关于DMA搬运的启停。当第一次搬运的时候多个通道是可以同时起步的,但是停止之后再初始化,通道的DMA搬运就不同步了,并且这个搬运的数组,会被吃掉一个值,这是什么
yzw-A 提问时间:2023-9-4 19:35 / 未解决
//溢出中断
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim) {
if(htim ->Instance == TIM1) {
    if(A ==0)
            HAL_TIM_Base_Stop(&htim2);
                    __HAL_TIM_SET_COUNTER(&htim2,0);
                    HAL_DMA_Abort(&hdma_tim2_ch1); // hdma为DMA句柄
                    HAL_DMA_Abort(&hdma_tim2_ch2_ch4); // hdma为DMA句柄
                    HAL_DMA_Abort(&hdma_tim2_ch3); // hdma为DMA句柄
                    HAL_DMA_DeInit(&hdma_tim2_ch1);
                    HAL_DMA_DeInit(&hdma_tim2_ch2_ch4);
                    HAL_DMA_DeInit(&hdma_tim2_ch3);
            __HAL_TIM_DISABLE_DMA(&htim2, TIM_DMA_UPDATE); // htim为PWM定时器句柄,TIM_DMA_UPDATE为DMA请求源
// HAL_TIM_PWM_Stop(&htim2, TIM_CHANNEL_1); // 停止PWM输出
         HAL_TIM_PWM_Stop(&htim2,TIM_CHANNEL_1);
         HAL_TIM_PWM_Stop(&htim2,TIM_CHANNEL_2);
         HAL_TIM_PWM_Stop(&htim2,TIM_CHANNEL_3);
            flag+=1;
            if (flag == 1  ||flag == 5)
                HAL_GPIO_WritePin(GPIOA, GPIO_PIN_7, GPIO_PIN_SET);//PA7的波形
            if(flag == 1 || flag ==3 || flag == 5)
                    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_SET);
                                                HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_SET);
                                                HAL_GPIO_WritePin(GPIOA, GPIO_PIN_3, GPIO_PIN_SET);
            if (flag == 3  ||flag == 5)
                HAL_GPIO_WritePin(GPIOA, GPIO_PIN_6, GPIO_PIN_SET);//PA6的波形
            HAL_TIM_OC_Start_IT(&htim1, TIM_CHANNEL_1); // 启动比较中断
//比较中断 void HAL_TIM_OC_DelayElapsedCallback(TIM_HandleTypeDef *htim) {
if (htim->Instance == TIM1) {
                if (htim->Channel == HAL_TIM_ACTIVE_CHANNEL_1) {
                    HAL_TIM_Base_DeInit(&htim2);
                    MX_MY_TIM2_Init(16,423,0);
                    HAL_TIM_Base_MspInit(&htim2);
                    HAL_TIM_PWM_Start_DMA(&htim2,TIM_CHANNEL_1,(uint32_t *)pulse1,(7));
                    HAL_TIM_PWM_Start_DMA(&htim2,TIM_CHANNEL_2,(uint32_t *)pulse2,(8));
                    HAL_TIM_PWM_Start_DMA(&htim2,TIM_CHANNEL_3,(uint32_t *)pulse3,(4));
                                flag+=1;
                                if (flag == 4 ||flag == 6)
                                    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_7, GPIO_PIN_RESET);
                                if (flag == 4 ||flag == 2 || flag == 6)
                                    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_RESET);
                                if (flag == 4 ||flag == 2)
                                    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_6, GPIO_PIN_RESET);
                                if (flag == 6)
                                        flag = 0;
赞 收藏 评论0 发布时间:2023-9-4 19:35
