不管怎么读 都是通道10的值 ,麻烦大牛们帮忙看看函数 ADC_HandleTypeDef hadc1; void MX_ADC1_Init(void) { ADC_ChannelConfTypeDef sConfig = {0}; hadc1.Instance = ADC1; hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4; hadc1.Init.Resolution = ADC_RESOLUTION_12B; hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc1.Init.ScanConvMode = ADC_SCAN_SEQ_FIXED; hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV; hadc1.Init.LowPowerAutoWait = DISABLE; hadc1.Init.LowPowerAutoPowerOff = DISABLE; hadc1.Init.ContinuousConvMode = DISABLE; hadc1.Init.NbrOfConversion = 2; hadc1.Init.DiscontinuousConvMode = DISABLE; hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; hadc1.Init.DMAContinuousRequests = DISABLE; hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED; hadc1.Init.SamplingTimeCommon1 = ADC_SAMPLETIME_12CYCLES_5; hadc1.Init.SamplingTimeCommon2 = ADC_SAMPLETIME_12CYCLES_5; hadc1.Init.OversamplingMode = ENABLE; hadc1.Init.Oversampling.Ratio = ADC_OVERSAMPLING_RATIO_256; // 16bit hadc1.Init.Oversampling.RightBitShift = ADC_RIGHTBITSHIFT_4; hadc1.Init.Oversampling.TriggeredMode = ADC_TRIGGEREDMODE_SINGLE_TRIGGER; hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH; if (HAL_ADC_Init(&hadc1) != HAL_OK) { Error_Handler(); } sConfig.Channel = ADC_CHANNEL_10; sConfig.Rank = ADC_RANK_CHANNEL_NUMBER; if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK) { Error_Handler(); } sConfig.Channel = ADC_CHANNEL_15; sConfig.Rank = ADC_RANK_CHANNEL_NUMBER; if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK) { Error_Handler(); } } uint16_t ADC_Read(uint32_t Channel) { uint32_t value; ADC_ChannelConfTypeDef sConfig; sConfig.Channel = Channel; sConfig.SamplingTime = ADC_SAMPLINGTIME_COMMON_1; /* 通道 */ if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK) { Error_Handler(); } HAL_ADC_Start(&hadc1); HAL_ADC_PollForConversion(&hadc1, HAL_MAX_DELAY); value = HAL_ADC_GetValue(&hadc1); HAL_ADC_Stop(&hadc1); return value; } |
STM32G071C8的ADC问题,测量6路交流信号,端口使用PA2-PA7,信号来自电流互感器次级用20欧电阻转为电压信号,并联T4,通过1K,104滤波后到ADC引脚,个别芯片出现PA3结果是固定值,即使直接把引脚对地短短接,结果也是2000多个数,可能是什么原因
STM32G030F6P6TR 48MHz下Flash擦写必HardFault?官方库疑似有坑,求勘误或替代方案
stm32g071的rtc初始化后会直接进入中断怎么办?
STM32G030死机问题
A Guide to Mastering Slope
STM32G0B1
无源晶振开关电路设计
STM32G031F8P6开启读保护后,数据全变成0?
stm32g030f6p6的LL库,ADC多通道,DMA错位问题请教
STM32G030x6/x8被淋雨进水了但未通电,风险如何?怎么处理?
你如果现在的确需要逐个通道地查询获取ADC值。
你先在CubeMx仅选择1个通道比方通道15完成配置,生成初始化工程。
然后,基于cubeMx创建的工程额外加点代码,加个基于单个通道的初始化代码。
void User_Channel_Config(uint32_t ChannelNum )
sConfig.Channel = ChannelNum;
Error_Handler();
具体操作时,需要用哪个通道就启用哪个通道。比方这样:
while (1)
HAL_Delay(500);
Channel_Config(ADC_CHANNEL_15 );
HAL_ADC_PollForConversion(&hadc1,0xffff);
Adc_ch15 = HAL_ADC_GetValue(&hadc1);
Channel_Config( ADC_CHANNEL_10 );
Adc_ch10 = HAL_ADC_GetValue(&hadc1);
这样操作是可以的,我刚才验证测试过。你可以参考下。
另外,看到你代码里启动ADC后,读取一次结果就停止了ADC,现在是扫描模式的话,这样不会每次只读到1个通道的数据,第2通道数据不会丢掉?
大佬你好,版本号我回头看一下,我试了一下把IN10和IN15分开初始化,就是写了两个初始化函数,每次读参数的时候都重新初始化一下就没问题, 现在就是放一下初始化 ,就不行 只能读到IN10的值。麻烦告知一下怎么改是好。
