H% P
; Y6 ~/ j: x5 J. h
* s1 I/ J( Q6 e8 X$ e9 L
' {3 |  K, X& h
2.生成工程
+ W( E% O( G4 u! G1 T1 m+ X4 j点击GENERATE CODE生成代码后点击Open Project即可。
) D! m6 L' s( L9 j! O: e3 t5 S- z$ m. r/ a
03e1e8fdfabf4a92ad903add83876ee4.png 1 q; A# |3 r/ I2 Q. t( Z
5 `  J: ^5 h, O. \+ _
2 S' ?, V, b  T3 Z: k% Q3.测试代码
, i' i- @% M" D9 ~1 G$ p5 _  Ainterrupt.h:
  1. #ifndef __INTERRUPT_H__  I- g# R; L$ V, v0 P3 R# L
  2. #define __INTERRUPT_H__/ Y& \6 O+ S* r# ^7 @+ C# Q
  3. / \7 U  W1 O5 r9 D
  4. #include "main.h"9 \" K& D, m( S% E9 |- A5 t
  5. " X* h/ D' V% B' c, ~) D
  6. void HAL_TIM_IC_CaptureCallback(TIM_HandleTypeDef *htim);9 W2 t9 ?% Q2 B7 p
  7. void HAL_TIM_OC_DelayElapsedCallback(TIM_HandleTypeDef *htim);
    ! E/ J9 Z. ~9 \3 {8 @
  8. % A1 G* |8 b$ Y4 D2 ~
  9. #endif
    0 F" {; @9 z( e9 ^
  10. ' K: c) D8 D% S0 `
4 c% D2 u$ z5 u- A2 h9 iinterrupt.c:5 ?) n" L) N0 m/ S0 f% ]3 W1 ~
  1. #include "interrupt.h"
    % x7 O- N1 l; v! |, ]% J6 u
  2. #include "lcd.h"$ P8 F/ I- k- Y8 c/ a
  3. #include "stdio.h"' L4 \; [5 t1 F$ M) G- e# p3 Z
  4. unsigned int Period = 0;
    + D+ M  g: H+ }! E2 W
  5. unsigned int HighTime = 0;
    4 J; P0 o* F$ j; _: f
  6. unsigned char OC1_Duty = 25;) ?: r( N- {1 ]
  7. unsigned char OC2_Duty = 75;  J2 d8 Q% @1 E- h8 z+ g6 V3 K
  8. unsigned short OC1_Pulse = 1000;
      m9 Q( Q  k! ?, |
  9. unsigned short OC2_Pulse = 4000;
    , e8 `  A7 a3 @* w
  10. $ O4 @) S6 |& ?, O2 u) S" R& x
  11. ) j! \, X) F' _" E( ^1 y, H/ \
  12. void HAL_TIM_IC_CaptureCallback(TIM_HandleTypeDef *htim)
    8 N% _5 _6 r3 A4 M- i
  13. {
    4 r; N& }+ k- T) P# u3 G! m4 I
  14.         if(htim->Instance == TIM2); S* _1 M! X( r- X$ s- A- x2 Q
  15.         {
    % `9 ~8 ]" N' O( n
  16.                 if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_1)
    & G/ g( i2 v; s  \
  17.                 {9 H- S0 p8 u: U7 `
  18.                         Period = HAL_TIM_ReadCapturedValue(htim, TIM_CHANNEL_1); //读取直接通道
    1 f: ?& P* V/ o! b. y, V
  19.                         HighTime = HAL_TIM_ReadCapturedValue(htim, TIM_CHANNEL_2); //读取间接通道8 `) `. f" Z. H: j( |
  20.                         __HAL_TIM_SetCounter(htim, 0);1 d' q( `6 j  l- M/ C9 N9 @
  21.                         HAL_TIM_IC_Start_IT(htim, TIM_CHANNEL_1); //开启中断以便于下次采值" G3 n: k. c# s: g
  22.                         HAL_TIM_IC_Start_IT(htim, TIM_CHANNEL_2);- l  v5 s" f  O/ r. t6 |- X4 }
  23.                 }
    ! I# L8 x: H. `1 E. g" u+ @$ ?
  24.         }) ]2 ]. f2 k) l; D/ _( \% n
  25. }5 K5 E* o' S% ^; G
  26. & u$ S1 E+ C  ]2 Y: Y2 U
  27. void HAL_TIM_OC_DelayElapsedCallback(TIM_HandleTypeDef *htim)
    * X  l! X2 m; T! v
  28. {
    - Z) _) k- w- J" @$ }& Q
  29.         if(htim->Instance == TIM15)2 T/ j  T3 x0 i( j+ _
  30.         {
    , U! ~/ X# J7 m/ P3 Y# u
  31.                 unsigned short CapVal = 0;
    + p" _/ j/ b' p# V' u5 F" u; q6 M
  32.                 if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_1)
    6 u7 n* @2 ?3 j" P: w0 f9 m# t& p9 Z
  33.                 {+ b% K2 \- i2 Q% T) j
  34.                         CapVal = __HAL_TIM_GetCompare(htim, TIM_CHANNEL_1);
    ! u9 K0 ?5 w; X1 ~7 u" r2 A6 N
  35.                         if(HAL_GPIO_ReadPin(GPIOA, GPIO_PIN_2) == GPIO_PIN_RESET)- g' S3 }; X* x& c$ [  K% y9 [9 G
  36.                         {9 j: {5 W( p" S% ]9 p1 }
  37.                                 __HAL_TIM_SET_COMPARE(htim, TIM_CHANNEL_1, CapVal + OC1_Pulse - OC1_Duty / 100.0 * OC1_Pulse);
    - D( y  ?  ^, Y5 _3 M
  38.                         }
    3 w# T( Y4 O! G) y2 @
  39.                         else6 ]) G1 l6 S% g$ I+ k6 }8 ]
  40.                         {/ V  e8 g$ n' B% O, K- S* R# U
  41.                                 __HAL_TIM_SET_COMPARE(htim, TIM_CHANNEL_1, CapVal + OC1_Duty / 100.0 * OC1_Pulse);0 P. I$ u. d- n: n2 V
  42.                         }% s5 g4 U) f$ }  b, n5 l
  43.                                 , k1 q/ ]9 ?! u: u& W
  44.                 }7 N' w- V4 b3 k- l7 r5 B0 ?
  45.                 else if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_2)6 H: x+ m, Y+ U7 l! g, ]
  46.                 {3 b7 }) p" ~5 Q# ]
  47.                         CapVal = __HAL_TIM_GetCompare(htim, TIM_CHANNEL_2);) z! r% ~2 w9 _1 Y0 h
  48.                         if(HAL_GPIO_ReadPin(GPIOA, GPIO_PIN_3) == GPIO_PIN_RESET)
    0 r" ~6 e' }4 ^( B
  49.                         {  q* {& J5 Q0 A, G. E
  50.                                 __HAL_TIM_SetCompare(htim, TIM_CHANNEL_2, CapVal + (1 - OC2_Duty / 100.0) * OC2_Pulse);5 [; l' _* e& N% j" \9 ~& O
  51.                         }1 o  k  U; M' \1 c2 h2 i: Y  ~
  52.                         else
    4 `  O' L# h# B/ l* t  L) |$ O: ]6 p
  53.                         {( T1 F; \+ N. r4 |- j5 P* U
  54.                                 __HAL_TIM_SetCompare(htim, TIM_CHANNEL_2, CapVal + OC2_Duty / 100.0 * OC2_Pulse);0 _- a+ j/ y- _# E" _* W6 `7 O1 z
  55.                         }! \+ A1 s2 |, j) m
  56.                 }
    ) C. a; y4 w- ?# J: J! Q& O
  57.         }
    - h6 b( N( Z* C+ ^8 z. N
  58. }0 C& G: }0 b& ?# L! L$ ^
  59. $ L# L9 n8 t$ D8 g
* \* [1 p4 @; M( Q. P2 O+ n% ^) nmain.c:
8 a6 s- b( a$ m6 K; T* B' p' K
  1. /* USER CODE BEGIN Header */2 S8 n8 L7 c, U9 D9 P
  2. /**# y# G1 R7 A% I* N* p$ p
  3.   ******************************************************************************0 D! c& F. `% r9 _2 S7 }
  4.   * @file           : main.c
      ?% T# G) g4 w7 w7 \$ P
  5.   * @brief          : Main program body
    8 P1 B- C, `: W8 t3 V( N0 u4 U
  6.   ******************************************************************************9 X% q) B4 @% a' Q
  7.   * @attention
    & g# i3 b, s1 a; D3 _. a
  8.   *. l3 h1 n" i3 M7 O/ L- O
  9.   * <h2><center>© Copyright (c) 2023 STMicroelectronics.! V/ v" ~& R  ]0 n! `( n
  10.   * All rights reserved.</center></h2>
    8 {2 |4 h3 x4 R" L
  11.   *4 R- {9 I1 }) h4 F
  12.   * This software component is licensed by ST under BSD 3-Clause license," g$ F/ M  |) o( i' H( R( i8 Y( ^
  13.   * the "License"; You may not use this file except in compliance with the
    6 S% Q( B. T9 X$ {% n
  14.   * License. You may obtain a copy of the License at:
    7 d9 O" G' q  P% F3 ?; {; z2 E' a- j
  15.   *                        opensource.org/licenses/BSD-3-Clause. r( H6 g7 m# q  v* F8 z6 l
  16.   *
    3 N& ]! [. Q( o0 Q# o
  17.   ******************************************************************************
    $ u# W9 _% f; g+ t- @) ~+ j/ F8 }
  18.   */# {9 W8 F8 m8 s+ g
  19. /* USER CODE END Header */% M' |& i; I  I9 c1 d; ~$ @# V
  20. /* Includes ------------------------------------------------------------------*/' [  C# c- m9 ~$ @  ^* V6 E
  21. #include "main.h"
    4 \9 N" }+ Q/ U9 p2 g& }( M* b
  22. #include "tim.h"  Z7 \/ L) K: @# h7 r
  23. #include "gpio.h"
    8 l4 v  f& ~% u5 Z- G
  24. / D/ q# b& x1 y, Y* G! M! \
  25. /* Private includes ----------------------------------------------------------*/
    / A4 `' ]/ V1 }) d
  26. /* USER CODE BEGIN Includes */
    6 ~0 T/ T) f  y+ z
  27. #include "lcd.h"! h9 s6 F5 Z3 q- j( ]( ~' z) X
  28. #include "stdio.h"
    ; X3 }# |+ Y( T- F: h: R
  29. /* USER CODE END Includes */
    , L6 X+ {* N0 u- \% z: f! k- J; a( k2 m
  30. " S/ G/ U; V- I  L' m  P
  31. /* Private typedef -----------------------------------------------------------*/
    0 i/ Z0 {9 u6 A( V/ l. g+ O
  32. /* USER CODE BEGIN PTD */
    5 f0 E  V% E% B8 p9 H+ k
  33. + B" Q, F& ^2 T# N: _
  34. /* USER CODE END PTD */
    - P. h) g9 s3 D$ d/ i$ b
  35. 4 d3 j/ D# @, `" C( Q8 R
  36. /* Private define ------------------------------------------------------------*/' r$ @. f' v! u1 S1 A; A, m
  37. /* USER CODE BEGIN PD */
    0 c8 ~4 ]: N: I" y7 v) R
  38. /* USER CODE END PD */3 y$ U/ L9 j, i
  39. ! Z; x! O" e% k3 P1 i3 y
  40. /* Private macro -------------------------------------------------------------*/5 `4 w& `- G( B
  41. /* USER CODE BEGIN PM */! [" [! v3 \+ ]; ]) O! n
  42. , `# a: o4 H; z+ q
  43. /* USER CODE END PM */
    ! t0 {# }/ h" B9 U
  44. 2 b7 v# x8 I5 S, |" l1 e6 z) ?: D
  45. /* Private variables ---------------------------------------------------------*/
    ) P8 ]' M- i. r! s/ ^& O# s' b
  46. 6 A# ?# S8 u8 ~6 D( F* M' c/ Q! `
  47. /* USER CODE BEGIN PV */
    # V( Z, j. q# ~9 ?  |5 w
  48. extern unsigned int Period;  e6 _- U% {0 d( Q! D0 c. s
  49. extern unsigned int HighTime;- W3 Y( [# P6 I+ N# V& J- d
  50. char text[30];6 q  l% K4 {: y5 i
  51. /* USER CODE END PV */7 b: g  b* ~; c% q1 @% _
  52. ( W; |7 b7 i) y" P
  53. /* Private function prototypes -----------------------------------------------*/2 c5 F' q$ p9 l
  54. void SystemClock_Config(void);8 O: D, [5 k: U0 `& k* Y  i3 ]
  55. /* USER CODE BEGIN PFP */+ s8 u& K- i/ a! V/ e
  56. 7 B) k9 Q' l4 W7 _
  57. /* USER CODE END PFP */. C: z7 V" K# ]+ B$ C$ q% o% d
  58. $ C8 i( @" h  X. ?- W2 H4 d
  59. /* Private user code ---------------------------------------------------------*/
    . G3 y: |. G& Y. ~0 H- x
  60. /* USER CODE BEGIN 0 */
    ) ^1 c4 A( d! ~: k1 k; S9 O! ~
  61. 6 I3 R/ V' h. ], c6 V  {+ c
  62. /* USER CODE END 0 */4 l/ O3 c0 ~3 Y" ^
  63. ! P7 i9 N" ]. w  S' f2 w$ [
  64. /**
    $ a9 y  r& K% X6 w# z5 Q
  65.   * @brief  The application entry point.
    0 _/ t; Q7 I, G
  66.   * @retval int$ k+ W% e& R/ ~6 y4 i/ s
  67.   */; e+ T, K3 K# v. [: B# h4 z
  68. int main(void)
    4 m; Z( j* |, R' f% p9 N
  69. {' {- _0 B" ]: m
  70.   /* USER CODE BEGIN 1 */
    / A* n' ~$ G4 Z( t$ u
  71. 0 V: \8 h6 \! T7 X& x
  72.   /* USER CODE END 1 */6 J, d  e* `$ ]6 x# o; b
  73. # v" N1 ]% {! g1 C  X! y; V* x
  74.   /* MCU Configuration--------------------------------------------------------*/
    & G7 E! g  Q, v% v6 V2 Q# n
  75. 6 D" {8 W; R/ M' g3 c% O$ D
  76.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */8 P, z4 F( S( s2 m5 e1 H, G/ q
  77.   HAL_Init();  Q# u( r( Y3 C3 t5 U) j# |
  78. . o5 m! k' \, @9 c) Q
  79.   /* USER CODE BEGIN Init */! f$ b, C% n4 B5 d9 ?9 r( t+ H
  80. ( S* r  E9 m- E! A4 O5 Y2 F
  81.   /* USER CODE END Init */2 X; r" a4 _7 `- S* R
  82. : z9 u3 A  \3 I  F2 f9 H, |6 l3 D; X
  83.   /* Configure the system clock */. d' m( b$ e2 r& ^
  84.   SystemClock_Config();: g0 @, i4 J( M" c" U0 ^
  85. 4 s  R/ R0 R( @1 p1 A* H- ?% T
  86.   /* USER CODE BEGIN SysInit */
    7 L3 C* [4 C! D6 Y$ L
  87. 0 t( V7 L/ Y+ L% s; l. L  z0 a
  88.   /* USER CODE END SysInit */& Y; {  l0 {3 Z5 I% a; ]
  89. ' x" H+ H, ^7 p1 k! I7 G4 U" W4 G
  90.   /* Initialize all configured peripherals */3 A. O. U! `6 Q! v& H/ G- Z
  91.   MX_GPIO_Init();* E4 P$ G/ v+ S2 K3 a% J7 ^2 h! p
  92.   MX_TIM2_Init();
    + e6 R7 r; L( L0 p
  93.   MX_TIM15_Init();
      B: U6 C" \/ S* q* h
  94.   MX_TIM3_Init();! }. J) s" P. I- ]7 H4 R
  95.   /* USER CODE BEGIN 2 */2 v: V+ _" R& `' b
  96.         HAL_TIM_IC_Start_IT(&htim2, TIM_CHANNEL_1);, p2 u( B# m  f8 q
  97.         HAL_TIM_IC_Start_IT(&htim2, TIM_CHANNEL_2);* i( x- [! H0 O/ C
  98.         HAL_TIM_OC_Start_IT(&htim15, TIM_CHANNEL_1);2 C) y7 [: e; x7 V% Y6 N5 f4 ^
  99.         HAL_TIM_OC_Start_IT(&htim15, TIM_CHANNEL_2);
    - z8 F! a8 ?' m+ c5 a# J
  100.         LCD_Init();5 n' M4 j1 ^" m3 Y+ z5 d8 Z
  101.         LCD_Clear(Black);
    + n2 f0 C% K8 F9 a
  102.         LCD_SetBackColor(Black);
    # v+ ^! t5 ]$ B
  103.         LCD_SetTextColor(White);
    ! ~1 d0 d. C5 U
  104.   /* USER CODE END 2 */3 I& p) z. n" Q$ ^7 L
  105. 0 z3 Z" _5 @5 a7 g# @
  106.   /* Infinite loop */
    " b5 o" D9 D) M  f: l, ~, N
  107.   /* USER CODE BEGIN WHILE */3 z/ e3 A; x& l7 ?
  108.   while (1)5 h9 |/ l( n# Z( T; S
  109.   {
    1 `7 @7 E: s( Q9 T% S
  110.     /* USER CODE END WHILE */
    # Q" D( H; p4 D' F8 i0 j% |& Y  W
  111. ' k3 r& V2 Q6 _" m- S: ^
  112.     /* USER CODE BEGIN 3 */
      U0 L' u3 f/ k. f
  113.                 sprintf(text, "frq:%.2f   ", 1000000.0 / Period); //分频成1MHz所以这里1000000.0作为被除数2 y, l% d% X4 P  @/ E
  114.                 LCD_DisplayStringLine(Line0,  text);
    " U+ a0 C! l0 q+ E8 [
  115.                 sprintf(text, "Duty:%.2f   ", HighTime / (float)Period * 100); //占空比为高电平时间 / 周期 * 100%
      t8 t7 u) L% D5 q
  116.                 LCD_DisplayStringLine(Line1,  text);7 v' j1 N2 [3 K( P3 M
  117.   }
    4 \4 v0 i4 c# n* F$ d4 f, y$ N8 [: q
  118.   /* USER CODE END 3 */
    * Z5 q1 [: s( u
  119. }
    * W' B4 N% q( h8 V6 w4 J
  120. % ?0 v1 Q  d- c
  121. /**
      A% e2 ]) |/ \" b2 R  V( S
  122.   * @brief System Clock Configuration
    " @1 b' {9 o' V4 _9 A" W
  123.   * @retval None4 d, P: c1 T  D' ]2 ~( Q6 U3 X
  124.   */
    , Q  ?, f, C' z1 L5 x
  125. void SystemClock_Config(void)
    7 k7 |. |' o8 m
  126. {
    0 X1 \! i* O5 A8 s5 d2 B  U) M2 o7 y
  127.   RCC_OscInitTypeDef RCC_OscInitStruct = {0};
    ( P& f2 u6 O- h5 A! l, j
  128.   RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};! H: X0 p6 v5 ~
  129.   j9 D* _0 R' I$ M) P7 n0 O  [
  130.   /** Configure the main internal regulator output voltage/ R2 Q1 y  _% }: k! Q# D: {# L
  131.   *// t4 \" D+ T( }0 a" a. A% n
  132.   HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
    & T& U9 f) D1 E& S
  133.   /** Initializes the RCC Oscillators according to the specified parameters
    : @5 H* Z- M6 S* E/ F: U9 s
  134.   * in the RCC_OscInitTypeDef structure.$ G% o% w, k8 @6 l& K! m
  135.   */  U$ J3 s7 D4 \
  136.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;0 L. N0 d5 r+ h3 ?+ t: n
  137.   RCC_OscInitStruct.HSEState = RCC_HSE_ON;9 ]+ \& Z/ ]5 d. S- v# w! O
  138.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
    & Y4 V; ~3 \$ ~, m* [* A# s
  139.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;& y/ Y/ p* a0 F5 @, |
  140.   RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV3;7 N. j8 y5 k( H! `% @9 _
  141.   RCC_OscInitStruct.PLL.PLLN = 20;
    9 |- ^3 o: v: m$ i
  142.   RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
    0 h  B# R. b/ D/ ~3 B
  143.   RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;# j' Y! z- u- ^9 [5 j
  144.   RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
    ) E" \  h) s4 L0 q
  145.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    . W$ h7 e. N  s6 z7 M+ @
  146.   {% b$ O+ L8 R/ ~' B5 ~
  147.     Error_Handler();
    $ e+ v+ s+ V" R; ~) W& R- r; _+ u
  148.   }, @# ^  |+ `% ]  g! c4 H- ^
  149.   /** Initializes the CPU, AHB and APB buses clocks5 ^! O. [  P- J2 u$ g
  150.   */
    & }) m  V. W5 _8 n7 l
  151.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
    2 p4 O  o" [/ h2 ?1 l
  152.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
    , r  Z' S' |1 |) X! q
  153.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;3 d, R- \0 g1 f3 B* g
  154.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
      ]/ _2 H1 o7 v! L1 B# \
  155.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
    & h% E& V8 E, q1 D
  156.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;" |- g6 Q1 e+ a9 q, u3 l/ J
  157. # t( a- ^9 q" N, f7 \, v. L: E. K
  158.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)6 L! ~! a' Q0 y9 V
  159.   {
    " J* M- ~6 H# N
  160.     Error_Handler();
    ! Z! B6 _4 m6 t
  161.   }5 {3 ^7 b0 d( [( D
  162. }/ f8 q6 H- n$ W: T6 x9 M
  163.   i/ ~. d! o5 l+ ^0 n' x% Z5 p
  164. /* USER CODE BEGIN 4 */: J: b) Z! u9 H0 M+ m3 l1 M1 y
  165. + c6 |- G" S5 Y+ j- G/ Z2 L
  166. /* USER CODE END 4 */
    6 b9 [  s, X- B4 W
  167. % n  S$ u5 A- f5 y/ J+ M
  168. /**: {6 w& ^' f& m' M+ W
  169.   * @brief  This function is executed in case of error occurrence.
    # K  Q/ k. F2 p
  170.   * @retval None, B: J9 I/ [3 P% `
  171.   */
    2 V0 n7 y* B% K
  172. void Error_Handler(void)+ p) N/ ?; H  e4 u5 y. y
  173. {
    : {. ^! Q0 |) {: \2 t" b" K0 G0 E
  174.   /* USER CODE BEGIN Error_Handler_Debug */: s0 N( s% x2 H0 |- b4 _
  175.   /* User can add his own implementation to report the HAL error return state */; v& |( J: l+ J( c/ P/ |' p- J
  176.   __disable_irq();
    ; A2 k7 M9 k* j7 \" ~: n
  177.   while (1)8 W8 P( w0 g& ~, c' c
  178.   {" \4 A, J, \) G
  179.   }; b/ {+ y1 l/ _( u0 `
  180.   /* USER CODE END Error_Handler_Debug */; D5 i* Y7 H% s- Y. M& N/ v: G# }4 A
  181. }% T; f( A& y; ~* N/ ^9 _
  182. : |- ^2 h% ]  h( v
  183. #ifdef  USE_FULL_ASSERT& |9 s* i/ q2 c5 L8 x' D+ C" g
  184. /**
    ; g1 M2 r+ h' Q' s( S
  185.   * @brief  Reports the name of the source file and the source line number# h! ~( r1 D4 c) Q% m% X( V! [
  186.   *         where the assert_param error has occurred.1 g+ X7 W/ w0 @, D0 e, U
  187.   * @param  file: pointer to the source file name4 |, z4 u2 u! q$ K" K% D6 v$ _
  188.   * @param  line: assert_param error line source number: h$ a% Z6 m  A# q0 A/ l0 ]0 G# J
  189.   * @retval None
    $ D0 e9 K$ W* m- v! S2 m% V( {4 b
  190.   */
    / i% o8 \& |8 ~& `
  191. void assert_failed(uint8_t *file, uint32_t line)8 C9 j& _  K3 ?) `; j5 s
  192. {
    2 ~: J5 X0 K8 X% z0 G
  193.   /* USER CODE BEGIN 6 */
    5 c( T" g# |+ k4 z/ |
  194.   /* User can add his own implementation to report the file name and line number,
    6 K3 I2 n- ~& ~% x- d% S+ g5 m
  195.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
    ( n, _6 p& L2 e
  196.   /* USER CODE END 6 */* {. K: D' w! U7 ^. }. u. @1 |6 m1 Q
  197. }' m4 E& ^7 _# T
  198. #endif /* USE_FULL_ASSERT */
    . V+ k4 h3 |8 `, ]5 K
  199. , X! F3 r8 p; z* a0 m5 {! u, j
  200. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/7 K4 d+ I. m5 d  b* f" v: M
  201. / g! P' e# X- O" }) C# Q4 _) {
; y8 R9 S( q4 L5 b7 j) {
4.演示效果( V/ q  H, `- N/ e" M3 Z
0 j  [2 S5 Q! a# S9 i; V1 x
# }5 e5 S# x+ g; T7 g8 \' L: p$ g1 l1 C" I
3 ]9 X4 p$ e! z4 T* T9 ^5 q总结
- ]3 `8 @$ m, X" V/ Y# R从结果来看我们目标是PA2输出1000Hz占空比为25%的PWM波但最后测量频率为1026和23%的波形,误差比较大。PA3目标输出250Hz占空比为75%的PWM波,但最后输出的是252.84Hz和74.72%的PWM波,误差虽然存在但与PA2输出的波形比较,误差算是少一点,我们可以知道OC输出高频率PWM波时存在很严重的波形失真现象,但在输出低频率PWM波时这种情况就好一点,TIM的PWM模式不会有这样的问题但是PWM模式下定时器各个通道输出PWM波频率相同(占空比可以不同),不能实现每个通道占空比不同且频率也不同的情况。OC模式下虽然不支持输出高频率PWM波,但是它能实现每个通道的PWM波频率不同占空比也不同。) l) W' c% F0 N" \- ^* M
: N5 Y3 h$ Q* O% t% Z
% I8 v) d1 L. C' B1 \$ a! l以上就是OC的配置过程,测试代码以及测试效果
6 h4 h, E1 @. r5 o3 o( G# x$ X————————————————' ^- s) L+ X* h/ ^
版权声明:火花页.
1 E2 O" S. w) R% {6 M
  R% q" \7 h+ p8 s4 Q! M9 \  ~& i- x, Z. _  s9 H
赞 收藏 评论0 发布时间:2023-3-1 20:55
