关于STM32U5的HIGH SPEED USB时钟源的问题
陳勝・呉広 提问时间:2024-4-3 18:36 / 未解决
如题,STM32U595,USB要使用HIGH SPEED,也就是480M总线速度,手册上说的HS必须要用HSE做时钟源,但是现在试了下,用HSI做时钟源,也是可以的,这是个例还是确实可以用HSI做时钟源?如果批量出产品,用HSI做USB HS时钟源,会不会经常故障,良品率不高?
USB on-the-go high-speed (OTG_HS) The devices embed an USB OTG high-speed device/host/OTG peripheral with integrated transceivers. The OTG_HS peripheral is compliant with the USB 2.0 specification and with the OTG 2.0 specification. It has software-configurable endpoint setting and supports suspend/resume. This interface requires a precise 60 MHz clock that is generated from the internal USB PHY PLL (the clock source must use a HSE crystal oscillator).
收藏 评论1 发布时间:2024-4-3 18:36
xmshao 回答时间:2024-4-7 10:30:14
这个地方手册都明确强调MUST了,当然要基于HSE时钟源来进行USB、CAN之类的通信了。至于你现在手头开发板使用HSI可以,不代表所有板子及场合都行。总之,按手册的来。
