如何基于stm32定时器同时实现定时和输出PWM
攻城狮Melo 发布时间:2023-3-14 14:11
对于普通定时器如TIM2、TIM3、TIM4、TIM5,如下配置:% c4 u( x2 V4 b# d: o) I% k
  1. //TIM3 PWM部分初始化
    5 D- R4 \+ [. b$ ~) P) i
  2. //PWM输出初始化+ v6 L  I8 N5 K% b( l# k
  3. //arr:自动重装值
    3 Q% C5 M9 [7 Q: H: K( I9 s
  4. //psc:时钟预分频数
    1 Z2 Q+ K+ M7 \3 L2 _/ L& B0 `2 l# |
  5. void TIM3_PWM_Init(u16 arr, u16 psc)
    1 O8 g& U2 d& K( H4 I. o
  6. {- c* B! ~! v" ?0 k3 o' P
  7.     GPIO_InitTypeDef GPIO_InitStructure;9 c% K) `6 k" _, c% D' i
  8.     TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;' E+ K# k4 i( e6 [$ |2 Q6 S. ^& w
  9.     TIM_OCInitTypeDef  TIM_OCInitStructure;) f# ^/ d2 ?) @: `/ _
  10.     NVIC_InitTypeDef NVIC_InitStructure;. `) b- K4 C/ }6 i
  11. 0 `3 i1 t, U* J! w7 c# P0 Q5 {
  12. 8 c9 p" x+ x2 t. s, Y3 `
  13.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);        //使能定时器3时钟0 {6 u$ M, N- G8 x
  14.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB  | RCC_APB2Periph_AFIO, ENABLE);  //使能GPIO外设和AFIO复用功能模块时钟; Y% S+ ?+ N) p4 v1 M
  15. ; l  X2 z' i, s. W+ S7 d& O: r' J' a
  16.     GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE); //Timer3部分重映射  TIM3_CH2->PB5# j- J7 i) L0 ]3 f8 r
  17. . d# p: _* I* V% S" I; [% r
  18.     //设置该引脚为复用输出功能,输出TIM3 CH2的PWM脉冲波形        GPIOB.5
    $ Z8 w- v1 Q, \+ N
  19.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //TIM_CH2
    $ T6 |$ E0 r- [
  20.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //复用推挽输出
    / n  R" g) {! B9 ^: `' ^- [
  21.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    5 g( Y; I/ `! W# }3 e
  22.     GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIO
    8 w9 Y" ~  e- A$ x5 ^! C
  23. * U8 c" ^( _% C" v
  24.     //初始化TIM30 E3 m+ Y6 L0 ]* M# ^, X/ ^
  25.     TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值
    5 o, f  ~  ^( \8 r* n' d; W
  26.     TIM_TimeBaseStructure.TIM_Prescaler = psc; //设置用来作为TIMx时钟频率除数的预分频值
    * F# a/ \0 W( T
  27.     TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_tim
    . [) G# N# m+ ~
  28.     TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
    * Z: D" \3 x9 Y" `, s* X& s
  29.     TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
    + C9 ]* T8 v: J$ E/ N
  30. * J) f$ M6 f+ ?, a9 U
  31.     TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE ); //使能指定的TIM3中断,允许更新中断( X; G% C  g' Q, t0 [& \
  32. # s- s* G& W) m8 F2 b
  33.     NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;  //TIM3中断
    & O4 Z/ A5 \, O6 r; |1 q2 K6 f
  34.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;  //先占优先级0级
    & F: U8 h  u3 v  B' _
  35.     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;  //从优先级3级
    6 _( v0 D- p) Q# g# N. C! B
  36.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
    / i& Z2 U+ c! c/ ^' o
  37.     NVIC_Init(&NVIC_InitStructure);  //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器& e4 N5 G- ^$ q6 d# ?% y' Z
  38. 8 [+ I) l! D  p
  39.     //初始化TIM3 Channel2 PWM模式
    : z2 w% P& x" ~+ w& ~1 r* G# j) K
  40.     TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //选择定时器模式:TIM脉冲宽度调制模式2
    9 ^1 C% p5 x  |& m
  41.     TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能
    ! o( L# n# I. l- D" W
  42.     TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //输出极性:TIM输出比较极性高! o7 ?6 Q% C9 ?# C
  43.     TIM_OC2Init(TIM3, &TIM_OCInitStructure);  //根据T指定的参数初始化外设TIM3 OC2
    ( ~+ T2 _3 g) i
  44. 6 h( I2 d. M+ j) R' P' Y
  45.     TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);  //使能TIM3在CCR2上的预装载寄存器
    & j# L: J3 h2 q; m, I
  46. 5 K9 b: Z# v4 W( E
  47.     TIM_Cmd(TIM3, ENABLE);  //使能TIM3
    $ {3 e6 k& @( S4 f1 k& m
  48. ; ~6 E+ e: Y6 x. `5 H
  49. }5 M  O& D7 r& j+ i
  50. //定时器3中断服务程序. k! i4 k; A! h
  51. void TIM3_IRQHandler(void)   //TIM3中断
    - s2 l4 y/ L- r* e- B# u' T
  52. {' w- k$ V8 @- o  c  K& Z
  53.     if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //检查指定的TIM中断发生与否:TIM 中断源* i3 o( Z; U  r5 m2 w# E; C
  54.     {3 D" F3 M; a1 t) H4 d
  55.         TIM_ClearITPendingBit(TIM3, TIM_IT_Update  );  //清除TIMx的中断待处理位:TIM 中断源
    & q- s) w7 s  W' [4 C
  56.         LED1 = !LED1;" {( x; V+ m& _" Z2 ^
  57.     }
    " ?) c/ |  y7 |# l; V/ F
  58. }
    8 |9 [9 q0 Z" {8 Z+ k7 I" S6 ?5 q
  59. 1 J3 y( D" n$ C) Q& Y# \
  60. int main(void)
    + y& V: U& Y) a( F
  61. {: T4 Z; u, X6 s0 f: q4 {' Y
  62.     u16 led0pwmval = 0;
    9 @! f9 K; x9 N8 n! ?
  63.     u8 dir = 1;/ z; T  R" W3 f+ n+ B9 v
  64.     u8 keyval;3 C. m- G( W$ {3 Y
  65.     delay_init();                     //延时函数初始化
    . h: L7 F! C% B6 x4 g) E) T
  66.     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);          //设置NVIC中断分组2:2位抢占优先级,2位响应优先级) s$ E7 s+ ?; p
  67.     uart_init(115200);         //串口初始化为115200
    ; I) ]* Q' k5 k+ x0 g, a4 H  b
  68.     LED_Init();                             //LED端口初始化0 e2 i! X; t; Z. h
  69.     KEY_Init();                                        //初始化按键
    $ E+ k& @" C) }; Q
  70.     TIM3_PWM_Init(1000 - 1, 72 - 1);         //不分频。PWM频率=72000000/900=80Khz: p& K* }0 t0 _' \+ y2 _; }4 \( `
  71.     while(1)
      }9 a; U+ r( F( ?- o
  72.     {8 o1 M& r) R: o% T. \8 T4 j
  73.         delay_ms(10);0 `7 J: ]% M1 |& I- ?
  74.         if(dir)led0pwmval++;! l- ~# m2 U5 Q/ _' q0 u( T
  75.         else led0pwmval--;; a7 A) u7 D' i1 h- x6 Y3 }$ X
  76. " x2 v3 r  Y& e8 I* x
  77.         if(led0pwmval > 300)dir = 0;
      c2 P7 `, t3 ?
  78.         if(led0pwmval == 0)dir = 1;
    3 ^$ p+ \3 q; M2 [2 b/ P7 z- Q
  79.         TIM_SetCompare2(TIM3, led0pwmval);/ E$ j/ X+ L: T$ K
  80.
    + K" w4 {7 f1 v# X
  81.                         4 L. V( u, a) V( p
  82.         keyval = KEY_Scan(0);
    7 I) m2 D5 R$ }4 M1 Z% P
  83.         if(keyval == KEY1_PRES)
    1 I9 U$ f: n: g* h0 [
  84.         {0 J9 [! Z+ R0 n# t
  85.             TIM_CCxCmd(TIM3, TIM_Channel_2, TIM_CCx_Disable);
    ' i' Q; _, Z0 P
  86.                                         6 W( q- i( ~. q9 c+ @* [
  87.         }
    $ s3 z6 I) x$ c& n# x
  88.         else if(keyval == KEY0_PRES)
    - s+ y8 ]4 v( a) k# d) s
  89.         {
    7 ?" z/ G/ K' j$ u- _' |
  90.             TIM_CCxCmd(TIM3, TIM_Channel_2, TIM_CCx_Enable);
    . [7 [8 {, @9 x5 G% B% B. m* i8 f# V
  91.         }
    ! E2 i/ e* Y7 c" {) B3 ?
  92.     }4 P8 |' @- ^1 T0 C3 k% o) \
  93. }
    % @$ x9 F; j& }5 r6 m1 c
  94. ' `5 S, t0 [( o- H4 R
  95. 8 ~6 O) U0 d' v3 v$ a' L
% O3 L- h; `3 ?通过TIM_CCxCmd(TIM3, TIM_Channel_2, TIM_CCx_Enable);启动PWM通道输出,TIM_CCxCmd(TIM3, TIM_Channel_2, TIM_CCx_Disable);停止PWM通道输出。
. _) _8 A7 u8 U# r* v( z" I6 o对于高级定时器如TIM1、TIM8则参考原子的步进电机驱动程序:1 w+ I$ K! A4 K1 y6 Z* S% H- t
  1. void TIM8_OPM_RCR_Init(u16 arr,u16 psc)4 d0 u- G1 |+ x, U8 Q1 q8 V
  2. {
    ' p" b' D7 d8 S% `! k, f2 l, n
  3.         GPIO_InitTypeDef GPIO_InitStructure;% \4 i4 m* t" r) ^' H: @
  4.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;8 W: E: P* c4 ^. C. \3 W- _
  5.         TIM_OCInitTypeDef  TIM_OCInitStructure;
    , f/ K* u9 p/ Q. ^. F2 X
  6.         NVIC_InitTypeDef NVIC_InitStructure;7 f. e  @$ P3 n) T
  7. # J2 m* ^% _1 ~! U+ H8 }4 B+ P
  8.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE); //TIM8时钟使能
    7 ]+ ]' [9 ^8 s2 c  u) s" `
  9.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC , ENABLE);  //使能GPIOC外设时钟使能        0 C% ?4 R* V8 i
  10. 4 z* k0 x( [3 c* P/ ?- K
  11.   //设置该引脚为复用输出功能,输出TIM8 CH2的PWM脉冲波形
    9 U5 a) ?4 t* `- b
  12.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; //TIM8_CH2: N' @& k3 p* v! j
  13.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //复用推挽输出
    8 h( b/ Y' E" ?
  14.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    / L! D0 o8 Y" i  x* P' G
  15.         GPIO_Init(GPIOC, &GPIO_InitStructure);
    # H0 O9 j* t) r: @6 G1 N* S
  16.
    ; Z* K3 l  d5 m' e( y, U7 j
  17.         TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);: ~5 L1 F8 M( ^7 c2 ^7 o
  18.
    ( |6 y4 {# P% |9 ?8 ?* B+ A0 A
  19.         TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值         7 w; {$ ]- k- d5 e
  20.         TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值  : c( O" ^( A) @2 I) a
  21.         TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_tim
    $ {  @1 w7 v, K* c. ^, Y
  22.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
    4 r( g9 N) H: P
  23.         TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
    2 i6 O# n5 i9 T& b# [  ]1 V: S# D, _
  24.         TIM_ClearITPendingBit(TIM8,TIM_IT_Update);3 O6 ~* W7 x: D' o! Y5 I0 r4 J* K
  25. 6 L) g; u# B) B& I8 D* c% T
  26.         TIM_UpdateRequestConfig(TIM8,TIM_UpdateSource_Regular); /********* 设置只有计数溢出作为更新中断 ********/
    1 v' A& W% q/ e3 C+ a
  27.         TIM_SelectOnePulseMode(TIM8,TIM_OPMode_Single);/******* 单脉冲模式 **********/
    ' R7 c+ h$ n- y! I+ m* E
  28. 7 d2 C+ X2 K6 i% k, v4 ~* }
  29.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //选择定时器模式:TIM脉冲宽度调制模式2
    , W6 w& W! d4 `
  30.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出2使能
    : P4 {! L+ n2 Z1 c4 U$ Y6 ]
  31.         TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable; /****** 比较输出2N失能 *******/
    , s) Q2 [- ^) }+ V7 D) v" z9 L
  32.         TIM_OCInitStructure.TIM_Pulse = arr>>1; //设置待装入捕获比较寄存器的脉冲值0 g' ?4 S' o: b1 f
  33.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //输出极性:TIM输出比较极性高
    + t, q% \0 ~' |5 S5 T. b
  34.         TIM_OC2Init(TIM8, &TIM_OCInitStructure);  //根据TIM_OCInitStruct中指定的参数初始化外设TIMx- T/ H$ g# Q; L. G
  35. - [" u4 ]8 m# ~/ q+ U
  36.         TIM_OC2PreloadConfig(TIM8, TIM_OCPreload_Enable);  //CH2预装载使能         $ x" F- r! n6 O. v& T! U$ s
  37.         TIM_ARRPreloadConfig(TIM8, ENABLE); //使能TIMx在ARR上的预装载寄存器1 ?& ^3 }' B% e2 z- O+ l9 u; R; S
  38.         $ o0 V+ I/ _$ M( w5 u7 G7 J* R
  39.         TIM_ITConfig(TIM8, TIM_IT_Update ,ENABLE);  //TIM8   使能或者失能指定的TIM中断
    % U- c" m/ d. k+ r1 R
  40. 9 p& k9 `  Z" `  D
  41.         NVIC_InitStructure.NVIC_IRQChannel = TIM8_UP_IRQn;  //TIM8中断
    & R$ \% x" l) X; `5 i
  42.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;  //先占优先级1级8 Z$ q1 G$ o0 G
  43.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;  //从优先级1级
    ; R8 {2 k8 K: o3 R4 |8 u5 ]% J
  44.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能: V2 P& z& d" p0 c! R6 ^, a
  45.         NVIC_Init(&NVIC_InitStructure);  //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器
    $ r6 D( u; \3 o( J2 P4 Q/ c- o; k6 T
  46.
    - E  g  z! c# [5 d# m, e) U. ^
  47.         TIM_ClearITPendingBit(TIM8, TIM_IT_Update);  //清除TIMx的中断待处理位:TIM 中断源
    2 |9 h8 y! z+ ?' R" k
  48.         TIM_Cmd(TIM8, ENABLE);  //使能TIM8        $ u" t3 X: N6 y" g
  49. }
    0 `/ Z8 ]4 _/ [1 M1 \
  50. & z$ B8 O4 n/ Y7 M7 A6 c* A4 J# T
  51. 9 b9 J; N& Y8 Z! w
  52. void TIM8_UP_IRQHandler(void)  B- _8 A" c9 r& B7 h
  53. {% f6 G0 _  j+ Q; `8 i$ @) ?8 L* p
  54.     if(TIM_GetITStatus(TIM8, TIM_FLAG_Update) != RESET) //更新中断
    * S* n' ]; X1 b) T  j# S7 z" J
  55.     {( _+ g2 ^; D- p( l4 e
  56.         TIM_ClearITPendingBit(TIM8, TIM_FLAG_Update); //清除更新中断标志位
    . B; ~+ ]+ D1 U. _7 @2 ?
  57.         if(is_rcr_finish == 0) //重复计数器未设置完成
    ! i, L8 {) H1 _2 K* S- b; S4 v
  58.         {, q  b+ u9 Y" @- e; _
  59.             if(rcr_integer != 0) //整数部分脉冲还未发送完成" U  t5 v: v: S( `- f
  60.             {4 N: M: i% M' a) [9 V* V
  61.                 TIM8->RCR = RCR_VAL; //设置重复计数值
    : }  e' S6 o1 y; B
  62.                 rcr_integer--;//减少RCR_VAL+1个脉冲
    4 Y+ S$ R- O; m# x$ U4 y# @1 L1 ]4 h
  63.             } else if(rcr_remainder != 0) //余数部分脉冲 不位0
    6 o. W3 d, [3 c7 r. I6 F/ Z
  64.             {
    8 }$ S( a( ]& U
  65.                 TIM8->RCR = rcr_remainder - 1; //设置余数部分2 G6 C1 z8 i. q1 L
  66.                 rcr_remainder = 0; //清零/ L+ `+ R3 I% @' b5 B
  67.                 is_rcr_finish = 1; //重复计数器设置完成7 k' R1 Q# ?1 T% Z- D' x" w/ g
  68.             } else goto out;   //rcr_remainder=0,直接退出4 Y- ]! L& N& O! g
  69.             TIM_GenerateEvent(TIM8, TIM_EventSource_Update); //产生一个更新事件 重新初始化计数器0 Q- ]9 }5 T* e. a4 K
  70.             TIM_CtrlPWMOutputs(TIM8, ENABLE);        //MOE 主输出使能6 m. x$ A" k4 x2 i3 f
  71.             TIM_Cmd(TIM8, ENABLE);  //使能TIM8
    # h; Q5 D$ Y  u6 z* o
  72.             if(motor_dir == CW) //如果方向为顺时针
    ! I3 ]5 z; C. `8 f' A4 C( j
  73.                 current_pos += (TIM8->RCR + 1); //加上重复计数值
    8 P  r; n* L# u! F
  74.             else          //否则方向为逆时针
    / ]7 f* |' G8 O7 o
  75.                 current_pos -= (TIM8->RCR + 1); //减去重复计数值
    2 ?& m2 V6 j; l' \( q7 k; j" s. q5 j
  76.         } else
    ! b1 T5 M- |$ Q' z( b$ ~
  77.         {
      S, [/ J3 a6 v8 Y) Z; g
  78. out:' v+ u1 @# J$ }8 ]
  79.             is_rcr_finish = 1; //重复计数器设置完成
    3 _6 n7 h* V* w! |  O1 M: f
  80.             TIM_CtrlPWMOutputs(TIM8, DISABLE);        //MOE 主输出关闭7 `  X, O' b% U8 e+ `1 E: C, N
  81.             TIM_Cmd(TIM8, DISABLE);  //关闭TIM82 K) R  `& A. @+ y
  82.             printf("当前位置=%ld\r\n", current_pos); //打印输出9 ?: Z( V, j; J$ Q
  83.         }
    $ S' @  ~! y+ R- H
  84.     }
    4 t6 _. u" u0 L* v2 Z3 ~
  85. }
    - M" d( f8 G7 K! a
  86. : @2 s, M  s3 y  }$ Z
  87. ( D7 A( `  I4 R. T8 w! f( B0 w
  88. % ?8 a) n+ E9 i5 L( w- i
  89. int main(void)
    ' g, o) Z" @9 P7 E& f
  90. {- C# g- B2 \+ s" b; W4 U7 V: i
  91.     u8 i;
    1 _7 \; z$ E* @! q9 B' `6 h
  92.     u8 keyval;8 k, Z: b+ X; q/ z5 \
  93.     delay_init();                     //延时函数初始化4 R3 P1 \) b. G- |' b. C7 M- i
  94.     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);          //设置NVIC中断分组2:2位抢占优先级,2位响应优先级; X- n7 m( n0 M/ E, b* B  o) w+ }; v
  95.     uart_init(115200);                 //串口初始化为115200
    9 x% b7 `' v- G# Y0 e
  96.     usmart_dev.init(72);         //初始化USMART
    % A$ ?7 j, [7 Q
  97.     LED_Init();                             //LED端口初始化
    , O8 O) L- L( G7 X
  98.     KEY_Init();                                        //初始化按键
    . K! I  A) ?$ @/ K( _: \
  99.     Driver_Init();                        //驱动器初始化
    2 x" j7 ]+ a+ @* j1 D% S6 S4 \' {
  100.     TIM8_OPM_RCR_Init(999, 72 - 1); //1MHz计数频率  单脉冲+重复计数模式
    6 g* ]0 d. E8 W
  101.     while(1)
    ! b* c2 E" ?% Y7 U
  102.     {( V& U& F- I) Q: B3 E
  103.         keyval = KEY_Scan(0);
    1 I: V$ i, |, v# H+ n
  104.         if(keyval == WKUP_PRES)
    ! q1 G6 g/ C8 N
  105.         {
    . ?3 I6 w1 X- r* \- y$ w6 \5 }
  106.             Locate_Abs(0, 500); //按下WKUP,回零点
    $ U7 X! `/ R# ~: K0 N
  107.         } else if(keyval == KEY0_PRES)' J. f$ A9 ]) ]  z
  108.         {+ i. K3 x8 ?! g
  109.             Locate_Rle(200, 500, CW); //按下KEY0,以500Hz的频率 顺时针发200脉冲
    8 M/ Q0 n6 N1 m5 L) j
  110.         } else if(keyval == KEY1_PRES)' h9 T  b) p) J4 g; H
  111.         {: d2 K9 X: B* m1 Z
  112.             Locate_Rle(40000, 500, CCW); //按下KEY1,以500Hz的频率 逆时针发400脉冲
    # s! P7 `" x6 l$ Z% y
  113.         }
    - p  M) i9 s0 v1 i
  114.         delay_ms(10);4 n5 @4 L! z" {7 x/ F, G0 Z
  115.         i++;# r( j8 X& L9 }1 _4 L* v' Y
  116.         if(i == 50)
    ! w1 d' J- v0 ^1 \7 M7 |
  117.         {
    3 h# v, A# k. i& l: Y
  118.             i = 0;
    . b4 H$ L- K, w$ \0 m
  119.             LED1 = !LED1;% V$ P$ ^. Z! [" F6 ?
  120.         }* h% k7 m) k+ H
  121.     }
    4 x: o' {) w7 J6 e+ Y' b
  122. }: u2 Q) s1 n2 S6 T
  123. / k6 y' H0 [1 w* x" L: ?
( [" z! O" ?+ u/ [% o. M% k
————————————————9 g2 M, N. e. H% Q7 Z) j
版权声明:小盼你最萌哒
" M8 D  G5 E3 R  k' n如有侵权请联系删除) X' V9 l! ?% {2 h& N8 [
赞 收藏 评论0 发布时间:2023-3-14 14:11
