使用HX711变送器模块+5kg的传感器。
) K: Q8 N) I6 [- " g5 j6 I, m' }2 L& h' e
- #define HX711_DATA PEin(0)
, r* G" i4 l9 b* r - #define HX711_SCK PEout(1)
, _) Y5 q. J: T: _1 P6 n b
+ ?+ G# `7 V, K2 N4 y6 w
. _4 `/ _6 J* F6 H/ d) a) C' L- : ?. z; j# ~1 z/ H* n- o/ T9 p
- void HX711_init(void)
: o. \! z- Q Z/ f - {
+ y4 Y/ L$ O) e* k( V6 Q2 ~ - GPIO_InitTypeDef GPIO_InitStructure;! X k& E9 m; s2 A1 X
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);, w( j- h& l! }: G4 [4 i, v. z
- ' v. C! n6 f) G7 g
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;2 O' I; S, {/ ]' v1 D) C
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
* M/ T; ~& i$ H( a4 A( ` - GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;/ y8 V% C. ^8 L" t$ t
- GPIO_Init(GPIOE, &GPIO_InitStructure);$ K7 _) |- [6 c4 M
- GPIO_SetBits(GPIOE, GPIO_Pin_1);3 K+ p! D8 b7 H
- % H; {' u% a" r" R5 ^
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
! L* e$ R1 i5 g: n& l - GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;, D$ u2 O' V. p4 L- z M# w
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;9 P9 T3 ?4 p7 b7 ^
- GPIO_Init(GPIOE, &GPIO_InitStructure); S$ u, `, @' l' P
- }: D' T: ^3 U! R8 X2 K( `# U* ]0 A5 `( i
) D/ ?% a; N* J2 Q( ~2 g1 |6 t- $ ^1 h3 Z/ L2 b8 c4 \: H2 U0 \
- uint8_t HX711_GetValue(uint32_t *value)
/ s6 q& \% x2 ?' A1 b( e - {6 i5 j8 a& j0 f) `. e
- int retry = 0;
( b2 P! O* X4 X. \& j' a- v - uint32_t ret = 0;
8 A& Q; G' r6 q6 c7 s: X0 B
9 d* @/ k O: g; N4 ~* y- HX711_SCK = 0;( U5 h `1 i% |' ~' y2 ]
- while (retry < 200)
. G6 A( n" u5 t) _! v0 o - {, @. W* p n3 J! T$ u6 y
- delay_us(1);8 Y; b7 n( y7 R
- if (HX711_DATA == 0)
0 J, Z4 @0 ?) A5 i, Q, M - break;; v1 W. m9 M1 |" G* D
- else
- A" W5 w+ x" Z# c - retry++;
" ~8 E% H6 W. s- Q2 n5 C - }* \" N5 J: E) Z0 A- f/ [$ W! f1 f, |
- if (retry == 200) return 1;( d& I: o0 ~' x. t0 h
- - p8 ~4 l( b. ~, ^3 W# |3 |
- for (int i = 0; i < 24; i++)
" u+ ]2 C0 [' K4 z - {# V; J8 D" h3 X8 B$ ~8 L* X
- HX711_SCK = 1;/ N5 s' k3 B, ]* k
- delay_us(1);
8 c u, ^0 E0 I1 E l - ret = ret << 1;
3 S' G0 U, v5 T# H, J - HX711_SCK = 0;
; I2 y3 u j% T3 `2 N, a - ret |= HX711_DATA;
" b# f' B* }8 x - delay_us(1);
, f3 J% ?# \! x# T - }
. K9 S/ a5 Q3 l3 x: U - & D( E( l0 r5 s/ H
- HX711_SCK = 1;
8 |4 U* H/ J8 M3 Z( z w, z2 H) A3 [ - delay_us(1);# P& b# b+ \! Z: V V9 b: b3 l
- *value = ret ^ 0x800000;( e: ?5 M G3 u4 J9 k K2 }
- //*value = ret;
# `% J( t. i$ a& K4 @" g - HX711_SCK = 0;( G/ H& z. j0 f( M
- delay_us(1);5 ? e0 E. d; B; L* \ p
- , D/ J+ y3 N0 i2 N1 m1 l
- return 0;
3 l* j& U4 c5 M$ F9 c& A$ x' P - }8 ~( A' ]( S. N$ L& {2 Q9 _
8 I! P% ]. C$ g. e& x3 j
/ k9 Z& ]" K2 h- w- # K n/ c: M+ W, d
- int main(void)
: Q7 r! D3 X" b" }. I8 c - {/ a* `+ V5 ]) ]! G
- u16 t;( C# _8 Z7 w, u- g
- u16 len;$ _ {# x+ y# X; h8 G X7 i
- u16 times = 0;
# m1 S L+ z4 |, t - uint32_t value = 0;
. S% Q, I5 E0 `+ w* `/ y" Z: c3 A% ~ - delay_init(); //延时函数初始化
4 g7 i h8 i" O+ l v/ s2 b7 m - NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置NVIC中断分组2:2位抢占优先级,2位响应优先级! C2 M& q" C6 |3 z6 F# z! o+ V
- uart_init(115200); //串口初始化为115200
) k$ Q. w. M2 y& n+ U - LED_Init(); //LED端口初始化
* }# s. i5 r5 u) [ - KEY_Init(); //初始化与按键连接的硬件接口
+ M8 r: }( e r0 W% c% L8 j - HX711_init();
. v" _8 ^; k, Z% L - HX711_GetValue(&value);
( R' d: y8 \: _5 w7 Z- K - printf("0x%x\r\n", value);
! W& T5 h; M% R. B3 D3 L - delay_ms(500);
3 i9 A! b- q! Y6 h7 \7 I2 R. z - HX711_GetValue(&value);3 G0 W; g* P- i A6 y
- printf("0x%x\r\n", value);- J5 C# b {& W7 _4 ?- ~
- delay_ms(500);
( z2 ?8 d. ^+ P/ k. j# K8 r1 m$ z - HX711_GetValue(&value);
# [: O% y) D4 W& H - printf("0x%x\r\n", value);$ `. t5 p4 Y# A$ j) r7 E
- delay_ms(500);9 j# Y; O: {: S2 `3 {
- HX711_GetValue(&value);7 Z; V3 Q" i' a, }/ l/ I3 d
- printf("0x%x\r\n", value);% E5 \4 E6 \9 L) {/ E4 f4 t( H
- delay_ms(500);; `$ P+ K- T$ ^% E3 ] h9 P
- HX711_GetValue(&value);8 X2 W; k. @# T
: s# o$ ]- H* }7 d5 N! U - delay_ms(500);: y; G4 e L0 ?- G6 u/ ?5 [: ?
- uint32_t zero = value;
; d# e4 X3 D4 W' W8 G, b3 V O& V. ^ - printf("0x%x\r\n", value);' o& s C S' I; G6 t9 E
- while (1)
3 C6 f' |& \7 G8 V! R4 @( [4 m - {
4 k N+ j2 i0 k3 S - if (HX711_GetValue(&value) == 0)
" Y$ S! G" L8 r6 ` - {% V; D7 ^" n/ \/ T5 \* X6 l/ T
- printf("0x%x\t%d\r\n", value, value - zero);- X; @" v* M- h4 C
- if (value < zero) value = zero;/ W4 a0 }9 _- P
- uint32_t weight = (value - zero) / 430;
. g' v# T* ~4 _; P+ P( i7 ^ - weight = weight / 0.89;
/ e6 d( L* C" n$ G! @/ I - printf("%d\t\r\n", weight);
2 y& [! S+ p3 m t Z7 S3 q$ K2 K - }% `; S0 ^6 }# Q, L4 L
- else
; d5 i2 ~/ S; P/ N1 ~4 N, d6 r- B - {0 x* r+ r! ~0 o) ?; v; F
- printf("read error\r\n");
- W) w* a2 r, Z9 R( r1 g& E - }
0 o4 R B1 k3 ~, W+ J - delay_ms(1000);
' ]: G3 E2 F8 Z: L& w - }; D7 P9 G" L- A7 T9 n2 R1 o6 v
- }0 x! W4 W% ?* l- e7 k& e' Q1 Q) ?
. O) \$ W6 K6 w" u代码中的*value = ret^0x800000;相当于把传感器读到的值加了0x800000,即原来的差分读出来假设是-2.5V ~ +2.5V,现在变成了0V ~ 5V,转换成了无符号数更加好计算。& C( k, c% T+ v" _/ q
7 n/ U* W& T; k
" x. x2 d' n9 m9 v% m. z+ _
) E$ U3 ~, N& w5 `$ w% [+ m, O
% {* B& \& v& k0 B) \! o' m' T: e
# V" P7 O; i" |3 x3 h: v
测量出来的重量uint32_t weight = (value - zero) / 430;,由于应变片工艺问题,可能其值并不等效于,最终通过砝码标定,得出重量:weight = weight / 0.89;
4 [0 |% H: E& q3 ]———————————————— K9 ?2 _5 {! Z' D/ ?
版权声明:小盼你最萌哒
6 e2 x" u8 I% c! ?( s; ]& l如有侵权请联系删除& }: k5 D3 {2 u% V' T; ^
