如何区别stm32F1和F4对GPIO的操作
攻城狮Melo 发布时间:2023-3-14 16:48
以下是stm32f4xx.h中对GPIO的定义。5 G, H& d8 \5 Q4 e
  1. typedef struct1 A9 z3 T5 j. m2 W* E
  2. {
    " T& k! }5 Q$ X6 X+ ~% w& I7 E3 o' L/ \
  3.   __IO uint32_t MODER;    /*!< GPIO port mode register,               Address offset: 0x00      */
    ' K. p% M8 y$ k9 Z; o
  4.   __IO uint32_t OTYPER;   /*!< GPIO port output type register,        Address offset: 0x04      */- I/ n% S; G% C2 q6 F
  5.   __IO uint32_t OSPEEDR;  /*!< GPIO port output speed register,       Address offset: 0x08      */
    . s9 N+ k5 i8 ]! G+ ]4 Z' `
  6.   __IO uint32_t PUPDR;    /*!< GPIO port pull-up/pull-down register,  Address offset: 0x0C      */
    * t) \& u  g0 g* D  e) O2 u
  7.   __IO uint32_t IDR;      /*!< GPIO port input data register,         Address offset: 0x10      */
    ! s4 B: Z1 ^- X8 w4 K+ d
  8.   __IO uint32_t ODR;      /*!< GPIO port output data register,        Address offset: 0x14      */2 [; m( r2 J2 X0 u+ L  ^$ X
  9.   __IO uint16_t BSRRL;    /*!< GPIO port bit set/reset low register,  Address offset: 0x18      */! A; L4 z! {& ]( s0 V( `
  10.   __IO uint16_t BSRRH;    /*!< GPIO port bit set/reset high register, Address offset: 0x1A      */
    & {1 v5 a5 u( w8 y/ V* \: ]8 y
  11.   __IO uint32_t LCKR;     /*!< GPIO port configuration lock register, Address offset: 0x1C      */- h9 [7 B, t5 t! V- }8 @
  12.   __IO uint32_t AFR[2];   /*!< GPIO alternate function registers,     Address offset: 0x20-0x24 */0 s: [( t: l" z1 r; b6 w
  13. } GPIO_TypeDef;
    + \5 p' B3 V; q3 L) [2 |. }
+ ]/ l! ^- x, e' T
以下是stm32f10x.h中对GPIO的定义。
' _" |9 D& g! P  f+ ]
  1. typedef struct  [+ f6 n5 Q7 n& t5 R3 C% C& x
  2. {: d" b5 `4 W) u) |) l
  3.   __IO uint32_t CRL;/ S/ y% A9 i2 r5 i$ D
  4.   __IO uint32_t CRH;/ Z& h( z/ R: z
  5.   __IO uint32_t IDR;
    9 h- L# S' c' g! h( F- C% U
  6.   __IO uint32_t ODR;
    ) B2 S5 E8 Q' {% n
  7.   __IO uint32_t BSRR;
    7 X7 p+ i0 b0 V1 E' k( h2 _
  8.   __IO uint32_t BRR;- h# b  ?% }2 J; Q+ M% T
  9.   __IO uint32_t LCKR;: ^# j# x0 p! o8 |
  10. } GPIO_TypeDef;
    / ?3 d( q7 S# L6 |+ A1 m
1 ~! c& G1 E- X" K; g- S
F1的CRL、CRH用于配置输入输出、推完开漏模式、速度、上下拉输入、复用输出,和F4的MODER、OTYPER、OSPEEDR、PUPDR、AFR[2]等效。: _7 H1 j/ [- E$ ~( P- k% T) B
2 T% D% X! ?+ P1 v! E# [1 |/ uIDR和ODR都是一样的,输入输出寄存器。2 s& Q1 Y, [* W' a& R! p: ]
1 V& Y0 a% N' Q' |* E6 d! K
F1的BSRR的低16位是置位,F4的BSRRL是置位。(F1的BSRR高16位和BRR等效,都是复位)2 S/ [% F; B3 F/ U9 y3 x0 a
2 P! T5 F. @4 N4 [F1的BRR是复位,F4的BSRRH是复位。
* X8 X; ]* Q% m5 _2 t9 l. d' }& C" V) V3 m$ w% P  H
LCKR是锁存配置,一般不用。( I8 `6 w8 g1 ?( g, v
9 b3 ?! v7 R. y) m  U然后F1的AFIO是独立的,不在GPIO的结构体里。
. H0 w$ j' H3 {5 f+ m! ?# n- _* G. L
: _- O4 K0 W9 Z
下面举个F4设置IO电平的例子:
9 w# U3 I$ L2 x3 v9 ^/ s% u
  1. #define CONVST_1()        GPIOC->BSRRL = GPIO_Pin_6
    ) v8 k7 _0 [6 C
  2. #define CONVST_0()        GPIOC->BSRRH = GPIO_Pin_64 |' h- U# w, l4 J+ E
& k  H0 b" Y; z
F1设置IO电平的例子:: l" N: a( h$ x9 x+ f
  1. #define CONVST_1()        GPIOC->BSRR = GPIO_Pin_64 S* N% z* Y1 x  |+ j6 ^
  2. #define CONVST_0()        GPIOC->BRR = GPIO_Pin_6
    1 t* }6 s! v2 E# a3 L- l
' ?- w; z4 v2 ?5 r  U" l% Q操作之前记得初始化!
0 Z8 I6 b* K3 {9 \' O- L7 L————————————————
6 o4 I) p/ M/ k5 }$ R版权声明:小盼你最萌哒
/ p, y7 ?' S- f- `如有侵权请联系删除: r0 [& g. T& b) _$ B
赞 收藏 评论0 发布时间:2023-3-14 16:48
