基于STM32 OTA的读写FLASH
攻城狮Melo 发布时间:2023-3-21 16:51
读写FLASH
* G% n: S1 U8 I7 X1. 简述
8 F) C% F% b  s5 y7 `6 C5 o
STM32的写FLASH相对简单,直接读即可,写FLASH相对复杂。首先看STM32的内存大小和分配。
4 N2 E+ _- v0 g9 H( E5 A% A( A" O; O; E7 r' l/ z$ _
用到的HAL库函数:1 S% N, \  L0 i
  1. HAL_StatusTypeDef HAL_FLASH_Unlock(void);
    : x1 q5 X  p0 @4 Z
  2. HAL_StatusTypeDef HAL_FLASHEx_Erase(FLASH_EraseInitTypeDef *pEraseInit, uint32_t *SectorError);
    3 v# |. s! h4 j1 Z
  3. HAL_StatusTypeDef FLASH_WaitForLastOperation(uint32_t Timeout);
      Y6 ~" u: i4 H( W& _% o$ v! s
  4. HAL_StatusTypeDef HAL_FLASH_Program(uint32_t TypeProgram, uint32_t Address, uint64_t Data);1 I& k- \8 j! r* _7 Z2 s
  5. HAL_StatusTypeDef HAL_FLASH_Lock(void);7 @' }+ |6 E" h) @- S
. {; ?3 r2 ^5 E5 c2 R2. 读写FLASH代码
  1. #define STM32_FLASH_BASE 0x08000000
    ) y* H2 y0 X/ b
  2. 8 h3 o+ K, i& k, r; p6 J  F( }
  3. /* 获取扇区号 */
    2 H5 s' A7 l0 S: @# w% ~% D
  4. static uint8_t bsp_flash_get_sector(uint32_t addr)
    0 Y. T' ]- h% r! `
  5. {
    $ @* N- |+ f: S& ^5 l# Y7 O& X! m
  6.         if (addr < ADDR_FLASH_SECTOR_1)       return FLASH_SECTOR_0;
    : x& A  P7 O8 y5 g3 m! p
  7.         else if (addr < ADDR_FLASH_SECTOR_2)  return FLASH_SECTOR_1;
    % t/ B6 A0 l" L% W
  8.         else if (addr < ADDR_FLASH_SECTOR_3)  return FLASH_SECTOR_2;
    8 N' g- G  d/ b% a; Y" p
  9.         else if (addr < ADDR_FLASH_SECTOR_4)  return FLASH_SECTOR_3;
    , W: B/ X5 l: ^* b, O
  10.         else if (addr < ADDR_FLASH_SECTOR_5)  return FLASH_SECTOR_4;& V6 m  S: H7 l3 i+ M9 T/ ^
  11.         else if (addr < ADDR_FLASH_SECTOR_6)  return FLASH_SECTOR_5;/ Q4 F6 H, }: Q( V! Q2 G, F
  12.         else if (addr < ADDR_FLASH_SECTOR_7)  return FLASH_SECTOR_6;
    / H  H  P3 U  `# k* U
  13.         else if (addr < ADDR_FLASH_SECTOR_8)  return FLASH_SECTOR_7;
    " K0 y" P& p$ y" J2 P5 `
  14.         else if (addr < ADDR_FLASH_SECTOR_9)  return FLASH_SECTOR_8;+ D- a8 J1 [( r( [. `! e
  15.         else if (addr < ADDR_FLASH_SECTOR_10) return FLASH_SECTOR_9;1 X" |6 a3 j% ~: Y7 c; h3 {
  16.         else if (addr < ADDR_FLASH_SECTOR_11) return FLASH_SECTOR_10;   , _6 \8 T8 Q# C  ^9 C; ~# }3 L* w$ |9 ?! R
  17.         return FLASH_SECTOR_11;
    * |2 H$ V2 Y' G& B: h
  18. }6 z$ }6 Y9 A7 E' U4 y. H) a
  19. 1 }3 d7 K* H& r2 E+ x" U) ?
  20. /* 读FLASH */+ l! N) d* D3 C. J, i
  21. uint32_t bsp_flash_read(uint32_t addr)
    3 r6 v( p1 H" E# ~5 X
  22. {7 x6 W  O; z9 {5 ]0 x2 r  K3 l
  23.         return *(__IO uint32_t*)(addr);1 {9 ^( T; {5 q1 q' w
  24. }
    + l4 P4 }7 D( M, }. ]
  25. ; ^$ B8 x3 H4 O, Q* s1 k! ~4 A3 ]* @" t
  26. /* 写FLASH */
    ! K( C: g1 y2 N( S6 c" _2 {- F& y
  27. void bsp_flash_write(uint32_t addr)' Y8 T! J3 W- L8 @# V
  28. {
    ( ^& Q+ k8 M$ h
  29.         FLASH_EraseInitTypeDef f;
    # W. r  H+ Y  R- o
  30.         uint32_t sector_error=0;- Y4 m4 e) s1 A$ G
  31.         uint32_t start_addr = addr;
    6 X3 j/ d# Z1 Y' I/ \' q
  32.         uint32_t end_addr = start_addr + (size * 4);8 b( ?2 x4 I3 u4 z
  33.         ' b. Y8 }3 m! W$ h8 b
  34.         /* 1. 判断地址合法 */- L8 F7 O& k- y7 w
  35.         if ((start_addr < STM32_FLASH_BASE) || (addr % 4)) return;' x4 h! g& J! X$ u$ y0 f. T
  36.
    . D; ~" Z% _) b
  37.         /* 2. 解锁 */
    / @" t5 a! O5 ]3 l7 i. z
  38.         HAL_FLASH_Unlock(); 0 x+ E( H3 w- K5 \0 _- S6 `
  39.         4 J- }! F: [) [" n3 [% }. Z: F6 Q
  40.         /* 3. 擦除 */
    ' W8 x0 f4 V0 B1 y* ]4 z3 i9 f( ~
  41.         if (addr < 0x1FFF0000) + T( v+ w  t6 N. D
  42.         {4 Y0 n  K. F  n( n4 a5 l: n. r
  43.                 while (addr < end_addr)
    + e' I4 F; w4 z! O' x6 O* m! n
  44.                 {
    # T) z2 {2 `( R6 y3 a' @
  45.                         if (hal_flash_read(addr) != 0XFFFFFFFF)
    0 I: Y: S. ~1 z: ], _' x
  46.                         {5 Y& ?0 Q0 F+ @/ x' ~' l) c
  47.                                 f.TypeErase = FLASH_TYPEERASE_SECTORS;
    % r# I7 E5 b) Y6 `) ?2 w7 @, D
  48.                                 f.Sector = hal_flash_get_sector(addr);
    ) x3 D2 z1 r1 N6 ?, R; ~
  49.                                 f.NbSectors = 1;0 a; n* d3 _+ U4 l- M
  50.                                 f.VoltageRange = FLASH_VOLTAGE_RANGE_3;+ q% t1 |) M, o. T7 Y5 D, w
  51.                                 if (HAL_FLASHEx_Erase(&f, §or_error)!=HAL_OK) break;7 A3 Z: u* g& ~' e( Q: D
  52.                         }
    * `( b! ^) @6 n4 x! Y  F8 i7 F
  53.                         else addr += 4;
    . z  f& n3 X: ]+ O, y
  54.                         FLASH_WaitForLastOperation(50000);. G5 E$ x8 G0 ~
  55.                 }% Z1 K6 n; `& o9 E, g' J' n- u) o
  56.         }
    8 B# x  p' J9 U
  57.         ) z( B! w8 h! H9 q" ~1 ?; P6 r& t- z
  58.         /* 4. 写入 */
    8 [5 I4 K8 m0 ?0 }& S) z
  59.         addr = start_addr;
    9 j6 c0 A: N; r1 b' p- ~
  60.         while (addr < end_addr)
    - }% {1 L! q/ m( z5 i
  61.         {
    / ]+ e- A( d  ^. g. ?7 a
  62.                 if (HAL_FLASH_Program(FLASH_TYPEPROGRAM_WORD, addr, *data) != HAL_OK) break;        3 N2 f0 O! c8 a8 i- T
  63.                 addr += 4;9 b$ \6 T, ]$ a0 W1 B, M; A
  64.                 data++;( {3 {$ {7 r  q' T+ n: K% [5 X* v
  65.         }4 d2 ^6 v6 S& `. [  p
  66.
    # \2 u  v' V) ]0 Q
  67.         /* 5. 上锁 */
      {& h4 @" q5 q# C; k! W
  68.         HAL_FLASH_Lock();
    / {, J) Q( [# N6 V
  69. }
( _1 @2 {& j. ^————————————————
9 H$ Q  c3 b* w: W* d版权声明:lljwork2021
8 k$ r: k& R7 }2 s; B, b
; S5 J  {8 n, j9 u
0 P* b5 k+ J4 X& r/ A5 _
1 |: s' B7 b: j3 R/ ^4 ]" t
赞 收藏 评论0 发布时间:2023-3-21 16:51
